Old 19th February 2017, 12:46   #25641  |  Link
Avinash KN
Subtitle not in sync for multi-file source
Sorry. missed out some more info:
I have enabled Movie-only backup option. Alternate output is not enabled.
Avinash KN is offline   Reply With Quote
Old 20th February 2017, 08:59   #25642  |  Link
Weirdo
I think I got confirmation on something I've always wanted to ask: can the user-set settings of LAV filters (outside of BD-RB) interfere with a a backup? I completed a backup (I've deleted it) of a Blu-Ray with 1080i/25fps content and everything played in slow motion in the backup. This also happens with "Preview this item" in BD-RB.
In the LAV Video Configuration, I have Software Deinterlacing/YADIF enabled. If I disable it, the Preview plays fine in BD-RB with this Blu-Ray and I assume a new backup will also work fine.
Can BD-RB ignore the LAV user-settings or do the LAV Filters always need to be set in a specific way?
Win 10 Pro x64
Weirdo is offline   Reply With Quote
Old 20th February 2017, 09:25   #25643  |  Link
Lathe
Lathe's Avatar
Originally Posted by Weirdo View Post
...everything played in slow motion
Hmmm, so, uh..., were you maybe smok'n a little somethin...?
Lathe is offline   Reply With Quote
Old 20th February 2017, 09:28   #25644  |  Link
Weirdo
Much slower speed, if you prefer. No smoking involved and I still have the BD anyway so it's easily reproduced.
Win 10 Pro x64
Old 20th February 2017, 09:36   #25645  |  Link
Lathe
Lathe's Avatar
That really IS odd... JD or one of the other experts here will likely know why...
Old 20th February 2017, 11:12   #25646  |  Link
Weirdo
Just created another backup and indeed it works perfectly with YADIF disabled in the LAV settings. The problem is obviously with the interlaced videos. Also note that when YADIF is enabled on the 25p/30p setting, the problem also doesn't appear. My original setting was 50p/60p, and that's what causes trouble.
Win 10 Pro x64
Old 20th February 2017, 11:49   #25647  |  Link
colinhunt
If it doesn't -- it is in violation of the standard. But I have my doubts that is the issue.
Was there a hidden option that would force BD-RB to make BDMV + SSIF directory structure for 3D back-ups? My memory's kinda hazy on that.
colinhunt is offline   Reply With Quote
Old 20th February 2017, 15:36   #25648  |  Link
jdobbs
Only for movie-only backups. But, as I said, it's likely something other than in-mux -- since that is a standard backup that is also present on commercial discs. I suspect you are blaming the wrong problem.
Website: www.jdobbs.net
Old 20th February 2017, 15:38   #25649  |  Link
jdobbs
There are lots of ways you can create an issue in a backup. Using filters is a good example. I don't see how deinterlacing would do it -- but if combined with certain settings maybe... of possibly it is showing up as 1080i/25p (which is illegal)?
I'd need an example and your settings to test it.
Old 20th February 2017, 16:00   #25650  |  Link
Weirdo
[02-20-17] BD Rebuilder v0.50.23
[10:25:44] Source:
  - Input BD size: 20.40 GB
  - Approximate total content: [03:29:08.428]
  - Target BD size: 4.36 GB
  - Windows Version: 6.2 [9200]
  - Resize: 1080p to 720p enabled
  - Quality: Better (Faster), CRF
  - Decoding/Frame serving: DirectShow
  - Audio Settings: AC3=0 DTS=1 HD=1 Kbs=640
[10:25:58] PHASE ONE, Encoding
 - [10:25:58] Processing: VID_00002 (1 of 26)
 - [10:25:58] Extracting A/V streams [VID_00002]
 - [10:26:23] Reencoding video [VID_00002]
   - Rate/Length: 25.000fps, 10,941 frames
   - Convert: 1280x720, 50.000fps, 21,882 frames
 - [10:26:23] Encoding using constant rate factor.
 - [10:33:27] Video Encode complete
 - [10:33:27] Processing audio tracks
 - [10:33:27] Multiplexing M2TS
 - [10:33:33] Blanking: VID_00011 (2 of 26)
 - [10:33:33] Blanking: VID_00012 (3 of 26)
 - [10:33:33] Blanking: VID_00013 (4 of 26)
 - [10:33:33] Processing: VID_00019 (5 of 26)
 - [10:33:33] Extracting A/V streams [VID_00019]
 - [10:33:39] Reencoding video [VID_00019]
   - Rate/Length: 23.976fps, 1,051 frames
 - [10:33:39] Encoding using constant rate factor.
 - [10:34:31] Video Encode complete
 - [10:34:31] Processing audio tracks
 - [10:34:31] Multiplexing M2TS
 - [10:34:35] Processing: VID_00021 (6 of 26)
 - [10:34:35] Extracting A/V streams [VID_00021]
 - [10:34:39] Reencoding video [VID_00021]
   - Rate/Length: 23.976fps, 240 frames
 - [10:34:39] Encoding using constant rate factor.
 - [10:34:44] Video Encode complete
 - [10:34:44] Processing audio tracks
 - [10:34:44] Multiplexing M2TS
 - [10:34:48] Blanking: VID_00072 (7 of 26)
 - [10:34:48] Blanking: VID_00079 (8 of 26)
 - [10:34:48] Blanking: VID_00080 (9 of 26)
 - [10:34:48] Processing: VID_00087 (10 of 26)
 - [10:34:48] Extracting A/V streams [VID_00087]
 - [10:36:13] Reencoding video [VID_00087]
   - Rate/Length: 25.000fps, 48,678 frames
   - Convert: 1280x720, 50.000fps, 97,356 frames
 - [10:36:13] Encoding using constant rate factor.
 - [11:07:51] Video Encode complete
 - [11:07:51] Processing audio tracks
 - [11:07:51] Multiplexing M2TS
 - [11:08:05] Blanking: VID_00098 (11 of 26)
 - [11:08:05] Processing: VID_00099 (12 of 26)
 - [11:08:05] Extracting A/V streams [VID_00099]
 - [11:08:50] Reencoding video [VID_00099]
   - Rate/Length: 24.000fps, 27,414 frames
   - Convert: 1280x720, 24.000fps, 27,414 frames
 - [11:08:50] Encoding using constant rate factor.
 - [11:20:49] Video Encode complete
 - [11:20:49] Processing audio tracks
 - [11:20:49] Multiplexing M2TS
 - [11:20:57] Processing: VID_00100 (13 of 26)
 - [11:20:57] Extracting A/V streams [VID_00100]
 - [11:21:08] Reencoding video [VID_00100]
   - Rate/Length: 24.000fps, 4,617 frames
   - Convert: 1280x720, 24.000fps, 4,617 frames
 - [11:21:08] Encoding using constant rate factor.
 - [11:24:11] Video Encode complete
 - [11:24:11] Processing audio tracks
 - [11:24:11] Multiplexing M2TS
 - [11:24:16] Processing: VID_00101 (14 of 26)
 - [11:24:16] Extracting A/V streams [VID_00101]
 - [11:24:28] Reencoding video [VID_00101]
   - Rate/Length: 24.000fps, 5,178 frames
   - Convert: 1280x720, 24.000fps, 5,178 frames
 - [11:24:28] Encoding using constant rate factor.
 - [11:27:26] Video Encode complete
 - [11:27:26] Processing audio tracks
 - [11:27:26] Multiplexing M2TS
 - [11:27:30] Processing: VID_00102 (15 of 26)
 - [11:27:30] Extracting A/V streams [VID_00102]
 - [11:27:39] Reencoding video [VID_00102]
   - Rate/Length: 24.000fps, 3,061 frames
   - Convert: 1280x720, 24.000fps, 3,061 frames
 - [11:27:39] Encoding using constant rate factor.
 - [11:29:18] Video Encode complete
 - [11:29:18] Processing audio tracks
 - [11:29:18] Multiplexing M2TS
 - [11:29:22] Processing: VID_00103 (16 of 26)
 - [11:29:22] Extracting A/V streams [VID_00103]
 - [11:29:36] Reencoding video [VID_00103]
   - Rate/Length: 24.000fps, 6,792 frames
   - Convert: 1280x720, 24.000fps, 6,792 frames
 - [11:29:36] Encoding using constant rate factor.
 - [11:33:34] Video Encode complete
 - [11:33:34] Processing audio tracks
 - [11:33:34] Multiplexing M2TS
 - [11:33:39] Processing: VID_00104 (17 of 26)
 - [11:33:39] Extracting A/V streams [VID_00104]
 - [11:33:51] Reencoding video [VID_00104]
   - Rate/Length: 24.000fps, 5,287 frames
   - Convert: 1280x720, 24.000fps, 5,287 frames
 - [11:33:51] Encoding using constant rate factor.
 - [11:36:53] Video Encode complete
 - [11:36:53] Processing audio tracks
 - [11:36:53] Multiplexing M2TS
 - [11:36:57] Processing: VID_00105 (18 of 26)
 - [11:36:57] Extracting A/V streams [VID_00105]
 - [11:37:10] Reencoding video [VID_00105]
   - Rate/Length: 24.000fps, 5,715 frames
   - Convert: 1280x720, 24.000fps, 5,715 frames
 - [11:37:10] Encoding using constant rate factor.
 - [11:40:11] Video Encode complete
 - [11:40:11] Processing audio tracks
 - [11:40:11] Multiplexing M2TS
 - [11:40:16] Processing: VID_00106 (19 of 26)
 - [11:40:16] Extracting A/V streams [VID_00106]
 - [11:40:28] Reencoding video [VID_00106]
   - Rate/Length: 24.000fps, 4,825 frames
   - Convert: 1280x720, 24.000fps, 4,825 frames
 - [11:40:28] Encoding using constant rate factor.
 - [11:43:26] Video Encode complete
 - [11:43:26] Processing audio tracks
 - [11:43:26] Multiplexing M2TS
 - [11:43:31] Processing: VID_00107 (20 of 26)
 - [11:43:31] Extracting A/V streams [VID_00107]
 - [11:43:42] Reencoding video [VID_00107]
   - Rate/Length: 24.000fps, 4,727 frames
   - Convert: 1280x720, 24.000fps, 4,727 frames
 - [11:43:42] Encoding using constant rate factor.
 - [11:46:10] Video Encode complete
 - [11:46:10] Processing audio tracks
 - [11:46:10] Multiplexing M2TS
 - [11:46:15] Processing: VID_00108 (21 of 26)
 - [11:46:15] Extracting A/V streams [VID_00108]
 - [11:46:24] Reencoding video [VID_00108]
   - Rate/Length: 24.000fps, 3,738 frames
   - Convert: 1280x720, 24.000fps, 3,738 frames
 - [11:46:24] Encoding using constant rate factor.
 - [11:48:37] Video Encode complete
 - [11:48:37] Processing audio tracks
 - [11:48:37] Multiplexing M2TS
 - [11:48:41] Processing: VID_00109 (22 of 26)
 - [11:48:41] Extracting A/V streams [VID_00109]
 - [11:48:54] Reencoding video [VID_00109]
   - Rate/Length: 24.000fps, 4,936 frames
   - Convert: 1280x720, 24.000fps, 4,936 frames
 - [11:48:54] Encoding using constant rate factor.
 - [11:51:51] Video Encode complete
 - [11:51:51] Processing audio tracks
 - [11:51:51] Multiplexing M2TS
 - [11:51:55] Processing: VID_00110 (23 of 26)
 - [11:51:55] Extracting A/V streams [VID_00110]
 - [11:52:07] Reencoding video [VID_00110]
   - Rate/Length: 24.000fps, 4,640 frames
   - Convert: 1280x720, 24.000fps, 4,640 frames
 - [11:52:07] Encoding using constant rate factor.
 - [11:54:59] Video Encode complete
 - [11:54:59] Processing audio tracks
 - [11:54:59] Multiplexing M2TS
 - [11:55:04] Processing: VID_00111 (24 of 26)
 - [11:55:04] Extracting A/V streams [VID_00111]
 - [11:55:13] Reencoding video [VID_00111]
   - Rate/Length: 24.000fps, 3,340 frames
   - Convert: 1280x720, 24.000fps, 3,340 frames
 - [11:55:13] Encoding using constant rate factor.
 - [11:57:16] Video Encode complete
 - [11:57:16] Processing audio tracks
 - [11:57:16] Multiplexing M2TS
 - [11:57:21] Processing: VID_00112 (25 of 26)
 - [11:57:21] Extracting A/V streams [VID_00112]
 - [11:57:31] Reencoding video [VID_00112]
   - Rate/Length: 24.000fps, 3,988 frames
   - Convert: 1280x720, 24.000fps, 3,988 frames
 - [11:57:31] Encoding using constant rate factor.
 - [11:59:37] Video Encode complete
 - [11:59:37] Processing audio tracks
 - [11:59:37] Multiplexing M2TS
 - [11:59:41] Processing: VID_00113 (26 of 26)
 - [11:59:41] Extracting A/V streams [VID_00113]
 - [11:59:55] Reencoding video [VID_00113]
   - Rate/Length: 24.000fps, 6,479 frames
   - Convert: 1280x720, 24.000fps, 6,479 frames
 - [11:59:55] Encoding using constant rate factor.
 - [12:03:34] Video Encode complete
 - [12:03:34] Processing audio tracks
 - [12:03:34] Multiplexing M2TS
[12:03:39]PHASE ONE complete
[12:03:39]PHASE TWO - Rebuild Started
 - [12:03:39] Rebuilding BD file Structure
[12:03:41] - Encode and Rebuild complete
 - WORKFILES folder removed.
[12:03:41] JOB: finished.
[02-20-17] Checking System Settings
  - BD-Rebuilder v0.50.23
  - Working Path Free Space: 50.76GB
  - AVISYNTH Version: 2.6.0.5, Ok
  - LAVFILTERS:  Ok
  - AnyDVD settings check: Ok.
  - X264:  Ok
  - AFTEN:  Ok
  - FAAC:  Ok
  - MP4BOX:  Ok
  - WAVI:  Ok
  - TSMUXER:  Ok
  - FRIMEncode:  Ok
  - FRIMDecode:  Ok
[02-20-17] Systems Settings Check complete
Win 10 Pro x64
Old 20th February 2017, 16:03   #25651  |  Link
jdobbs
Can you post your settings (the contents of the BDREBUILDER.INI file)?
Note this in your log, it's probably the root of the problem:
Old 20th February 2017, 16:10   #25652  |  Link
Weirdo
Oh ok, sorry. I now see in the preview that the 1080p/24 files do not display video speed issues (with the same LAV/YADIF setting enabled) but the audio goes out of sync. The 1080i/25 ones are worse, as described.
[Options]
ENABLE_TEST=1
VERSION=0.50.0.23
FORCE_ENCODE=1
FIXED_CRF=19
ENCODER=0
MODE=0
ENCODE_QUALITY=1
ONEPASS_ENCODING=1
AUTO_QUALITY=0
AUDIO_TO_KEEP=eng;
SUBS_TO_KEEP=all
SD_CONVERT=0
OPEN_GOP=0
RESIZE_1080=1
RESIZE_1440=0
RESIZE_720=0
DEINTERLACE=1
SD_TO_1080=0
IGNORE_3D=0
CONVERT_WIDE=0
WIDE_PERCENT=100
WIDE_OFFSET=1
DTS_REENCODE=1
AC3_REENCODE=0
AC3_640=1
AC3_192=0
KEEP_HD_AUDIO=1
AUDIO_DRC=0
DECODER=0
AVCHD=1
REMOVE_WORKFILES=1
REMOVE_OUTPUT=0
USE_FILTERS=0
BDMV_CERT_ONLY=0
IVTC_PULLDOWN=0
ASSUME_DVD_PAL=0
FRIMSOURCE=0
COMPLETION_BEEP=0
OUTPUT_SBS=0
NEROAAC=0
SUPTITLE=0
AUDIO_TRACK_LIMIT=0
SUBTITLE_TRACK_LIMIT=0
CUSTOM_TARGET_SIZE=7000
MINIMIZE_TO_TRAY=1
TARGET_SIZE=4469
PGSTOSRT=0
ENABLE_BLANKING=1
PRIORITY_CLASS=1
MOVIEONLY_TYPE=11
ALTCRF=19
ALT_TARGET=1024
ALT_CRF_TARGET=1024
ALTMETHOD=0
ALTAUTOCROP=0
[Paths]
SOURCE_PATH=
WORKING_PATH=
Win 10 Pro x64
Old 20th February 2017, 17:39   #25653  |  Link
bebopper
1920x2160i output from 1080i source
I've not posted before, but recently experiencing some issues, all 1080i source related (both 23.97 & 29.97fps content). This started happening with v0.50.19, which prompted a switch to v0.50.23 but with same results. The output video is 1920x2160i, fps is unchanged, but audio is then out of sync with video (audio plays faster, I think). I'm using all suggested ffdshow settings. Any help or suggestions would be greatly appreciated. Thanks.
My BD-RB settings are as follows:
VERSION=0.50.0.23
ENCODER=0
MODE=0
ENCODE_QUALITY=2
ONEPASS_ENCODING=0
AUTO_QUALITY=0
AUDIO_TO_KEEP=eng;
SUBS_TO_KEEP=eng;
SD_CONVERT=0
OPEN_GOP=0
RESIZE_1080=0
RESIZE_1440=0
RESIZE_720=0
DEINTERLACE=1
SD_TO_1080=0
IGNORE_3D=0
CONVERT_WIDE=0
DTS_REENCODE=1
AC3_REENCODE=0
AC3_640=1
AC3_192=0
KEEP_HD_AUDIO=0
AUDIO_DRC=0
DECODER=4
AVCHD=1
REMOVE_WORKFILES=0
REMOVE_OUTPUT=0
USE_FILTERS=0
BDMV_CERT_ONLY=0
IVTC_PULLDOWN=0
ASSUME_DVD_PAL=0
FRIMSOURCE=0
COMPLETION_BEEP=0
OUTPUT_SBS=0
NEROAAC=0
SUPTITLE=0
PGSTOSRT=0
AUDIO_TRACK_LIMIT=0
SHUTDOWN_SLEEP=1
CUSTOM_TARGET_SIZE=4574
TARGET_SIZE=26550
AUTO_BURN=0
bebopper is offline   Reply With Quote
Old 20th February 2017, 18:54   #25654  |  Link
thekiller
1. Please post the contents of your ALTERNATE.TXT file so I can see if it's entered correctly.
2. Are any other encodes working?
3. As gonca suggested, please post INSPECT results.
hello, thank you for the reponse
#  The options below show up in the Alternate Output Dialog
#  Settings:
#  caption=Text to show on alternate selection list
#  vEncoder=Video encoder, 0=x264 (default), 1=x265, 2=HC Encoder (MPEG-2)
#           Note: A cType of 3 or 4 (see below) forces MPEG-2 via HCEncoder
#  vBitrate=Bitrate to use for two-pass video encoding, * = variable (DVD only)
#  aBitrate=Bitrate to use for audio encoding, * = automatic (constant quality encode, not allowed for iPod & iPad)
#  aType=Output Audio Type, 0=AC3, 1=AAC  (Note: Audio bitrate less than 384Kbs implies stereo downmix)
#                           2=[Intact audio -- MKV & MP4 only]
#  vFormat=Video Format:  0=320x240/180, 1= 480x360/270, 2= 640x480/360, 3= 1024x768/576,
#                         4= 1280x720, 5= 1920x1080, 6= 720x480/576, 7= No Resizing, 8=Intact
#  vKeyint=Video GOP size (interval):  Default=24, "Auto" = 10x framerate (MKV & MP4 only)
#  cType= Container/limits type, 0=iPod (mp4), 1=MKV, 2=iPad (mp4), 3=DVD-5, 4=DVD-9, 5=MP4 6=iPad 2+ (MP4)
[00001]
caption=DVD-5, 720x480/576, AC3 Audio
vBitrate=*
aBitrate=*
aType=0
vFormat=6
cType=3
[00002]
caption=DVD-9, 720x480/576, AC3 Audio
vBitrate=*
aBitrate=*
aType=0
vFormat=6
cType=4
[00003]
caption=iPod MP4, 640x480/360, 128Kbs AAC
vBitrate=583
aBitrate=128
aType=1
vFormat=2
cType=0
[00004]
caption=iPod MP4, 480x360/270, 112Kbs AAC
vBitrate=421
aBitrate=112
aType=1
vFormat=1
cType=0
[00005]
caption=iPod MP4, 320x240/180, 64Kbs AAC
vBitrate=281
aBitrate=96
aType=1
vFormat=0
cType=0
[00006]
caption=MKV Container, 720x480/576, 128Kbs AC3
vBitrate=872
aBitrate=128
aType=0
vFormat=6
cType=1
[00007]
caption=MKV Container, 1280x720, 192Kbs AC3
vBitrate=1230
aBitrate=192
aType=0
vFormat=4
cType=1
[00008]
caption=MKV Container, 1280x720, 448Kbs DD5.1
vBitrate=1230
aBitrate=448
aType=0
vFormat=4
cType=1
[00009]
caption=MKV Container, 1920x1080, 192Kbs AC3
vBitrate=1941
aBitrate=192
aType=0
vFormat=5
cType=1
[00010]
caption=MKV Container, 1920x1080, 640Kbs DD5.1
vBitrate=1941
aBitrate=640
aType=0
vFormat=5
cType=1
[00011]
caption=MKV Container, 1920x1080, Intact Audio
vBitrate=3000
aBitrate=0
aType=2
vFormat=5
cType=1
[00012]
caption=iPad MP4 HD, 1280x720, 128Kbs AAC
vBitrate=1500
aBitrate=128
aType=1
vFormat=4
cType=2
[00013]
caption=iPad MP4 HD, 1024x768/576, 128Kbs AAC
vBitrate=1009
aBitrate=128
aType=1
vFormat=3
cType=2
[00014]
caption=iPad MP4 SD, 640x480/360, 128Kbs AAC
vBitrate=583
aBitrate=128
aType=1
vFormat=2
cType=2
[00015]
caption=iPad MP4 SD, 480x360/270, 112Kbs AAC
vBitrate=421
aBitrate=112
aType=1
vFormat=1
cType=2
[00016]
caption=iPad MP4 SD, 720x480/576, 128Kbs AAC
vBitrate=872
aBitrate=128
aType=1
vFormat=6
cType=2
[00017]
caption=MKV Container, 1920x1080, Auto-AAC
vBitrate=3000
aBitrate=*
aType=1
vFormat=5
cType=1
[00018]
caption=MKV Container, 1280x720, Auto-AAC
vBitrate=2000
aBitrate=*
aType=1
vFormat=4
cType=1
[00019]
caption=MP4 Container, 1920x1080, AutoGOP, Auto-AAC
vBitrate=3000
aBitrate=*
aType=1
vFormat=5
vKeyint=Auto
cType=5
[00020]
caption=MP4 Container, 1280x720, AutoGOP, Auto-AAC
vBitrate=2000
aBitrate=*
aType=1
vFormat=4
vKeyint=Auto
cType=5
[00021]
caption=MP4 Container, NO_RESIZE, AutoGOP, Auto-AAC
vBitrate=2000
aBitrate=*
aType=1
vFormat=7
vKeyint=Auto
cType=5
[00022]
caption=MKV Container, NO_RESIZE, AutoGOP, Auto-AAC
vBitrate=2000
aBitrate=*
aType=1
vFormat=7
vKeyint=Auto
cType=1
[00023]
caption=iPad 2+/iPhone 4s+, 1920x1080, 160Kbs AAC
vBitrate=3000
aBitrate=160
aType=1
vFormat=5
cType=6
[00024]
caption=iPad 2+/iPhone 4s+, 1280x720, 128Kbs AAC
vBitrate=2000
aBitrate=128
aType=1
vFormat=4
cType=6
[00025]
caption=iPad 2+/iPhone 4s+, 720x480/576, 128Kbs AAC
vBitrate=872
aBitrate=128
aType=1
vFormat=6
cType=6
[00026]
caption=MP4, Intact Video, AutoGOP, Auto-AAC
vBitrate=2000
aBitrate=*
aType=1
vFormat=8
vKeyint=Auto
cType=5
[00027]
caption=MKV, Intact Video, AutoGOP, Auto-AAC
vBitrate=2000
aBitrate=*
aType=1
vFormat=8
vKeyint=Auto
cType=1
[00028]
caption=MKV, Intact Video, Intact Audio
aType=2
vFormat=8
cType=1
[00029]
caption=MP4, Intact Video, Intact Audio
aType=2
vFormat=8
cType=5
[00030]
caption=MKV Container, 720x480/576, Intact Audio
vBitrate=872
aType=2
vFormat=6
cType=1
[00031]
caption=MP4 Container, Full-SBS (3D), Intact Audio
vBitrate=4000
aType=2
vFormat=7
cType=5
[00032]
caption=MKV Container, Full-SBS (3D), Intact Audio
vBitrate=4000
aType=2
vFormat=7
cType=1
[00033]
caption=MKV Container, HEVC 1920x1080, Auto-AAC
vEncoder=1
vBitrate=2000
vKeyint=Auto
aBitrate=*
aType=1
vFormat=5
cType=1
[00034]
caption=MKV Container, HEVC 1280x720, Auto-AAC
vEncoder=1
vBitrate=1300
vKeyint=Auto
aBitrate=*
aType=1
vFormat=4
cType=1
[00035]
caption=MKV Container, HEVC Full-SBS 3D,Auto-AAC
vEncoder=1
vBitrate=2000
vKeyint=Auto
aType=1
aBitrate=*
vFormat=7
cType=1
[00036]
caption=MKV Container, HEVC Half-SBS 3D, Intact Audio
vEncoder=1
vBitrate=2000
vKeyint=Auto
aType=2
vFormat=5
cType=1
[00037]
caption=MKV Container, NO_RESIZE, AutoGOP, Auto-AC3
vBitrate=2000
aBitrate=*
aType=0
vFormat=7
vKeyint=Auto
cType=1
[00038]
caption=MP4 Container, NO_RESIZE, AutoGOP, Auto-AC3
vBitrate=2000
aBitrate=*
aType=0
vFormat=7
vKeyint=Auto
cType=5
[00039]
caption=MKV Container, HEVC 1920x1080, 448Kbs DD5.1
vEncoder=1
vBitrate=2000
vKeyint=Auto
aBitrate=448
aType=0
vFormat=5
cType=1
INSPECT -->
[02/20/17] Checking System Settings
- Working Path Free Space: 3*242,76GB
- AVISYNTH Version: 2.6.0.6, Ok
- LAVFILTERS: Ok
- X264: Ok
- AFTEN: Ok
- FAAC: Ok
- MP4BOX: Ok
- WAVI: Ok
- TSMUXER: Ok
- FRIMEncode: Ok
- FRIMDecode: Ok
[02/20/17] Systems Settings Check complete
On the other hand it takes me by default not the video bonn of the film, it takes me a long version!
thekiller is offline   Reply With Quote
Old 20th February 2017, 19:02   #25655  |  Link
jdobbs
1. 1920x2160i ? Is it a 3D source? If so, how could it have been interlaced?
2. Audio plays faster? I don't see how that is even possible -- it is never adjusted.
Old 20th February 2017, 20:55   #25656  |  Link
bebopper
1. Not a 3D source; titles I'm having trouble with are nature documentaries from BBC or (US) PBS Nature. I really don't know how the output becomes interlaced (goes from 1920x1080i 16:9, verified with BDInfo, VLC player etc, to 1920x2160i 8:9). As you can see from my settings, I use almost all default settings except choosing a custom target size and whether to convert DTS to DD. I've tried turning deinterlacer off, but output is exactly the same.
2. By audio playing faster, I mean relative to the video image, after BD-RB processing. The audio becomes out of sync with video very quickly when starting from the beginning.
I just noticed there is the "IVTC with 3:2 pulldown" option in setup menu, which I've not tried before, should I try it to see what the output looks like? Thanks.
Old 20th February 2017, 22:12   #25657  |  Link
jdobbs
I'm definitely confused. BD-RB hasn't even an option to possibly output 1920x2160i.
Are you using a Blu-Ray disc as your source, or are you importing first?
Old 20th February 2017, 22:28   #25658  |  Link
bebopper
I've tried processing from a ripped BD image to HDD and from a main movie only BD file structure extracted from ripped BD image (using clownBD), but not direct from BD. In both cases I've tried, the results are the same.
So, I misspoke in my earlier post. The BD-RB processed video playback is faster than the audio, not the other way around. Sorry.
And, thinking about it more, the IVTC with 3:2 pulldown option won't help since I'm not looking to convert into a "film". Apologize for the brain fart. Thanks.
Old 20th February 2017, 23:33   #25659  |  Link
jdobbs
This one is weird. Can you post the log?
Old 21st February 2017, 00:05   #25660  |  Link
bebopper
Ok, here are 2 logs: (1) used BD-RB on just the main movie, (2) used BD-RB on blu-ray disk image:
[02/05/17] BD Rebuilder v0.50.23
[21:56:10] Source: SUPER_HUMMINGBIRDS_PCM
- Input BD size: 13.04 GB
- Approximate total content: [00:52:59.209]
- Target BD size: 4.58 GB
- Quality: High Quality (Default), Two Pass
- SHUTDOWN at completion enabled
- Decoding/Frame serving: FRIMSource
- Audio Settings: AC3=0 DTS=1 HD=0 Kbs=640
[21:56:10] PHASE ONE, Encoding
- [21:56:10] Processing: VID_00000 (1 of 1)
- [21:56:10] Extracting A/V streams [VID_00000]
- [21:58:30] Reencoding video [VID_00000]
- Rate/Length: 29.970fps, 95,281 frames
- Bitrate: 10,749 Kbs
- [21:58:30] Reencoding: VID_00000, Pass 1 of 2
- [22:29:47] Reencoding: VID_00000, Pass 2 of 2
- [23:43:09] Video Encode complete
- [23:43:09] Processing audio tracks
- Track 4352 (eng): Reencoding audio to AC3...
- [23:43:26] Multiplexing M2TS
[23:44:11]PHASE ONE complete
[23:44:11]PHASE TWO - Rebuild Started
- [23:44:11] Rebuilding BD file Structure
[23:44:11] - Encode and Rebuild complete
- Computer SLEEP initiated.
[06:11:41] JOB: SUPER_HUMMINGBIRDS_DTS-CORE finished.
[02/06/17] BD Rebuilder v0.50.23
[06:30:12] Source: SUPER_HUMMINGBIRDS
- Input BD size: 14.18 GB
- Approximate total content: [00:54:09.421]
- Target BD size: 4.53 GB
[06:30:12] PHASE ONE, Encoding
- [06:30:12] Processing: VID_00000 (1 of 5)
- [06:30:12] Extracting A/V streams [VID_00000]
- [06:30:20] Reencoding video [VID_00000]
- Rate/Length: 29.970fps, 1,382 frames
- Bitrate: 10,762 Kbs
- [06:30:20] Reencoding: VID_00000, Pass 1 of 2
- [06:30:52] Reencoding: VID_00000, Pass 2 of 2
- [06:32:07] Video Encode complete
- [06:32:07] Processing audio tracks
- Track 4352 (und): Keeping original audio
- [06:32:07] Multiplexing M2TS
- [06:32:12] Processing: VID_00001 (2 of 5)
- [06:32:12] Extracting A/V streams [VID_00001]
- [06:32:15] Reencoding video [VID_00001]
- Rate/Length: 23.976fps, 217 frames
- Bitrate: 632 Kbs
- [06:32:15] Reencoding: VID_00001, Pass 1 of 2
- [06:32:17] Reencoding: VID_00001, Pass 2 of 2
- [06:32:19] Video Encode complete
- [06:32:19] Processing audio tracks
- [06:32:19] Multiplexing M2TS
- [06:32:23] Processing: VID_00002 (3 of 5)
- [06:32:23] Extracting A/V streams [VID_00002]
- [06:32:27] Reencoding video [VID_00002]
- Rate/Length: 29.970fps, 225 frames
- Bitrate: 7,998 Kbs
- [06:32:27] Reencoding: VID_00002, Pass 1 of 2
- [06:32:32] Reencoding: VID_00002, Pass 2 of 2
- [06:32:42] Video Encode complete
- [06:32:42] Processing audio tracks
- Track 4352 (und): Reencoding audio to AC3...
- [06:32:42] Multiplexing M2TS
- [06:32:46] Processing: VID_00003 (4 of 5)
- [06:32:46] Extracting A/V streams [VID_00003]
- [06:32:50] Reencoding video [VID_00003]
- Bitrate: 9,086 Kbs
- [06:32:50] Reencoding: VID_00003, Pass 1 of 2
- [06:32:55] Reencoding: VID_00003, Pass 2 of 2
- [06:33:05] Video Encode complete
- [06:33:05] Processing audio tracks
- [06:33:06] Multiplexing M2TS
- [06:33:09] Processing: VID_00004 (5 of 5)
- [06:33:09] Extracting A/V streams [VID_00004]
- [06:35:31] Reencoding video [VID_00004]
- Rate/Length: 29.970fps, 95,282 frames
- Bitrate: 10,394 Kbs
- [06:35:31] Reencoding: VID_00004, Pass 1 of 2
- [07:07:29] Reencoding: VID_00004, Pass 2 of 2
- [08:20:37] Video Encode complete
- [08:20:37] Processing audio tracks
- [08:20:56] Multiplexing M2TS
[08:22:08]PHASE ONE complete
[08:22:08]PHASE TWO - Rebuild Started
- [08:22:08] Rebuilding BD file Structure
[08:22:08] - Encode and Rebuild complete
[08:34:25] JOB: SUPER_HUMMINGBIRDS finished.
Thanks very much for your help.
