Old 21st January 2022, 15:05   #81  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
Originally Posted by joearmstrong View Post
The example from Avisynth wiki seems to be wrong:
Converting to linear produces errors. Maybe a bug? Without linear the reults are fine for me:
z_ConvertFormat(pixel_type="RGBP16", colorspace_op="2020ncl:st2084:2020:l=>rgb:st2084:2020:f", dither_type="none")
Cube("...\test.cube")
z_ConvertFormat(pixel_type="YV12", colorspace_op="rgb:st2084:2020:f=>709:709:709:l", dither_type="ordered")
It depends on what the LUT is doing.
If the LUT is converting to BT709 SDR, then you don't need to put st2084 to 709 in z_ConvertFormat, otherwise you would be converting it twice!
This is what I use at Sky for PQ to HLG:
#BBC HDR PQ to HDR HLG LUT
#From 4:2:2 16bit planar Narrow Range to RGB Planar 16bit Full Range
z_ConvertFormat(pixel_type="RGBP16", colorspace_op="2020:st2084:2020:limited=>rgb:st2084:2020:full", resample_filter_uv="spline64", dither_type="error_diffusion")
#From PQ to HLG with 16bit precision
Cube("\\mibcisilonsc\avisynth\Server\encoder\encoder\Processors\avs_plugins\LUTs\1a_PQ1000_HLG_mode.cube", fullrange=true)
#From RGB 16bit planar Full Range to YUV422 10bit planar Narrow Range with dithering
z_ConvertFormat(pixel_type="YUV422P10", colorspace_op="rgb:std-b67:2020:full=>2020:std-b67:2020:limited", resample_filter_uv="spline64", dither_type="error_diffusion")
and it's what I believe should be a good example.
Old 21st January 2022, 20:37   #82  |  Link
joearmstrong
joearmstrong's Avatar
You're right, FranceBB.
I think this should be correct:
Cube("C:\Downloads\HDR to SDR\LUT von der rabe\Lut Eigen_HDR to SDR 02.cube", fullrange=true)
z_ConvertFormat(pixel_type="YV12", colorspace_op="rgb:709:709:f=>709:709:709:l", dither_type="ordered")
joearmstrong is offline   Reply With Quote
Old 21st January 2022, 23:38   #83  |  Link
videoh
Useful n00b
National squirrel appreciation day today :tip: gonca. Cube is the ham and the convert stuff is the bread. The ham tastes great.
Old 22nd January 2022, 10:24   #84  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
Yeah the last one you posted is correct.
Originally Posted by videoh View Post
National squirrel appreciation day today.
I thought you were just fooling us all, Donald, but I googled it and it's actually really the Squirrel Appreciation Day O_O
Old 24th January 2022, 21:28   #85  |  Link
Dogway
My monitor profile doesn't work anymore in latest version v1.3. Here's a link. It was working at least up to v1.1. Do I need to conform the .cube file to another format?
i7-4790K@Stock::GTX 1070] AviSynth+ filters and mods on GitHub + Discussion thread
Old 25th January 2022, 12:41   #86  |  Link
videoh
Useful n00b
Doesn't work means what? And post your script.
Old 25th January 2022, 17:59   #87  |  Link
Dogway
Means white output. This is what I have been using the past years:
	ConvertBits(16)
	ConvertToPlanarRGB()
	Cube("MonitorLUT.cube", 2, true)
	ConvertBits(8,dither=1)
Old 26th January 2022, 01:29   #88  |  Link
videoh
Useful n00b
Thank you. I'll look into it.
Old 26th January 2022, 05:43   #89  |  Link
poisondeathray
	ConvertBits(16)
Vapoursynth vscube_r3 produces "white" output too , unless the input is RGBS . r2a worked ok with RGB48
Old 26th January 2022, 13:10   #90  |  Link
videoh
Useful n00b
What is RGBS and how would one arrange the input to be RGBS?
Old 26th January 2022, 13:19   #91  |  Link
Reel.Deel
32-bit float and ConvertBits(32).
Old 26th January 2022, 13:32   #92  |  Link
videoh
Useful n00b
Thank you. Investigating...
Old 27th January 2022, 01:02   #93  |  Link
StvG
I can reproduce the issue with the white output with only Cube("....", 2). cpu 0 and 1 are fine. Using just Cube("....") is fine and it seems AVX2 is used.
StvG is offline   Reply With Quote
Old 27th January 2022, 01:21   #94  |  Link
poisondeathray
for avscube 1.3 and vscube 1.3 , cpu 0 and 1 are ok for me too. But it picks 2 by default for me, and white screen (unless RGBS in put for VPY)
Old 27th January 2022, 18:30   #95  |  Link
videoh
Useful n00b
Looks like a bug in lut_avx2.cpp, as when I replace that with the version from r2a, it works. Intrinsics and assembly are Greek to me, so I posted an issue at sekrit's site:
https://github.com/sekrit-twc/timecube/issues/7
Meanwhile, don't use cpu=2. You can try cpu=3 for AVX512, which seems to work for me.
Old 27th January 2022, 20:36   #96  |  Link
StvG
That's why for me Cube("...") (w/o specifying cpu) is working (AVX512). But cpu=3 isn't mentioned in the readme/avs wiki.
Old 27th January 2022, 23:41   #97  |  Link
videoh
Useful n00b
Yeah, I need to update the help file.
Old 29th January 2022, 00:12   #98  |  Link
videoh
Useful n00b
sekrit committed a fix for this. I'll update the Avisynth build.
Old 29th January 2022, 03:04   #99  |  Link
videoh
Useful n00b
I updated the 1.3 release with the fix for cpu=2:
http:\\rationalqm.us\hdr\avscube_1.3.zip
Old 29th January 2022, 06:28   #100  |  Link
StvG
3dl, cube, hdr, lut, sdr
