23rd October 2019, 16:52 | #462 | Link |
The link on the first page works for me
28th April 2020, 16:26 | #465 | Link |
since SmoothAdjust is close source and original SmoothLevels Thread is closed
here a HBD update for the old SmoothLevels (now renamed as oSmoothLevels) https://github.com/realfinder/AVS-St...othLevels.avsi try it with useGF=false for now
See My Avisynth Stuff |
1st June 2020, 15:14 | #468 | Link |
How similar are oSmoothLevels results to Smoothadjust dll ?
[could it be used as source for CPP re-write]
28th June 2020, 11:18 | #469 | Link | |
anyway, I did another update to not use useGF by default in HBD and another changes that almost same as I did for MCTemporalDenoise (use GradFun2DB3 from my edit of GradFun2DBmod in avs26/avs+)
28th June 2020, 13:55 | #470 | Link |
Thanks RF.
7th July 2021, 12:09 | #471 | Link |
For planar YUV input sources >8bit (e.g. using convertbits(12)) I am getting weird outputs with SmoothAdjust (SmoothTweak, SmoothLevels). Only the left half of the picture is affected and badly color distorted. The right half remains untouched. Using SmoothAdjust.dll version 3.20. Any explanation what could be wrong?
7th July 2021, 12:53 | #472 | Link |
Try use oSmoothLevels of real.finder replace
https://raw.githubusercontent.com/re...othLevels.avsi |
7th July 2021, 15:08 | #474 | Link |
Try use internal function tweak() replace
http://avisynth.nl/index.php/Tweak |
7th July 2021, 21:11 | #476 | Link |
Big Bit Savings Now !
To use SmoothAdjust with 16 bit, just
vidcurve=SmoothCurve16(ConvertToStacked(vid), HQ=true, interp=100, Ycurve="0-0;15360-30720;65535-65535", Ucurve="0-0;65535-65535", Vcurve="0-0;65535-65535").ConvertFromStacked()
8th July 2021, 00:17 | #477 | Link | |
Source() ConvertBits(16) ConvertToStacked(16) SmoothTweak16(saturation=1.6,Lmode=2) ConvertFromStacked(16) Edit: oops, I didn't see Emulgator's post, I started to reply some hours ago and had to leave |
4th February 2024, 21:38 | #479 | Link |
When using:
ClearAutoloadDirs() SetFilterMTMode("DEFAULT_MT_MODE", MT_MULTI_INSTANCE) LoadPlugin("F:\Hybrid\64bit\Avisynth\avisynthPlugins\LSMASHSource.dll") LoadPlugin("F:\Hybrid\64bit\Avisynth\avisynthPlugins\dither.dll") LoadPlugin("F:\Hybrid\64bit\Avisynth\avisynthPlugins\SmoothAdjust.dll") Import("F:\Hybrid\64bit\Avisynth\avisynthPlugins\mtmodes.avsi") # loading source: C:\Users\Selur\Desktop\Tonight (with Emma Hewitt) (M).mov # color sampling YUY2@10, matrix: bt709, scantyp: progressive, luminance scale: limited LWLibavVideoSource("C:\Users\Selur\Desktop\Tonight (with Emma Hewitt) (M).mov",cache=false,format="YUV422P16", prefer_hw=0,repeat=true) # current resolution: 1920x815 # cropping Crop(0,1,0,0)# 1920x814 SmoothTweak16(brightness=25600) # adjust color to RGB32 (color matrix: Rec709) ConvertToRGB32(matrix="Rec709") # setting output fps to 25.000fps AssumeFPS(25,1) PreFetch(16) # output: color sampling RGB32@16, matrix: bt709, scantyp: progressive, luminance scale: limited return last Code:
SmoothAdjust: Width and height must be MOD2! (J:\tmp\tempPreviewAvisynthFile21_32_41_409.avs, line 13) Cu Selur Ps.: I'm using Avisynth+ 3.7.3 Last edited by Selur; 4th February 2024 at 21:44. |
