22nd September 2010, 15:19 | #8522 | Link |
--------------------------------------------------------------------------------- Format : BDAV Format/Info : Blu-ray Video File size : 17.4 GiB Duration : 1h 11mn Overall bit rate : 34.7 Mbps Maximum Overall bit rate : 48.0 Mbps Video ID : 4113 (0x1011) Menu ID : 1 (0x1) Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.1 Format settings, CABAC : Yes Format settings, ReFrames : 3 frames Codec ID : 27 Duration : 1h 11mn Bit rate mode : Variable Maximum bit rate : 33.3 Mbps Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate : 29.970 fps Standard : NTSC Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : MBAFF Color primaries : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177 Transfer characteristics : BT.709-5, BT.1361 Matrix coefficients : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177 Audio #1 ID : 4352 (0x1100) Menu ID : 1 (0x1) Format : PCM Format settings, Endianness : Big Format settings, Sign : Signed Muxing mode : Blu-ray Codec ID : 128 Duration : 1h 11mn Bit rate mode : Constant Bit rate : 4 608 Kbps Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 96.0 KHz Bit depth : 24 bits Stream size : 2.31 GiB (13%) Audio #2 ID : 4353 (0x1101) Menu ID : 1 (0x1) Format : AC-3 Format/Info : Audio Coding 3 Format profile : TrueHD / Core Mode extension : CM (complete main) Muxing mode : Stream extension Codec ID : 131 Duration : 1h 11mn Bit rate mode : Variable / Constant Bit rate : Variable / 640 Kbps Maximum bit rate : 6 840 Kbps / 640 Kbps Channel(s) : 6 channels Channel positions : Front: L C R, Side: L R, LFE Sampling rate : 96.0 KHz / 48.0 KHz Bit depth : 16 bits Text #1 ID : 4608 (0x1200) Menu ID : 1 (0x1) Format : PGS Codec ID : 144 Video delay : 2s 2ms Text #2 ID : 4609 (0x1201) Menu ID : 1 (0x1) Format : PGS Codec ID : 144 Video delay : 2s 2ms Text #3 ID : 4610 (0x1202) Menu ID : 1 (0x1) Format : PGS Codec ID : 144 Video delay : 2s 2ms Text #4 ID : 4611 (0x1203) Menu ID : 1 (0x1) Format : PGS Codec ID : 144 Video delay : 2s 2ms Text #5 ID : 4612 (0x1204) Menu ID : 1 (0x1) Format : PGS Codec ID : 144 Video delay : 2s 2ms Text #6 ID : 4613 (0x1205) Menu ID : 1 (0x1) Format : PGS Codec ID : 144 Video delay : 2s 2ms ==================================== Where is the mistake or what should I do to solve the problem ??? |
22nd September 2010, 18:28 | #8525 | Link | ||
22nd September 2010, 18:43 | #8526 | Link | |
The Black Reaper
I am sure many of the users can live with installing real alternative to use RipBot264 to encode .rmvb source until ffdshow supports .rmvb. Pretty please? |
22nd September 2010, 19:19 | #8527 | Link | |
command line: "C:\Program Files\Tools\eac3to\eac3to.exe" "C:\Documents and Settings\mustBeMe\Desktop\00006.m2ts" 1: "J:\temp\RipBot264temp\job1\video.mkv" -seekToIFrames 3: "J:\temp\RipBot264temp\job1\audio_Undetermined.thd.w64" -down16 -progressnumbers -log="J:\temp\RipBot264temp\job1\demuxlog.txt" ------------------------------------------------------------------------------ M2TS, 1 video track, 2 audio tracks, 6 subtitle tracks, 1:11:52, 60i /1.001 1: h264/AVC, 1080i60 /1.001 (16:9) 2: RAW/PCM, 2.0 channels, 24 bits, 96kHz 3: TrueHD/AC3, 5.1 channels, 96kHz, dialnorm: -27dB (embedded: AC3, 5.1 channels, 640kbps, 48kHz, dialnorm: -27dB) 4: Subtitle (PGS) 5: Subtitle (PGS) 6: Subtitle (PGS) 7: Subtitle (PGS) 8: Subtitle (PGS) 9: Subtitle (PGS) [v01] Extracting video track number 1... [a03] Extracting audio track number 3... [a03] Extracting TrueHD stream... [a03] Removing TrueHD dialog normalization... [a03] Decoding with libav/ffmpeg... [a03] Reducing depth from 24 to 16 bits... [a03] Writing W64... [a03] The libav decoder reported error -1 while decoding. <ERROR> [v01] Muxing video to Matroska... Aborted at file position 1048576. <ERROR> |
22nd September 2010, 20:51 | #8528 | Link |
Atak_Snajpera
Thank you to each one problem solved! but for some reason when I load in some movies RipBot program does not see the audio track? have to separately add an audio track! tell me how to make the program to see any audio tracks? |
23rd September 2010, 11:24 | #8529 | Link | ||
@benjyv update eac3to and try again. This is also weird Quote:
@lighto send me some .rmvb samples to www.mediafire.com
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 23rd September 2010 at 11:33. |
23rd September 2010, 14:16 | #8531 | Link | |
The Black Reaper
Thanks for accepting my request! It contains 2 sample, 1 with cook audio and 1 with raac audio. Hope it's not too much to ask, but do you mind adding this feature to the to-do list for future version of RipBot264? Last edited by Lighto; 25th September 2010 at 05:43. |
23rd September 2010, 17:09 | #8532 | Link | |
I've downloaded the new version of eac3to within C:\Program Files\Megui\Tools.... I've kept the old version too.... Scuze me , but I don't know how to update this soft All the time I had troubles with this soft or tell me how to check within Ripbot if the update was made..... Should I delete and re install Ripbot to take new updates into account ??? I'm a lil confused Thanks !! Last edited by benjyv; 23rd September 2010 at 18:34. |
26th September 2010, 05:56 | #8534 | Link |
How can I fix the audio of a damaged source
[v02] The MKV file was created without making use of the gap/overlap information. <WARNING> [v02] Please check whether audio is in sync. If it is in sync everything is fine. <WARNING> [v02] Otherwise ask eac3to to repeat the muxing. It will then automatically make <WARNING> [v02] use of the detailed gap/overlap information. <WARNING> [a03] Audio has a gap of 544ms at playtime 0:08:04. <WARNING> [a03] Starting 2nd pass... [a03] Realizing (E-)AC3 gaps... [a03] Creating file "M:\temp\RipBot264temp\job2\audio_English.ac3"... Added fps value (24 /1.001) to MKV header. Video track 2 contains 142787 frames. eac3to processing took exactly 5 minutes. Done. |
26th September 2010, 19:26 | #8538 | Link |
get the latest version from: http://forum.doom9.org/showthread.php?t=125966
extract contents to: RipBot264\Tools\eac3to |
27th September 2010, 07:45 | #8539 | Link |
When I installed last version of Ripbot it makes just 2 files : Ripbot.exe and Ripbot.ini....Where could be Tools ???
I've extract it into Megui\tools\eac3to...I hope will work , even it says that is a 2008 version Why is so old ??? Last edited by benjyv; 27th September 2010 at 08:00. |
27th September 2010, 13:36 | #8540 | Link | |
The Black Reaper
