Old 11th April 2023, 10:58   #1681  |  Link
oniiz86
Originally Posted by -QfG- View Post
I wrote this to the support but i do it here, too:
In version 22.12 the entry under video "BitsPixel_Frame" is changed to "Bits-Pixel_Frame". I use a PHP script to read via a JSON file all video informations. But the "-" is a problem in PHP, this will be called as an function .
Example (older version)
$json["bitrate"]          = $video[0]->BitRate_String." => ".$video[0]->BitsPixel_Frame." Bits/(Pixel*Frame)";
works fine.
Example (v22.12)
$json["bitrate"]          = $video[0]->BitRate_String." => ".$video[0]->Bits-Pixel_Frame." Bits/(Pixel*Frame)";
crashing, because the "-"
Is there any chance to rallback to "BitsPixel_Frame" in JSON output?
@-QfG- I was wondering if you were able to confirm if this issue has been fixed in the latest v23.04 release?
@-QfG- It looks to have been fixed with the v23.03 MediaInfo release, according to the changelog, https://mediaarea.net/MediaInfo/ChangeLog
x JSON/XML: Remove minus sign from element names
oniiz86 is offline   Reply With Quote
Old 8th May 2023, 16:08   #1682  |  Link
Lan4
Are there versions of MediaInfo with normal text scaling for modern operating systems? Now the text is very small, or the text is blurry when scaling.
Lan4 is offline   Reply With Quote
Old 11th May 2023, 08:15   #1683  |  Link
hajj_3
https://github.com/stax76/MediaInfo.NET/releases
Old 14th May 2023, 20:48   #1684  |  Link
Lan4
Originally Posted by hajj_3 View Post
Thank you. This is a quality app and good job!
Old 19th May 2023, 23:06   #1685  |  Link
Thunderbolt8
is there any update for mediainfo v22.04?
Laptop Lenovo Legion 5 17IMH05: i5-10300H, 16 GB Ram, NVIDIA GTX 1650 Ti (+ Intel UHD 630), Windows 10 x64, madVR (x64), MPC-HC (x64), LAV Filter (x64), XySubfilter (x64) (K-lite codec pack)
Old 19th June 2023, 06:22   #1686  |  Link
Perenista
is there a way to...
1) Open more than one file at the same time, to gather the informations about it
and
2) Remove the file path, or just leave its name, on the result?
Perenista is offline   Reply With Quote
