7th January 2022, 23:40 | #22 | Link | |
It's not entirely surprising that it might have a bigger impact on kinds of content that aren't part of typical encoder test libraries, like anime, but it's not something I'd heard about before. Cool! |
8th January 2022, 10:57 | #23 | Link |
Pig on the wing
x265's SAO has been broken since the dawn of time. What it needs is a parameter for strength, but that won't happen.
@tormento, try with --no-sao if you lose details. Also --rdoq-level 1 --psy-rd 1.8 --psy-rdoq 5 might be useful.
12th January 2022, 08:15 | #24 | Link |
Acid fr0g
Why with x265 medium I don't get full CPU utilization such as with slow preset?
I have tried both AVS and VS script and they just do the frame serving part, without any filter. I have tried different decoders too: DGDecNV, FFVideo, FFMS2, etc. --pme and --pmode utterly decrease performace.
@turment on Telegram |
12th January 2022, 08:34 | #25 | Link |
Broadcast Encoder
If you're not encoding UHD but rather FULL HD, try to play with the --merange and --ctu.
For instance, for FULL HD you might benefit from limiting CTU to 32. Try with --ctu 32 --merange 25 and toss --pme and --pmode and tell me how it goes. P.s too bad you're nowhere near Milan Santa Giulia, but rather in Pavia, 'cause we would have had breakfast together otherwise. |
12th January 2022, 08:36 | #26 | Link | |
Acid fr0g
Isn't better to increase pool number?
@turment on Telegram Last edited by tormento; 12th January 2022 at 09:04. |
12th January 2022, 18:31 | #27 | Link | |
You can look in your --log-level 2 .csv file to see how often 64x64 gets used in your encodes. |
17th January 2022, 00:07 | #29 | Link | |||
18th January 2022, 12:05 | #30 | Link | |
Lost my old account :(
"The default is derived from the default CTU size (64) minus the luma interpolation half-length (4) minus maximum subpel distance (2) minus one extra pixel just in case the hex search method is used. If the search range were any larger than this, another CTU row of latency would be required for reference frames." As I see that you ask a lot of questions regarding the different options for x265 I strongly recommend the docs as they covers most questions you have been asking https://x265.readthedocs.io/en/master/cli.html Last edited by excellentswordfight; 18th January 2022 at 12:07. |
18th January 2022, 12:35 | #31 | Link | |
Pig on the wing
I personally use --merange 26 for 1080p or less, --merange 58 for 1440p and CTU 32 for both. I don't know if there's any real benefit from using --hme for >1080p.
22nd January 2022, 02:21 | #32 | Link | ||
