Old 15th May 2006, 23:14   #2281  |  Link
videomixer9
ffdshow fan
just open video_ts.ifo
videomixer9 is offline   Reply With Quote
Old 16th May 2006, 01:39   #2282  |  Link
Schrade
Schrade's Avatar
Originally Posted by fanbanlo
How can I play ripped VIDEO_TS with MPC?
Thank you.
Drag and drop the VIDEO_TS folder on top of the MPC window.
Schrade is offline   Reply With Quote
Old 16th May 2006, 16:19   #2283  |  Link
CiTay
CiTay's Avatar
Thank you.
Uh... associate "DVD File" with MPC and then double-click on VIDEO_TS.IFO?
CiTay is offline   Reply With Quote
Old 26th November 2007, 10:47   #2284  |  Link
SmartUK
keen but ignorant...
frame step and virtual surround
Hi, Gabest. I've been using various incarnations of MPC for ages, so many thanks for that.
Two issues: one is I can't get mpc to frame step back - forward's okay; the keys seem to be assigned properly (vk_left and right respectively). I'm also not clear as to how to assign a new key properly. The other issue is whether MPC supports any kind of virtual surround output.
You're bound to ask me what version I've got; I dowloaded both the latest version of MPC plus the Home Cinema version - if you need file numbers I'll need to check when I get home tonight.
all the Best,
Smart
SmartUK is offline   Reply With Quote
Old 26th November 2007, 11:40   #2285  |  Link
cweb
cweb's Avatar
all the Best,
Smart
Is it one of the latest contributed builds or an older one?
PC specs for bug reports: Intel Core i7-4790K @4Ghz Win10(Linux VM) PCI express NVIDIA RTX 2060 SUPER graphics card
http://twitter.com/cwebdesign
cweb is offline   Reply With Quote
Old 26th November 2007, 12:51   #2286  |  Link
SmartUK
mpc
I only downloaded it on Saturday and I'm pretty sure it said "latest version" or something similar; typically I can't now remember where I got it or its version number - I'll get the details tonight! Thanks for your help.
Old 26th November 2007, 13:56   #2287  |  Link
Leak
ffdshow/AviSynth wrangler
Leak's Avatar
I don't think so, but you could use ffdshow's audio decoder, it supports downmixing surround using a HRTF or headphone spatialization, if you meant that.
As for stepping back - I'd be surprised if it actually worked since DirectShow doesn't really support it; you can single-step forward but not backward with it, and seeking back some fraction of a second might also be off...
now playing: [artist] - [track] ([album])
Leak is offline   Reply With Quote
Old 10th December 2007, 14:51   #2288  |  Link
SmartUK
mpc
Okay; sorry for the delay - my existing MPC is 6.4.8.2
Since then I got mplayerc_20071015 [mplayerc_1107] and mplayerc_homecinema_x86_v1.0.11.0
Has anyone ever written a user guide for non-techies like me? I've looked on the home page but there doesn't seem to be any documentation (not for mere mortals, anyway!)
Cheers.
Old 10th December 2007, 15:08   #2289  |  Link
SmartUK
surround
Hi, Leak. Yes, I was thinking about virtual surround support for headphones or two speakers. I'm not sure I know enough about setting ffdshow, though!
Old 10th December 2007, 19:48   #2290  |  Link
Brother John
(schein)heilig
Brother John's Avatar
I don’t know about non-techie. But there is documentation on the guliverkli project page: http://sourceforge.net/project/showf...kage_id=144472
Brother John
When lost in BeSweet's options, have a look at the Commandline Reference.
DVD nach MPEG-4 klappt nicht? Verzweifelt? Auf zum Encodingwissen!
Brother John is offline   Reply With Quote
Old 13th December 2007, 07:13   #2291  |  Link
grace88
waiting
grace88 is offline   Reply With Quote
Old 14th December 2007, 07:48   #2292  |  Link
4Dude
An Awesome Dude
Welcome to the site!
This looks good doesnt it?
4Dude is offline   Reply With Quote
Old 14th March 2009, 01:55   #2293  |  Link
phrentec
waprout?
phrentec's Avatar
Media player classic with FFmpeg 0.5
March 10, 2009. FFmpeg 0.5 is out with many speed improvements.
Gabest, is there any chance to have a version of media player classic with ffmpeg built in? I hope your still out there. Thank you.
phrentec is offline   Reply With Quote
Old 14th March 2009, 02:01   #2294  |  Link
LoRd_MuldeR
Software Developer
LoRd_MuldeR's Avatar
You know that Gabest didn't work on MPC for years and that there's the "Media Player Classic - Home Cinema" project now ???
http://mpc-hc.sourceforge.net/
Recent builds can be found here:
http://www.xvidvideo.ru/content/category/1/1/2/
Old 14th March 2009, 11:34   #2295  |  Link
Leak
Leak's Avatar
You probably should have also mentioned that it's got FFmpeg built-in already...
np: Yagya - Rigning Fimm (Rigning)
