Old 30th April 2024, 15:49   #281  |  Link
Kuler087
Kuler087's Avatar
Yes, except that I'm still using an old 20.5 build because I have some movies that won't resume in v21.
DoVi_Scripts
Kuler087 is offline   Reply With Quote
Old 30th April 2024, 17:13   #282  |  Link
jayper
Thank you so much!
jayper is offline   Reply With Quote
Old 30th April 2024, 18:27   #283  |  Link
Balthazar2k4
Is it possible to batch process the 8-2-3 ProRes workflow? I would like to queue up some titles to convert to ProRes overnight so that I can run them through Resolve that next day.
Balthazar2k4 is offline   Reply With Quote
Old 30th April 2024, 19:00   #284  |  Link
Kuler087
Kuler087's Avatar
You can use Staxrip for that. Here's my prores template: https://drive.google.com/file/d/1KUs...ew?usp=sharing
Put it in StaxRip\Settings\Templates
DoVi_Scripts
Old 30th April 2024, 19:03   #285  |  Link
Balthazar2k4
Awesome! Much appreciated! I'll give it a try.
Old 1st May 2024, 01:14   #286  |  Link
jayper
When you want to create a ST-DL MKV from a disc with FEL/MEL, what process do you recommend? Rip with MakeMKV, or with MKVToolNix? I am particularly curious about discs with seamless branching? I used to demux everything with TSMuxer first, now I am not so sure if there's a better/recommended route.
Old 1st May 2024, 02:12   #287  |  Link
Kuler087
Kuler087's Avatar
I've always used tsmuxer to demux the audio from seamless branching discs. Then mkvtoolnix to mux the video + demuxed audio + subs.
dgdemux or the latest eac3to might be even better, I don't know but I never had issues using tsmuxer on my x800m2. So far so good on the Ugoos but I'm not sure if I've watched a SB rip yet.
DoVi_Scripts
Old 1st May 2024, 02:24   #288  |  Link
jayper
Thanks, appreciate the response and the perspective. I'll give that a try. I also had great luck with tsmuxer and my Oppo, so I was inclined to stick with it.
Old 2nd May 2024, 18:15   #289  |  Link
jayper
The only times I generate DV for a movie that has retail DV are:
1- static L1 and L2. (Static L1 + dynamic L2 is fine.)
2- P5 web-dl is a different grade and cant be injected into the bluray
3- The original DV was done in cmv2.9(2.5nits avg floor) without any manual trims
4- if the bluray is cmv2.9 MEL and web is 4.0, I injected the web metadata like in: Aquaman and the Lost Kingdom, Migration.2023, Wonka.2023, The.Hunger.Games.The.Ballad.of.Songbirds.and.Snakes.2023
Why? because cmv2.9 content has crushed/clipped black and cmv4.0 does not. It also has better tone mapping.
PS Ugoos AM6B+ has arrived and looks VERY promising: https://www.youtube.com/watch?v=4QUURfLy5ew
I'm guessing that all the Star Wars D+ shows fall into this camp. Spot-checked a few Andor episodes and it looks like static L2. Thinking about generating DV using cm4.0 and the newly released discs.
Old 2nd May 2024, 20:06   #290  |  Link
Kuler087
Kuler087's Avatar
No, Andor is not static, at least not in this episode:
DoVi_Scripts
Old 2nd May 2024, 20:11   #291  |  Link
jayper
OK, good to know. I was clearly looking in the wrong place. Thanks!
Also, curious to know if this warning is anything to be concerned with:
plugin_manager: ←[33;1mWARNING←[0m ←[Kplugin does not contain dlb_plugin_file_io_init_v1
Old 2nd May 2024, 20:32   #292  |  Link
Kuler087
Kuler087's Avatar
You can ignore it.
DoVi_Scripts
Old 2nd May 2024, 21:19   #293  |  Link
jayper
Thank you so much!
Old 4th May 2024, 03:47   #294  |  Link
TheHooligan95
sometimes ffmpeg gives me (running the script in 4-1 mode), during the first part of the process:
Application provided invalid, non monotonically increasing dts to muxer in stream 0: (number)>=(number)
It seems to depend on sync issues of the source (framerate?). The result will infact have audio and subtitles out of sync with the video, which will anticipate the audio and the subs. Asked on ffmpeg irc and almost got laughed at, they told me that it would be much easier to make dovitools better than to make ffmpeg fix this
TheHooligan95 is offline   Reply With Quote
Old 4th May 2024, 04:21   #295  |  Link
Kuler087
Kuler087's Avatar
You can disable ffmpeg piping when it causes issues.
line 171
set ffmpeg_pipe=YES
DoVi_Scripts
Old 5th May 2024, 11:48   #296  |  Link
TDS
Formally known as .......
TDS's Avatar
Strange behaviour..
Hi Reset,
I updated to 2.0.5, and downloaded the newer tools.7z, etc, yesterday, got everything sorted out (didn't want to overwrite anything in the 2.0.3 folders.
And it's performing well, but I just wanted to tell you of a strange thing that happened when attempting a 5 minute chunk with 8-5 (I think)...
I had 4 movies I wanted a chunk of, and this one movie "Kate & Leopold", threw up some really strange errors msg's, and would fail...
Part of the error msg was Leopold, so I changed the name, and it showed the same error, so I shortened the name even more, same msg, so I decided to run it thru MKVToolNix, stripped out everything I didn't want, the error msg was not displayed, and I got my chunk....so there must have been something DS didn't like.
BTW, is there a simple way to change the 5 minute chunk to something a little shorter, like 2 minutes ??
Cheers
Long term RipBot264 user.
RipBot264 modded builds..
*new* x264 & x265 addon packs..
TDS is offline   Reply With Quote
Old 5th May 2024, 12:51   #297  |  Link
Kuler087
Kuler087's Avatar
The only change is the mkvtoolnix files are in a separate folder so you probably had the same MSG in the previous version. You can provide a sample and I'll have a look.
You can change the 8-5 sample timestamp at line: 125
:: choose the timestamp for the sample maker workflow (8-5) (default=5m)
set timestamp=00:00:00-00:05:00
DoVi_Scripts
Old 5th May 2024, 14:13   #298  |  Link
TDS
TDS's Avatar
Yes, I'm sure I would have had the same error...this movie in question had many subtitles..it must have something to do with one of them...problem has been solved, I don't really think there's any need to provide a sample..unless you really want one !
I'd have to do it MKVToolNix.
for the tip on the chunk size
Old 6th May 2024, 18:32   #299  |  Link
jayper
Did you install avisynthplus?
https://github.com/AviSynth/AviSynth...3_20230715.exe
If it's for a profile 5 webdl, your GPU must support Vulkan.
Sorry, all is well. I mistakenly had a space in my new install folder location. I deleted my prior comment, hoping that you wouldn't have seen it.
Old 9th May 2024, 14:51   #300  |  Link
jayper
Sorry to ask this here, but I haven't been able to find a clear answer on the CoreELEC forums. For the Ugoos AM6b+, I understand that the device hardware is fixed at outputting a rec709 flag.
But there are two options presented to change this via ssh:
echo Y > /sys/module/hdmitx20/parameters/dovi_tv_led_no_colorimetry
echo Y > /sys/module/hdmitx20/parameters/dovi_tv_led_bt2020
I have an older TV, TCL 65R617 (2018 Model), is it best to send out no colorimetry flag? Or send bt2020? It sounds like newer TVs it doesn't matter, but I was curious if you had thoughts on this? Appreciate your time!
batch scripts, dolby vision processing, dovi_scripts
