Old 1st August 2010, 16:00   #1  |  Link
freshhh
Suggestion for a DVD ripper with those requirements
Hi there,
I'm looking for a DVD ripper software with requirements listed bellow, any suggestions ?
√ CUDA / GPU support
√ multi-core CPU
√ dual audio tracks (both in .avi / .mkv file container)
√ dual / multi external subtitles
√ support for forced subtitles
√ xvid/divx/h264/x264 encoding
√ (true native x64 version)
freshhh is offline   Reply With Quote
Old 1st August 2010, 16:46   #2  |  Link
stax76
stax76's Avatar
MeGUI can use 64-bit AviSynth, using it requires effort and expertise though.
StaxRip uses 32-bit AviSynth but can use 64-bit x264 with some piping workaround, if 64-bit AviSynth would be a great gain I don't know, also requires effort and expertise but slightly less I believe.
Old 2nd August 2010, 04:06   #3  |  Link
Video Dude
Senior Member
Your requirements describe encoding software, not a DVD ripper.
Video Dude is offline   Reply With Quote
Old 5th August 2010, 23:52   #4  |  Link
Blue_MiSfit
Derek Prestegard IRL
Blue_MiSfit's Avatar
You don't actually want CUDA / GPU support... you just want a Really Fast encoder. x264 will beat any GPU encoder out there at equivalent speed...
Old 11th August 2010, 14:03   #5  |  Link
freshhh
SPAM ?
I was just doing a fair comparative of several softwares I've tested and my conclusion is that there is no winner atm (they have all pro/cons).
I checked in FAQ, I don't see any rules about commercial softwares that cannot be listed & reviewed...
I said [spam] because there are products doing the whole process (removing protection or region code/ripping/encoding) and called like that...
Many softwares like MeGui / Handbrake / RipBot / Staxrip are only encoders GUI...
MeGUI is a great encoding tool but I'm looking for a "nice"/quick steps GUI to rip & encode with some advanced options and with no need to install manually 10 softwares/plugins...
I do want CUDA / GPU support.
x264 = an algorithm.
CABAC = Context-adaptive binary arithmetic coding
I believe x264 encoding with Intel Quad Cores & CUDA / GPU with a NVIDA GFX card can be faster than x264 alone...
Old 11th August 2010, 14:47   #6  |  Link
It's rule 5. It is the moderator's judgment to decide if your intent was to advertise a product. You also missed rule 16 which requires you to obey moderator instructions and rule 17 which prohibits you from discussing the rules in the public forum.
When you have a question about the rules or their interpretation, use PM to the moderator to get clarification or to argue for a reconsideration.
Old 11th August 2010, 17:06   #7  |  Link
J_Darnley
J_Darnley's Avatar
No it can't. x264 with CPU+GPU = x264 with CPU
x264 log explained || x264 deblocking how-to
preset -> tune -> user set options -> fast first pass -> profile -> level
Doom10 - Of course it's better, it's one more.
J_Darnley is offline   Reply With Quote
cuda, dual audio, multi-core cpu, multiple subtitles, x64
