Thread Tools Display Modes
Old 13th January 2025, 11:48   #32121  |  Link
MrVideo
MrVideo's Avatar
Originally Posted by gonca View Post
Are the two files on the list part of a playlist with more files?
Yes. IMHO that should not make a difference. The two examples are 1 sec black clips added to the end of various videos. Pretty stupid, since they could have just encoded the 1 sec of black as part of all the files and just added a chapter mark at that location.
The 1 sec black doesn't need to be recoded, only the longer videos that use it. The non-recoded file will work in the playlist. The min-size setting should be honored, no matter what.
If there is a way to make it do that, please let me know.
Old 13th January 2025, 13:14   #32122  |  Link
gonca
In BD_RB if 1 file in a mpls has to be encoded then all the files will be encoded, if I remember correctly.
This keeps common specs (level etc) for all the files in the mpls.
Prevents possible playback issues, I guess.
gonca is offline   Reply With Quote
Old 13th January 2025, 17:22   #32123  |  Link
DanDare1983
In regards to the 1 sec black clips, I genuinely can't believe how many movies have them. I'd like to find a way of removing them as I have many movies like this and it's always annoying when I go to backup a disc and the playlist has an extra m2ts for no reason whatsoever.
DanDare1983 is offline   Reply With Quote
Old 13th January 2025, 21:36   #32124  |  Link
MrVideo
MrVideo's Avatar
Well, that can cause issues.
Doing recoding during backups doesn't do any level changes, etc. That would certainly screw up any HDR/DV videos. Besides, these are short black videos.
I'd be happy to have a hidden option that overrides this behavior.
Old 13th January 2025, 21:41   #32125  |  Link
MrVideo
MrVideo's Avatar
Unfortunately, they do have a reason. If you look at the end of the video that precedes the 1 sec black, you will find that it ends without any black. That end piece is what allows you to skip to the end, as there is a chapter mark at that point. If that were removed, you would not be able to skip to the end and then do the next operation, be it going to the next episode/video or the menu. You'd have to press the menu key. They play a purpose, but they are a backup annoyance.
Old 13th January 2025, 22:48   #32126  |  Link
DanDare1983
Thank you for responding. I had no idea the 1 sec m2ts was needed. So the last chapter will be at the end of the 1 sec m2ts and not the main m2ts? I like to make remux, would it be best to keep the 1sec m2ts at the end or would it be beneficial to move it?
Old 13th January 2025, 23:31   #32127  |  Link
MrVideo
MrVideo's Avatar
The last chapter is actually at the end of the video preceding it/start of the 1 sec black. Best to leave it in place. If you are remuxing to a MKV file (for example), the 1 sec black will be added to the end, making it one continuous file.
Old 14th January 2025, 09:29   #32128  |  Link
MrVideo
MrVideo's Avatar
Backup video recode failure
Doing a backup of a UHD in which the main video is UHD and DV. Weird is that the log said the bitrate was 500kb.
The encoder didn't fail right at the start. It got a way in before failing.
Is there a last command somewhere that I can run to get the encoder's error?
ADDED INFO: I decided to recode the M2TS file and ended up with this error:
avcuvid: error occured while reading file: 591 frames, Resource temporarily unavailable
There is nothing wrong with the m2ts file as I was able to copy it to another HDD,
Old 16th January 2025, 07:16   #32129  |  Link
MrVideo
MrVideo's Avatar
No additional info regarding my UHD backup issue?
Old 16th January 2025, 08:12   #32130  |  Link
jz1276
After years of using this great program with numerous BluRays, I've run into my first issue. I've tried both BD-25 & 50 target sizes. Please let me know if more info is needed and any help is appreciated.
[01/16/25] BD Rebuilder v0.62.12
[02:09:32] Source: BLURAY
- Input BD size: 19.98 GB
- Approximate total content: [01:52:18.083]
- Target BD size: 46.26 GB
- Windows Version: 6.2 [9200]
- Auto Quality: Very Good (Very Fast), 1-Pass VBR
- Decoding/Frame serving: DirectShow
- Audio Settings: AC3=0 DTS=0 HD=0 Kbs=640
[02:09:34] PHASE ONE, Encoding
- [02:09:34] Processing: VID_00002 (1 of 2)
- [02:09:34] Extracting A/V streams [VID_00002]
- TSMUXER ERR: 0xFFFFFFFD
- Extracting video streams [VID_00002]
- Bitstream exception std::exception. It does not have to be! Please contact application support team for more information.
- Error in attempt to extract video.
[02:09:41] - Failed to retrieve audio, aborted
jz1276 is offline   Reply With Quote
Old 16th January 2025, 10:30   #32131  |  Link
MrVideo
MrVideo's Avatar
Attach mediainfo output of the video file. Code wrap the text file.
Old 16th January 2025, 16:33   #32132  |  Link
jdobbs
Not sure... but it sounds like a system error of some type.
jdobbs.softworks@gmail.com
Old 17th January 2025, 04:34   #32133  |  Link
MrVideo
MrVideo's Avatar
No idea either. I've never seen that error. Not sure how it is a system error, since this has never happened before. I'm suspecting with the file.
Old 22nd January 2025, 17:35   #32134  |  Link
jdobbs
Yes. The last command is always recorded in LASTCMD.TXT located in the BD-RB folder. You can cut-and-paste it into a CMD window to test it. You normally should to do it immediately after getting the error -- assuring that all involved files etc. are still accessible.
Old 23rd January 2025, 04:57   #32135  |  Link
MrVideo
MrVideo's Avatar
I know I've seen that file in the past, but for this UHD backup job, no such file.
Old 14th February 2025, 11:25   #32136  |  Link
doobre
30fps BD becomes 60fps after rebuild
Hi there
this is bound to be a simple setting that I have overlooked, I haven't been doing any copying for a long while, so probably "finger trouble".
Anyway, below are the mediainfo details for the source and the BD-RB output, along with the current INI file and the LASTCMD text log.
I am trying to make a backup of a BD with variable rate FPS (59.940 to 29.970), and the output from BD-RB is 59.940fps [while the audio seems to be 29.970], therefore the video ends up playing double speed while the audio sounds fine, played in VLC and powerDVD.!!!? the file size is half of what I expect, also!
Just in case I ran it through with a restored original INI file, and then using the alternative 264 encoder, no diff.
Help anyone!?
cheers CD
info of MakeMKV output
General
Complete name : D:\EXPORTS\MakeMKV_Export\SHERYL_CROW_LIVE\Sheryl Crow - Live on Soundstage.mkv
Format : Matroska
Format version : Version 2
File size : 25.1 GiB
Duration : 1 h 31 min
Overall bit rate mode : Variable
Overall bit rate : 39.1 Mb/s
Frame rate : 59.940 FPS
Encoded date : 2025-02-14 02:11:53 UTC
Writing application : MakeMKV v1.17.7 win(x64-release)
Writing library : libmakemkv v1.17.7 (1.3.10/1.5.2) win(x64-release)
Video
ID in the original source medium : 4113 (0x1011)
Format : AVC
Format profile : High@L4.1
Format settings : CABAC / 2 Ref Frames
Format settings, CABAC : Yes
Format settings, Reference frames : 2 frames
Format settings, GOP : M=2, N=26
Codec ID : V_MPEG4/ISO/AVC
Bit rate mode : Variable
Bit rate : 30.0 Mb/s
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Variable
Frame rate : 59.940 (60000/1001) FPS
Original frame rate : 29.970 (30000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
Scan type, store method : Separated fields
Scan order : Top Field First
Bits/(Pixel*Frame) : 0.241
Stream size : 19.2 GiB (77%)
Language : English
mediainfo of BD-RB output mkv
Video
Menu ID : 1 (0x1)
Format : AVC
Format profile : High@L4.2
Format settings : CABAC / 3 Ref Frames
Format settings, Reference frames : 3 frames
Codec ID : 27
Bit rate : 17.8 Mb/s
Maximum bit rate : 35.0 Mb/s
Color space : YUV
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.143
Stream size : 11.4 GiB (86%)
BDREBUILDER.INI file
[Options]
VERSION=0.61.0.29
AC3_192=0
AC3_640=1
AC3_REENCODE=0
ASSUME_DVD_PAL=0
AUDIO_DRC=0
AUDIO_TO_KEEP=eng;und;
AUDIO_TRACK_LIMIT=0
AUTO_BURN=2
AUTO_BURN=2
AUTO_QUALITY=1
AVCHD=1
BDMV_CERT_ONLY=0
COMPLETION_BEEP=1
CONVERT_WIDE=0
CUSTOM_TARGET_SIZE=22900
DECODER=0
DEINTERLACE=1
DTS_REENCODE=0
ENCODER=1
ENCODE_QUALITY=0
FRIMSOURCE=0
IGNORE_3D=0
IMPORT_KEEP_PLAYALL=0
IMPORT_LIMIT_LANG=0
IMPORT_PREPARE_MKV=0
IMPORT_THRESHOLD=10
IVTC_PULLDOWN=0
KEEP_HD_AUDIO=0
MENU_ACTIVE_COLOR=WHITE
MENU_AUDIO=E:\BD_Rebuilder\tools\blankclip\blank.ac3
MENU_AUTO_BACKGROUND=0
MENU_AUTO_DVDAUDIO=0
MENU_BACKDROP_AUTOSIZE=1
MENU_BACKDROP_OPACITY=140
MENU_BACKGROUND=D:\4k sources\FOR DISK COPY\Studio Ghibli\studio ghibli bkgrnd-1.jpg
MENU_HORIZONTAL=250
MENU_FONT=Microsoft Sans Serif
MENU_PLAY_SEQUENTIAL=0
MENU_START_WITH_MENU=1
MENU_TOP=250
MIN_M2TS_SIZE=0
MIN_PLAYLIST_MINS=15
MODE=3
NEROAAC=0
NVENC_CAPABLE=1
ONEPASS_ENCODING=2
OPEN_GOP=0
OUTPUT_SBS=0
PGSTOSRT=0
PRIORITY_CLASS=2
PRIORITY_CLASS=2
QUICK_PLAY_THRESHOLD=10
REMOVE_OUTPUT=0
REMOVE_WORKFILES=0
RESIZE_1080=0
RESIZE_1440=0
RESIZE_720=0
SD_CONVERT=0
SD_TO_1080=0
SUBS_TO_KEEP=eng;und;
SUBTITLE_TRACK_LIMIT=0
SUPTITLE=0
TARGET_SIZE=22900
USE_FILTERS=0
OUTPUT_FOLDER=H:\RENDERS\ImgBurn_Renders\
[Paths]
WORKING_PATH=D:\D-TEMP\
SOURCE_PATH=D:\D-TEMP\IMPORTS\SHERYL_CROW_-_LIVE_ON_SOUNDSTAGE\
LAST CMD TXT
"E:\BD_Rebuilder\tools\nvenc\nvencc.exe" --avhw --fps 59.94 --interlace tff --vpp-deinterlace adaptive -i "D:\D-TEMP\IMPORTS\SHERYL_CROW_-_LIVE_ON_SOUNDSTAGE\BDMV\STREAM\00000.m2ts" --codec h264 --preset performance --qp-min 0 --multipass 2pass-full --vbr 35000 --aq --aq-temporal --keyfile "D:\D-TEMP\WORKFILES\VID_00000.CHP" --sar 1:1 --aud --pic-struct --vbv-bufsize 30000 --max-bitrate 35000 --lookahead 24 --no-b-adapt --gop-len 60 -o "D:\D-TEMP\WORKFILES\VID_00000.AVS.264"
doobre is offline   Reply With Quote
Old 14th February 2025, 18:51   #32137  |  Link
Moviewatcher666
Godzilla 1954 4K Criterion disc subtitle problem
Greetings all,
First, I want to commend JDobbs on his commitment to this great program. Well done!
I am playing with a full backup of the new Godzilla Criterion 4K release.
The backup is in ISO format and when I play it in PowerDVD v20, it plays properly with the proper English subtitles. When I play the original disc in my 4K player, it plays fine (of course).
When I process the ISO to fit onto a BD50 in BDRebuilder, everything works except the English subtitles (even when selected in the main menu of the disc).
When I look at the M2TS file, there appears to be the subtitle
Rather frustrating when watching and listening with the Japanese sound track and no English subtitles.
I am attaching my log files to show the work done on the disc.
What am I missing? Or is there a bug that does not set the proper flag when rebuilding the file so that the subtitles turn on?
I appreciate any feedback, assistance or help offered.
Thanks,
Moviewatcher666
[Status]
LABEL=GODZILLA_1954_UHD
VERSION=v0.62.12
SOURCE_SIZE=72166433618
SOURCE_VIDEO_SIZE=71773759488
TARGET_SIZE=49283072000
REDUCTION=.681173707755605
RESIZE_1080=0
RESIZE_1440=0
AUDIO_TO_KEEP=eng;jpn;
KEEP_HD_AUDIO=-1
SUBS_TO_KEEP=eng;jpn;
BACKUP_MODE=0
MOVIEONLY_TYPE=0
USE_LAVF=0
INSTANCES=4
DGDECNV=-1
DGDECIM=0
FRIMSOURCE=0
FFMS2=0
SSIF_MODE=0
UHD_V3_MODE=0
QUICK=1
ENCODE_STEP=0
COMPLETED=3
REBUILD_COMPLETE=1
[00009]
AUDIO=11
PGS=
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=61948313
NSTART=27000000
NEND=27360360
NSIZE=4141056
FLINK=0
MLINK=0
[00007]
AUDIO=1
PGS=
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=96417054
NSTART=27000000
NEND=27900900
NSIZE=11464704
FLINK=0
MLINK=0
[00005]
AUDIO=11
PGS=1
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=48874792110
NSTART=27000000
NEND=287720460
NSIZE=38200246272
FLINK=0
MLINK=0
[02/14/25] BD Rebuilder v0.62.12
[09:02:47] Source: GODZILLA_1954_UHD
- Input BD size: 67.21 GB
- Approximate total content: [01:37:41.855]
- Target BD size: 45.90 GB
- Quality: High Quality (Default), CQM
- UHD-BD source detected.
- Decoding/Frame serving: NVENCC
[09:02:47] PHASE ONE, Encoding
- [09:02:47] Processing: VID_00009 (1 of 3)
- [09:02:47] Extracting A/V streams [VID_00009]
- [09:02:53] Reencoding video [VID_00009]
- Track 4353 (eng): Keeping original audio
- [09:03:09] Processing: VID_00007 (2 of 3)
- [09:03:09] Extracting A/V streams [VID_00007]
- [09:03:13] Reencoding video [VID_00007]
- Track 4352 (min): Keeping original audio
- [09:03:24] Processing: VID_00005 (3 of 3)
- [09:03:24] Extracting A/V streams [VID_00005]
- [09:09:48] Reencoding video [VID_00005]
- Analyzing 1.00 [1.00]
- Track 4352 (jpn): Keeping original audio
[09:49:05]PHASE ONE complete
[09:49:05]PHASE TWO - Rebuild Started
- [09:49:05] Rebuilding BD file Structure
[09:49:07] - Encode and Rebuild complete
[09:49:07] Writing BD structure to ISO file
- ImgBurn completed successfully
[09:58:06] JOB: GODZILLA_1954_UHD finished.
LASTCMD.txt "C:\Program Files (x86)\BD_Rebuilder\tools\nvenc\nvencc.exe" --avhw --fps 23.976 -i "Q:\BDMV\STREAM\00005.m2ts" --codec hevc --preset default --profile main10 --output-depth 10 --repeat-headers --colorprim bt709 --transfer bt709 --colormatrix bt709 --qp-min 0 --multipass 2pass-full --vbr 0 --vbr-quality 1 --aq --aq-temporal --keyfile "D:\BD REBUILDER WORKING FILES\WORKFILES\VID_00005.CHP" --sar 1:1 --aud --pic-struct --vbv-bufsize 45000 --max-bitrate 48000 --lookahead 24 --no-b-adapt --gop-len 24 -o "D:\BD REBUILDER WORKING FILES\WORKFILES\VID_00005.AVS.hevc"
[Options]
VERSION=0.62.0.12
MIN_M2TS_SIZE=10
;[UHD_IGNORE_HDR=1]
MIN_PLAYLIST_MINS=10
MULTIPROCESS=1
ENABLE_TEST=1
ENCODER=1
MODE=0
ENCODE_QUALITY=2
ONEPASS_ENCODING=1
AUTO_QUALITY=0
TARGET_SIZE=47000
AUTO_BURN=2
SD_CONVERT=0
OPEN_GOP=0
RESIZE_1080=0
RESIZE_1440=0
RESIZE_720=0
DEINTERLACE=1
SD_TO_1080=0
IGNORE_3D=0
CONVERT_WIDE=0
DTS_REENCODE=0
AC3_REENCODE=0
AC3_640=1
AC3_192=0
KEEP_HD_AUDIO=1
AUDIO_DRC=0
DECODER=3
AVCHD=0
REMOVE_WORKFILES=0
REMOVE_OUTPUT=0
USE_FILTERS=0
BDMV_CERT_ONLY=0
IVTC_PULLDOWN=0
ASSUME_DVD_PAL=0
FRIMSOURCE=0
COMPLETION_BEEP=0
OUTPUT_SBS=0
NEROAAC=0
SUPTITLE=0
PGSTOSRT=0
AUDIO_TRACK_LIMIT=0
CUSTOM_TARGET_SIZE=47000
QUICK_EXTRAS=1
MENU_BACKGROUND=C:\Program Files (x86)\BD_Rebuilder\misc\menuback.jpg
MENU_AUDIO=C:\Program Files (x86)\BD_Rebuilder\tools\blankclip\blank.ac3
IMPORT_THRESHOLD=10
MENU_AUTO_BACKGROUND=1
MENU_AUTO_DVDAUDIO=1
IMPORT_LIMIT_LANG=1
ENABLE_BLANKING=1
VERBOSE_STATUS=0
MOVIEONLY_TYPE=0
ALTCRF=23
ALT_TARGET=1024
ALT_CRF_TARGET=1024
ALTMETHOD=0
ALTAUTOCROP=0
PRIORITY_CLASS=0
NVENC_CAPABLE=1
[Paths]
SOURCE_PATH=Q:\
WORKING_PATH=D:\BD REBUILDER WORKING FILES\
DGIndexNV=C:\Program Files\dgdecnv_255\DGIndexNV.exe
DGDecNV=C:\Program Files\dgdecnv_255\DGDecodeNV.dll
DGDecNV=0
SupTitlePath=C:\Program Files (x86)\BD_Rebuilder\Tools\suptitle_v2.0.8_x86\SupTitle.dll
;SupTitlePath=C:\Program Files (x86)\BD_Rebuilder\Tools\suptitle.dll
File Type: txt GODZILLA_1954_UHD.inf.txt (857 Bytes, 3 views)
File Type: txt LASTCMD.TXT (568 Bytes, 1 views)
Last edited by Moviewatcher666; 21st February 2025 at 17:03. Reason: attachments didn't work
Moviewatcher666 is offline   Reply With Quote
Old 14th February 2025, 23:38   #32138  |  Link
Emulgator
Big Bit Savings Now !
Emulgator's Avatar
There is no VFR BD to begin with, so you would have to take care of that before importing any source to BD-RB.
Old 15th February 2025, 02:09   #32139  |  Link
doobre
mediainfo details
hi there, and thanks for your reply..
the resultant file from Makemkv shows it as VFR.!?
Format : AVC
Also handbrake fails to do the job!
[23:33:26] CPU: Intel(R) Core(TM) i7-2600 CPU @ 3.40GHz
[23:33:26] - Intel microarchitecture Sandy Bridge
[23:33:26] - logical processor count: 4
[23:33:26] Intel Quick Sync Video support: no
[23:33:26] hb_scan: path=D:\EXPORTS\MakeMKV_Export\SHERYL_CROW_LIVE\title_t00.mkv, title_index=1
[23:33:26] hb_stream_open: open D:\EXPORTS\MakeMKV_Export\SHERYL_CROW_LIVE\title_t00.mkv failed
[23:33:26] scan: unrecognized file type
[23:33:26] libhb: scan thread found 0 valid title(s)
hb_dict_to_job: Title 1 doesn't exist
[23:33:26] Finished work at: Fri Feb 14 23:33:26 2025
[23:33:26] libhb: work result = 3
# Job Failed to Initialise. Check log and input settings (3)
I will try to rip the BD with handbrake instaed of makemkv.
cheers CD
Old 15th February 2025, 06:29   #32140  |  Link
doobre
Handbrake v1.3.1 came to the rescue (again) ripped the BD to mkv with CBR of 59.940, avg 30Mbs final size 23Gb.
Thread Tools
