Old 12th October 2022, 13:45   #181  |  Link
excellentswordfight
Lost my old account :(
Originally Posted by HD MOVIE SOURCE View Post
When it comes to encoding like this as though its for ststreaming, you mayas well use 250 or is it 260 keyint right to reduce the impact even on iframes right? I downloaded Ben's encodes and they look very good for having a 1 Mbps target bit-rate. I actually didn't think it was possible to get video this acceptable with bit-rates that low.
No, cause that will impact seeking and abr-switching. 2-4s interval is usually whats recommended for dash and hls streaming. The restrictions/scenario is very streaming-centered, as it imo should, as that is the biggest real life scenario for low-bitrate encoding. 5s (120=24*5) is already stretching this a bit, i've not seen a lot of GOP encodes going above 4s (or 120f). Broadcasters is usually in the 1-2s range (I also think thats what recommended by DVB partly cause its affect on channel switching). So in the real world it basically only for private use were large GOPs are used (like the common 10s GOP limit). Not sure though how its in the realm of extreme low bitrate cases like video-conference etc.
From what i've seen is that the compression gain starts to flat out after about 4s, but were going from 1s to 2s can make a rather noticeable impact.
excellentswordfight is offline   Reply With Quote
Old 14th October 2022, 17:17   #182  |  Link
benwaggoner
I gues the biggest thing here is keeping the bit-rate low, but having enough buffer than upon a scenecut, there's enough buffer to give that scenecut enough bits so artifacts are kept at bay. This is definitely something that Physical Media has issues with and can be improved with streaming because of the one second buffer on discs.
Yeah, my encodes are also a few years old. I could do them even better today. We get year-on-year improvements with existing codecs based on better code and better understanding of tuning. Then big step-change improvements with new codecs.
Today we can do a decent 1440p HDR with 2 Mbps ABR. When I started encoding, 2 Mbps got me a lousy looking 240x180 12 fps with 8-bit 11 KHz mono audio in QuickTime 1.0. Which wouldn't even play well off a (forthcoming) 1x CD-ROM. Like many Moore's Law dependent technologies, it's pretty amazing how what seemed like science fiction five years earlier is best practices today.
Higher keyint values are a tradeoff between random access speed (worse) and compression efficiency (potentially improved). I picked 96 for this test as a pretty common value, and less than some longer shots so we could see how the encoder handles a new GOP mid-shot, where visual discontinuities can happen.
To make sure there's enough VBV for IDRs, using 2-pass encoding or a lot of lookahead are key. For x265, setting --rc-lookahead = --keyint can reduce quality fluctuations significantly. Uses a lot of RAM, though! I was doing some 8K encoding a few days ago where a single x265 process was using about 40 GB.
Ben Waggoner
My Compression Book
Old 14th October 2022, 17:26   #183  |  Link
benwaggoner
I've certainly seen 5 sec segments in DASH, and HLS originally recommended 10 sec per segment. It's a tradeoff between efficiency and ABR switching latency. Longer segments are easier to get away with in VOD since the client can download them faster than realtime. Live needs shorter segments as one can't download fragments (or sub-fragments) that haven't been encoded yet.
Yeah, 3-5 has been a pretty safe bet for a couple of decades now. I've used up to 20 sec before for special cases, like simple animations that don't require random access. Some years back I was able to get some of the Kindle Fire preloaded intro videos down to 100 Kbps 1080p24 HEVC with that and other content-specific tuning.
Ben Waggoner
My Compression Book
Old 15th October 2022, 19:16   #184  |  Link
excellentswordfight
I've certainly seen 5 sec segments in DASH, and HLS originally recommended 10 sec per segment. It's a tradeoff between efficiency and ABR switching latency. Longer segments are easier to get away with in VOD since the client can download them faster than realtime. Live needs shorter segments as one can't download fragments (or sub-fragments) that haven't been encoded yet..
Oh, I dont doubt that its used! And as someone that comes from a broadcast-background and are mostly involved with live encoders 4s is already rather high for me And most VOD content i've come across has used 2 or 4s, but vod-streaming as an interest is relatively new to me.
But gop length and segment size are different things, no? Gop size doesnt have to be the same as the segment length as long as the IDR-placements fits the segments or have i missed something? Current Apple HLS recommendation is 2s for the gop size and 6s for the segment afaik.
Old 16th October 2022, 21:58   #185  |  Link
benwaggoner
Correct, one can have multiple GOPs in a single segment. HLS famously recommended 3 second GOPs in 10 sec segments, for example. But, but 3*3<>10 I said! Never really found out the "why" of that
That said, most adaptive streaming targets H.264 or HEVC, which support non-IDR I-frames. Those are fully intra coded frames, but don't preclude a frame after it referencing a frame before it. There's no practical downside to using those inside a GOP, and some minor upsides, so generally things are encoded with an IDR at the start of every fragment, and a non-IDR I-frame for any natural keyframes inside that segment.
An advantage of this approach is that a packager doesn't have to figure out which IDRs are at segment boundaries and which ones aren't. A non-IDR I doesn't have to carry the once-per-GOP metadata. And if the I-frame is just a single flash frame like a strobe light, the frames after can reference the frames before, which can save a whole lot of bits (it's the same reason that VC-1 had intra-only B-frames (BI frames) to substitute a flash frame that would otherwise be coded as a P-frame).
Ben Waggoner
My Compression Book
Old 21st October 2022, 10:56   #186  |  Link
HD MOVIE SOURCE
HD MOVIE SOURCE's Avatar
Yeah, I encoded Big Buck Bunny at 60 frames per second and it used a lot more RAM. I've had a few encodes just stop because of it so I upgraded my RAM and I've never had any issues with that anymore.
So, I encoded Tears of Steel with your advice, on buffer and maxrate and it came out to a hair over your bit-rate on your file so I was happy. It looked much better. But, I kept the restrictions as though it was a 4K Blu-ray, just for science. I might upload it into my Google drive if you want to take a look.
Just wondering, do Blender even post fully uncompressed open movies, that haven't already been encoded? I'm currently encoding all of their open movies, but most are MP4s, and tears of steel got a DCP which was really nice. I re-scale mine, because 4K Blu-ray doesn't use the max 4K it uses 3840x2160p, so it downscales, and then you add borders get the pixels back to 2160p. I notice that a lot, even on their other open movies, they use strange resolutions most of the time. If they're not originally 4K I upscale them, which I've found doesn't look as poor as I originally thought upscaling would look. I've seen some poor upscales on 4K Blu-ray and just always assumed it must be because they upscaled from 2K, but I've found it to be quite good.
I noticed on the spears on munsil Blu-ray, it had Big Buck Bunny at 30 frames per second and the version was different it had the opening logo when looking at the tree at the start. The 4K version I use doesn't show the title at the tree scene of Big Buck Bunny. And, the 4K version, the original file has banding in a few scenes, whereas the spears and munsil Blu-ray version did not have that. So I looked around and could not find that version. So, I wonder if they got a special version? I contacted Blender and asked if they had listings for all their movies un-encoded, completely uncompressed, but weren't really that helpful. I subbed to their website to get access to a few more open movies, and support their work. I watched my encoded version and against the original file, and both had the banding in the same spot. It's hard to see if you're not like me (I'm crazy lol), but it's there.
I like what Netflix has done with SolLevante, its completely uncompressed, that turned out absolutely perfect with HDR too. I wanted to put dolby atmos audio on the encode too, but they provided a completely uncompressed atmos track that needed to be encoded. I couldn't believe how big just the audio file was. Its like 110Mbps LOL, just for audio. So, I had to use the 5.1 track, which I converted to AC3 at 640kbps. I think I'd need a special Dolby encoder to encode the audio, which is way out of my league.
I encoded sprite fright and that came out really well. As long as the source is clean even though they've encoded it, it will come out good, but I wish they did a prores or MOV files just so I could sleep better at night LOL.
So, your encodes used the DCP for tears of steel right? Thats the one I used, then I muxed the 5.1 audio to it, turned out really nice in the end. I don't like the grain structure they used though. It's blurry, and inconsistent. I checked the source file and it's imperfect on the source too. You can see this on the credits, the grain that they're using isn't a fine grain, its almost noisy.
Just realized Ive been talking a bit too long now, LOL Thanks for listening.
HD MOVIE SOURCE is offline   Reply With Quote
Old 22nd October 2022, 23:54   #187  |  Link
benwaggoner
Blender seems to be paywalling the sources for their newer titles for subscribers. Even for the older ones, there have been a variety of different versions, some added years after the original.
IIRC, my ToS came from a 4K high bit TIFF image sequence. Also, the 60 fps Big Buck Bunny came out some time after the original 24p render. BBB is a fun clip, but it is also pretty absurdly easy to encode, so I don't like to use it for encoding tests.
Now that StEM2 is out with free source downloads, I imagine that's going to be the most popular encoder test clips for years to come. They did a great job of including all sorts of elements that can stress all sorts of compression, image processing, and display processes. It's available in full 2020 PQ HDR, 709, up to 8K, etc. https://theasc.com/asc/stem2.
It's absolutely what I'd use for an updated version of this test today.
Ben Waggoner
My Compression Book
Old 24th October 2022, 19:20   #188  |  Link
excellentswordfight
Wow, that looks amazing! Thanks for sharing the link. Very nice to have both HDR & SDR masters as well.
Before I start downloading do you know the specs of the IMF packages? "lossy HDR App 2E" is twice the size of "lossy SDR App 2E", is the SDR 1080p and hdr 2160p? I think Im going to create a 1080p h264 bluray compatible SDR-version and one 2160p h265 uhd-bluray compatible HDR10-version if I need something leaner and to use as bluray-reencode simulations and tuning, and Im thinking what versions would be best to use as sources.
Old 24th October 2022, 21:09   #189  |  Link
benwaggoner
I've not looked at the DCP packages yet. I've just started playing with the DNxHD QuickTime.
Note that SDR is available in two different aspect ratios.
Ben Waggoner
My Compression Book
Old 9th November 2022, 07:52   #190  |  Link
HD MOVIE SOURCE
I'll check that out thank you. Are there any 4K UHD prores The Rings of Power trailers? I'd like to see how close to the stream quality I can get. Trailers are generally quite busy so more bit-rates are needed for high scene-cut segments. I think it would be a good test also.
Old 15th November 2022, 05:37   #191  |  Link
HD MOVIE SOURCE
I've encoded the 4K version of StEM2 twice now and at 5 mins and 08 seconds, there seems to be some digital artifact. It is a line that goes across the top portion of the screen for half a second and disappears. I've encoded it twice and its in the same place. I think it could be an artifact with the file itself. I think what I'll do is download the 4K DCP file and see if that file has corrected the error.
I downloaded the 126GB file.
Do they have a contact? Ill see if I can shoot them an email about it.
Old 15th November 2022, 09:14   #192  |  Link
excellentswordfight
I noticed it as well, its present in all versions, It doesnt look like an re-encoding issue tbh, more like a glitch during capture. But its strange that it wasnt noticed and fixed in post...
Old 16th November 2022, 01:05   #193  |  Link
benwaggoner
Certainly none that are available to the public!
Also for the newly updated --hist-scenecut algorithm.
Ben Waggoner
My Compression Book
Old 21st November 2022, 06:33   #194  |  Link
HD MOVIE SOURCE
Interesting, so what has changed for --hist-scenecut algorithm? Scenecuts are something I honestly haven't played around with, is there anything that could help with keyint=24 BD content? Making scenecuts hold higher bit-rates or anything like that?
Old 21st November 2022, 06:36   #195  |  Link
HD MOVIE SOURCE
Very strange, we noticed it on first viewing, was really easy to spot. If it was a capture issue, couldn't they have blurred or managed it somehow is post?
I've checked multiple versions and they all contain the glitch.
Old 20th December 2022, 18:44   #196  |  Link
Forteen88
Herr
Today I did a new encode with SolLevante_SDRv2_1080p24_8bit.y4m as video-source.
My encode filename is SolLevante_SDRv2_1080p24_8bit_out(MC-HEVC10,24fps,Aspect16-9,ColorRange-Full,2pass,PQ30,target1000,max4000,AdaptiveBFramePlacement).mp4
Using MainConcept TotalCode Studio 5.30 (which uses MainConcept H.265/HEVC video encoder Version: 12.2.0.3600)
MC-HEVC10 Main 10(Main 10)@4.1 (standard settings except I enabled "Adaptive B-Frame Placement"). 24fps, Aspect16:9, ColorRange-Full, 2pass, PQ30 (which is maximum quality but longest encode-time). Only the default 7 B-Frames.
Target Bitrate: 1000kbps
Max bitrate: 4000kbps
https://www.sendspace.com/file/na8jbn
I see lots of blockings, like in BenWaggoner's x265-encode.
EDIT: Oh, I also see now that I should've used 8bit, not 10bit in this challenge, but I think that more people here are interested in 10bit-encodes.
BenWaggoner wrote: "This specific test is 8-bit specific, mainly because comparing 8-bit encodes is less fraught.
But a 10-bit HDR test would be an obvious next step. Perhaps with Sol Levante."
Also, shouldn't have set color range to FULL (which was the default in TotalCode Studio), I should have set it to "Clamped" (aka "Limited"). MSU Video Quality Measurement Tool doesn't allow different color range videos to be compared.
Forteen88 is offline   Reply With Quote
Old 22nd December 2022, 19:57   #197  |  Link
Forteen88
Herr
Sol Levante's 4K HDR source is available under Creative Commons, from which I derived an 8-bit SDR 1080p .y4m, as 8-bit SDR playback and testing is still a lot more available.
I've kicked off a 1000 Kbps test encode with x265 for reference that I should post tomorrow.
How come the Sol Levante's 4K HDR source is 4:23 minutes long but that x265-encode of it is only 4:01 minutes long?
Old 9th February 2023, 12:04   #198  |  Link
DTL
With all the talk about VP9 and AV1 and VVC and different encoder implementations for all of them, I thought it might be fun to set up an open challenge for folks to deliver the best possible quality for each.
To that end, in a semi-inebriated late-night conversation at IBC, we defined a scenario relevant to some important real-world scenarios that reasonably stress current encoders.
  • No preprocessing
As for the 'real-world' moving pictures content physically damaged by 'real physics' photon shot noise it is no good to limit 'preprocessing'. And it significantly limit 'compressability' of moving pictures content.
As we see with AV1 encoder it may internally apply 'very slight' denoise of about 3..5 averaging frames and 'massive beat' HEVC in compression tests to xx% .
But if allow to make preprocessing - the total challenge is turned in comparison of quality of denoiser+MPEG pair.
As I see modern video cameras to get 'real world' images have good progress of 'internal denoisers' so the world of broadcasting really moves to this direction. When you buy new set of video cameras with lower noise to your studio with less noise you also got great benefit to the quality of the compressed by MPEG encoders content for broadcasting. But it may be also simulated by (much cheaper) denoise hardware unit before your master MPEG coder. Or even software of zero price if you make software file-based processing and use software MPEG encoder.
Also internally both temporal denoiser and MPEG encoder based on the same ideas of motion tracking (block or object based) so may use same hardware to make motion estimation (and may be MPEG encoder may reuse motion estimation from denoiser). May be it is already implemented in modern codecs after HEVC - like in AV1.
So the 'preprocessing' between real world and MPEG coder is really essential part of total moving pictures compression process. To remove 'real world' random data and to clean really required visual information about scene from random noise of intermediate scene-view transfer media of photons flux.
The inter-frame 'denoiser' simply simulate video camera with more accumulating time per each scene object in compare with 'primary scene frame-based' camera. Primary camera (if not using internal interframe digital denoise) is limited to inter-frame time interval to accumulate photons. Also can not perform individual scene objects trackng.
The 'motion compensated denoiser' can extend accumilating time to about total visibility time of the object in the cut-scene and perform individual tracking if each scene object is not static relative to the primary video camera. So it simulates massive array (equal to the blocks number in blocks-based denoiser) of 'secondary video cameras' with individual tracking and much more extending data accumulating time without motion blur.
And after this 2-stages physical + simulated secondary video cameras scene data transform you got more clean scene data to MPEG encoder and pass it to simple enough MPEG encoder and got better output quality because MPEG can now spent more bits to the real scene objects encoding and not to residual noise encoding after non-complete motion compensation of nosied blocks.
Old 10th February 2023, 22:59   #199  |  Link
benwaggoner
--hist-scenecut is supposed to do better scene cut decisions, so it would help in that regard. I've not heard much positive feedback that it does so, particularly in pre-3.5 implementations.
--scenecut-aware-qp would be of more specific interest, as it will save some bits around natural scene cuts where the big temporal discontinuity will mask small ones for a few frames. I've not experimented with it much myself, but the idea is certainly sound.
Ben Waggoner
My Compression Book
Old 11th February 2023, 10:15   #200  |  Link
Boulder
Pig on the wing
Boulder's Avatar
--hist-scenecut definitely works better than the classic mode in 8-bit encodes and 10-bit HDR encodes which are not black and white.
