25th September 2017, 05:14 | #45961 | Link | |
Finally!! It was working for me all the time, so I had a hard time understanding why it failed for everyone else... madshi is offline Report Post [/QUOTE] Does that mean now I can go out to buy any AMD RX4xx/5xx card to enjoy HDR without any worry ? |
25th September 2017, 07:25 | #45962 | Link | |
The limited and full range options do not change the data format, 0-255 (8-bit) is always sent, the only difference is if the range is compressed or not. If you need the double compression your TV is using bad settings or has terrible black crush. Try out the levels test patterns AVS-HD 709, they help with understanding what your TV is doing.
madVR options explained |
25th September 2017, 09:05 | #45963 | Link | |
Win11 Pro x64 b23H2 Ryzen 5950X@4.5Ghz 32Gb@3600 Zotac 3090 24Gb 551.33 madVR/LAV/jRiver/MyMovies/CMC Denon X8500HA>HD Fury VRRoom>TCL 55C805K |
25th September 2017, 09:30 | #45964 | Link | |
Note that there are 2 places in mpc-hc where you can set sub position. Other question: can madvr output mvc 3d to 2 output like stereopistic player can? My friend has a dual projector setup. Thanks
Ryzen 5 2600,Asus Prime b450-Plus,16GB,MSI GTX 1060 Gaming X 6GB(v398.18),Win10 LTSC 1809,MPC-BEx64+LAV+MadVR,Yamaha RX-A870,LG OLED77G2(2160p@23/24/25/29/30/50/59/60Hz) | madvr config |
25th September 2017, 09:46 | #45965 | Link | ||||||||||||
I can say with 100% reliability that setting both the GPU control panel *and* madVR to 16-235 ("limited") is definitely an incorrect setup and will never produce perfect results. If you guys get proper black & white levels only by setting both the GPU control panel and madVR to "limited" then something somewhere is totally screwed up. Because as Asmodian explained, in this situation the HTPC would output black as 30. Maybe your TV settings are screwed up. Or maybe your GPU has an invalid calibration GPU gamma ramp installed. Or something else. Quote:
You mean sending the left eye to one screen and the right eye to another screen? No, that's currently not supported. |
25th September 2017, 10:20 | #45966 | Link | ||
The only test patterns I understood how to use and tested on are for checking the dynamic range here: https://referencehometheater.com/201...ll-vs-limited/ and here http://www.neogaf.com/forum/showthread.php?t=1248012 Are you talking I should find something different in AVS the Forum? Sorry, but I really do not know what to do, I know very little about calibrating. Quote:
How it does? Am I not understanding your FAQ correctly? |
25th September 2017, 10:31 | #45967 | Link | |
The FAQ explains what happens in the background, and which effect setting the GPU control panel and madVR to 16-235 or 0-255 has exactly. As such it always applies, to any PC/situation. I'm not sure why you're getting incorrect black levels with a proper setup. There must be something wrong somewhere, but it's hard for me to analyze from a distance. Are you using a dedicated PCIe GPU? Or are we talking Laptop? Can you make screenshots of your Nvidia control panel (all pages related to TV and color setup) and upload them somewhere for us to look at? Please don't post the images in full in this thread, just post links to the images here. |
25th September 2017, 11:12 | #45968 | Link | |
Not to say that the GPU isn't doing anything else, but enabling the "send HDR metadata" in MadVR produces the same effect as switching the HDR on in the OS display property, so it would be good to see if something else can be done, for example looking at that PQ flag. I'll investigate and will let you know what we find.
25th September 2017, 12:15 | #45969 | Link | |
I'm on Windows creator update (not insider), gtx1070 and gtx1060, driver 385.69 |
25th September 2017, 12:24 | #45970 | Link | |
Is there any configuration in madvr where that setting touch the video range? Something like hardware upscaling If that setting is working then video range will be PC Levels and with gpu output to limited and display expecting limited ... range levels would be correct even if madvr is sending limited. |
25th September 2017, 13:26 | #45971 | Link | |
No worries
25th September 2017, 14:52 | #45972 | Link | |
Haven't tried scaling with DVD to 4K yet with this card. *Win7, latest Crimson stuff, JRiver MC x64
Win7Ult || RX560/4G || Ryzen 5 |
25th September 2017, 15:40 | #45973 | Link | |||
The links below contain albums with the settings you requested, if you need more or missed something let me know and I will post it ASAP. The ones relating to the TV are in order, so if an option is highlighted in a screenshot the next image is that option's settings, otherwise there is a description on the top left corner. NVIDIA CP: https://imgur.com/a/VXouP TV: https://imgur.com/a/DtNcO |
25th September 2017, 15:45 | #45974 | Link | |
Btw, which NGU have you tested, NGU AA, NGU Standard or NGU Sharp ? |
25th September 2017, 15:57 | #45975 | Link |
Finally am home and was able to do some more testing of my equipment. So for me, my Panasonic plasma certainly "allows" limited and full, even on 3D playback. However, for 3D, it *MUST* receive limited in order for playback to be correct. If I use full, and I tested this on my xbox one just to be sure it wasn't something screwy with my HTPC, it will "ghost" the background. At least I can rule out the HTPC as being the problem. As I said, limited->full->limited works fine for me and your explanation of what's happening in the FAQ with those settings works for me. I may experiment with setting the TV to auto and using a profile to set madvr to full for all non-3D content and limited for 3D and see if that works.
25th September 2017, 16:00 | #45976 | Link |
I've tried to read few pages back but maybe I missed something, it seems like my LAV Video cannot see my GPU under "active hardware accelerator" no matter if I use native or copy-back, the result is always "none", I used to see it just a while ago before update madVR to 0.92.3, is it something related to madVR by the way?
I updated today to 0.92.4, but I didn't pay attention if this happened also with the 0.92.3, sorry If I am asking something wrong, here's a couple of screenshot: https://imgur.com/a/AVpfD Last edited by yukinok25; 25th September 2017 at 16:02. |
25th September 2017, 16:52 | #45978 | Link | |
so the file is maybe incompatible |
25th September 2017, 17:02 | #45979 | Link | |||||
Looking at your TV settings screenshots, the most important setting is probably "HDMI RGB Range", which you currently have set to "AUTO". Have you tried different settings there? The "HDMI Content Type" settings in your TV also look like they could be related. Does changing that stuff do anything to your black and white levels? |
25th September 2017, 17:18 | #45980 | Link | |
I don't have a 4K/HDR screen currently and I have to give this machine up in a couple of days and the next build I do will most likely be with a Vega variant of some sort....I hope to have a 4K/HDR option available at that point (hopefully in a month or so).
