Old 2nd April 2023, 14:11   #2301  |  Link
Boulder
Pig on the wing
Boulder's Avatar
The default SetMemoryMax plays it too safe. 4K processing can easily require over 10GB of cache
Old 2nd April 2023, 14:21   #2302  |  Link
FTLOY
Friend of a friend..
FTLOY's Avatar
Originally Posted by LeXXuz View Post
You probably have to. 16GB is not very much for more complex filtering of 4k content.
Change of subject...
Is there a way to add .srt subtitles with AVS, and edit font size.
FTLOY is offline   Reply With Quote
Old 2nd April 2023, 14:43   #2303  |  Link
poisondeathray
Nothing to do with this thread. You should post somewhere else or start a new one
You can convert to .ass and specify font size there
Old 2nd April 2023, 14:50   #2304  |  Link
FTLOY
FTLOY's Avatar
Well, you never know what Dogway may have hidden in amongst all his scripts / filters.
Old 2nd April 2023, 15:46   #2305  |  Link
coolgit
Put .srt sub with same filename as video in same folder and your player will load it and use player to change font size.
coolgit is offline   Reply With Quote
Old 2nd April 2023, 17:08   #2306  |  Link
FTLOY
FTLOY's Avatar
I do that most of the time, but I want to hardcode them for a series, before editing out lengthy intros, etc.
Old 2nd April 2023, 17:33   #2307  |  Link
Emulgator
Big Bit Savings Now !
Emulgator's Avatar
SubtitleEdit is your friend. Go to thread
https://forum.doom9.org/showthread.php?t=162721
Old 2nd April 2023, 22:16   #2308  |  Link
Dogway
Originally Posted by Dogway View Post
Simply used:
pre=ex_Median(mode="IQMST",thres=255)
STTWM(sw=50,tw=50,aw=100,sthres=5,tthres=5)
SMDegrain(tr=2,thSAD=200,thSADC=100,contrasharp=true,prefilter=pre,str=1.2,refinemotion=true)
FrameRateConverterMIX(FrameDouble=true)
in AvsPmod, and I think without Prefetch() even as I only use it when encoding.
You might need to review your workflow, use avs+ test 9, setmemorymax to an appropiate value, and load the mt-modes.avsi. Also test with other source loaders.
I think I might have figured out what's going on...
What type (resolution) video did you test this script on ?
I am trying to use FrameConverter on 4K HDR10 content, and I think the combination is just too much for it, 'cause it seems to be ok, but slow, on lesser resolution's.
4K changes it all. Look at the script, 4 temporal filters, that requires a lot out of order access. Unless you have a lot of cache or/and use your highest RAM it's going to run very slow, and I'm not sure even if AVS+ is ok for smooth 4K workflows. You might improve it using RequestLinear(2*24) just before FrameRateConverter.
Also being HDR10 you need to supply SMDegrain (and ideally FrameRateConverter) an SDR prefilter, as suggested in the docs or at the top of the SMDegrain script.
Should these two be identical in output?
PRE=ex_Median(mode="IQMST", UV=3,thres=255)
PRE0=ex_Median(mode="IQMST", UV=3,thres=255)
PRE=ex_blend(PRE0,"blend",opacity=1)
Since opacity is clamped between 0,1 in ex_blend
-output with opacity=0 seems identical with the last clip, as it should.
-output with opacity=1 seems not identical with the blend clip, which I would've expected.
Also I noticed some flickering in the output when opacity is used with anything but 0.
Quite subtle but noticeable in some backgrounds when you're very susceptible to flicker. Could these be rounding errors from the blending process by any chance?
Sorry I missed this post, I thought you were referring to the SceneStats issue. Yes this is a bug, only when opacity is 1 in 'blend' mode for TV range sources. It's fixed now.
As for the flicker, are you sure about that? it's a basic 2 clips blends, I forgot to say but you could also do Merge(clip1,clip2,0.5), output should be similar, that means it should not show flicker either.
i7-4790K@Stock::GTX 1070] AviSynth+ filters and mods on GitHub + Discussion thread
Old 3rd April 2023, 00:01   #2309  |  Link
coolgit
Don't hardcode them. What if there is a spelling mistake, missing word, lines etc. With subtitleedit you can fix them easily. With hardcode you will have to fix the subs and compress the files all over again.
Hardcode subs are a very bad idea.
Old 3rd April 2023, 01:05   #2310  |  Link
FTLOY
FTLOY's Avatar
I find it interesting how many continuing comments you can get with an off topic subject
This will be the last comment I make about subtitles here, as it is WAY off the thread's topic....kinda wish I hadn't brought it up, here.
I know hard coded has all those issues, but when you want to edit, cut, trim, the video & audio, (for example the first 2 minutes of every Game of Throne episode), you'd have to separately re-time the subtitles to suit the new running time, whereas if the video is hard coded (and double checked for typo's etc), then the trimming will take care of the subtitles
@ Emulgator
And I know that "SubtitleEdit is your friend", I have been using it for years, but I don't think you can change the font size for .srt's.
If you want to reply, please send me a PM, not on here.
Old 3rd April 2023, 01:08   #2311  |  Link
FTLOY
FTLOY's Avatar
Sorry about the subtitles stuff
Yes, I will be changing a few things with the info I've got about this, I'm glad I mentioned the 4K HDR10 thing.
But as for the SDR pre-filter, if that is to change the HDR to SDR, I don't want to do that!!
UPDATE:-
OK, I've had some success
Added TIVTC, so as to use RequestLinear(2*24), and modified the script.
Now using
SetCacheMode()
SetMemoryMax(20480)
I found that using SetCacheMode(0) was a little slower.
And going from SetMemoryMax 16384 (16Gb) to 20480 (20Gb) was a nice little bump, however, going up to 24576 (24Gb), it basically maxed out my 32G of DD5 and didn't really even want to start
So if there's anyone else out there that's silly enough to want to use FrameRateConverter on 4K, you need to add all this to the script
I'm sure that if I upped the system RAM to 64Gb or beyond it would process even faster. but DDR5 RAM is a bit too much $.
Old 3rd April 2023, 01:19   #2312  |  Link
coolgit
Actually it isn't off topic as Dogway does have a sub filter SwipeSubs https://github.com/Dogway/Avisynth-S...ster/EX%20mods therefore your query and hope
was valid within the realm of this thread even though it not what you wanted.
Re timing the srt files is easy and quicker, 10 seconds per file. I have been doing this for 2 decades. Trust me if you hardcode them you will create more problems and waste more time.
Up to you.
Old 3rd April 2023, 01:40   #2313  |  Link
FTLOY
FTLOY's Avatar
Actually it isn't off topic as Dogway does have a sub filter SwipeSubs https://github.com/Dogway/Avisynth-S...ster/EX%20mods therefore your query and hope was valid within the realm of this thread even though it not what you wanted.
Up to you.
Well, all right then
Yes, it's not really what I'm after, so maybe Dogway might come up with a solution to my situation.
I know that re-timing would be reasonably easy with just a trim at the start, but when you're chopping out bits throughout the video, makes it pretty difficult.
I've done hard with a few series, and the only issue I have is the font size.
Old 3rd April 2023, 10:30   #2314  |  Link
LeXXuz
21 years and counting...
LeXXuz's Avatar
Not at all. It is just for the prefiltering process before handing the prefiltered clip to mvtools. Since mvtools does not support HDR, you need to change your HDR content to SDR with an additional prefilter like DGHDRtoSDR().
If not, mvtools "sees" the prefilter-clip like you would on a SDR screen, with heavily compressed luma and chroma range. Which reduces the accuracy of the motion estimation quite a lot.
Thanks Dogway.
Well, since you ask me that way, no, I'm not 100% sure anymore.
I'll do some more testing on different sources with the fixed ex_blend() and compare it with merge().
LeXXuz is offline   Reply With Quote
Old 3rd April 2023, 12:34   #2315  |  Link
FTLOY
FTLOY's Avatar
OK, thanks for the explanation, would you be so kind to provide a example of a call for DGHDRtoSDR() as a pre-filter ??
Wait, what, I think I found it here:-
DGHDRtoSDR as pre filter
Something like this :-
pre=DGHDRtoSDR(mode="pq",white=112)
pre2=ex_Median(mode="IQMST",thres=255) or pre2=pre.ex_Median(mode="IQMST", UV=3, thres=255)
SMDegrain(tr=2,thSAD=200,thSADC=100,contrasharp=true,prefilter=pre,prefilter=pre2,str=1.2,refinemotion=true)
RequestLinear(2*24)
Old 3rd April 2023, 17:42   #2316  |  Link
coolgit
If you must use .srt instead of .ass then you can use
assrender("filepath and name.srt", scale=1.2, srt_font="verdana")
Scale adjust size of font.
Or use subtitleedit and load srt file and use <font size="10px">Hello World</font>. For each line.
I surmised assrender would be easier.
Old 4th April 2023, 03:24   #2317  |  Link
FTLOY
FTLOY's Avatar
It works a treat
The only problem is you'd have to change the script's subtitle path for EVERY episode, so you could end up with MANY scripts
Old 4th April 2023, 06:34   #2318  |  Link
LeXXuz
LeXXuz's Avatar
RequestLinear(2*24)
You can only set one prefilter in SMDegrain and the white point is pretty low. Use 400 and adjust from there. That really depends on the source. Str of 1.2 is also quite below recommended default of 5.0.
Try:
pre=ex_Median(mode="IQMST",thres=255).DGHDRtoSDR(mode="pq",white=400)
RequestLinear(2*24)
Old 4th April 2023, 07:33   #2319  |  Link
FTLOY
FTLOY's Avatar
Try:
RequestLinear(2*24)
Hi LeXXuz,
Yes, I found that out the hard way, but I think I might have got it going, but I removed the DGHDR call, tho, afterwards.
I tried this, not sure if it worked, tho...
SMDegrain(prefilter=pre2)
RequestLinear(2*24)
But I will definitely try your script suggestion...
Quick Update:-
Just ran your script (only as a quick preview test), but it worked
Next thing I'm curious about is, FrameConverter doubles the original FPS, but is there a script/filter that you can enter the FPS you want ???
There probably is, I just haven't found it yet, or forgotten.
Old 4th April 2023, 10:35   #2320  |  Link
LeXXuz
LeXXuz's Avatar
Hi LeXXuz,
RequestLinear(2*24)
That way you would run SMDegrain twice. And the 2nd time with default settings and no HDR to SDR conversion for the prefilter either which would make your first call with those subtle settings pretty much useless.
Also you have quite low thresholds for 4k but use a pretty strong prefilter with IQMST mode of ex_Median.
You may want to balance that a little more. Your low thresholds plus extra refinement will do you no good to preserve fine details if your prefilter is too strong and kills them in the first place.
avisynth, dogway, filters, hbd, packs
