Go Back   Doom9's Forum > General > Linux, Mac OS X, & Co
Old 30th July 2016, 13:21   #41  |  Link
microchip8
ffx264/ffhevc author
microchip8's Avatar
ChangeLog for ffhevc 2.6.6
* Update to the default encoding options
TV: Samsung 50" QE50Q60T AVR: Yamaha RX-V481 5.1 CD Player: Yamaha CD-S300 DAB+ Tuner: Yamaha T-D500 BD Player: Samsung UBD-M8500 UHD Speakers: Klipsch 5.1 Reference Phono: Audio-Technica AT-LP120XUSB
Old 12th August 2016, 00:15   #42  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 2.6.7 and ffx264 2.8.3
* Set the first video/subtitle/audio track as default
Old 16th August 2016, 13:37   #43  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 2.6.8 and ffx264 2.8.4
* Check the value of the astrm variable. This allows to properly remove any audio options in case no audio is detected
* Only display the audio codecs menu when audio has been detected or the user explicitly sets the track ID
Old 16th August 2016, 19:15   #44  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 2.6.9 and ffx264 2.8.5
* Switched to using getopts for parsing the options
* Added support for using x264/x265 tune profiles
Old 17th August 2016, 03:02   #45  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 2.7.0 and ffx264 2.8.6
* Added support for custom preset files (loaded with the new -c option)
* Added an example custom preset file to the package
* Added support for editing the config file with the vi text editor, using the new -e option of ffhevc/ffx264
* Updated the README file
Old 18th August 2016, 11:10   #46  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 2.7.1 and ffx264 2.8.7
* Added an EDITOR variable to the config file so the user can set his preferred editor for the -e option
* Added -r option to reset the config file to its defaults
* Cosmetics in the help info code
* Added man page
Old 18th August 2016, 17:38   #47  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 2.7.2 and ffx264 2.8.8
* Support asking for CRF value if it isn't set in the config file
* Support custom config files with using the x264/x265 preset/tune profiles
* Minor code updates
* Updated the man page
Old 19th August 2016, 15:04   #48  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 2.7.3 and ffx264 2.8.9
* Increased the frames value for the crop detection code
* Added ogv to list of containers not supporting DTS
* Cosmetics
Old 19th August 2016, 23:33   #49  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 2.7.4 and ffx264 2.9.0
* Added support for E-AC-3 audio encoding
* Add title metadata to the video stream
Old 20th August 2016, 21:26   #50  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 2.7.5 and ffx264 2.9.1
* NOSOUND audio option takes precedence so clear any other audio options given
* Workaround an ffmpeg disposition issue where in some cases it sets the default flag on all subsequent subs/audio tracks
* Bumped up default AAC bitrate
* Move the MOOV atom for MP4 files to the beginning of the file, for streaming-friendly files
* Enforce lower-case for container extension
* Added install script to the package
Old 23rd August 2016, 13:14   #51  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 2.7.6 and ffx264 2.9.2
* Merged the AC3/EAC3 channel check
* Bumped up EAC3 default bitrate to 768 kbps
* Use none instead of metadata flag for disposition for subsequent subs/audio tracks
Old 1st September 2016, 23:42   #52  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 2.7.7 and ffx264 2.9.3
* Renamed config variable MAX_AUD_TRKS to MAX_AUD_TRACKS
* Removed -strict -2 option for AAC audio. It is no longer needed since about mid 2015
Old 2nd September 2016, 13:59   #53  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 2.7.8 and ffx264 2.9.4
* Added support for multipass encoding, to be activated with the new -m option
* Added support for calculation of video bitrate for target file size when using bitrate-based encoding
* Replaced some simple if conditionals with test cases
* Updated the man page and README file
Old 5th September 2016, 09:18   #54  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 2.7.9 and ffx264 2.9.5
* Improved crop detection
* Removed dependence on MPlayer
* Added support for encoding to PCM audio
* Use ffprobe directly instead of outputting to files
Old 5th September 2016, 23:06   #55  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 2.8.0 and ffx264 2.9.6
* Don't encode audio during first pass of 2-pass mode
* Bugfix: fix audio copy
* Target file size calc does not work with FLAC, PCM or Copy so just skip it
* Reduced ffmpeg command line options duplication in the encoder_func() function
Old 6th September 2016, 13:51   #56  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 2.8.1 and ffx264 2.9.7
* Added support for the new vaguedenoiser filter. Requires latest ffmpeg from git
* Merged the mp3 audio code with the rest
* Auto-add a metadata comment
Old 9th September 2016, 12:00   #57  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 2.8.2 and ffx264 2.9.8
* Adaptive channel range and defaults based on audio codec
* Made metadata comment optional, allow to modify it and place it in the config file
* Some minor tweaks
Old 14th September 2016, 14:45   #58  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 2.8.3 and ffx264 2.9.9
* Removed stray, unneeded MPLAYERPARAMS from config file
* Don't set by default a color prim/matrix in the x264 options in the config file
* Added support for rotating with the transpose filter
* Support setting the color primaries/matrix/transfer
Old 18th September 2016, 17:18   #59  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 2.8.4
* Add undefined option to the color primaries and make it default
* Support asking for crop values if autocrop is disabled
* Made most audio/video filters optional by allowing to enable or disable a filter in the config file
* Use menu tables for the audio sample rates
* Cosmetics
ChangeLog for ffx264 3.0.0
* Force threads to auto
* Cosmetics
Old 28th September 2016, 22:40   #60  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 2.8.5 and ffx264 3.0.1
* Added support for the atadenoise video filter
