20th April 2014, 18:45 | #2041 | Link |
Why lossless webp is being saved with webpll extension? Chrome can't open this and IrfanView is saying that's not a correct extension. Why not just save it with normal webp extension?
Sure, I can rename webpll files to webp but I'm just asking out of curiosity. |
22nd April 2014, 20:44 | #2042 | Link |
MPC-BE DEV
MPC-BE 1.4.3.4823 Dev.:
MPC-BE 1.4.3.4823 Dev (sourceforge.net) MPC-BE 1.4.3.4823 Dev (dev.mpc-next.ru)
Win11 x64, i7 8700K 5Ghz, ASUS MAXIMUS X HERO, G.Skill (2x8GB) Trident Z F4-3600C16D-16GTZ, RX 5700,TV Philips 43PUS6703/12, Zappiti 4K HDR Media Player Classic - BE x86/x64. Team of developers. |
22nd April 2014, 22:10 | #2043 | Link |
Can't use latest devs posted here on my notebook connected to tv using hdmi: selecting hdmi out on windows audio control panel, files plays accelerated (like at 2 or 3x); selecting notebook built-in speakers everyting work fine.
Last working dev is MPC-BE 1.4.3.4783
Notebook HP HDX16-1040el (Intel Core 2 Duo p8400, 4GB DDR2, nvidia GeForce 9600M GT 512MB, windows 7 x64, 16" 1080p dual-back-light lcd display) |
23rd April 2014, 00:08 | #2044 | Link |
Aleksoid1978, I don't have many wmv-files, but I noticed VC1 (DXVA) doesn't work anymore (at least on my WinXP pc) starting from r4486. r4461 still works, so I guess r4473 is the culprit. Coincidentally the revision that fixed my previous problem with H.264 (DXVA1).
My hobby website |
23rd April 2014, 04:09 | #2045 | Link | |
AMD Ryzen 5 3600 /GIGABYTE B450 Gaming X /Patriot 32Gb@3200 /Kingston 500Gb M.2 /RTX 4060 /Samsung U28R550UQI /OLED Philips 55OLED707 /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215 |
23rd April 2014, 04:43 | #2046 | Link | |
23rd April 2014, 11:20 | #2047 | Link | |
23rd April 2014, 22:08 | #2048 | Link |
I can't test on another pc with WinXP, because I only have 1. I can tell you though that with VC-1 (DXVA) as well as WMV3 (DXVA) MPC-BE doesn't crash, but simply doesn't start playing. The video does load okay, the video-resolution is properly initialized, but I get a black screen and the timer stays at 0:00.
2 samples: sunrise (WVC1).wmv Pinball (WMF9).wmv One issue I noticed not only on my WinXP pc, but on a Win7 pc as well(!): To use MPC-BE's Video Decoder for VC-1 (DXVA) and WMV3 (DXVA), enabling these 2 in Options -> Internal Filters somehow isn't enough, because "VC-1 (FFmpeg)" and "WMV1/2/3" also need to be enabled, which is rather strange if you ask me. So playing a VC1 or WMV3 video with only VC-1 (DXVA) and WMV3 (DXVA) enabled loads LAV Filters (or any other DS filter) instead! Only when you enable all 4 decoders will get you playback with DXVA.
My hobby website |
24th April 2014, 02:08 | #2049 | Link |
CoRoNe
1 - on Win7/Win8 all good with VC1/WMV3 DXVA.(also if "VC-1 (FFmpeg)" & "WMV1/2/3" is disabled/unchecked) 2 - i can't test on WinXP. If don't work at you PC - try use old standalone filters.
AMD Ryzen 5 3600 /GIGABYTE B450 Gaming X /Patriot 32Gb@3200 /Kingston 500Gb M.2 /RTX 4060 /Samsung U28R550UQI /OLED Philips 55OLED707 /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215 Last edited by Aleksoid1978; 24th April 2014 at 02:11. |
24th April 2014, 18:14 | #2050 | Link |
Okay, no problem.
My hobby website |
24th April 2014, 19:46 | #2051 | Link |
MPC-BE DEV
MPC-BE 1.4.3.4831 Dev.:
MPC-BE 1.4.3.4831 Dev (sourceforge.net) MPC-BE 1.4.3.4831 Dev (dev.mpc-next.ru)
27th April 2014, 19:37 | #2052 | Link |
Great work on this branch. Nice that you can move DVD/Bluray PGS subtitles with SHIT-CTRL-UP/DOWN-ARROW. But to reset the subtitle position I first tried "reset" under Pan & Scan. But this only resets the video position. "Reload Subtitles" did the trick and also resetted the subtitle position.
Is there any way to position the seekbar at the top of the screen instead of the bottom (or move it up higher)? Or if not, will there be such an option in the foreseeable future? That's the only damn reason i still use Zoomplayer, as in my setup the bottom of the screen gets masked in the screens cache. |
28th April 2014, 01:19 | #2053 | Link | |
28th April 2014, 15:12 | #2054 | Link |
You can try to enable something else like the info panel(I don't have it in front of me so I don't know the terms) for example, it might make the seekbar show up higher if its position is under it, it might be a good enough "fix" for you.
AMD Ryzen 9 5950X and EVGA RTX 3080 with G.skill 64Gb 3600 (2 16x2 kit) on Asrock X570 Taichi with Samsung 980 Pro 500Gb NVMe SSD running Win10 x64 on LG 34GN850-B 34.0" 3440 x 1440 160 Hz |
29th April 2014, 13:02 | #2055 | Link |
MPC-BE DEV
MPC-BE 1.4.3.4843 Dev.:
MPC-BE 1.4.3.4843 Dev (sourceforge.net) MPC-BE 1.4.3.4843 Dev (dev.mpc-next.ru)
30th April 2014, 01:44 | #2056 | Link |
selecting Audio device
I have 2 Dacs attached to my computer a Teralink for SPDIF output & a dragonfly for phones but I can't control which one is selected by MPC-BE.
Both of then appear in the output/Audio Renderer there are various entries for both devices in the list as either Direct sound or SPDIF for the Teralink Changing the settings Doesn't seem to have any effect & neither does changing the windows settings. Most of the time either the dragonfly gets the nod or I get no sound at all any help would be appreciated Regards Beebee Last edited by ibbeebee; 30th April 2014 at 01:46. Reason: more information |
1st May 2014, 12:44 | #2057 | Link |
Thanks for your work, very good player
A little question : is it possible to hide playlist in full screen mode ? Or it is necessary to uncheck playlist in menu ? Edit : Do you think it is possible to add more informations on MP3 player (album, genre, year...) ? And do you think it is possible to add tag MKV support ? Thanks ! Last edited by Nico8583; 1st May 2014 at 12:58. |
