#21181 | Link | |
I assume Bt2446 is something that Ripbot is using? With my movies that doesn't produce good looking results what it comes to brightness. It's just too dark to me. This is from 1080p Blu-Ray disc: https://images2.imgbox.com/8d/cd/Dp4nRzWH_o.png 4K disc, RipBot Tonemap enabled: https://images2.imgbox.com/d2/76/iDHR6K0A_o.png 4D disc, no Tonemap: https://images2.imgbox.com/30/03/IDkM3A6N_o.png Is there a way for me to test what results I get in Ripbot if I try different methods? How do I apply those commands to a Ripbot job? (Mobius, Hable, Reinhard etc.). I'm happy to use any method/settings that produces results as if the source were a 1080p blu-ray disc. Last edited by Juha; 10th March 2025 at 19:52. |
#21182 | Link | |
You should be able to make as many changes to the HDRtoSDR.avs as you like, until you get the desired result. This might help:- http://www.avisynth.nl/index.php/HDRTools Other options would be creating your own custom script, or running FFMPEG after RipBot has completed the encode. Last edited by TR-7970X; 15th March 2025 at 04:06. |
#21183 | Link | |
TONEMAP OFF ![]() TONEMAP ON (BT2446)
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 12th March 2025 at 14:41. |
#21185 | Link | |
You can't really roll back, due to the way RB gets updated. However, rlev11 posted some older versions here:- https://forum.doom9.org/showthread.p...63#post2012363
Main Systems:- 9970X on Gigabyte TRX50 AERO D 7970X on Asus Pro WS TRX50-Sage WiFi 9950X3D on MSI Carbon X670E 7950X on Gigabyte Aorus Elite B650 i9-13900KF on MSI Tomahawk B660 |
#21186 | Link | |
#21187 | Link | |
Looks more like the input file has a problem.
Main Systems:- 9970X on Gigabyte TRX50 AERO D 7970X on Asus Pro WS TRX50-Sage WiFi 9950X3D on MSI Carbon X670E 7950X on Gigabyte Aorus Elite B650 i9-13900KF on MSI Tomahawk B660 Last edited by TR-7970X; 15th March 2025 at 09:11. |
#21188 | Link | |
folder from time to time I was able to preview one of them and the other one always errored out. I've had the same errors with 1.27.4 and now 1.27.3 but I think I might have fixed it. It appears it's as simple as only having one cube file in the Lut folder. I put the cube file that was erroring out every single time by itself now in the Lut folder. It immediately worked. |
#21189 | Link | |
Any change to share that piece of the clip in it's original 4K HDR format where that scene is? I'd like to try tonemapping that scene on my end. Last edited by Juha; 16th March 2025 at 12:36. |
#21190 | Link |
You should modify the HDRtoSDR.avs until you get your desired result !
#21191 | Link |
#21192 | Link |
I'm having a issue that I have seen occasionally in the past but now it happened twice in a row.
When using distributed encoding, the Encoding client gets stuck at 100 %. Ripbot window says "Please wait..." but waiting never finishes as the process doesn't complete - it's just stuck at 100 %. https://images2.imgbox.com/b6/9c/cGtDXuLz_o.png I can "resolve" this by ending the encoding client process in the task manager - after this, RB starts to mux the encoded file. Last edited by Juha; 19th March 2025 at 20:51. |
#21193 | Link | |
When using tonemap, the end result is quite similar on my end, compared to yours: https://images2.imgbox.com/c3/72/b22ErA4X_o.png Interestingly, that original clip looks quite different on my end, compared to you: https://images2.imgbox.com/24/fa/P6d7NMo1_o.png Maybe Media Player Classic / K-Lite codec pack does some tweaks to the 4K HDR video... Anyway, as I have major share of my movies in 1080p SDR, I want to rip my 4K movies to look exactly like them because I have used to the brighter image ![]() Though, that one particular scene does look fine, I admit. But I still don't like the overall look of BT2446 in other movies so I guess I'll need to do some setting tweaking. Last edited by Juha; 19th March 2025 at 22:37. |
#21194 | Link | ||
But I don't know exactly what these values: (Lhdr & Lsdr) do (other than affect brightness someway) and how changing them affects the end result. If I could get some advice how to use those values, I would appreciate. http://avisynth.nl/index.php/HDRTools doesn't explain much. Quote:
#21195 | Link |
Can you upload unprocessed hdr sample which looks too dark after tonemap?. I would like to take a look...
#21196 | Link | |
You could still create your own Custom script, instead of changing HDRtoSDR.avs
#21197 | Link |
I just tried to run a few episodes through Ripbot. I am taking the HD remux to an hevc. As soon as I hit start encoding it finishes immediately. I'm still running v 126.0.0 but the last time I used it (last month?) it worked fine.
Edit: Tried on 1.27.1 and it went through fine. Why wouldn't the older version work? Last edited by stryker412; 29th March 2025 at 17:25. |
#21198 | Link |
Rendered Subtitles Issue
I'm burning/rendering the English subs for Italian dialogue for the Godfather trilogy using the latest 1080p BD's. Wherever you use them, media players et cetera they are gold(ish) colored. After using BDSup2Sub or rendering with Ripbot they are bright yellow. I saw that Ripbot converts the sup file to sub/idx. Is there anyway to edit those files to bring it back to gold(ish) again?
#21199 | Link | |
SMDegrain Lite package for RipBot264: https://cloud.chrisdos.com/s/yiXwKbkMsQoNo6X |
#21200 | Link | |
| Tags |
| 264, 265, appletv, avchd, bluray, gui, iphone, ipod, ps3, psp, ripbot264, x264 2-pass, x264 gui, x264_64, x265, xbox360 |
| Thread Tools | |
| Display Modes | |
