Old 29th January 2022, 19:38   #4641  |  Link
~ VEGETA ~
The cult of personality
~ VEGETA ~'s Avatar
Originally Posted by DJATOM View Post
Try to load explicitly via core.std.LoadPlugin. That way you will see an error if plugin fails to load.
well, now it worked fine by itself. i just re-installed it via the vsrepo after uninstalling it.
my problem now is with vsedit 2 not working
~ VEGETA ~ is offline   Reply With Quote
Old 9th February 2022, 10:19   #4642  |  Link
Selur
Selur's Avatar
Small question: Is there a deflicker filter for Vapoursynth? (as alternative to http://avisynth.nl/index.php/DeFlicker or https://github.com/Asd-g/ReduceFlicker on AviSynth)
found https://github.com/VFR-maniac/VapourSynth-ReduceFlicker, but sadly no binaries for it.
Old 9th February 2022, 11:24   #4643  |  Link
kedautinh12
Here:
https://github.com/AmusementClub/ReduceFlicker
Old 9th February 2022, 11:34   #4644  |  Link
Selur
Selur's Avatar
Nice! Thanks!
Cu Selur
Old 9th February 2022, 12:11   #4645  |  Link
ChaosKing
Also available via vsrepo.
Btw you can also quickly lookup vsrepo plugins online via https://vsdb.top/vsrepogui
Old 9th February 2022, 12:21   #4646  |  Link
Selur
Selur's Avatar
Thanks
Old 9th February 2022, 13:24   #4647  |  Link
Jukus
What can do if the DVD has video in two angles? If just use d2vwitch then get video and audio where 2 seconds of video comes from one angle and then the same action from the other angle.
Jukus is offline   Reply With Quote
Old 9th February 2022, 14:55   #4648  |  Link
Selur
Selur's Avatar
Use PGCDemux or similar to extract the content you want.
There is no Vapoursynth filter (neither is there one for Avisynth) which properly parses DVD structures in details.
Old 9th February 2022, 16:38   #4649  |  Link
Boulder
Pig on the wing
Boulder's Avatar
Why not use the good old DGIndex to create the d2v file.
Old 9th February 2022, 17:50   #4650  |  Link
Jukus
I don't feel like using Windows programs even under Wine
Thanks for the answers
Old 9th February 2022, 18:00   #4651  |  Link
ChaosKing
Linux / cross plattform alternative https://github.com/dubhater/D2VWitch
Old 9th February 2022, 18:03   #4652  |  Link
Jukus
Old 9th February 2022, 18:48   #4653  |  Link
Boulder
Pig on the wing
Boulder's Avatar
What if you pretend that it's not a Windows program
Or ask if videoh could do a Linux build. Or use a Linux build of DGIndexNV+DGSource if you have a suitable GPU.
Old 9th February 2022, 19:59   #4654  |  Link
Jukus
not very elegant, but solved my problem with https://www.makemkv.com/
Old 14th February 2022, 14:22   #4655  |  Link
Selur
Selur's Avatar
Is there an Vapoursynth plugin for inpainting?
Old 14th February 2022, 14:32   #4656  |  Link
kedautinh12
Here:
https://github.com/invisiblearts/VapourSynth-Inpaint
Old 14th February 2022, 14:50   #4657  |  Link
Selur
Selur's Avatar
Does that actually work? Code seems rather short with 133lines. (cpp file)
Also is there a compiled version of this?
Old 17th February 2022, 15:58   #4658  |  Link
Selur
Selur's Avatar
Is it possible to restrict the number of threads for just a specific filter?
PRAGMA suggested:
One mistake people are doing is letting VS use the default multi-threading with EGVSR when it should be disabled with `core.num_threads = 1`. Once you do this, it will only run the model on the current frame + n(interval) next frames at a time, instead of e.g. 72 frames with a num_threads of 1
source: https://forum.doom9.org/showpost.php...4&postcount=83
So I was wonder whether one could limit the threads just for vsgan and keep the rest of the script running with the full number of threads?
Cu Selur
Old 18th February 2022, 01:27   #4659  |  Link
Myrsloik
Professional Code Monkey
Myrsloik's Avatar
Recompile/binary hack the filter to be a parallel requests filter instead of true parallel.
I guess.
Myrsloik is offline   Reply With Quote
Old 18th February 2022, 05:58   #4660  |  Link
Selur
Selur's Avatar
Okay, that isn't really an option or generic use, but thanks for clearing that up.
Cu Selur
speed, vaporware, vapoursynth
