Old 13th December 2013, 00:23   #1  |  Link
Nozdrum
How to trim during encoding, in x264?
I was trying to trim directly while encoding with x264, but I couldn't find any way, I wonder if there're any --zones settings to skip the given zones, something like:
--zones 1100,2300,skip=1/7600,8900,skip=1
In MeWiki I didn't find anything similar to this, I know that it's possible with Avisynth but I think it could be nice if it were possible directly from x264.
Any ideas?
Nozdrum is offline   Reply With Quote
Old 13th December 2013, 02:24   #2  |  Link
nhakobian
The setting --seek lets you indicate what the starting frame of the encode is, and --frames tells it how many frames to encode. For example:
--seek 2500 --frames 1000
tells x264 to start encoding at frame 2500 and end at frame 3500.
I am not sure how this interacts with the --zones feature.
nhakobian is offline   Reply With Quote
Old 13th December 2013, 04:08   #3  |  Link
Nozdrum
I think this is good enough, I can make a batch file with multiple instances of x264 for each part that needs to be trimmed, I think it's really good actually!
Thanks I'll try it asap
Old 13th December 2013, 09:52   #4  |  Link
the_weirdo
Yes, I'm weird.
the_weirdo's Avatar
Remember to add "--stitchable" to the commandline so you don't get into trouble joining them together later.
“Never argue with stupid people, they will drag you down to their level and then beat you with experience.” — Mark Twain
the_weirdo is offline   Reply With Quote
Old 13th December 2013, 20:40   #5  |  Link
Nozdrum
I was thinking to foce some key frames using --qpfile but this sounds better, it's probably gonna save me some time, thanks!
Old 13th December 2013, 20:50   #6  |  Link
sneaker_ger
--stitchable has nothing to do with keyframes, but if you do each encode separately you won't have trouble with keyframes when appending them in the end anyways. Keyframes are only a problem if you plan on splitting a long encode into smaller parts, not the other way around.
avisynth, seek, trim, x264, zones
