Old 14th May 2020, 14:21   #3841  |  Link
Selur
Selur's Avatar
@Txico: you can also do something like:
# Import scripts folder
scriptPath = '/home/myuser/vapoursynth-scripts'
sys.path.append(os.path.abspath(scriptPath))
to allow "import havsfunc as haf" when the havsfunc.py is inside the '/home/myuser/vapoursynth-scripts' folder.
Note that this will not automatically import the libraries,...
@all: are there any Intel® Open Image Denoise filters for Vapoursynth out there?
Old 16th May 2020, 20:29   #3842  |  Link
ChaosKing
Lets talk again about this problem here https://forum.doom9.org/showthread.p...96#post1840996
I'm now very sure that this problem is in some way connected to FrameEval()
Problem: Functions with a high temporal radius (called by frameEval) produces different results then without FrameEval
I don't think that all 4 plugins are storing temporal state incorrectly.
Example script:
import functools
import vapoursynth as vs
import mvsfunc as mvf #https://github.com/HomeOfVapourSynthEvolution/mvsfunc/blob/master/mvsfunc.py
core = vs.get_core()
def comp(a, b, crop=0):
	return core.std.StackHorizontal([
		core.std.CropRel(a, crop,crop,0,0), \
		core.std.CropRel(b, crop,crop,0,0), \
# Goal here is to remove dynamic grain and replace it with similar static grain
def ReGrainDenoise(clip):
	# test denoiser 1
	#clip = mvf.Depth(clip, 32)
	#sup = core.mvsf.Super(clip)
	#vec = core.mvsf.Analyze(sup, radius=9, overlap=4)
	#vec = core.mvsf.Recalculate(sup, vec, blksize=4, overlap=2)
	#denoised = core.mvsf.Degrain(clip, sup, vec, thsad=1600)
	# test denoiser 2
	#import havsfunc as haf #https://github.com/HomeOfVapourSynthEvolution/mvsfunc/blob/master/mvsfunc.py
	#clip = mvf.Depth(clip, 16)
	#denoised = haf.SMDegrain(clip, tr=3, thSAD=1500)
	#denoised = denoised.flux.SmoothST( temporal_threshold=16,  spatial_threshold=16)
	#denoised = mvf.Depth(denoised, 32)
	# test denoiser 3
	##lip = mvf.Depth(clip, 16)
	#denoised = clip.knlm.KNLMeansCL(d=8, h=6)
	# test "denoiser" 4
	denoised = clip.misc.AverageFrames(weights=[1]*31)[::31].misc.AverageFrames(weights=[1]*31)
	# add back static grain
	grain = denoised.grain.Add(var=1200.0, constant=True)
	diff_clip = core.std.Expr([clip, denoised], 'x y - abs').std.Inflate(threshold=200/255).std.Inflate(threshold=200/255)
	mask_clip = diff_clip.std.Binarize(threshold=[3.3/219, 3.3/224], v0=0, v1=80/255)
	clip = core.std.MaskedMerge(clipa=denoised, clipb=grain, mask=mask_clip)
	return mvf.Depth(clip, 32)
clip = core.std.BlankClip(format=vs.YUV420P16, width=120*2, height=80*2, length=100, color=[206,235,135])
clip = clip.grain.Add(var=100.0, constant=False)
orig=clip
def CalledbyFrameEval(n, c):
	return ReGrainDenoise(c)
WithFrameEval = clip.std.FrameEval(functools.partial(CalledbyFrameEval, c=clip))
NoFrameEval = ReGrainDenoise(clip)
clip = comp(
		WithFrameEval.text.Text("called from FrameEval").std.AddBorders(right=2),
		NoFrameEval.text.Text("Without FrameEval").std.AddBorders(right=2), crop=0
clip = comp(clip, orig.text.Text("unfiltered"), crop=0)
clip.set_output()
EDIT: Added AverageFrames() as "denoiser"
Old 18th May 2020, 19:15   #3843  |  Link
feisty2
I'm Siri
feisty2's Avatar
I have 2 questions regarding the API
1) what kind of filter outputs multiple clips, and what is the python syntax to bind the outputs of such filter?
is it
clips = core.???.filter(...)
#clips[0], clips[1], ...
or
clip1, clip2, ... = core.???.filter(...)
2) does audio support break compatibility with the current API? where can I find the audio API?
feisty2 is offline   Reply With Quote
Old 18th May 2020, 20:00   #3844  |  Link
Myrsloik
Professional Code Monkey
Myrsloik's Avatar
is it
or
1. It returns a list of clips so your first guess is used.
2. Audio support doesn't break the API at all, simply extends it. You can find it in the doodle1 branch. Expect a new test release in a few days when I finish writing and testing a few more simple audio filters.
Myrsloik is online now   Reply With Quote
Old 25th May 2020, 19:34   #3845  |  Link
HuBandiT
What is the problem you are trying to solve?
Do you really need FrameEval() for it?
Also, why are you denoising in YUV space? Your result will look blurry.
HuBandiT is offline   Reply With Quote
Old 2nd June 2020, 20:20   #3846  |  Link
feisty2
I'm Siri
feisty2's Avatar
why does vspipe freeze then crash if I comment out this line (which assumes the default multithreading mode, fmParallel)?
the default multithreading mode however seems to work with vsedit (preview)
Old 2nd June 2020, 20:34   #3847  |  Link
Myrsloik
Myrsloik's Avatar
Does this require a C++20 comoiler to test?
Old 2nd June 2020, 20:42   #3848  |  Link
feisty2
I'm Siri
feisty2's Avatar
yes, GCC10 is required to compile this thing, I guess clang10 should also work. However I believe this problem could be reproduced with the C API as well, since I copied this parallel request mode from the core code base.
Old 3rd June 2020, 10:41   #3849  |  Link
ortoni
Getting an odd compilation error Cython compiling vapoursynth.c during vapoursynth make:
Error compiling Cython file:
def keys(self):
cdef const VSMap *m = self.funcs.getFramePropsRO(self.constf)
cdef int numkeys = self.funcs.propNumKeys(m)
result = set()
for i in range(numkeys):
set.add(self.funcs.propGetKey(m, i).decode('utf-8'))
src/cython/vapoursynth.pyx:1095:19: Call with wrong number of arguments (expected 2, got 1)
make: *** [Makefile:2368: src/cython/vapoursynth.c] Error 1
Ubuntu 20.04 on Windows Linux Subsystem, did a pip3 install cython: Successfully installed cython-0.29.19
added /home/<username>/.local/bin to $PATH, all the usual stuff.
Any ideas/ further information needed? I successfully installed on Native Ubuntu 19.10 a while back and updated to 20.04; all still A-OK there.
TIA
ortoni is offline   Reply With Quote
Old 3rd June 2020, 10:52   #3850  |  Link
Myrsloik
Myrsloik's Avatar
def keys(self):
result = set()
TIA
Update to latest master and try again. And specify that it's master you're compiling next time.
Old 4th June 2020, 00:31   #3851  |  Link
ortoni
And that did the trick! Thanks for this - and thanks for the all-around majorly awesome VapourSynth project. You, Sir, are a scholar and a gentleman.
Old 7th June 2020, 06:26   #3852  |  Link
ortoni
Interesting scripting error arose:
outclip = core.std.StackVertical(clip,clip,clip,clip) gave the error File "src/cython/vapoursynth.pyx", line 1822, in vapoursynth.Function.__call__
vapoursynth.Error: StackVertical: Too many unnamed arguments specified.
Is there not a way to stack the same clip vertically or horizontally, or am I missing something?
TIA
Old 7th June 2020, 07:05   #3853  |  Link
poisondeathray
TIA
Enclose in square brackets
outclip = core.std.StackVertical([clip,clip,clip,clip])
Old 7th June 2020, 19:17   #3854  |  Link
feisty2
I'm Siri
feisty2's Avatar
suggestion: dynamically typed filter arguments should be supported (something like "param: dynamic: opt")
this could greatly simplify the user interface of filters like std.SetFrameProp
"intval", "floatval" and "data" could be unified by a single dynamically typed parameter "val"
there's no need to separate arguments of different data types since whenever the user passes a value to "val", the C++ plugin could query the type of the item associated with "val", then decide how "val" should be handled, example here: https://github.com/IFeelBloated/vsFi...e/Map.vxx#L159
Old 7th June 2020, 23:54   #3855  |  Link
ortoni
...aaaand thank you! Normal service has resumed
Old 10th June 2020, 09:26   #3856  |  Link
Myrsloik
Myrsloik's Avatar
Those of you who are interested in audio support should take a look at the latest audio build and the audio development thread.
Old 14th June 2020, 04:18   #3857  |  Link
nacho
Hi I need some help.
I have a clip with the property 'Scenechange' added to all frames (by WWXD) I want to do the following:
For every scenechange frame I want to extract 4 frames:
The two before it, the marked frame and the 1 after it. I also want to label them with their frame numbers in the source (using Text).
I then want all these series' of 4 frames in sequence as 1 clip.
Can someone help me please? Also FrameEval is runtime evaluated and I don't know if I need that...
Edit:
Here's what I've come up with... it seems fairly slow - vsedit hangs for a bit. And the 4 frames all have the same frame# (of the scenechange), can anyone tell me if this is the right way to go about what I want.
def extractSC(clip):
    scdetect = core.wwxd.WWXD(clip=clip)
    extract = core.std.BlankClip(clip=scdetect, length = 1)
    sceneChangeNr = 0
    for i in range(scdetect.num_frames-1):
        frame = scdetect.get_frame(i)
        if frame.props['Scenechange'] == 1:
            sceneChangeNr+=1
            before = i - 2
            after = i + 2
            if i < 2:
                before = i
            extract += core.text.Text(scdetect[before:after], "Frame No.: " + str(i) '\nScene Change: ' + str(sceneChangeNr))
    return extract
nacho is offline   Reply With Quote
Old 15th June 2020, 19:05   #3858  |  Link
stax76
stax76's Avatar
Is there maybe something like AviSynth AddAutoloadDir?
Old 15th June 2020, 19:15   #3859  |  Link
ChaosKing
I don't think so but it's easy to make your own Autoloaddir with something like
import glob
plugins = glob.glob(r"C:\plugins64\*.dll")
for plugin in plugins:
	try:
		vs.core.std.LoadPlugin(plugin)
	except:
		print("some err")
Old 15th June 2020, 19:30   #3860  |  Link
stax76
stax76's Avatar
The reason why I ask is in portable mode VapourSynth has an auto load folder defined but I don't want staxrip users to modify anything within the startup folder because then it would be difficult to update staxrip, so for portable mode I'm adding another auto load folder located in the staxrip settings folder, it can be opened in the main menu the same way as the installed auto load folder. I've added code like suggested so no problem.
speed, vaporware, vapoursynth
