#8201 | Link | |
#8202 | Link |
![]() Join Date: Oct 2001
@tekmobile
I did do some work in that area on the latest version. Let me know if you still get the error.
jdobbs.softworks@gmail.com |
#8205 | Link |
Actually that was fixed in v0.33.06:
- Updated the audio AVS so that sample rates and sample sizes that are not compatible with AFTEN AC3 output are converted before being sent to the encoder. This fixes some issues that cause audio encoding failures.
#8206 | Link |
Thanks. I have a job going right now that has a huge number of M2TS parts so I can test it too.
#8207 | Link | |
#8209 | Link |
Don't waste your time. I know what's happening and I'm working on it. Hopefully you'll see a fix in a day or two.
#8210 | Link |
Sorry guys to post this when i'm sure someone may have asked before but i need help. Been a user of Bdrebuilder for about 6 months now. Great program, Jdobbs, much appreciated. But for some reason i cannot get the subs for the foreign language scenes in the Iron man bluray to work correctly. I either get everything in subs or nothing no matter which english i select. I use "all languages" under settings then changed it to english, Still nothing. I did a search and thats the only thing i found for this type of issue so far in the threads. I even did another try today when i got the new build, nothing. Any advice?
#8211 | Link | |
#8212 | Link |
SLOVEHEART
BD-RB 3307 and AviSnth 2.5.8 + questions
No sooner than I mentioned that I used AviSynth 2.5.8 (in Afterdawn forum) and now it seems as though the latest release of BD-RB supports it! It wasn't mentioned in the changelog - so I am posting the Inspect.exe app's readout from my rig:
- Windows Version: 6.1 [7600] - AVISYNTH Version: 2.5.8.0, Ok - HAALI Splitter: Ok - FFDSHOW: 3439, not recommended version I have since reverted to 3326 (cslid) - WIN7 preferred AVC CODEC: Ok - WIN7 preferred VC-1 CODEC: Ok - WIN7 preferred MPEG2 CODEC: Ok - FFDSHOW VC-1 set to "wmv9", Ok - FFDSHOW MPEG2 set to "libavcodec": Ok - FFDSHOW AVC set to "ffmpeg-mt": Ok - BD Rebuilder v0.33.0.7, Ok - X264: Ok - AFTEN: Ok - FAAC: Ok - MP4BOX: Ok - WAVI: Ok - TSMUXER: Ok I know my FFDShow is off I have an intersting experience with installing CoreAVC's codec on my rig - ended up causing trouble with Haali Splitter - that wasn't corrected by uninstalling the CoreAVC codec and reinstalling the correct Matroska splitter - had to delete the Haali folder in Program Files and then reinstall Matroska again. When I tried to Preview stream in BD-RB window by right clicking on a stream - media player states that CoreAVC couldn't be found - this led me to try installing the codec. Is there a way to correct this? The stream will play after closing the info window... Also, when right clivking a stream - there is a greyed out 'Blank this stream' option - is this for the future? Another question: under encoder options - encoder - greyed out is FFmpeg encoder - I tried installing this encoder - but BD-RB doesn't recognize it - is this also something for the future? Cheers... Thank you J. Dobbs for your work, and to all those who help - thank you too and for everyone who drinks BD-RB - to your health and burning!! I just donated a token amount to Mr. Dobbs - everyone should give up a small contribution - J.Dobbs really could be charging for this app by now - let's help him with his efforts...
ROSE... Last edited by SLOVEHEART; 17th May 2010 at 05:49. |
#8213 | Link | |
Webmaster
Thanks for the update. Another thing I noticed (could be just me reading it wrong) MOVIE-ONLY/ALTERNATE OUTPUT mode enabled - Auto Quality: High Quality (Default), Two Pass Makes if sound like it should be doing a 2 pass encode but noticed it only did a single pass Last edited by tekmobile; 17th May 2010 at 09:19. |
#8214 | Link | |
#8215 | Link | |
As for CoreAVC -- I can only say that I bought it, and ended up reverting to FFDSHOW because it had issues with playback of some sources. So if you decide to use it, always remove it and try FFDSHOW before posting a bug. Yes, "Blank this stream" is planned for future implementation. Probably not for FFMPEG, although at one point I added that as a placeholder. Frankly X264 works so well that other choices (like I had in BD Rebuilder) seem senseless now.
jdobbs.softworks@gmail.com Last edited by jdobbs; 17th May 2010 at 13:52. |
#8216 | Link | |
thanks Jdobbs for the great program, I have just about worn out a couple of computers using it already, Worknstiff
#8217 | Link | |
I have to completely disagree with " "a lot of problems with studdering and out-of-sync" -- I think that almost all of those reports were cause by people who disregarded my advice and used helper programs that aren't recommended. I've done many hundreds of discs and have never seen stuttering or out-of-sync. The only exception I would make is the recent report by SoniG -- which I'm working right now.
#8218 | Link |
Error Message BD Rebuilder v. 0.33.07
I downloaded and installed BD Rebuilder v 0.33.07 (twice after deleting the 33.05 folder) and get BD-RB Warning message: " Could not find valid path for these required tools: X264.EXE TSMUXER.EXE WAVI.EXE AFTEN.EXE DECOMB.DLL MKVMERGE.EXE Recommend you reinstall using all included files." What did I do wrong?
#8219 | Link | |
#8220 | Link | |
| Display Modes | |
