Old 27th May 2024, 13:15   #321  |  Link
Lucky38
ok. So what will happen when my RPU has 0/0 px but my encoded video has 1/1 pixel on top/bottom? Does it mean encode is broken?
Lucky38 is offline   Reply With Quote
Old 27th May 2024, 13:34   #322  |  Link
Gatorman3385
Gatorman3385's Avatar
No, the encode isn't broken. However, the RPU L5 values should be edited to 0,0,1,1 (left, right, top, bottom).
Gatorman3385 is offline   Reply With Quote
Old 27th May 2024, 13:41   #323  |  Link
Kuler087
Kuler087's Avatar
The DV tone mapping will be applied to the whole image including the 1px top/bottom row.
PS: This metadata (level 5) is ignored by 99% of the HDMI player. Only the TVs internal player uses it. On HDMI devices, the DV tone mapping is always applied to the whole image, letterbox included.
DoVi_Scripts
Kuler087 is offline   Reply With Quote
Old 27th May 2024, 15:06   #324  |  Link
smaiderman
Hello. First of all, thank you very much for the tools.
I need some help.
Im trying to convert DOVI to SDR, and im using the 8-2-4 flow, but I get this error.
https://pastebin.com/iHXdeEVa
But I don understand, as after scanning the file with 2-2-q flow, it says it has that info.
https://pastebin.com/KnrWKBHQ
What am I doing wrong?
Im using the UHD bluray disc, created a mkv with mkvtoolnix from the index.bdmv in the bluray.
Thank you for the help!
smaiderman is offline   Reply With Quote
Old 27th May 2024, 15:28   #325  |  Link
Kuler087
Kuler087's Avatar
It looks like there's something ffmpeg doesnt like about your input. There's an option to bypass ffmpeg piping but unfortunately, it's not implemented in this workflow (8-2-4).
Try the next beta (tonight or tomorrow)
[hevc @ 0000028e222fd0c0] Application provided invalid, non monotonically increasing dts to muxer in stream 0: 19 >= 18
[hevc @ 0000028e222fd0c0] Application provided invalid, non monotonically increasing dts to muxer in stream 0: 19 >= 19
Error: Invalid PPS index
Error: No RPU found
::choose if you dont want to use ffmpeg piping for 4-1 demuxing. Might need to be disable if you notice issues. only valid for the mkv version and when the script is set to mux all audio/subs (default = YES)
set ffmpeg_pipe=YES
DoVi_Scripts
Old 27th May 2024, 21:40   #326  |  Link
smaiderman
Thank you Kuler. I'm not in a hurry. I'll be checking
Old 27th May 2024, 22:23   #327  |  Link
Kuler087
Kuler087's Avatar
In the latest beta, ffmpeg piping can now be disabled for 8-2-4. (Line 173)
let me know if it fixes your issue.
DoVi_Scripts
Old 27th May 2024, 23:44   #328  |  Link
smaiderman
Sorry to say that this didnt solve the problem.
https://pastebin.com/AzvWcHq9
Old 28th May 2024, 00:01   #329  |  Link
Kuler087
Kuler087's Avatar
You have to disable ffmpeg piping at line 173
This setting will never be disabled by default because it speeds up demuxing and causes issues only for a few rips.
DoVi_Scripts
Old 28th May 2024, 08:12   #330  |  Link
smaiderman
After This setting will never be disabled by default because it speeds up demuxing and causes issues only for a few rips.
I edited the bat like this: (it said YES before, so I guess it is NO what I have to write)
::choose if you dont want to use ffmpeg piping for 4-1 / 8-2 / 7-1 demuxing. Might need to be disable if you notice issues.  In 4-1: its only valid for the mkv version and when the script is set to mux all audio/subs (default = YES)
set ffmpeg_pipe=NO
This looked different this time. It showed a progress bar that wasnt there before, but still, errored.
  Donate: https://www.paypal.com/donate/?hosted_button_id=6ML5KUZG9XGB6                  Date: 28/05/2024 08:15
  Contact: R3S3T_9999@proton.me                                                          Version: 2.0.7.beta_MKV
    _____    __      ___       _____           _       _
   |  __ \   \ \    / (_)     / ____|         (_)     | |
   | |  | | __\ \  / / _     | (___   ___ _ __ _ _ __ | |_ ___
   | |  | |/ _ \ \/ / | |     \___ \ / __| '__| | '_ \| __/ __|
   | |__| | (_) \  /  | |     ____) | (__| |  | | |_) | |_\__ \
   |_____/ \___/ \/   |_|    |_____/ \___|_|  |_| .__/ \__|___/
   -Author: RESET_9999--------------------------|__|-----------
1) MODE.I=  DoVi Inject/Convert/Edit/Re-sync TWO INPUTS (P8 Hybrid Maker/Injector)
2) MODE.F=  DoVi Fix/Edit/Extract/Verify/Info ONE INPUT
3) MODE.H=  DoVi Maker from HDR10 (Dolby Algo or MadVR or HDR10+)
4) MODE.7=  DoVi Profile 7 Input (MKV/BDMV)
5) MODE.B=  DoVi MKV Batch Muxer
6) MODE.P=  Plotter
7) MODE.S=  Screenshots & Player
8) MODE.M=  MIXED: Audio/Remover/Encoder/Playlist/Sample
9) Exit
Choice? [1,2,3,4,5,6,7,8,9]?8
      * CHOOSE A MODE *
1) MODE.1= AUDIO Encoding (DDP, THDAC3, DEE)
2) MODE.2= VIDEO Encoding (x265/Prores/dovi_baker/libplacebo/cm_offline)
3) MODE.3= Find Main Movie Playlist (BD MPLS)
4) MODE.4= Dolby Vision / HDR10plus Remover
5) MODE.5= MKV Sample Maker
6) MODE.6= Find a video frame count
7) MODE.7= Subtitles_Tonemap (reduce SUP subtitles brightness)
Choice? [1,2,3,4,5,6,7]?2
     * CHOOSE A WORKFLOW *
1) Workflow.1= X265: HDR to HDR (DVP7/DVP5/HDR10/HLG)
2) Workflow.2= X265: HDR to SDR (DVP7/DVP5/HDR10/HLG)
3) Workflow.3= PRORES:   HDR to HDR (DVP7/DVP5/HDR10/HLG)
4) Workflow.4= PRORES:   DV to SDR (Dolby CM_Offline 100nits L2 trim pass delivery)
5) Workflow.5= PRORES:   SDR to HDR-100nits
6) Workflow.6= back to main menu
Choice? [1,2,3,4,5,6]?4
-- Can Encode any DV source that has a 100nits trim pass to SDR PRORES 422 HQ
-- Require Dolby CM_offline.exe
-- P7 fel baking requires and Nvidia GPU
-- Input MUST be PQ/HDR with a 100nits Level 2 trim.
-- Require a lot of HDD space and -qscale:v 3 is hardcoded since higher value reduce quality
-- Require Vapoursynth
  Drag and drop a video and press enter...
C:\Users\Emilio\Desktop\GODMASTER.mkv
Extracting track 0 with the CodecID 'V_MPEGH/ISO/HEVC' to the file 'H:\HDRtoSDR\HDRtoSDR\temp.folder49\BL.P7.hevc'. Container format: HEVC/H.265 elementary stream
Progress: 100%
Indexing the base layer...
Project
100
Indexing the enhancement layer...
Project
100
Error: No RPU found
[avisynth @ 000002088c1393c0] DoViBaker: parse_rpu_bin_file: Errored while parsing: No RPU found
(H:\HDRtoSDR\HDRtoSDR\temp.folder49\script.avs, line 7)
[in#0 @ 000002088c11aa80] Error opening input: Unknown error occurred
Error opening input file H:\HDRtoSDR\HDRtoSDR\temp.folder49\script.avs.
Error opening input files: Unknown error occurred
Error: El sistema no puede encontrar el archivo especificado. (os error 2)
Input doesnt have a 100nits trim pass.
Old 28th May 2024, 09:51   #331  |  Link
Fuso
Is there a way to change the output bitrate for 7.1 encoding? I get 1024 kbps (which I want to keep for 5.1 DD+) but I want to set it higher e.g. 1536.
Fuso is offline   Reply With Quote
Old 28th May 2024, 11:59   #332  |  Link
Kuler087
Kuler087's Avatar
the maximum bitrate for 7.1 EC3 without a core in ffmpeg is 1024.
You can get 1536kbps in the DEE workflows 8-1-3 but DEE produces dynamic range metadata that can't be turned off, at least on my AVR. IIRC it's like a -10DB offset and it sucks.
Error: No RPU found
Then something is odd about your file. Which movie is that?
Also, did you try with other movies?
DoVi_Scripts
Old 28th May 2024, 12:13   #333  |  Link
Fuso
I see, so it's better to stick to default 1024.
1024 for 7.1 is still better than 640 for 5.1
1024 / 8 = 128kbps
640 / 6 = ~106kbps
Old 28th May 2024, 12:17   #334  |  Link
Kuler087
Kuler087's Avatar
You can set it to 1536 and it will work for 5.1 audio.
DoVi_Scripts
Old 28th May 2024, 23:14   #335  |  Link
smaiderman
It is Godzilla minus one. The UHD from the full collection.
Can it be a problem while exporting the mkv from the blu-ray disc?
Do you have any tip about a "proper" way to do it?
I didn't try with any other movie. This was my first attempt regrading
Thanks again
Old 29th May 2024, 12:02   #336  |  Link
Kuler087
Kuler087's Avatar
Thanks again
Ah, that explains it. This movie is strangely authored and cant be processed in Dovi_scripts. You can try to demux the hevc stream from the original M2TS file and do everything manually in resolve
1024 / 8 = 128kbps
640 / 6 = ~106kbps
I've added a workaround in the DEE (8-1-3) workflow and it should now produce the same quality as 8-1-1 but at 7.1 channels + 1536kbps bitrate.
It turns out, my AVR (and many others) can't disable the Dialogue Normalization of DDP tracks.
DoVi_Scripts
Old 29th May 2024, 13:52   #337  |  Link
smaiderman
[QUOTE=Kuler087;2002322]Ah, that explains it. This movie is strangely authored and cant be processed in Dovi_scripts. You can try to demux the hevc stream from the original M2TS file and do everything manually in resolve
I'm going to watch the video, but the leading problem that made me discover your tool, was because daVinci studio can't import the hvec extracted from the bluray. (I use mkvtoolnix to extract the heck video file). But daVinci refuses to read that hevc
Thanks again
Old 29th May 2024, 14:15   #338  |  Link
Kuler087
Kuler087's Avatar
Thanks again
Your video must be in a mkv or mp4 container for Resolve to see it but don't do that, Resolve has poor hevc decoding. You must convert it to prores 422 like the tutorial if you want frame-accurate results.
Also I heard mkvtoolnix is not prrocessing this movie correctly, it will fail to play on the Ugoos and Shield. If you demux the original M2TS with tsmuxer, you should be able to extract the DV metadata for Resolve 100nits SDR delivery.
DoVi_Scripts
Old 29th May 2024, 21:03   #339  |  Link
Fuso
Thank you! I will try it...
Old 30th May 2024, 17:07   #340  |  Link
smaiderman
Hi. Im trying to follow the tutorial, and I have some news.
Regarding your suggestion to use TsMuxer, your software instantly closes as I try to drag and drop the file obtained with TsMuxer, and I think that this happens because there is a step missing: converting the prores.mov to MKV.
Can you suggest a way to do this avoiding MKVtoolnix?
Davinci can importe the proress file, but I cant make the neccessary steps involving Dovi_tools
Thank you!
batch scripts, dolby vision processing, dovi_scripts
