Old 2nd December 2008, 16:49   #1  |  Link
snd303
snd303's Avatar
How to compile libx264.dll for Avidemux?
Hi, everyone. Does anyone know how to compile libx264.dll for Avidemux?
My System
Windows XP Prof SP3
So here is what I did so far
  • Installed all the programs listed in that guide
    Step by step x264 compilation guide for complete newbies:
  • I always tried to install the newest version of each program
    binutils-2.19-mingw32-rc1-bin.tar.gz
    gcc-part-core-4.3.0-20080502-2-mingw32-alpha-bin.tar.gz
    Git-1.6.0.2-preview20080923.exe
    MinGW-5.1.4.exe
    w32api-3.12-mingw32-dev.tar.gz
    yasm-0.7.2-win32.exe
    zlib-1.2.3.exe
    gpac-0.4.4-rc2.zip (I guess not necessary for Avidemux?)
    pthreads-w32-2-8-0-release.exe
  • Get the newest x264 build with Git
    git clone git://git.videolan.org/x264.git
  • Open MSYS and start to configure the source
    configure --prefix=/mingw --enable-pthread --enable-avis-input --enable-shared
    Gives me the following result
    ./version.sh: git: command not found
    Platform:   X86
    System:     MINGW
    asm:        yes
    avis input: yes
    mp4 output: no
    pthread:    yes
    debug:      no
    gprof:      no
    PIC:        no
    shared:     yes
    visualize:  no
    You can run 'make' or 'make fprofiled' now.
  • Then start to compile
    make SONAME=libx264.dll
    Some warnings appear during compiling but nothing to worry about I guess…
Everything’s finished and I have a brand new x264.exe (1,12 MB) and libx264.dll (803 KB).
Testing x264.exe
$ x264.exe --version
x264 0.65.x
built on Dec  2 2008, gcc: 4.3.0 20080305 (alpha-testing) mingw-20080502
Overwriting the existing libx264.dll in the Avidemux folder and try to encode a video in x264 gives me the following result:
Filter Init Failed
Looking forward for some advice.
snd303
snd303 is offline   Reply With Quote
Old 2nd December 2008, 18:50   #2  |  Link
LoRd_MuldeR
Software Developer
LoRd_MuldeR's Avatar
You must make sure that you use the same core version of libx264-xx.dll that Avidemux was compiled for!
Usually the x264 API is unchanged over several revisions, but once it is changed, Avidemux needs to be re-compiled with latest x264.h too!
For example if a Avidemux shipped with libx264-65.dll, then it will only work with libx264 core version 65...
BTW: You need to apply the alignment fix patch to make libx264-xx.dll work properly, otherwise it will crash when executing some of the SSE functions.
And you need GCC 4.2.x or newer to make the alignment fix work. Also Avisynth input is useless for the x264 DLL.
My build script looks like this:
echo
echo --------------------------------------------------------------------------
echo
cd x264
patch -p1 < ../avidemux.diff
echo
echo
./configure --enable-shared --extra-cflags="-march=pentium2"
echo
echo
make fprofiled VIDS="../sample.avs ../sample2.avs"
echo
The patch is as follows:
*** a/encoder/encoder.c	Fri Sep 19 23:19:33 2008
--- b/encoder/encoder.c	Sat Sep 20 03:38:48 2008
*************** static int x264_slices_write( x264_t *h
*** 1328,1329 ****
--- 1341,1343 ----
+ __attribute__((force_align_arg_pointer))
  int     x264_encoder_encode( x264_t *h,
Last but not least, latest libx264-65.dll for Avidemux r4494 can be found here:
http://forum.doom9.org/showthread.ph...26#post1218226
Old 3rd December 2008, 01:50   #3  |  Link
snd303
snd303's Avatar
THX a lot LoRd_MuldeR. I always seeing you around since I’m using Avidemux. My libx264.dll works fine with your latest Avidemux build.
snd303
Old 3rd December 2008, 02:03   #4  |  Link
LoRd_MuldeR
Software Developer
BTW: It's Gruntster's Avidemux build that I mirror on my site. He also came up with the alignment fix patch
avidemux, compile, libx264.dll, mingw, msys
