Old 5th March 2024, 07:09   #101  |  Link
TDS
Formally known as .......
TDS's Avatar
Hi Reset,
I did a 3-1 with the latest everything, and I'm not sure if this is important, or what it means:-
Input #0, avisynth, from 'D:\Dovi_Temp_MP4\temp.folder77\script.avs':
  Duration: 00:58:48.07, start: 0.000000, bitrate: N/A
  Stream #0:0: Video: rawvideo (Y3[11][10] / 0xA0B3359), yuv420p10le(tv, bt2020nc/bt2020/smpte2084, progressive), 3840x2160, 23.98 fps, 23.98 tbr, 23.98 tbn
Stream mapping:
  Stream #0:0 -> #0:0 (rawvideo (native) -> prores (prores_ks))
Press [q] to stop, [?] for help
Output #0, mov, to 'D:\Dovi_Temp_MP4\temp.folder77\Game of Thrones S01 E01_prores.422.mov':
  Metadata:
    encoder         : Lavf60.16.100
  Stream #0:0: Video: prores (HQ) (apch / 0x68637061), yuv422p10le(tv, bt2020nc/bt2020/smpte2084, progressive), 3840x2160, q=2-31, 200 kb/s, 23.98 fps, 24k tbn
    Metadata:
      encoder         : Lavc60.31.102 prores_ks
[out#0/mov @ 0000013ad8ed2600] video:34326861kB audio:0kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 0.002049%
frame=84589 fps= 71 q=-0.0 Lsize=34327565kB time=00:58:48.02 bitrate=79707.9kbits/s speed=2.98x
Copyright (c) 2013-2024 Dolby Laboratories, Inc. All Rights Reserved
03/05/2024/16:51:51.728000000 CPU: INFO 13th Gen Intel(R) Core(TM) i9-13900KF (GenuineIntel) [ mmx sse sse2 sse3 ssse3 sse41 sse42 avx avx2 fma ]
03/05/2024/16:51:51.755000000 plugin_manager: WARNING plugin does not contain dlb_plugin_file_io_init_v1
03/05/2024/16:51:51.813000000 plugin_manager: WARNING plugin does not contain dlb_plugin_file_io_init_v1
03/05/2024/16:51:51.899000000 plugin_manager: WARNING plugin does not contain dlb_plugin_file_io_init_v1
03/05/2024/16:51:51.937000000 plugin_manager: WARNING plugin does not contain dlb_plugin_file_io_init_v1
03/05/2024/16:51:51.956000000 plugin_manager: WARNING plugin does not contain dlb_plugin_file_io_init_v1
03/05/2024/16:51:51.995000000 plugin_manager: WARNING plugin does not contain dlb_plugin_file_io_init_v1
03/05/2024/16:51:52.109000000 plugin_manager: WARNING plugin does not contain dlb_plugin_file_io_init_v1
03/05/2024/16:51:52.204000000 plugin_manager: WARNING plugin does not contain dlb_plugin_file_io_init_v1
03/05/2024/16:51:52.365000000 plugin_manager: WARNING plugin does not contain dlb_plugin_file_io_init_v1
03/05/2024/16:51:52.459000000 cm_analyze: INFO Shot cut detection is disabled when shot list is used
03/05/2024/16:51:52.460000000 cm_analyze: INFO                Source: 'file:///D:/Dovi_Temp_MP4/temp.folder77/Game of Thrones S01 E01_prores.422.mov'
03/05/2024/16:51:52.460000000 cm_analyze: INFO        Master Display: 1000-nit, BT.2020, D65, ST.2084, Full
03/05/2024/16:51:52.460000000 cm_analyze: INFO              Src Info: '3840x2160x3 u16 interleaved 422 le tight 0-84588 23.976fps top_left pq ycbcr_bt2020 video bt2020'
03/05/2024/16:51:52.460000000 cm_analyze: INFO                Frames: 0 - 84588
03/05/2024/16:51:52.460000000 cm_analyze: INFO            Frame rate: 24000/1001
03/05/2024/16:51:52.460000000 cm_analyze: INFO     Algorithm Version: 4
03/05/2024/16:51:52.460000000 cm_analyze: INFO           XML Version: 4.0.2
I'm going to have to change what drives I do this on, NVME's preferably, doing in on old "spinner's" takes forever
Long term RipBot264 user.
RipBot264 modded builds..
*new* x264 & x265 addon packs..
TDS is offline   Reply With Quote
Old 5th March 2024, 12:57   #102  |  Link
Kuler087
Kuler087's Avatar
Yes I've noticed the warning when using the latest CM-Analyze, I don't think it matters. The output is the same as before.
DoVi_Scripts
Kuler087 is offline   Reply With Quote
Old 5th March 2024, 15:36   #103  |  Link
pancserzso
Hi, thanks for these scripts. I have two questions:
1. Can you tell me what do I need to run to convert a P7 mkv file to a P8 mkv?
2. Do I need to use MakeMKV to crate the source MKV from a BDMV folder, or I can use mkvmerge with the biggest m2ts file in STREAM? Is there any difference, other than the chapters?
pancserzso is offline   Reply With Quote
Old 5th March 2024, 16:10   #104  |  Link
Kuler087
Kuler087's Avatar
For any P7 source(mkv or bdmv) to Profile 8, use workflow 4-1.
For BDMV input, you should input the main playlist file and not the largest M2ts.
see tutorial: https://www.youtube.com/watch?v=sBUL2gjhqEE
DoVi_Scripts
Old 5th March 2024, 16:14   #105  |  Link
pancserzso
Originally Posted by Kuler087 View Post
Thanks a lot, video is perfect! About CM4, if my TV supports it (LG G2), then I should use rem_cmv4=NO right?
Old 5th March 2024, 16:55   #106  |  Link
Kuler087
Kuler087's Avatar
You should not remove cmv4.0 unless maybe if you use the AppleTV 4K with Infuse (non-beta).
Cmv4.0 has superior tone mapping to the old cmv2.9 algo
DoVi_Scripts
Old 5th March 2024, 20:49   #107  |  Link
giyo279
Any thoughts on NVENC vs x265 for dovi_baking? I know encoding settings can get pretty advanced, but are the default HDR_settings set for mostly transparent encodes?
giyo279 is offline   Reply With Quote
Old 5th March 2024, 21:21   #108  |  Link
Kuler087
Kuler087's Avatar
I'm no HEVC encode setting expert but as far as I can tell, if you use x265 with the script default settings, it should produce something transparent but depending on how much FEL adds, you might end up with a file larger than your source.
For NVENC, I don't know but from the quick tests I did, it seems to produce decent quality.
DoVi_Scripts
Old 5th March 2024, 21:24   #109  |  Link
CineManiac
CineManiac's Avatar
Hey, have you had a chance to check if the Infuse beta implementation of cmv4.0 has the same issues as the Plex version on ATV?
CineManiac is offline   Reply With Quote
Old 5th March 2024, 21:29   #110  |  Link
Kuler087
Kuler087's Avatar
Not yet, I have to get in the beta test group first but I'll definitely check it out.
DoVi_Scripts
Old 5th March 2024, 21:59   #111  |  Link
CineManiac
CineManiac's Avatar
Oh man, I'll have to re-inject everything with cmv4
Old 5th March 2024, 22:15   #112  |  Link
Kuler087
Kuler087's Avatar
haha, yes but it's worth it.
DoVi_Scripts
Old 5th March 2024, 22:56   #113  |  Link
Gatorman3385
Gatorman3385's Avatar
It seems my madVR install is broken. I've tried running "install.bat" as admin. 6-2 gives me the error,
Connecting LAV Video Decoder to madVR failed.
MPC-HC has stop using madVR as well. Any thoghts?
Gatorman3385 is offline   Reply With Quote
Old 5th March 2024, 23:37   #114  |  Link
Kuler087
Kuler087's Avatar
Yes, it happened to me on 3 different PCs a couple of days ago, and I don't understand how this is possible. It must be a Windows update that broke something, idk...
Re-download the tool pack and overwrite the madvr folder, which should fix it.
DoVi_Scripts
Old 5th March 2024, 23:51   #115  |  Link
Gatorman3385
That worked. Thanks.
Old 6th March 2024, 02:03   #116  |  Link
pancserzso
I'm using a M1 mac and the only way to run the scripts is through a Windows ARM install in UTM, +1 more layer inside Windows to do the CPU emulation. The files can also only be shared by a loopback network share, which is super super slow, about 12 MB/s only!
The native SSD under macOS on the other hand is super fast, a 100 GB demux only takes a few seconds.
So I've spend a few hours trying to understand what's the heart of P7 -> P8 conversion.
Do I understand it correctly that it's basically these 3 commands?
ffmpeg -i $MKVFILE -c:v copy -bsf:v hevc_mp4toannexb -f hevc - | dovi_tool demux -
dovi_tool -m 2 mux --bl BL.hevc --el EL.hevc --discard -o P8.hevc
mkvmerge --output $MKVFILE-P8.mkv --compression 0:none --default-duration 0:24000/1001p P8.hevc --no-video --compression 1:none $MKVFILE
And do I understand it correctly that the last command can be simplified into:
mkvmerge --output $MKVFILE-P8mod.mkv P8.hevc --no-video $MKVFILE
Is this correct?
Old 6th March 2024, 04:12   #117  |  Link
Kuler087
Kuler087's Avatar
Seems right but you should have a look at @nekno script for MAC
https://github.com/nekno/DV7toDV8
DoVi_Scripts
Old 6th March 2024, 04:14   #118  |  Link
TDS
TDS's Avatar
Can confirm that this IS the case
v5.4.1 does not display those WARNINGS.
v5.5.0 does
Old 6th March 2024, 04:39   #119  |  Link
TDS
TDS's Avatar
8-1-1
Has something changed with the audio conversions ??
I was sure that I had set it that when I encode audio, regardless of it's original bitrate, to would come out either as 1024 or 1536, but it's unchanged, keeping it's original bitrate.
I'll have to dig deeper.
EDIT:- I just figured it out, I wasn't adding the IGNOREBITRATE in the file name
Forgive me if I've asked this before (I have a very short term memory, sometimes).
I thought that 3-1 would encode any audio to EC3 at the bitrate set in the .bat.
Old 6th March 2024, 07:18   #120  |  Link
speedy
Infuse 7.7.2 beta support for CMv4 has been great in my early testing. The only downside is that I'm now likely going to want to go back through a number of my favorite releases and convert re-inject CMv4 metadata
speedy is offline   Reply With Quote
batch scripts, dolby vision processing, dovi_scripts
