#18222 | Link |
No.
But now another problem: After burning to disk, one of the menu buttons does not show up on TV, and the remaining menu buttons start the wrong episode (shifted by one, due to the missing button?) @jdobbs: While the structure in the titles.inf in the backup\playlist folder seems clear, it appears to me that the referenced playlists does not exist as .mpls. For example: 00120 = Episode 2 => I don't find a corresponding 00120.mpls Could this be the cause of the problem (or do the numbers in the titles.inf not refer to playlists)? Last edited by Sharc; 12th November 2013 at 14:11. |
#18223 | Link | |
Aging Video Hobbyist
![]() Nice. BTW I have had some odd problems with using TMT3 to test my BD-RB backups, such as listing all subtitle and audio tracks as English. So I'm not surprised it makes mistakes with the new features. I also have TMT5 and TMT6 that I've never installed but I guess they are broken too? Only PowerDVD11 works reliably? |
#18225 | Link | ||
![]() Join Date: Oct 2001
One other thing to watch: make sure you accidentally uncheck one of the items you want to keep. I've done that a couple of times.
jdobbs.softworks@gmail.com Last edited by jdobbs; 12th November 2013 at 15:35. |
#18226 | Link | |
jdobbs.softworks@gmail.com |
#18227 | Link |
I'll look at it. But if it is an BD-5 or BD-9 it isn't generally kept.
#18228 | Link | |
jdobbs.softworks@gmail.com Last edited by jdobbs; 12th November 2013 at 16:00. |
#18229 | Link |
I'm thinking that some of these reported issues may be related to changing the threshold values. Unfortunately when the threshold changes, the edits can become wrong because the list doesn't match the original. Can anyone confirm that may be the case in their report? I may have to put the threshold value into the INF file and ignore previous edits when it doesn't match.
If that isn't the case, I'd appreciate it if someone could provide me with a specific set of steps that will make a playlist be out-of-order etc so I can debug it... thanks.
jdobbs.softworks@gmail.com Last edited by jdobbs; 12th November 2013 at 16:12. |
#18230 | Link |
I'm a little confused about the CERTIFICATE folder reports -- because nothing should have changed related to that. Is it missing in the IMPORT folder or in the output after a reencode? If it's the latter -- I think it has always worked that way... because AVCHD doesn't use it.
Any additional information would be appreciated I'd like to nail all these bugs soon and get out a new release.
#18231 | Link | |
![]() I import 3 DVD compliant mpg files created from a set top DVD Recorder. These are 3 separate TV episode files. I have "Quick-Play Backup" enabled, Strict AVCHD is not checked. The contents of the IMPORTS folder has BDMV, CERTIFICATE and PSEUDO folders present. After pressing backup, the newly created encoded folder only has the BDMV folder present! Also: The imports folder starts with episode 1, then goes to the menu upon completion. The reencoded folder starts with the main menu. I would like to have the main menu appear first always. Is it possible to have the Imports folder start at the main menu, or is reencoding necessary to achieve this ? Last edited by Capsbackup; 12th November 2013 at 16:52. |
#18232 | Link | |
It's been a long time since talking about this, but if I recall correctly, generally you don't output a CERTIFICATE folder to a BD-5 or BD-9 backup -- because there are players that won't play back a DVD+-R formatted for BD if the CERTIFICATE folder exists (along with a couple of other folders). But I was thinking I only enforced it if "Strict AVCHD" was selected (the default). I'll have to go back and look.
jdobbs.softworks@gmail.com Last edited by jdobbs; 12th November 2013 at 17:21. |
#18234 | Link |
Definitely confusing. Full Backup and Quick-Play backup both use the same code for the copy/rebuild. I'll look and see if something changed.
#18235 | Link | |
CERTIFICATE folder: I confirm Capsbackup's findings. Something must have changed for the Quick-Play backup Scenario. |
#18236 | Link | |
@All Thanks, guys. I really appreciate all the testing.
jdobbs.softworks@gmail.com Last edited by jdobbs; 12th November 2013 at 19:22. |
#18237 | Link | |
The titles.inf with my edited menu text is in the \Bdmv\Backup\Playlist\ folder: Code:
[Titles] Title=BREAKING BAD: Season 5 Disk 2 00084=Extra 1 00098=Extra 2 00100= 00119=Tödliche Fracht 00120=Buyout 00121=Sagen Sie meinen Namen 00122=Walt Whitman [Position] 00084=5 00098=6 00100=0 00119=1 00120=2 00121=3 00122=4 [Selected] 00084=-1 00098=-1 00100=0 00119=-1 00120=-1 00121=-1 00122=-1 Looks all ok with the exception that this disk has no corresponding playlists in the same folder, like 00084.mpls 00098.mpls 00100.mpls 00119.mpls 00120.mpls 00121.mpls 00122.mpls |
#18238 | Link | |
#18239 | Link | |
#18240 | Link | |
I'll have to check and see if there is any way that the titles.inf file from one source scan can somehow get saved into another. That's the only way I can imagine MPLS numbers being created out of thin air.
jdobbs.softworks@gmail.com Last edited by jdobbs; 12th November 2013 at 19:55. |
| Display Modes | |
