Old 19th July 2018, 23:51   #21  |  Link
ChaosKing
thx updated locally.
Old 21st July 2018, 23:23   #22  |  Link
Cary Knoop
Cary Knoop
Cary Knoop's Avatar
This initiative is wonderful but may I suggest to get a better site to upload?
Zippyshare is giving me not very professional ads to say the least and creates new tabs to download all kind of software of questionable origin.
How about using dropbox?
Cary Knoop is offline   Reply With Quote
Old 22nd July 2018, 08:35   #23  |  Link
ChaosKing
Oh you're right. I visited zippyshare only with an adblocker and it looks very clean, without an ablocker not so much....
I changed the download url to dropbox.
Old 23rd July 2018, 15:33   #24  |  Link
MysteryX
Soul Architect
MysteryX's Avatar
I use https://mega.nz/ for all uploads and it works wonderfully and is fully encrypted -- for those who don't like ads and who don't like giving all their data to the government.
MysteryX is offline   Reply With Quote
Old 23rd July 2018, 16:29   #25  |  Link
ThePi7on
ThePi7on's Avatar
I tried Yuuno Editor, but when I try to
%load_ext yuuno
(as this indicates), I always get "The yuuno module is not an IPython extension."
ThePi7on is offline   Reply With Quote
Old 23rd July 2018, 17:11   #26  |  Link
ChaosKing
yuuno should already be loaded (autoload is active)
Did you try other commands, like %preview core.std.BlankClip(color=[0,255,255]) ?
Also more infos are needed, like what os are you using
Old 23rd July 2018, 18:09   #27  |  Link
poisondeathray
Thanks
First time I heard of "Yuuno Editor".
https://pypi.org/project/yuuno/
And it seems all the documentation links are down
https://yuuno.encode.moe/installation.html
https://yuuno.encode.moe/usage.html
Maybe I should start another thread on it, but can someone give a quick review pros/cons or comments ? Thanks
Old 23rd July 2018, 18:26   #28  |  Link
ChaosKing
https://forum.doom9.org/showthread.p...22#post1845422
Old 23rd July 2018, 19:46   #29  |  Link
ThePi7on
ThePi7on's Avatar
Thank for the reply,
Yes, I tried it, it returns "UsageError: Line magic function `%preview` not found."
All the magic functions I try return not found.
I also don't get any type of syntax highlight for vapoursynth related functions.
I'm on Windows 10 64bit up to date with version 1803.
Old 23rd July 2018, 20:01   #30  |  Link
ChaosKing
I think I deleted an important folder somewhere. I will post an updated version soon.
Old 25th July 2018, 17:58   #31  |  Link
Cary Knoop
Cary Knoop
Cary Knoop's Avatar
You might want to include a model folder with models for the waifu (Waifu2x-w2xc) based resizer.
Old 25th July 2018, 23:13   #32  |  Link
ChaosKing
New Update (inc newest Waifu2x models)
Please test Yuuno again.
Thanks to vsrepo most scripts and plugins can now be updated via one click.
Old 26th July 2018, 21:05   #33  |  Link
ThePi7on
ThePi7on's Avatar
Still doesn't work for me :/ Screenshot
If it can be useful, there's a software you can you to compare two folders or files, might help you catch the problem (if there's actually one, and it's not just me): Beyond Compare 4
Anyway, thanks for your work!
EDIT: don't know if it's a relevant info but: just noticed that in the 06-21-2018 version "Kernel" has a white dot, that reports "kernel idle". While the non working version only reports "kernel connected"
Old 26th July 2018, 22:30   #34  |  Link
ChaosKing
Try this please https://www.dropbox.com/s/eqksin710y...e_test.7z?dl=1
Old 26th July 2018, 23:26   #35  |  Link
ThePi7on
ThePi7on's Avatar
YES, this works perfectly, thank you!
Old 27th July 2018, 23:49   #36  |  Link
ChaosKing
New release, see first post.
Old 29th July 2018, 01:33   #37  |  Link
Pat357
Thank you so much for creating this very useful package.
One small thing may be not important, is that when I run _vs_plugin_check.bat I get the following output :
VapourSynth Video Processing Library
Copyright (c) 2012-2018 Fredrik Mellbin
Core R44
API R3.5
Options: -
Architecture 64bit - Windows-10-10.0.17134-SP0
Python build: ('v3.6.5:f59c0932b4', 'Mar 28 2018 17:00:18')
checking dlls in d:\programs\VapourSynth64Portable_2018_07_28\VapourSynth64Portable\VapourSynth64\vapoursynth64\plugins
Errors:
Failed to load d:\programs\VapourSynth64Portable_2018_07_28\VapourSynth64Portable\VapourSynth64\vapoursynth64\plugins\bilateralGPU.dll. GetLastError() returned 126. A DLL dependency is probably missing.
Plugin load failed, namespace focus already populated (d:\programs\VapourSynth64Portable_2018_07_28\VapourSynth64Portable\VapourSynth64\vapoursynth64\plugins\libtemporalsoften.dll)
Notices:
libfftw3-3.dll is a dependency by fft3dfilter or mvtools-sf
libfftw3f-3.dll is a dependency by fft3dfilter or mvtools-sf
libiomp5md.dll is part of the Waifu2x-w2xc filter
libmfxsw64.dll is part of the DGMVCSourceVS filter
svml_dispmd.dll is part of the Waifu2x-w2xc filter
w2xc.dll is part of the Waifu2x-w2xc filter
Found 109 dlls. Errors: 2 Notices: 6
Press any key to continue . . .
I guess the plugin bilateralGPU.dll needs some additional files to work.
About the second error on libtemporalsoften.dll : does this cause any further problems ?
Pat357 is offline   Reply With Quote
Old 29th July 2018, 04:35   #38  |  Link
Wolfberry
Helenium(Easter)
Wolfberry's Avatar
In order to use bilateralGPU.dll, you need to have opencv_core320.dll and opencv_cudaimgproc320.dll in the same path.
(Requirements: CUDA-Enabled GPU, OpenCV run-time library with CUDA module)
libtemporalsoften.dll and libfocus-em64t.dll have the same namespace. (focus.TemporalSoften)
Monochrome Anomaly
Wolfberry is offline   Reply With Quote
Old 29th July 2018, 09:34   #39  |  Link
ChaosKing
I don't have a nvidia card and therefore can't use or test this filter :/
Idk which temporalsoften is "better" so I left both for now. You probably will only use Temporalsoften2 anyway.
Old 29th July 2018, 16:57   #40  |  Link
Pat357
I have a Nvidia GTX-1070 TI, which has all this.
What extra package do I need to install then ?
