1st October 2021, 23:15 | #181 | Link |
Are there exist any built-in or plugin way of direct samples sequence setting (in 4:4:4 and sub-sampled interleaved or planar format) from text-line (or array) defined arguments to function ?
Something like Code:
Line(pix_fmt="YUV422P10",Y="64,64,940,940",U="512,512",V="512,512") Last edited by DTL; 1st October 2021 at 23:19. |
1st October 2021, 23:31 | #182 | Link | |
eg. Code:
BlankClip(length=300, fps=24, width=4, height=1, pixel_type="YUV444P10") Expr("64","512","512") KillAudio() |
1st October 2021, 23:40 | #183 | Link |
Formerly davidh*****
You can use Expr:
Blankclip(width = 4, height = 1, pixel_type="YUV422P10").Expr(" sx 0 == 64 sx 1 == 64 sx 2 == 940 940 ? ? ? "," sx 0 == 512 512 ? "," sx 0 == 512 512 ? ") |
2nd October 2021, 05:08 | #184 | Link |
My example was short for simplicity. I mean setting exact sequencies of samples values of longer length. For typical transient description I need to set about 8..10 Y values and 4..5 UV values. And for sustained borders I can use simple AddBorders.
For long non-fully scripting way I have a set of external simple program to wrtie UYVY set of samples and RawSource plugin. But it long way. So may be ask to add simple Debug-group function close to BlankClip but with extended color param (like array of values instead of one colour). So currently no way to set/get samples values at given (x,y) coordinate of framebuffer ? The hackway with StackHorizontal(BlankClip(width=2,height=1,color=2_UYVY_samples),second_blankclip_with second 2 UYVY) may not work with 10bit ? And not short form for defining string of 10 Y and 5+5 UV samples. If even use Expr() for 4:2:2 2*1 size clips (for further hor stacking) - how to set 2 different Y values of first and second Y samples ? Last edited by DTL; 2nd October 2021 at 05:25. |
2nd October 2021, 05:25 | #185 | Link | ||
Reading sample value at x,y is easier with vapoursynth editor, because it supports different pixel formats, bitdepths . You mouse over any location and it reads off x,y coordindate and corresponding Y,Cb,Cr or R,G,B value , 8,10,12,16bit, float. AVSPmod is good, but unfortunately only reads 8bit values. Even if you're not familiar with vapoursynth, you can load most avs scripts into vapoursynth and use vsedit to "see" the proper pixel values Not sure of a good way of setting pixel values at x,y . Maybe overlay as a workaround method Quote:
"UYVY" fourcc is 8bit422, so it does not work with 10bit per channel If you meant U, V in v210 or p210 (10bit 422 interleaved, and planar), then it will work |
2nd October 2021, 06:20 | #187 | Link |
Same question - how to set sequence of (exact and different) Y-only samples to 'grey' plane. And 10bit greatly wanted for HDR like PQ transfer.
Possibly without 'stacking' of 1*1 samples Y10 or Y16 clips. That is too long. No way with 'arrays' of new avisynth versions available ? Can array be argument of user function ? Can enviroment return number of members in array so may be loop of BlankClip(width=1,height=1,pix_fmt="Y10") and StackHorizontal possible to fill the line of samples of grey-plane from simple provided sequence of numbers ? Last edited by DTL; 2nd October 2021 at 06:29. |
2nd October 2021, 13:36 | #188 | Link | |
Alternatively: perhaps there is an image source filter which will read Netpbm files. |
2nd October 2021, 14:23 | #189 | Link |
"See my post just before yours."
Oh - thank you - it really works for required 10x1 4:2:2 clip like Code:
plY=Blankclip(width = 10, height = 1, pixel_type="Y10").Expr("sx 0 == 509 sx 1 == 509 sx 2 == 509 sx 3 == 509 sx 4 == 509 sx 5 = 498 sx 6 = 446 sx 7 == 361 sx 8 == 292 276 ? ? ? ? ? ? ? ? ?") plU=Blankclip(width = 5, height = 1, pixel_type="Y10").Expr("sx 0 == 270 sx 1 == 263 sx 2 == 330 sx 3 == 761 754 ? ? ? ?") plV=Blankclip(width = 5, height = 1, pixel_type="Y10").Expr("sx 0 == 203 sx 1 == 224 sx 2 == 271 sx 3 == 832 821 ? ? ? ?") CombinePlanes(plY, plU, plV, "YUV", "YYY", pixel_type="YUV422P10") |
6th December 2021, 13:22 | #191 | Link | |
Banana User
b=YourPreferedSourcePlugin("D:\yourvideo2.mkv") a++b Btw, this is wrong thread to ask questions about Avisynth:
InpaintDelogo, DoomDelogo, JerkyWEB Fixer, Standalone Faster-Whisper - AI subtitling |
7th December 2021, 08:33 | #193 | Link |
Broadcast Encoder
@VoodooFX is right, you use append, so you set your file to a variable, your other file to another variable and then you append them together with ++.
Now, here's the catch: they must be exactly the same, namely they must be with the same resolution, framerate, color sampling, bit depth and if they have audio, that should be the same too, like, you cannot append a clip with audio to another which doesn't have it. Of course, as a user and encoder writing a script, it's your duty to make sure those match, hence performing conversions. |
6th May 2022, 17:01 | #194 | Link |
Banana User
This thread is about wiki:
22nd September 2022, 04:57 | #196 | Link | |
https://gitlab.com/uvz/AviSynthPlus-Builds |
3rd October 2022, 16:24 | #197 | Link |
Broadcast Encoder
Just FYI, I raised an issue here https://github.com/AviSynth/AviSynthPlus/issues/302 'cause apparently WAVSource() cannot index files larger than 4 GB and that affected my supply chain...
14th October 2022, 10:27 | #198 | Link |
21 years and counting...
I have trouble on my Windows 11 machine with the default plugin folders of Avisynth+. It seems they don't get recognized and the plugins stored in
"C:\Program Files (x86)\AviSynth+\plugins64+" f.e. do not get auto-loaded. How can I fix that? Re-install of Avisynth+ did not help. Right now I have to import all my filters manually from that folder which is a little annoying. |
14th October 2022, 10:30 | #199 | Link | |
14th October 2022, 11:23 | #200 | Link |
Broadcast Encoder
Mine didn't get that problem either. They were loaded automatically just fine, as they should.
Could it be some permission issues about the Program Files folder? Or perhaps Windows Defender blocking it? Dunno. It works on my end, I cannot reproduce it. |
avisynth, faq |
