Old 30th September 2015, 05:39   #3541  |  Link
Zachs
Suptitle, MediaPlayer.NET
Originally Posted by Anima123 View Post
Just files with video encoded as WMV2 (Windows Media Video 8) as mediainfo reported.
Perhaps you installed the new LAV filters?
Zachs is offline   Reply With Quote
Old 30th September 2015, 05:45   #3542  |  Link
Anima123
Yes, the latest 0.66 one, with which other players, like mpc-hc work well.
Anima123 is offline   Reply With Quote
Old 30th September 2015, 06:11   #3543  |  Link
Zachs
I tested the wmv file you sent me via PM and that one worked fine. Can't tell if it's WMV2 though.
EDIT: Looks like all the wmv files I have are WMV3.
EDIT2: Is MPC-HC using LAV Source Splitter of the same version and not the internal one? Also make sure it isn't using any other source filters.
Old 30th September 2015, 06:17   #3544  |  Link
Anima123
Just sent you a sample via pm.
Old 30th September 2015, 06:21   #3545  |  Link
Zachs
Works fine.
Old 30th September 2015, 06:24   #3546  |  Link
Anima123
You're right, mpc-hc is using 'WM SF Reader' as splitter. I don't know how to force it to use LAVSplitter though.
Old 30th September 2015, 06:25   #3547  |  Link
Zachs
Using the latest LAV Filters, your sample clip works fine for me with MPDN. Something is causing LAV Source Splitter to refuse decoding the file on your system.
Old 30th September 2015, 06:31   #3548  |  Link
Anima123
It's strange, only this particular file has this problem. Other same encoded files do not.
Old 30th September 2015, 08:07   #3549  |  Link
Zachs
Might want to ask in the LAV filters thread instead.
Old 30th September 2015, 08:18   #3550  |  Link
burfadel
Try out this post-0.66 build and see if it still happens:
http://files.1f0.de/lavf/nightly/LAV...-0.66.0-12.exe
Old 30th September 2015, 09:33   #3551  |  Link
Shiandow
Might also be a good idea to make sure that "wmv" is selected in the input formats tab of the LAV splitter settings.
Old 30th September 2015, 14:14   #3552  |  Link
aufkrawall
Good news, with build 3475 playback is fine again with FM.
Did you have to roll anything back, or did you find a better way?
Edit: What I've noticed: Is it intended that MPDN doesn't show the frame you jump to when moving the seeking slider, unless playback is resumed?
Old 30th September 2015, 14:24   #3553  |  Link
Zachs
Partially reverted. I did find the problem but the newer method wasn't as smooth as the old one so done parts were reverted.
Old 30th September 2015, 17:39   #3554  |  Link
aufkrawall
That build doesn't render PNGs or this video file:
http://www.mediafire.com/download/fr...eg01f/files.7z
I guess the problem with the video file might be that it contains too few frames (less than fps).
Old 1st October 2015, 00:05   #3555  |  Link
Zachs
Ah yes that one will be fixed for proper release.
Old 1st October 2015, 07:40   #3556  |  Link
edison
Could you tell me where the settings of MPDN saved? I want to reset the config of MPDN?
edison is offline   Reply With Quote
Old 1st October 2015, 08:44   #3557  |  Link
Zachs
%localappdata%\MediaPlayerDotNet
Old 1st October 2015, 09:02   #3558  |  Link
cca
Anime Otaku
I had a try of this player, decent enough for 23p/24p content but cannot get smooth playback with 29.97p content, it just stutters no matter what option I select for rendering. Refresh rate is 60Hz, tried with and without fluid motion, tried DirectX9 and 11, no difference. Very strange. Not using render script, just normal scaling options at default.
Sent from my Nexus 9 using Tapatalk
AMD FX8350 on Gigabyte GA-970A-D3 / 8192 MB DDR3-1600 SDRAM / AMD R9 285 with Catalyst 1.5.9.1/ Asus Xonar D2X / Windows 10 pro 64bit
cca is offline   Reply With Quote
Old 1st October 2015, 09:04   #3559  |  Link
Zachs
Originally Posted by cca View Post
I have a try of this player, decent enough for 23p/24p content but cannot get smooth playback with 29.97p content, it just stutters no matter what option I select for rendering. Refresh rate is 60Hz, tried with and without fluid motion, tried DirectX9 and 11, no difference. Very strange.
Are you sure FluidMotion is actually enabled? By default it is deactivated for 29p on 60Hz.
Old 1st October 2015, 09:07   #3560  |  Link
cca
Anime Otaku
I know, so I changed the option myself to try with it. The result is the same, the video has stuttering, playback is not smooth and the stutters very noticeable.
On the same PC, MPC+madvr do not have any issues, so I do not think it's my drivers or something PC specific.
direct3d, mpdn, nnedi3, opencl, reclock
