Old 29th August 2021, 04:01   #261  |  Link
Pauly Dunne
Grumpy Old Man.
Pauly Dunne's Avatar
Hello again,
Can someone please tell me whats missing with this script :-
#Custom
LoadPlugin("%AVISYNTHPLUGINS%\mvtools\mvtools2.dll")
LoadPlugin("%AVISYNTHPLUGINS%\BM3D\x64\BM3DCPU_AVS.dll")
LoadPlugin("%AVISYNTHPLUGINS%\BM3D\x64\BM3D_VAggregate_AVS.dll")
LoadPlugin("%AVISYNTHPLUGINS%\dfttest\dfttest.dll")
LoadPlugin("%AVISYNTHPLUGINS%\RgTools\RgTools.dll")
Import("%AVISYNTHPLUGINS%\scripts\extras\ExTools52.avs")
Import("%AVISYNTHPLUGINS%\scripts\extras\Sharpeners Pack v0.5.avs")
Import("%AVISYNTHPLUGINS%\scripts\extras\SMDegrain326d.avs")
Import("%AVISYNTHPLUGINS%\scripts\extras\Utils-r41.avs")
Import("%AVISYNTHPLUGINS%\scripts\extras\Zs_RF_Shared.avs")
video=SMDegrain(video,tr=4,thSAD=400,contrasharp=true,refinemotion=true,prefilter=5)
It has a error with Line 160 of SMDegrain3.2.6d.
But if I run this, there's no error :-
#Custom
LoadPlugin("%AVISYNTHPLUGINS%\BM3D\x64\BM3DCUDA_AVS.dll")
BTW, I'm using either a 3950X or a 5950X.
Not poorly done, just doin' it my way !!!
Live every day like it's your last, because one day, it will be !! (M$B)
Pauly Dunne is offline   Reply With Quote
Old 29th August 2021, 04:45   #262  |  Link
kedautinh12
Originally Posted by Pauly Dunne View Post
Hello again,
In BM3D_CPU don't have fast=true, extractor_exp=6, just deleted it when you change BM3D_CUDA to BM3D_CPU
https://github.com/Dogway/Avisynth-S...2.6d.avsi#L617
Old 29th August 2021, 05:19   #263  |  Link
Pauly Dunne
Grumpy Old Man.
You're awesome, I could make a "custom" SMDegrain with those deleted, and get the script to call the modded one.
I'll give it a shot, and let you know
Reply:- OK, that didn't work at first, but when I changed something else, it did, but it's SLOW !!!!
BM3D_CUDA(sigma=[s,ch?s/2:0,ch?s/2:0], radius=r, chroma=ch, fast=true, extractor_exp=6)
to
BM3D_CPU(sigma=[s,ch?s/2:0,ch?s/2:0], radius=r, chroma=ch)
Maybe that could be tweaked....
Old 29th August 2021, 06:48   #264  |  Link
kedautinh12
Try this script i shared with BM3D_CPU & BM3D_CUDA. After benchmark between them
Prefetch(16) #or try any number can make a good speed fps
Old 29th August 2021, 09:20   #265  |  Link
Boulder
Pig on the wing
Boulder's Avatar
I personally wouldn't put too much effort on the prefiltering part. I use this kind of prefiltering method that was snatched from QTGMC (where it is used for prefiltering as well).
w = clip.Width()
h = clip.Height()
srchClip = clip.RemoveGrain(12,12).GaussResize(w,h, 0,0, w+0.0001,h+0.0001, p=2).MergeLuma(clip, 0.1)
Old 29th August 2021, 22:27   #266  |  Link
Yo Doggy,
does anything in your Extools [or other] whotsits, measure distance of current pixel to nearest eg black[or white] pixel ? [maybe result pixel 0->255 for 8 bit]
Thanks in advance.
EDIT: Or suggestion. I'm not really expecting any +ve reply, but thought I'de ask.
Good Doggy
Old 30th August 2021, 11:03   #267  |  Link
Dogway
Maybe you can try this. Binarize first, then expand (to calculate distance) and calculate output value.
ex_binarize(254)
aug = true  # to see the mask
aug = aug ? "0.250001 *" : "range_max / "
ex2 = ex_expand(2)
Expr(last,ex_expand(1),ex2,ex2.ex_expand(1),Format("x y z a + + + "+aug),"")
i7-4790K@Stock::GTX 1070] AviSynth+ filters and mods on GitHub + Discussion thread
Old 30th August 2021, 13:36   #268  |  Link
Woah, I really was not expecting anything at all, I'll give it a go, thanks very much
Old 31st August 2021, 14:55   #269  |  Link
Dogway
Just uploaded SMDegrain v3.2.7d, it includes a new function, ex_retinex(), its use is similar to ex_luma_rebuild() but more robust and a about half the speed although still fast.
I didn't like the implementations in VapourSynth or other sources so I directly ported from a paper and it works great. You can use it with SMDegrain argument "Str" and value 1.0, with value 0 it fallsback to frameprops to check if clip is TV levels and do a range conversion.
Also added a small optimization update to ex_minblur().
I also uploaded DeStripe() although either this or ex_retinex() make use of updates in ExTools that I still haven't uploaded, maybe this evening since I still want to do a quality check on ex_luts(), should be working fine but want to be sure.
I also ported from VapourSynth to ExTools Guided Blur and Anisotropic Guided Filtering, they are both slow. Will think for optimizations at another time.
Old 31st August 2021, 22:14   #270  |  Link
Julek
Julek's Avatar
I get an error with ex_lutxyza, did you forget to add it or did I do something wrong?
Julek is offline   Reply With Quote
Old 1st September 2021, 00:12   #271  |  Link
Dogway
I had a birthday tonight, will upload tomorrow ExTools update after some quality checks. I also think that ex_retinex() should better make use of AutoLevels instead of my runtime levels for better performance, will have a look tomorrow.
Old 1st September 2021, 00:24   #272  |  Link
Julek
Julek's Avatar
Oh, my bad.
Old 1st September 2021, 06:07   #273  |  Link
kedautinh12
It's strange. Your ex_retinex use int sigma but MSRCP use float sigma[...] and your don't have upper_thr
Old 1st September 2021, 13:40   #274  |  Link
Here something for Doggies Birthday[225 KB]:- https://www.mediafire.com/file/4fw6c...rthday.7z/file
Old 1st September 2021, 14:40   #275  |  Link
Dogway
Haha thank you, did I misscommunicate? I didn't mean my birthday lol. Thanks anyway
Just uploaded ExTools update. Didn't do a deep QC for ex_luts() today but should work fine for most things. If something odd arises I will fix on the go. I also had to update GradePack to allow floats in ex_levels() so ex_retinex() works fine.
Please test and if you see any issue let me know to fix it.
@kedautinh12: Just changed sigma to float. It wasn't an issue but I didn't port from anywhere. MSRCP is for RGB (chromaticity preservation), YUV doesn't need to preserve chroma as it is already detached from luma, one problem though is that YUV chroma is not entirely decorrelated, so one option I can add in the future is to preconvert to a better decorrelated color space. For SMDegrain prefiltering though this is not important.
@Julek: Test now with updated ExTools. Also if you let me know what type of Adaptive Threshold you use I can give it another stab. "Adaptive" is a generic family, some use integral other not. In your case it seemed to also use an edge mask. Here is a list of most kind of thresholds I could find.
Adaptive Mean
Adaptive Median
Adaptive Gaussian
Otsu Thresholding
Maximum Entropy Thresholding
Mixture Model Thresholding
Binary Clustering
Metric
Moment-Preserving Thresholding
Inner-class Variance
Pun Thresholding
Niblack Thresholding
Bernsen Thresholding
Abutaleb Thresholding
Sauvola Thresholding
Phansalkar Thresholding
PirahanSiah Adaptive Single thresholding based on PSNR ( www.pirahansiah.com )
Lloyd Thresholding
Ridler-Calvard Thresholding // Iterative Selection Thresholding
Johannsen Entropy Thresholding
Yen, Chang Thresholding
Sahoo, Wilkins, Yeager Thresholding // Renyi's Entropy Thresholding
Triangle Thresholding
Kittler-Illingworth Thresholding // Minimum Error Thresholding
Kapur, Sahoo, Wong Thresholding
Old 1st September 2021, 15:18   #276  |  Link
kedautinh12
Thanks, can i useable ex_retinex(sigma=[50, 200, 350])??
Old 1st September 2021, 15:25   #277  |  Link
Dogway
I haven't implemented custom sigmas, my reference paper did careful measurements to retrieve the optimal sigmas and weighted sums, so it is [1.5%, 5%, global mean] of width dimension and with weights [0.2, 0.1, 0.7]. 'sigma' arg is just a multiplier.
Do you have an example where this doesn't work fine?
Old 1st September 2021, 15:29   #278  |  Link
kedautinh12
Oh, i try use your ex_retinex for port retinex_edgemask to avs+
https://github.com/Irrational-Encodi...gefunc.py#L217
Old 1st September 2021, 15:55   #279  |  Link
Dogway
I don't have VS installed to compare results, so maybe that MSRCP call is not optimized enough, for example the sigmas there are fixed. I think you might be safe by replacing it entirely with ex_retinex(), if any play with the percentile value in my function to roughly match the dynamic range.
Old 1st September 2021, 16:57   #280  |  Link
tormento
Acid fr0g
tormento's Avatar
SMDegrain
Which filter do you suggest to lower HBD output from 16/12/10 bit SMDegrain to 8 bit? I am really not satisfied from the internal dithering used by x264 as it sometimes gives really visible banding.
I prefer modern filter ones.
@turment on Telegram
avisynth, dogway, filters, hbd, packs
