Thread Tools Display Modes
Old 6th June 2013, 15:03   #17381  |  Link
jdobbs
@Kurtnoise
Ok, I now have the chapter markers working in MP4 output that is aimed at iPod/iPhone/iPad targets. As I'm sure you know that required an update of MP4BOX because it wasn't supported in the version I was using (v0.4.5). The capability will be available in the next release of BD-RB.
jdobbs.softworks@gmail.com
Old 6th June 2013, 15:09   #17382  |  Link
Barcoed
Barcoed's Avatar
It is available, but only in Movie-Only mode (that's the way it has always been).
I read the earlier post where you said it’s only available in movie only mode, which is why I specifically said “(movie only)” in my post. To reiterate with (I hope) total clarity:
When attempting a movie only backup I am no longer able to right-click and choose “Turn on” to force subtitles. Single right click fails to cause the “Turn on” message to appear on screen (as it once did).
Sadly I can’t remember the version when it last worked. I’m currently using the latest version. The prerequisite s/w (Haali, FFDShow etc.) is unchanged from when the option was there.
Barcoed is offline   Reply With Quote
Old 6th June 2013, 15:10   #17383  |  Link
staina
Bug at conversion Blu-ray
Blu-ray movie converted in BD Rebuilder at fast rewinding forward in bottoms part movie sometimes displays stripes in green colour eventually in varicoloured stripes extraneous to now displayed parts movie.
Is that a normal effect if it doesn't what with by?
How Shall I set BD Rebuilder, to these stripes not displayed?
Thank all for help. Staina
staina is offline   Reply With Quote
Old 6th June 2013, 15:37   #17384  |  Link
Ch3vr0n
sounds like a corrupt source. That's not a normal effect. You'll need to provide the BDRB log and inspect.exe results to possibly determine your problem
Ch3vr0n is offline   Reply With Quote
Old 6th June 2013, 16:14   #17385  |  Link
staina
This problem is not only a near one's movie, but near of all what I'm convert and near of all was source original Blu- ray.
Here’s content LOG:
[06.03.13] BD Rebuilder v0.44.09 (beta)
[04:57:15] Source: LAWLESS_00000
- Input BD size: 27,41 GB
- Approximate total content: [01:55:44.937]
- Target BD size: 23,83 GB
- Windows Version: 6.1 [7601]
- MOVIE-ONLY mode enabled
- SHUTDOWN at completion enabled
- Quality: High Quality (Default), Two Pass
- Decoding/Frame serving: DirectShow
[04:57:17] PHASE ONE, Encoding
- [04:57:17] Processing: VID_00006 (1 of 1)
- [04:57:17] Extracting A/V streams [VID_00006]
- [05:10:12] Reencoding video [VID_00006]
- Rate/Length: 23,976fps, 166*512 frames
- Bitrate: 22*815 Kbs
- [05:10:12] Reencoding: VID_00006, Pass 1 of 2
- [05:51:40] Reencoding: VID_00006, Pass 2 of 2
- [08:03:47] Video Encode complete
- [08:03:47] Processing audio tracks
- Track 4353 (ces): Keeping original audio
[08:03:47]PHASE ONE complete
[08:03:47]PHASE TWO - Rebuild Started
- [08:03:47] Rebuilding BD file Structure
[08:12:05] - Encode and Rebuild complete
- Computer SHUTDOWN initiated.
Old 6th June 2013, 17:39   #17386  |  Link
jdobbs
When attempting a movie only backup I am no longer able to right-click and choose “Turn on” to force subtitles. Single right click fails to display the “Turn on” appearing on screen (as it once did).
I just tested it, and I can right-click on the subtitle and select to turn it on, no problem.
Old 6th June 2013, 18:12   #17387  |  Link
Ch3vr0n
and the inspect.exe results are where? You'll find inspect.exe in the bdrb installation folder
Old 6th June 2013, 19:37   #17388  |  Link
staina
Inspect.exe here:
- AVISYNTH Version: [2.5.8.0], Ok
- HAALI Splitter: [1.9.42.1], Ok
- FFDSHOW: [4513], not recommended version
- WIN7 preferred AVC CODEC: Ok
- WIN7 preferred VC-1 CODEC: Ok
- WIN7 preferred MPEG2 CODEC: Ok
- FFDSHOW VC-1 set incorrectly: [0]
- FFDSHOW MPEG2 set incorrectly: [0]
- FFDSHOW AVC set to "libavcodec": Ok
- BD Rebuilder v0.44.0.9, Ok
- X264: Ok
- AFTEN: Ok
- FAAC: Ok
- MP4BOX: Ok
- WAVI: Ok
- TSMUXER: Ok
Old 6th June 2013, 20:17   #17389  |  Link
Ch3vr0n
there's likely your problem. The wrong FFDshow version and the codecs arent properly set in FFDshow. Use the recommended FFDshow version then set the settings properly
Old 7th June 2013, 04:01   #17390  |  Link
wakko709
[06/06/13] BD Rebuilder v0.44.09 (beta)
[19:56:25] Source: BEAUTIFUL_CREATURES
- Input BD size: 32.35 GB
- Approximate total content: [02:57:50.743]
- Target BD size: 22.95 GB
- Auto Quality: Good (Very Fast), ABR
- Audio Settings: AC3=0 DTS=0 HD=0 Kbs=640
- Resuming from previously started job.
[19:56:28] PHASE ONE, Encoding
- [19:56:28] Processing: VID_00001 (1 of 5)
- [19:56:28] Reencoding video [VID_00001]
- Rate/Length: 23.976fps, 1,969 frames
- Bitrate: 6,926 Kbs
- [19:56:28] Reencoding: VID_00001, Pass 1 of 1
- [19:57:40] Video Encode complete
- [19:57:40] Processing audio tracks
- [19:57:40] Multiplexing M2TS
- [19:57:54] Processing: VID_00005 (2 of 5)
- [19:57:54] Extracting A/V streams [VID_00005]
- [19:58:08] Reencoding video [VID_00005]
- Rate/Length: 23.976fps, 3,601 frames
- Bitrate: 7,435 Kbs
- [19:58:08] Reencoding: VID_00005, Pass 1 of 1
- Encode failed. Aborting.
- BD-Rebuilder v0.44.09 (beta)
- AVISYNTH Version: 2.5.7.0, Ok
- HAALI Splitter: 1.9.42.1, Ok
- FFDSHOW: 3326, Ok
- FFDSHOW VC-1 set to "wmv9", Ok
- FFDSHOW MPEG2 set to "libavcodec": Ok
- AnyDVD settings check: Ok.
- X264: Ok
- AFTEN: Ok
- FAAC: Ok
- MP4BOX: Ok
- WAVI: Ok
- TSMUXER: Ok
[20:00:24] - Failed video encode, aborted
- AVISYNTH Version: [2.5.7.0], Ok
- FFDSHOW: [3326], Ok
- X264: Ok
- AFTEN: Ok
- FAAC: Ok
- MP4BOX: Ok
- WAVI: Ok
- TSMUXER: Ok
H.264 (MPEG-4 AVC) CRASHES
anyone help?
wakko709 is offline   Reply With Quote
Old 7th June 2013, 08:34   #17391  |  Link
Barcoed
Barcoed's Avatar
You are absolutely correct. I retested last night. I think what I must have done is used an ISO of a previously processed movie only backup and forgetting I had “full copy” selected because it looked like movie only as that was all that was available; thus it appeared not to be working. Oops.
- Which leads me to ask for a feature request. Could the option be offered for full backup? The reason I ask is that recently I imported a number of MKV episodes of a series, each containing subtitles. There is no menu (actually there is, a vestigial one with a starry background – goodness knows where that came from) and each episode follows on from the next when played (or each title can be manually picked). I have to use “full backup” in order to retain the multiple title imports, I would like to force subtitles on some as there is a modicum of foreign language (which is subtitled) during those episodes.
Old 7th June 2013, 12:14   #17392  |  Link
staina
NEW Inspect here
- FFDSHOW: [4422], Ok
- X264: Ok
- AFTEN: Ok
- FAAC: Ok
- MP4BOX: Ok
- WAVI: Ok
- TSMUXER: Ok
Result is same.
Old 7th June 2013, 17:05   #17393  |  Link
omegaman7
omegaman7's Avatar
Are you ONLY playing back on your computer? Because there's a multitude of factors involved there. Decoding, cables, the list goes on. Have you tried burning the result, and seeing how your Standalone player plays it?
Only one rooster, need be in the hen house...
omegaman7 is offline   Reply With Quote
Old 7th June 2013, 18:48   #17394  |  Link
jdobbs
It can't, because the full backups have their own set of software (JAVA & HDMV) that controls these things. A movie-only backup can do it only because the authoring is done by the backup program and is completely within its control.
Old 8th June 2013, 08:03   #17395  |  Link
AmigaFuture
AmigaFuture's Avatar
Hello JD,
Have you come across anything like this?
[21:18:47] Importing MKV: DIE_HARD_4
- Collecting audio/video streams from source...
- Building pseudo-BD source structure...
- Source issue found, attempting correction...
[21:38:42]ERROR: Failed to build BD structure. Aborted.
I figured I'd have BD-RB rerender for iPad (2) from an MKV Video Intact & DTS to AC3 or Keep AC3 profile I made. It seems some other multi M2TS...MKV's created files have this error also. I'm getting info together to share. I did not abort the operation, BD-RB 44.09 did. Thanks.
Life is not a journey to the grave; but rather to skid out broadside, thoroughly used, torn and warn and loudly proclaim; WOW; What a ride!!! Soon, I'm going to do it AGAiN in different skin!!
AmigaFuture is offline   Reply With Quote
Old 8th June 2013, 08:26   #17396  |  Link
staina
Burned out on Blu-ray Verbatim and playback on Home Cinema where not display strip green colours, only display like varicoloured stripes extraneous to now displayed parts movie.
Old 9th June 2013, 02:26   #17397  |  Link
jdobbs
Originally Posted by AmigaFuture View Post
Hello JD,
BD-RB first tries to remux from the extracted source (usually a .264 file) using TSMUXER. If that fails, it then creates a new MKV with specific settings, and tries to remux directly from that. If it fails the second time -- it almost always means the source is corrupt. I'll do some testing, though.
Old 9th June 2013, 04:18   #17398  |  Link
AmigaFuture
The Source was created with BD-RB. However, I'm testing with "Finding Nemo" and for some reason that MKV that was created has a corruption that MKMerge has detected. I'm testing more to figure what happened and I'm...wondering...if the old firmware for my USB 3 board adapter may have influenced it. I've since, updated the USB 3 driver and firmware.
Update...it isn't related to USB 3 firmware or driver. I think I found it...checking...
Update 2: I'll resume searching for the "Finding Nemo" corruption...but that's on "hold" while I'm checking some other MKVs. What I've noticed is: I added SRT Subtitles to many of my movies after being processed with BD-RB (Since no Conversion of SUP to SRT happens in auto...and I don't expect it..haha!) My Sharp HD TV does recognize SUP files as being there but won't display them. My LG BD Player doesn't recognize SUP at all, so I'm adding SRT using MKVMerge GUI to add them. Which both the TV and LG BD Player do recognize (since..standard). Now the the point.. In the Import process, of an MKV (SRT added) is where I'm noticing the 2nd..MKVMerge has to happen. It's failing the preparation process if an SRT is in the MKV. Are you able to fix/change that?
If I use MKVMerge (GUI) to reprocess the MKV, after Unchecking SRT, BD-RB seems to be processing well. Still testing...
Old 9th June 2013, 19:54   #17399  |  Link
setarip_old
setarip_old's Avatar
@AmigaFuture
Hi!
At the MakeMKV forums ("Blue-ray errors" and/or "General"), it's been noted in several different posts that the commercial "Finding Nemo" Blu-ray discs appear to suffer from flawed pressings...
setarip_old is offline   Reply With Quote
Old 9th June 2013, 19:56   #17400  |  Link
omegaman7
omegaman7's Avatar
Originally Posted by setarip_old View Post
@AmigaFuture
Hi!
Interesting... I've been meaning to run mine. Now I have a reason.
Thread Tools
