Old 21st December 2009, 10:54   #101  |  Link
cweb
cweb's Avatar
You're welcome...
PC specs for bug reports: Intel Core i7-4790K @4Ghz Win10(Linux VM) PCI express NVIDIA RTX 2060 SUPER graphics card
http://twitter.com/cwebdesign
cweb is offline   Reply With Quote
Old 2nd April 2010, 14:09   #102  |  Link
bigboss97
Great script! Thank you.
A question, I want to pan first and then zoom out. Do I have to do it in 2 calls of the function? which is very difficult for the second call because I've to make sure the start match the end of the first call.
or there's something in the parameter which I haven't found yet?
thanks in advance
Phuoc
bigboss97 is offline   Reply With Quote
Old 24th November 2010, 14:38   #103  |  Link
cludos
Thanks for this wonderful script.
cludos is offline   Reply With Quote
Old 8th December 2011, 04:56   #104  |  Link
t_2
AviSynth Plugin to zoom & pan HD video?
(Nice to be back again after several years!
Greetings to moderators & power posters - some of whom are new to me. Thanks for all the hard work you've been doing over the years! I haven't stopped using AviSynth!)
Now, to matter at hand: Tried to use zoom plug-in in VirtualDub to pan & zoom in a HD res photo that I turned into video using Image Sequence. Alas, zoom there only supports 3 decimal digits or a max res of 999 pixels. I noticed that Ken Burns Effect didn't work either. (Someone asked in a post why his video output moved about wildly with this script. Didn't see an answer, but I suppose it's because this script relies on zoom.dll which seems to have the same limitation.) At least I couldn't get it to work for me.
Also, ZoomBox script author said at end of his thread that he had given up trying to use his clever script with animate because it's simply too troublesome to code.
My question: Does anyone know of zoom plugin or script that doesn't have the 3 digit limit on resolution? Or does ZoomBox work with animate? I couldn't get it to. Thanks in advance!
t_2 is offline   Reply With Quote
Old 8th December 2011, 10:58   #105  |  Link
Gavino
Avisynth language lover
Are you talking about the Zoom plugin from this thread?
I am not aware of any such limitation there.
Old 9th December 2011, 20:06   #106  |  Link
t_2
Yes, I was. Thanks for tip. Will try again and repost.
Old 10th June 2012, 09:46   #107  |  Link
mikeytown2
Resize Abuser
mikeytown2's Avatar
It's been a little while but I would play around with the useZoomBox parameter; I think you can disable the usage of zoom.dll if you set this to 2 (the default).
mikeytown2 is offline   Reply With Quote
Old 8th July 2012, 19:56   #108  |  Link
Yellow_
Trying to use KenBurnsEffect & Zoombox on 2.58, getting an error message:
"There is no function named Max" Line 60
http://avisynth.org/mediawiki/Intern...eric_functions
Line 60 of ZoomBox script reads:
modzoom = Max(Float(c.width())/Float(width),Float(c.height())/Float(height))
This is the example script I'm trying from this thread:
Width=640
Height=480
Resize="BlackmanResize"
Align=-5
b=ColorBars(480,480, "YV12").Trim(0,-1).ZoomBox(Width,Height,Resize, Align=Align)
c=ColorBars(640,480, "YV12").Trim(0,-1).ZoomBox(Width,Height,Resize, Align=Align)
d=ColorBars(720,480, "YV12").Trim(0,-1).ZoomBox(Width,Height,Resize, Align=Align)
e=ColorBars(854,480, "YV12").Trim(0,-1).ZoomBox(Width,Height,Resize, Align=Align)
f=ColorBars(960,480, "YV12").Trim(0,-1).ZoomBox(Width,Height,Resize, Align=Align)
a+b+c+d+e+f
Any ideas?
I copy pasted the ZoomBox etc functions and saved into plugins folder, as an avsi file, like usual. Reopened the script, reopened avspmod too but same error.
Yellow_ is offline   Reply With Quote
Old 8th July 2012, 20:23   #109  |  Link
I think Max may have been one of Stickboy's script/plugins.
EDIT, here: http://avisynth.org/stickboy/
Old 8th July 2012, 20:51   #110  |  Link
Yellow_
Cheers, that's fixed the Max error, then had to change the BlackmanResize line and 'a' was missing for a+b+c+d+e, not bad for a 12 line script. :-)
anamorphic, crop, dar, pan and scan, resize
