Old 10th September 2012, 13:26   #101  |  Link
Originally Posted by Chikuzen View Post
However, DGMPEGDec can't be used because it requires avs internal crop function.
I can make a version without internal cropping if you like.
Old 10th September 2012, 13:32   #102  |  Link
Reel.Deel
Please do. That would be very nice. Thanks neuron2!
Reel.Deel is online now   Reply With Quote
Old 10th September 2012, 13:40   #103  |  Link
wOxxOm
Oz of the zOo
Regarding updating of avisynth plugins: as far as I can see, it's possible to make them native vapoursynth plugins by providing _VapourSynthPluginInit in addition to _AvisynthPluginInit2, so what are the benefits in general?
wOxxOm is offline   Reply With Quote
Old 10th September 2012, 13:43   #104  |  Link
Keiyakusha
契約者
Keiyakusha's Avatar
Originally Posted by Reel.Deel View Post
Also, I'm happy to see DGIndexNV work on Vapoursynth.
I don't understand why you need DGIndexNV if you have FFMS2 (which is free and awesome). if you have not very ancient CPU, nvidia decoding is not faster at all and not safe with more than one instance (or if you use some memory eating gpu filters). What are other possible benefits?
I used TS2AVI/MPEG2Dec3k after a long time...
When and what for if uses crop? You mean DgdecNV when decoding 1080p blu-ray? It should be possible to disable crop so it will output 1920x1088.
On the other hand DGMPEGDec Is what I'd like to see too. Not that it is irreplaceable, I'm just so used to it...
Old 10th September 2012, 13:51   #105  |  Link
TheFluff
Excessively jovial fellow
Native VS plugins can:
- interact directly with the VS thread pool (= potentially better multithreading performance, may require some work on the plugin though)
- support high bitdepth colorspaces (and some other exotics such as planar RGB) natively
- store arbitrary per-frame metadata (such as VFR timestamps) without having to resort to hiding it in obscure ways (the decomb/tfm hinting information is one example of plugins doing that)
Old 10th September 2012, 13:54   #106  |  Link
mandarinka
mandarinka's Avatar
Isn't FFMS2 (because of limitations in libavcodec) unable to properly decode interlaced h.264 streams? (At least when muxed in TS.) IIRC it also had problems with VC-1 streams.
mandarinka is offline   Reply With Quote
Old 10th September 2012, 13:56   #107  |  Link
Myrsloik
Professional Code Monkey
Myrsloik's Avatar
Unless you're willing to do a bit of extra coding, or at least code auditing, none. Here are some of my observations from looking at filter code about what different things you could expect:
1. Several filters use planar YUV422 internally and have to pack and unpack. These could quite easily be changed to directly accept planar YUV for a small speedup for YUY2.
2. Many of the same filters in category one are quite general and probably could be extended to full resolution planar YUV support at least with a bit more effort.
3. Native filters can select their best threading model. For example a filter like ColorMatrix probably never updates its conversion tables after initialization so they're safe to share. This means that the filter can be run on several frames in parallel.
4. If you lay off the inline assembler (you can still use yasm+that magic x264 asm.inc file) your plugins will work and compile on every civilized desktop OS from a single codebase.
5. No more hacks.
Myrsloik is offline   Reply With Quote
Old 10th September 2012, 13:59   #108  |  Link
Reel.Deel
Originally Posted by Keiyakusha View Post
I don't understand why you need DGIndexNV if you have FFMS2. if you have not very ancient CPU, nvidia decoding is not faster at all and not safe with more than one instance. What are other possible benefits?
I was just trying it out to see if it worked. Also IIRC FFMS2 was not frame accurate with VC-1 and and did not like interlaced H.264 (don't know if that's still the case).
Futhermore, I have a handfull of blu-rays that the movie is cut up into a 100+ segments and it's very easy just to drag the mpls onto DGIndexNV and index the entire movie. BTW I do have an ancient CPU (not for long) .
Old 10th September 2012, 14:11   #109  |  Link
Keiyakusha
契約者
Keiyakusha's Avatar
Hmm, didn't know that. I had impression that it only can work with single segment at one time or something like that. Maybe will try it someday.(I, as many others I guess, just remux the movie first, to make it one) Interlaced streams maybe true. I never saw any interlaced bluray though (or tv broadcasts that is not mpeg2)
Old 10th September 2012, 14:31   #110  |  Link
hajj_3
uk tv show blurays are 1080i for uk created tv shows.
Old 10th September 2012, 14:40   #111  |  Link
Also remember that DGDecNV can use the GPU for deinterlacing/resizing and that can bring a substantial speedup. Sure it's not QTGMC but the quality is pretty good and so offers a useful performance point. DGDecNV can load multiple files (including automatically from an MPLS playlist file); it's the old DGAVCDec that could open only one file.
Regarding DGMPGDec, it contains an internal Invoke call, which I assume is the source of the problem with Vapoursynth. I'd like to understand the problem better though. Is it only an issue for 1088 streams that get cropped automatically to 1080? Obviously we can't enable cropping in the GUI as that will trigger an Invoke("crop") in DGDecode, but if we have a non-1088 stream with no cropping enabled in the GUI does everything work?
Old 10th September 2012, 15:38   #112  |  Link
Reel.Deel
I tried DGMPGDec with a true 1080 stream (cropping disabled) and it gave me the following error:
Invoke not fully implemented, tried to call: crop but I will pretend it doesn'texist
Avisynth Error: escaped IScriptEnvironment::NotFound exceptions are non-recoverable, crashing...
BTW the file I used was 1080 not 1088.
*edit*
Just to be sure I tried DGMPGDec (same settings as before) with both a NTSC DVD stream and a 720p60 stream and they both worked.
Old 10th September 2012, 16:04   #113  |  Link
Yes, I know about the automatic 1088->1080 issue!
I'm asking if it fails when we don't have that case. Try an SD stream for example, with no cropping enabled in the GUI.
Old 10th September 2012, 16:21   #114  |  Link
tebasuna51
tebasuna51's Avatar
Just yesterday I make some test with r3.
With r5 (I never can download r4):
Python 3.2.3 (default, Apr 11 2012, 07:15:24) [MSC v.1500 32 bit (Intel)] on win32
Type "help", "copyright", "credits" or "license" for more information.
>>> import vapoursynth as vs
Traceback (most recent call last):
File "<stdin>", line 1, in <module>
ImportError: DLL load failed: No se puede encontrar el módulo especificado.
XP SP3 without changes from yesterday.
Reload r3 and work fine.
Old 10th September 2012, 16:30   #115  |  Link
Reel.Deel
Had the same problem yesterday. Try re-downloading r5 again and re-replace the binaries. It worked for me.
Old 10th September 2012, 16:32   #116  |  Link
Myrsloik
Myrsloik's Avatar
Did you download it within one hour of release? I forgot to select static linking and silently updated it.
If not I have no idea why you're getting that error since no dependencies have changed.
Old 10th September 2012, 16:41   #117  |  Link
No, it's coded as 1088. DGIndex hides that from you. It it were not coded as 1088, then the Invoke() call would not be made. If you are still adamant that it is 1080, then please post a sample.
OK, sweet, thank you.
Old 10th September 2012, 16:43   #118  |  Link
tebasuna51
tebasuna51's Avatar
Thanks, now work r5.
Old 10th September 2012, 17:45   #119  |  Link
06_taro
soy sauce buyer
Did some tests, and *.avs.MPEG2Source(d2v=r"d2vpath") works for SD sources.
BTW, I encountered "QWaitCondition: Destroyed while threads are still waiting" when finishing a session if I use Core() instead of Core(threads=1). Only occurs in r5.
06_taro is offline   Reply With Quote
Old 10th September 2012, 19:29   #120  |  Link
Myrsloik
Myrsloik's Avatar
That warning is harmless. It's just that I haven't made the destruction of the threadpool completely correct.
speed, vaporware, vapoursynth
