Old 8th December 2009, 05:04   #6221  |  Link
kanerulz69
Banned
I don't believe anything has changed that would correct that -- what you're seeing there is a TSMUXER error (usually, but not always, caused by a bad rip). About the best I could do is try to provide a workaround of some sort.
I gave it a try with the new version and still EARTH_US still had the same error, and i ripped the movie twice with anydvd as always and still the same error message. never had a problem with any other movie
kanerulz69 is offline   Reply With Quote
Old 8th December 2009, 16:21   #6222  |  Link
jdobbs
I added code as a workaround, and have that one fixed for the next release. You may see it later today.
jdobbs.softworks@gmail.com
Old 8th December 2009, 16:57   #6223  |  Link
kanerulz69
Banned
you tha man, thanks alot, I appreciate it
Old 8th December 2009, 17:07   #6224  |  Link
jdobbs
BD Rebuilder v0.31.05 (beta)
I've updated the first post of this thread with a new release of BD-RB (v0.31.05). Changes for this version:
- Added code to recognize "streams are not syncronized"
  errors from TSMUXER and take action to automatically
  workaround by extracting video/audio streams
  independently.  This should fix it in most cases.
- Build a workaround routine for movie-only encodes in
  which the TSMUXER output filename during A/V extract
  violates length restrictions and causes "Can't create
  output file" error.
- Added new hidden option "USE_NAL_HRD=n".  If set to
  "1" (the default) the "--nal-hrd" parameter is used in
  the command line.  This requires an X264 build which
  includes the NAL-HRD patch (as is the one included
  with BD Rebuilder). Setting to "0" (not normally
  recommended) disables the "--nal-hrd" switch.
- Corrected an error that could cause movie-only backups
  to not extract and remux properly when small enough to
  fit on the target and it consists of multiple parts.
- Updated the included version of X264.EXE to the
  latest release (r1360 w/nal-hrd patch).
- Other minor corrections and cosmetic fixes.
Old 8th December 2009, 18:42   #6225  |  Link
Choppermike
I have the US version of that one. I'll try it and see what I get.
[11:39:04] BD Rebuilder v0.31.04 (beta)
- Source: NIGHT_AT_THE_MUSEUM2
- Input BD size: 19.80 GB
- Approximate total content: [01:44:43.277]
- Target BD size: 4.27 GB
- Windows Version: 6.0 [6002]
- MOVIE-ONLY mode enabled
- Audio Settings: AC3=1 DTS=1 HD=0 Kbs=640
[11:39:06] PHASE ONE, Encoding
- [11:39:06] Extracting A/V streams [VID_00308]
- Error in attempt to extract audio/subs.
- Not enought buffer for parse video stream. Current frame num 34460
[11:40:03] - Failed to retrieve audio, aborted
I made adjustments as someone suggested re: audio setting. same issue. I should have mentioned. This is the US version and BDRB version is 31.04 Thank you in advance for your help!
Choppermike is offline   Reply With Quote
Old 8th December 2009, 18:45   #6226  |  Link
Warbucks81
You have one AC3 and one DTS audio track with a target size of a DVDR. My guess, not enough room, try adjusting your target size.
Warbucks81 is offline   Reply With Quote
Old 8th December 2009, 18:49   #6227  |  Link
Choppermike
Originally Posted by worknstiff View Post
Looks to me like you have keep HD Audio ticked and you are trying to encode a BD_5 disk and not enough room for the video.
Thanks Worknstiff. But I made adjustments without effect.
Old 9th December 2009, 01:10   #6228  |  Link
dragonknight
The org. (NOTORIOUS BIG) rip with anydvdhd plays back fine. ihave also tryed re-ripping the the disc and othe copy of the disc. i have tried all the newer versions of BD Rebuildier (0.31.05) that i have come after and still getting the following error message:
[00:14:33] BD Rebuilder v0.30.02 (beta)
  - Source:  NOTORIOUS_BIG
  - Input BD size: 41.79 GB
  - Approximate total content: [04:48:58.370]
  - Target BD size: 7.72 GB
  - Windows Version: 5.1 [2600]
[00:14:41] PHASE ONE, Encoding
 - [00:14:41] Extracting A/V streams [VID_00157]
 - [00:14:45] Reencoding: VID_00157 (1 of 86)
 - [00:14:53] Extracting A/V streams [VID_00100]
 - [00:14:55] Reencoding: VID_00100 (2 of 86)
 - [00:15:00] Extracting A/V streams [VID_00308]
 - [00:15:03] Reencoding: VID_00308 (3 of 86)
 - [00:15:20] Extracting A/V streams [VID_00306]
 - [00:15:23] Reencoding: VID_00306 (4 of 86)
 - [00:15:43] Extracting A/V streams [VID_00310]
 - [00:15:47] Reencoding: VID_00310 (5 of 86)
 - [00:16:08] Extracting A/V streams [VID_00314]
 - [00:16:12] Reencoding: VID_00314 (6 of 86)
 - [00:16:37] Extracting A/V streams [VID_00352]
 - [00:16:41] Reencoding: VID_00352 (7 of 86)
 - [00:16:41] Reencoding secondary video [TRK_02]
 - [00:17:19] Extracting A/V streams [VID_00001]
 - [00:17:24] Reencoding: VID_00001 (8 of 86)
 - [00:17:37] Extracting A/V streams [VID_00350]
 - [00:17:41] Reencoding: VID_00350 (9 of 86)
 - [00:17:41] Reencoding secondary video [TRK_02]
 - [00:18:41] Extracting A/V streams [VID_00312]
 - [00:18:45] Reencoding: VID_00312 (10 of 86)
 - [00:19:17] Extracting A/V streams [VID_00313]
 - [00:19:22] Reencoding: VID_00313 (11 of 86)
 - [00:19:54] Extracting A/V streams [VID_00398]
 - [00:19:58] Reencoding: VID_00398 (12 of 86)
 - [00:21:12] Extracting A/V streams [VID_00397]
 - [00:21:17] Reencoding: VID_00397 (13 of 86)
 - [00:22:33] Extracting A/V streams [VID_00393]
 - [00:22:37] Reencoding: VID_00393 (14 of 86)
 - [00:23:54] Extracting A/V streams [VID_00370]
 - [00:23:59] Reencoding: VID_00370 (15 of 86)
 - [00:23:59] Reencoding secondary video [TRK_02]
 - [00:24:13] Extracting A/V streams [VID_00394]
 - [00:24:18] Reencoding: VID_00394 (16 of 86)
 - [00:25:44] Extracting A/V streams [VID_00374]
 - [00:25:49] Reencoding: VID_00374 (17 of 86)
 - [00:26:08] Extracting A/V streams [VID_00369]
 - [00:26:14] Reencoding: VID_00369 (18 of 86)
 - [00:26:14] Reencoding secondary video [TRK_02]
 - [00:26:34] Extracting A/V streams [VID_00340]
 - [00:26:41] Reencoding: VID_00340 (19 of 86)
 - [00:26:41] Reencoding secondary video [TRK_02]
 - [00:27:49] Extracting A/V streams [VID_00399]
 - [00:27:56] Reencoding: VID_00399 (20 of 86)
 - [00:29:28] Extracting A/V streams [VID_00328]
 - [00:29:34] Reencoding: VID_00328 (21 of 86)
 - [00:29:34] Reencoding secondary video [TRK_02]
 - [00:30:54] Extracting A/V streams [VID_00307]
 - [00:31:00] Reencoding: VID_00307 (22 of 86)
 - [00:31:44] Extracting A/V streams [VID_00003]
 - [00:31:52] Reencoding: VID_00003 (23 of 86)
 - [00:32:13] Extracting A/V streams [VID_00319]
 - [00:32:19] Reencoding: VID_00319 (24 of 86)
 - [00:32:38] Extracting A/V streams [VID_00309]
 - [00:32:45] Reencoding: VID_00309 (25 of 86)
 - [00:33:29] Extracting A/V streams [VID_00366]
 - [00:33:36] Reencoding: VID_00366 (26 of 86)
 - [00:33:36] Reencoding secondary video [TRK_02]
 - [00:33:59] Extracting A/V streams [VID_00364]
 - [00:34:04] Reencoding: VID_00364 (27 of 86)
 - [00:34:04] Reencoding secondary video [TRK_02]
 - [00:34:26] Extracting A/V streams [VID_00358]
 - [00:34:33] Reencoding: VID_00358 (28 of 86)
 - [00:34:33] Reencoding secondary video [TRK_02]
 - [00:34:57] Extracting A/V streams [VID_00344]
 - [00:35:03] Reencoding: VID_00344 (29 of 86)
 - [00:35:03] Reencoding secondary video [TRK_02]
 - [00:36:32] Extracting A/V streams [VID_00316]
 - [00:36:40] Reencoding: VID_00316 (30 of 86)
 - [00:37:32] Extracting A/V streams [VID_00359]
 - [00:37:38] Reencoding: VID_00359 (31 of 86)
 - [00:37:38] Reencoding secondary video [TRK_02]
 - [00:38:03] Extracting A/V streams [VID_00346]
 - [00:38:10] Reencoding: VID_00346 (32 of 86)
 - [00:38:10] Reencoding secondary video [TRK_02]
 - [00:39:33] Extracting A/V streams [VID_00305]
 - [00:39:41] Reencoding: VID_00305 (33 of 86)
 - [00:40:09] Extracting A/V streams [VID_00311]
 - [00:40:17] Reencoding: VID_00311 (34 of 86)
 - [00:41:14] Extracting A/V streams [VID_00330]
 - [00:41:22] Reencoding: VID_00330 (35 of 86)
 - [00:41:22] Reencoding secondary video [TRK_02]
 - [00:43:00] Extracting A/V streams [VID_00392]
 - [00:43:08] Reencoding: VID_00392 (36 of 86)
 - [00:45:27] Extracting A/V streams [VID_00395]
 - [00:45:37] Reencoding: VID_00395 (37 of 86)
 - [00:48:05] Extracting A/V streams [VID_00322]
 - [00:48:13] Reencoding: VID_00322 (38 of 86)
 - [00:48:13] Reencoding secondary video [TRK_02]
 - [00:50:16] Extracting A/V streams [VID_00355]
 - [00:50:24] Reencoding: VID_00355 (39 of 86)
 - [00:50:24] Reencoding secondary video [TRK_02]
 - [00:50:57] Extracting A/V streams [VID_00342]
 - [00:51:06] Reencoding: VID_00342 (40 of 86)
 - [00:51:06] Reencoding secondary video [TRK_02]
 - [00:53:09] Extracting A/V streams [VID_00332]
 - [00:53:20] Reencoding: VID_00332 (41 of 86)
 - [00:53:20] Reencoding secondary video [TRK_02]
 - [00:55:16] Extracting A/V streams [VID_00360]
 - [00:55:26] Reencoding: VID_00360 (42 of 86)
 - [00:55:26] Reencoding secondary video [TRK_02]
 - [00:56:03] Extracting A/V streams [VID_00338]
 - [00:56:13] Reencoding: VID_00338 (43 of 86)
 - [00:56:13] Reencoding secondary video [TRK_02]
 - [00:58:15] Extracting A/V streams [VID_00365]
 - [00:58:26] Reencoding: VID_00365 (44 of 86)
 - [00:58:26] Reencoding secondary video [TRK_02]
 - [00:59:03] Extracting A/V streams [VID_00337]
 - [00:59:15] Reencoding: VID_00337 (45 of 86)
 - [00:59:15] Reencoding secondary video [TRK_02]
 - [01:01:29] Extracting A/V streams [VID_00327]
 - [01:01:39] Reencoding: VID_00327 (46 of 86)
 - [01:01:39] Reencoding secondary video [TRK_02]
 - [01:04:20] Extracting A/V streams [VID_00367]
 - [01:04:32] Reencoding: VID_00367 (47 of 86)
 - [01:04:32] Reencoding secondary video [TRK_02]
 - [01:05:13] Extracting A/V streams [VID_00336]
 - [01:05:24] Reencoding: VID_00336 (48 of 86)
 - [01:05:24] Reencoding secondary video [TRK_02]
 - [01:08:01] Extracting A/V streams [VID_00341]
 - [01:08:12] Reencoding: VID_00341 (49 of 86)
 - [01:08:12] Reencoding secondary video [TRK_02]
 - [01:11:00] Extracting A/V streams [VID_00372]
 - [01:11:14] Reencoding: VID_00372 (50 of 86)
 - [01:14:27] Extracting A/V streams [VID_00347]
 - [01:14:40] Reencoding: VID_00347 (51 of 86)
 - [01:14:40] Reencoding secondary video [TRK_02]
 - [01:17:36] Extracting A/V streams [VID_00348]
 - [01:17:49] Reencoding: VID_00348 (52 of 86)
 - [01:17:49] Reencoding secondary video [TRK_02]
 - [01:20:50] Extracting A/V streams [VID_00333]
 - [01:21:04] Reencoding: VID_00333 (53 of 86)
 - [01:21:04] Reencoding secondary video [TRK_02]
 - [01:23:50] Extracting A/V streams [VID_00363]
 - [01:24:03] Reencoding: VID_00363 (54 of 86)
 - [01:24:03] Reencoding secondary video [TRK_02]
 - [01:27:07] Extracting A/V streams [VID_00315]
 - [01:27:22] Reencoding: VID_00315 (55 of 86)
 - [01:31:04] Extracting A/V streams [VID_00368]
 - [01:31:20] Reencoding: VID_00368 (56 of 86)
 - [01:31:20] Reencoding secondary video [TRK_02]
 - [01:34:47] Extracting A/V streams [VID_00373]
 - [01:35:02] Reencoding: VID_00373 (57 of 86)
 - [01:38:57] Extracting A/V streams [VID_00371]
 - [01:39:13] Reencoding: VID_00371 (58 of 86)
 - [01:43:07] Extracting A/V streams [VID_00396]
 - [01:43:24] Reencoding: VID_00396 (59 of 86)
 - [01:53:38] Extracting A/V streams [VID_00331]
 - [01:53:59] Reencoding: VID_00331 (60 of 86)
 - [01:53:59] Reencoding secondary video [TRK_02]
 - [01:57:37] Extracting A/V streams [VID_00304]
 - [01:57:57] Reencoding: VID_00304 (61 of 86)
 - [02:05:50] Extracting A/V streams [VID_00343]
 - [02:06:08] Reencoding: VID_00343 (62 of 86)
 - [02:06:08] Reencoding secondary video [TRK_02]
 - [02:10:33] Extracting A/V streams [VID_00324]
 - [02:10:54] Reencoding: VID_00324 (63 of 86)
 - [02:10:54] Reencoding secondary video [TRK_02]
 - [02:15:33] Extracting A/V streams [VID_00362]
 - [02:15:55] Reencoding: VID_00362 (64 of 86)
 - [02:15:55] Reencoding secondary video [TRK_02]
 - [02:20:57] Extracting A/V streams [VID_00356]
 - [02:21:20] Reencoding: VID_00356 (65 of 86)
 - [02:21:20] Reencoding secondary video [TRK_02]
 - [02:26:29] Extracting A/V streams [VID_00303]
 - [02:26:57] Reencoding: VID_00303 (66 of 86)
 - [02:36:57] Extracting A/V streams [VID_00334]
 - [02:37:23] Reencoding: VID_00334 (67 of 86)
 - [02:37:23] Reencoding secondary video [TRK_02]
 - [02:42:51] Extracting A/V streams [VID_00361]
 - [02:43:20] Reencoding: VID_00361 (68 of 86)
 - [02:43:20] Reencoding secondary video [TRK_02]
 - [02:50:21] Extracting A/V streams [VID_00321]
 - [02:50:50] Reencoding: VID_00321 (69 of 86)
 - [02:50:50] Reencoding secondary video [TRK_02]
 - [02:58:11] Extracting A/V streams [VID_00302]
 - [02:58:46] Reencoding: VID_00302 (70 of 86)
 - [03:20:26] Extracting A/V streams [VID_00301]
 - [03:21:04] Reencoding: VID_00301 (71 of 86)
 - [03:43:11] Extracting A/V streams [VID_00349]
 - [03:43:41] Reencoding: VID_00349 (72 of 86)
 - [03:43:41] Reencoding secondary video [TRK_02]
 - [03:51:34] Extracting A/V streams [VID_00339]
 - [03:52:08] Reencoding: VID_00339 (73 of 86)
 - [03:52:08] Reencoding secondary video [TRK_02]
 - [03:59:27] Extracting A/V streams [VID_00325]
 - [04:00:07] Reencoding: VID_00325 (74 of 86)
 - [04:00:07] Reencoding secondary video [TRK_02]
 - [04:08:56] Extracting A/V streams [VID_00351]
 - [04:09:35] Reencoding: VID_00351 (75 of 86)
 - [04:09:35] Reencoding secondary video [TRK_02]
 - [04:19:20] Extracting A/V streams [VID_00381]
 - [04:20:03] Reencoding: VID_00381 (76 of 86)
 - [04:20:03] Reencoding secondary video [TRK_02]
 - [04:31:48] Extracting A/V streams [VID_00383]
 - [04:32:38] Reencoding: VID_00383 (77 of 86)
 - [04:32:38] Reencoding secondary video [TRK_02]
 - [04:45:31] Extracting A/V streams [VID_00323]
 - [04:46:23] Reencoding: VID_00323 (78 of 86)
 - [04:46:23] Reencoding secondary video [TRK_02]
 - [04:59:49] Extracting A/V streams [VID_00354]
 - Error in attempt to MKVMERGE.
[05:00:43] - Failed to retrieve audio, aborted
dragonknight is offline   Reply With Quote
Old 9th December 2009, 02:28   #6229  |  Link
Capsbackup
@dragonknight;
This may not be related, but it seems like an awful lot of content to be backed up to a BD9. (Approximate total content: [04:48:58.370])
Have you tried to BD-25, or even just a movie only backup to BD9, just to rule out a few other potential options?
Capsbackup is offline   Reply With Quote
Old 9th December 2009, 03:58   #6230  |  Link
cwh060
Odd Problem
Trying to back up Angels and Demons.
Full Movie Back up to BD25
[12:32:55] BD Rebuilder v0.31.05 (beta)
  - Source:  ANGELS_AND_DEMONS
  - Input BD size: 41.02 GB
  - Approximate total content: [03:01:14.905]
  - Target BD size: 22.46 GB
  - Audio Settings: AC3=1 DTS=1 HD=1 Kbs=640
[12:32:56] PHASE ONE, Encoding
 - [12:32:56] Extracting A/V streams [VID_00530]
 - [12:33:06] Reencoding: VID_00530 (1 of 53)
 - Error in attempt to multiplex: MUX_00530.meta
 - H.264 stream does not contain fps field. Muxing fps=23.976
[16:37:41] - Failed to build structure, aborted
Movie Only Backup appears to be working with no errors at VID_00530?
 - [21:21:38] Extracting A/V streams [VID_00530]
 - [21:21:47] Reencoding: VID_00530 (16 of 32)
 - [21:22:49] Extracting A/V streams [VID_00532]
Bad rip?
cwh
cwh060 is offline   Reply With Quote
Old 9th December 2009, 04:12   #6231  |  Link
Capsbackup
I had no problem with the region A version of Angels and Demons. Did a full movie backup to BD-25, and it looks excellent!
Old 9th December 2009, 15:17   #6232  |  Link
jdobbs
Bad rip?
cwh
Are you using the X264 version that is included in the BD Rebuilder zip?
Old 9th December 2009, 16:37   #6233  |  Link
SALVA47
I have a problem with the movie " the mummy 4, tomb of emperor dragon", error: Audio and/or PGS size too large. Probable oversize. Please helpme. thanks.
SALVA47 is offline   Reply With Quote
Old 9th December 2009, 16:57   #6234  |  Link
jdobbs
It usually means that the audio you are attempting to keep is too large for the target size selected and there is no room for the video.
Old 9th December 2009, 17:00   #6235  |  Link
drmih
This is usually caused by there being lots of duplicate and unnecessary audio tracks in the extras. Try changing your settings to only one audio and then adding in any extra ones you need in the main movie by double clicking on them (for instance for a commentary track). Sometimes you can just continue and the output size is okay. I certainly did Mummy 4 several months ago and it was okay.
drmih is offline   Reply With Quote
Old 9th December 2009, 17:10   #6236  |  Link
Choppermike
@jdobbs
Any luck w/ Night at Meuseum2? I'm still trying and still having issues. I did have an issue w/ Angels and Demons but 31.05 seems to have corrected it.
LG GGW-H20 Burner
PS3 Playback
Intel i7 920
Asus P6T
2X 9800 GT SLI
Vista
Region A
Location Texas
Old 9th December 2009, 18:26   #6237  |  Link
cwh060
@jdobbs
Yes, using the one included with 31.05
Am using Windows Vista 64b (i920CPU). When I was trying to reproduce the Full Version, there was also a pop up window, saying TSEMuxer failed and the option to "Close the Program". I was not near the computer when this happened so I can't give a timeline.
In the original log file the crash appears to have happened 4 hours after reporting the inital error. So my assuption is that TSEMUX, just died when nothing was happening.
I backed up Movie Only with no problem. I am going to try the full version again later today.
Thanks
cwh
Old 9th December 2009, 20:23   #6238  |  Link
Capsbackup
@jdobbs
I had no problems with a movie only backup to BD5 for Night at Meuseum2, US version.
You are having a setup issue with Haali or ffdshow.
Old 9th December 2009, 22:00   #6239  |  Link
ranger124
BD-Rebuilder
What happen to Iron man -----------------------
[21:44:55] BD Rebuilder v0.31.02 (beta)
- Source: IRON_MAN_D1
- Input BD size: 31.15 GB
- Approximate total content: [02:06:01.679]
- Windows Version: 6.0 [6000]
[21:44:55] PHASE ONE, Encoding
- [21:44:55] Extracting A/V streams [VID_00010]
- [21:58:29] Reencoding: VID_00010 (1 of 1)
- [21:58:29] Collecting video information
- Video: 1920x1080, 23.976fps, 181,299 frames
- Bitrate: 7,375 Kbs
- [21:58:29] Reencoding: VID_00010, Pass 1 of 2
- [00:27:50] Reencoding: VID_00010, Pass 2 of 2
- Encode failed. Retrying.
ranger124 is offline   Reply With Quote
Old 10th December 2009, 00:08   #6240  |  Link
jdobbs
You're using an outdated version, please update and try again. Also, make sure you have HAALI, AVISYNTH, and FFDSHOW installed. usually an error like you're seeing means one of those isn't installed/configured properly.
