#23 | Link |
Currently I'm using AviSynth 2.5.8's built-in scriptclip and conditionalreader. anyway I can adapt this code so that I can use Gavino's versions?
Filtered = RemoveNoiseMC(rdlimit=18,rgrain=1,denoise=0,sharp=true)
ScriptClip("ABC1 ? Filtered : Last")
ConditionalReader("seriously.txt","ABC1",false)
#24 | Link |
Avisynth language lover
If you just load the GRunT plugin (or install it in the plugin folder), it will use my version automatically (if running on Avisynth 2.58).
For your example, where the run-time script is very simple, you wouldn't actually gain very much. However, it would allow you to replace the ScriptClip call by ConditionalFilter(Filtered, last, "ABC1") which would be slightly faster. Even without GRunT, it could also be changed, although with the standard ConditionalFilter you would have to write ConditionalFilter(Filtered, last, "ABC1", "==", "true") GRunT does not have its own version of ConditionalReader, so you would continue to use the standard version. |
#26 | Link |
I have tried everything that I can think of. What I need is a single pass solution to step through a video and only retain frames where AverageLuma(a)>16 (IOW, retain only non-blank frames). Scriptclip can step through the video and conditionally test the AverageLuma value, but I can't get the new video out of the Scriptclip, even with GRunT. Any suggestions?
#27 | Link |
Yo dude, long time no see.
So far as I know, Scriptclip must produce same number of output frames as input. (+ same size, colorspace etc). So 1 single pass solution is unlikely. Although could do it as realtime 1st pass, with auto second pass. No idea what IOW means. But see here:- http://forum.doom9.org/showthread.php?t=172904 You might want to use YPlaneMinMaxDifference (Threshold=eg 0.2) to establish 'blank frame', and YPlaneMin or AverageLuma to establish level.
#28 | Link |
Something like this (writing frames to reject in realtime pass, as likely fewer than writing all selected frames)
Avisource("D:\V\StarWars.avi").Trim(0,10000)
GSCript("""
Function Test(Clip c, int n,int v1,Float th,String File,Bool Show) {
c
mx = RT_YPlaneMax(n,Threshold=th)
if(mx < v1) {
RT_WriteFile(File,"%d",n,Append=True) # Write unwanted frames (fewer than wanted)
(Show) ? RT_SubTitle("%d] mx=%d - DELETING",n,mx) : NOP
} else {(Show) ? RT_SubTitle("%d] mx=%d",n,mx) : NOP}
Return Last
OutFile = "Frames.txt"
RT_FileDelete(OutFile) # Delete existing
V1 = 18 # Was not deleteing anything for me at 16
th = 0.2 # Avoid 0.2% of noise above v1
Show=True # CHANGE to FALSE when happy with numbers
SSS = "Test(current_frame,V1,th,OutFile,Show)"
ARGS= "v1,th,OutFile,Show"
ScriptClip(SSS,args=ARGS,after_frame=True)
(!Show) ? ForceProcessAVI() : NOP # Force Pass 1 (From TWriteAVI v2.0) ie force writing of frames file
(!Show&&Exist(OutFile)) ? RejectRanges(Cmd=Outfile) : NOP # If Outfile does not exist, then none to Reject.
Return last
Function RejectRanges(clip c,String "SCmd",String "Cmd",Bool "TrimAudio",Float "FadeMS") {
# RejectRanges() by StainlessS. Required:- FrameSel, Prune, RT_Stats
# Wrapper to delete frames/ranges along with audio, can supply frames/ranges in SCmd string And/Or Cmd file.
# The wrapper makes for easier usage of Prune() which supports up to 256 input clips, but requires a clip index,
# eg '3, 100,200' would specify clip 3, range 100 to 200. The wrapper does away with the necessity for the clip index as we
# are only using a single clip here. Prune also does not have a 'reject' arg to delete specified frames rather than select them,
# this wrapper also converts a list of frames to delete into a list of frames to select so that we can use Prune and its audio
# capability.
# SCmd: Frames/Ranges specified in String (Frames/Ranges either Chr(10) or ';' separated, infix ',' specifies range, eg 'start,end').
# Cmd: Frames/Ranges specified in file (one frame/range per line, comments also allowed, see FrameSel for Further info).
# TrimAudio:
# True(default), deletes audio belonging to deleted frames
# False, returns original audio, probably out of sync.
# FadeMS: (default 1.0 millisec). Linear Audio Fade duration at splices when TrimAudio==true, 0 = dont fade (might result in audio 'clicks/cracks').
c
TrimAudio=Default(TrimAudio,True) # default true trims audio, false returns original audio (audiodubbed, as Framesel returns no audio)
FadeMS=Float(Default(FadeMS,1.0)) # 1 millisecond linear fadeout/fadein at splices
PruneCmd = (TrimAudio) ? "~Prune_"+RT_LocalTimeString+".txt" : ""
(!TrimAudio)
\ ? FrameSel(scmd=SCmd,cmd=Cmd,reject=true)
\ : FrameSel_CmdReWrite(PruneCmd,scmd=SCmd,cmd=Cmd,reject=true,Prune=True,range=true)
(TrimAudio) ? Prune(Cmd=PruneCmd,FadeIn=True,FadeSplice=True,FadeOut=True,Fade=FadeMS) : NOP
# If TrimAudio==true then delete Prune temp file, Else restore original Audio to the now audio-less clip
(TrimAudio)
\ ? RT_FileDelete(PruneCmd)
\ : (c.HasAudio) ? AudioDub(c) : NOP
Return Last
SelectRanges(Cmd=Outfile) # or change to RejectRanges to view kept after 1st pass script
Return last
# From Prune [req FrameSel]
Function SelectRanges(clip c,String "SCmd",String "Cmd",Bool "TrimAudio",Float "FadeMS",Bool "Ordered") {
# SelectRanges() by StainlessS. Required:- FrameSel, Prune, RT_Stats
# Wrapper to Select frames/ranges along with audio, can supply frames/ranges in SCmd string And/Or Cmd file.
# Cmd: Frames/Ranges specified in file (one frame/range per line, comments allowed, see FrameSel for Further info).
# *** NOTE ***, If both Cmd and SCmd supplied AND Ordered == False, then will process Cmd file and then SCmd string afterwards, ie
# Will select ranges in Cmd file and in order specified (rather than auto ordering ranges) and then append ranges specified in
# SCmd string (and in order specified).
# TrimAudio:
# True(default), selects audio belonging to selected frames/ranges
# False, returns original audio, probably out of sync (maybe totally out of whack if Ordered == false and selected ranges out of order).
# Ordered:
# True(default), all frames/ranges are returned in sequencial order. Any frame specified more than once will return only 1 instance.
# False, All frames/Ranges are returned in specified order, Cmd processed first and then SCmd. Frames/ranges specified more than once
# will return multiple instances. Allows out-of-order trimming of clip, eg re-sequencing of scenes in movie.
# Does not make much sense to select individual frames with audio, best used with ranges.
# Will coalesce individually selected adjacent frames/ranges before any Fade, ie only audio fade where sensible to do so.
# TrimAudio==false with non Ordered selection will result in completely out of sync audio.
c
Ordered=Default(Ordered,True) # True (default) frames/ranges will be Ordered and selected only once even if specified more than once.
# False, frames/ranges returned in specified order, Cmd processed 1st and then SCmd.
(!TrimAudio)
\ ? FrameSel(scmd=SCmd,cmd=Cmd,Ordered=Ordered)
\ : FrameSel_CmdReWrite(PruneCmd,scmd=SCmd,cmd=Cmd,Ordered=Ordered,Prune=True,range=true)
(TrimAudio)
Return Last
Requires RT_Stats, FrameSel, Prune, and TWriteAVI v2.0. http://forum.doom9.org/showthread.ph...ight=twriteavi EDIT:: Oops, and GSCript and Grunt too. EDIT: This is more like what you asked for, set Show = False to do it for real, when true only shows metric On my clip it was not deleting anything as all frames were above Ave luma 16. Code:
GSCript("""
Function Test(Clip c, int n,Float th,String File,Bool Show) {
c
Ave = RT_AverageLuma(n)
if(Ave < th) {
(Show) ? RT_SubTitle("%d] %f - DELETING",n,Ave) : NOP
} else {(Show) ? RT_SubTitle("%d] %f",n,Ave) : NOP}
Return Last
th = 18.0 # Keep >= 18.0
Show = True # CHANGE to FALSE when happy with numbers
SSS = """Test(current_frame,th,OutFile,Show)"""
ARGS="th,OutFile,Show"
(!Show&&Exist(Outfile)) ? RejectRanges(Cmd=Outfile) : NOP # If Outfile does not exist, then none to Reject.
Return last
# capability.
# TrimAudio:
c
(!TrimAudio)
(TrimAudio)
Return Last
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 13th March 2016 at 09:50. |
#29 | Link |
StainlessS. Thank you for this. I have been quite busy with my lab and creating FOSS (Free Open Source Software) that now has over 30,000 downloads and is relied upon by law enforcement worldwide. This would never have been possible without amazing programmers like you and Gavino. Your work has helped to solve crimes and has saved lives!!!! As for this script, it requires two functions I didn't have. I found "ForceProcessAVI" in your TWriteAVI_dll DLL but where do I find "RejectRanges"? Also IOW is a mostly American expression short for "In Other Words" which just means that something is being restated in another way.
#30 | Link |
Select/Reject Ranges is in the Prune AVS directory. (also requires FrameSel to do the clever Select to Reject conversion for Prune).
IOW, I thought it could not possibly stand for "Isle Of White" ![]() Prune: http://forum.doom9.org/showthread.ph...ighlight=Prune FrameSel: http://forum.doom9.org/showthread.ph...light=FrameSel EDIT: Or Select/Reject Ranges both posted in above code snippits, but still need the Prune and FrameSel plugins.
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 13th March 2016 at 08:47. |
#31 | Link | |
DeleteFrames("AverageLuma() <= 16")
BTW Nice to hear my code is being used in real practical applications! |
#32 | Link |
Yes indeed big G.
Although, an advantage of the frames file method is that it is easily repeatable without a second compile time run. Also, RT_AverageLuma is faster than built-in so would cut down overhead on longer clips.
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 13th March 2016 at 10:15. |
#35 | Link |
I've taken the liberty to compile the .dll myself. Had to also change some stuff to make it compile with latest avs+ headers. Hopefully this comes useful to someone. srestore now tested working on a fully x64 setup.
here it is |
#36 | Link | |
See My Avisynth Stuff |
#38 | Link |
yes, but I use it some times (for setmtmode) and 2.5 plugin work with avs+ too
#40 | Link | |
with srestore(frate=23.976) I get http://i.imgur.com/yHVtNvM.png in the top of video frame but with same GrunT-x64-25 in avs+ it's fine!
| Tags |
| conditional, plugin, run-time, scriptclip |
| Thread Tools | |
| Display Modes | |
