Thread Tools | Display Modes |
#1701 | Link | |||
When the colorist does trim pass(es), those adjustments get baked into the base layer as well when encoding to P7. In some cases, the colorist raise the 100-nit SDR trim above the HDR master’s mid-range, which can result in the FEL appearing darker in comparison.
DoVi_Scripts //// Dolby Vision Stuff (more tabs below) LG OLED G5 77'' + 7.2.4 Denon AVR + Ugoos AM6Bplus + Kaleidescape Strato E Sorry for my English Last edited by Kuler087; 2nd February 2026 at 13:02. |
#1702 | Link |
Video ID : 1 Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main 10@L5.1@Main HDR format : Dolby Vision, Version 1.0, Profile 8.6, dvhe.08.06, BL+RPU, no metadata compression, Blu-ray compatible / SMPTE ST 2086, Version HDR10, HDR10 compatible Codec ID : V_MPEGH/ISO/HEVC Duration : 2 h 0 min Bit rate : 17.9 Mb/s Width : 3 840 pixels Height : 1 600 pixels Display aspect ratio : 2.40:1 Frame rate mode : Constant Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 (Type 2) Bit depth : 10 bits Bits/(Pixel*Frame) : 0.122 Stream size : 15.1 GiB (99%) Writing library : x265 unknown:[Linux][GCC 7.5.0][64 bit] 10bit Encoding settings : cpuid=1111039 / frame-threads=3 / numa-pools=8 / wpp / no-pmode / no-pme / no-psnr / no-ssim / log-level=2 / input-csp=1 / input-res=3840x1600 / interlace=0 / total-frames=0 / level-idc=51 / high-tier=1 / uhd-bd=0 / ref=4 / no-allow-non-conformance / repeat-headers / annexb / aud / hrd / info / hash=0 / no-temporal-layers / open-gop / min-keyint=23 / keyint=250 / gop-lookahead=0 / bframes=4 / b-adapt=2 / b-pyramid / bframe-bias=0 / rc-lookahead=25 / lookahead-slices=4 / scenecut=40 / hist-scenecut=0 / radl=0 / no-splice / no-intra-refresh / ctu=64 / min-cu-size=8 / no-rect / no-amp / max-tu-size=32 / tu-inter-depth=1 / tu-intra-depth=1 / limit-tu=0 / rdoq-level=1 / dynamic-rd=0.00 / no-ssim-rd / signhide / no-tskip / nr-intra=0 / nr-inter=0 / no-constrained-intra / strong-intra-smoothing / max-merge=3 / limit-refs=3 / no-limit-modes / me=3 / subme=3 / merange=57 / temporal-mvp / no-frame-dup / no-hme / weightp / no-weightb / no-analyze-src-pics / deblock=-3:-3 / no-sao / no-sao-non-deblock / rd=4 / selective-sao=0 / no-early-skip / rskip / no-fast-intra / no-tskip-fast / no-cu-lossless / no-b-intra / no-splitrd-skip / rdpenalty=0 / psy-rd=1.00 / psy-rdoq=3.00 / no-rd-refine / no-lossless / cbqpoffs=0 / crqpoffs=0 / rc=cbr / bitrate=18000 / qcomp=0.60 / qpstep=4 / stats-write=0 / stats-read=2 / cplxblur=20.0 / qblur=0.5 / vbv-maxrate=18000 / vbv-bufsize=36000 / vbv-init=0.9 / min-vbv-fullness=50.0 / max-vbv-fullness=80.0 / ipratio=1.40 / pbratio=1.30 / aq-mode=3 / aq-strength=1.00 / cutree / zone-count=0 / no-strict-cbr / qg-size=32 / no-rc-grain / qpmax=69 / qpmin=0 / no-const-vbv / sar=1 / overscan=0 / videoformat=5 / range=0 / colorprim=9 / transfer=16 / colormatrix=9 / chromaloc=1 / chromaloc-top=2 / chromaloc-bottom=2 / display-window=0 / master-display=G(13250,34500)B(7500,3000)R(34000,16000)WP(15635,16450)L(10000000,001) / cll=1033,311 / min-luma=0 / max-luma=1023 / log2-max-poc-lsb=8 / vui-timing-info / vui-hrd-info / slices=1 / no-opt-qp-pps / no-opt-ref-list-length-pps / no-multi-pass-opt-rps / scenecut-bias=0.05 / hist-threshold=0.03 / no-opt-cu-delta-qp / no-aq-motion / hdr10 / hdr10-opt / no-dhdr10-opt / no-idr-recovery-sei / analysis-reuse-level=0 / analysis-save-reuse-level=0 / analysis-load-reuse-level=0 / scale-factor=0 / refine-intra=0 / refine-inter=0 / refine-mv=1 / refine-ctu-distortion=0 / no-limit-sao / ctu-info=0 / no-lowpass-dct / refine-analysis-type=0 / copy-pic=1 / max-ausize-factor=1.0 / no-dynamic-refine / no-single-sei / no-hevc-aq / no-svt / no-field / qp-adaptation-range=1.00 / scenecut-aware-qp=0conformance-window-offsets / right=0 / bottom=0 / decoder-max-rate=0 / no-vbv-live-multi-pass Language : English Default : No Forced : No Color range : Limited Color primaries : BT.2020 Transfer characteristics : PQ Matrix coefficients : BT.2020 non-constant Mastering display color primar : Display P3 Mastering display luminance : min: 0.0001 cd/m2, max: 1000 cd/m2 Maximum Content Light Level : 1033 cd/m2 Maximum Frame-Average Light Le : 311 cd/m2 |
#1703 | Link |
hello
just a little correction to do, in your bat file ::choose DEE 8-1-3 DDP Atmos mode: streaming or bluray (default = bluray) streaming max bitrate = 1024 @ 5.1ch /// Bluray max bitrate = 1536 @ 7.1ch + ac3 core set DDP_DEE_mode=streaming streaming is by default not a big deal but a friend drive nuts because he was losing 7.1
#1705 | Link | |
Yes, I know, and it was fixed in the beta a while ago. Thanks anyway.
DoVi_Scripts //// Dolby Vision Stuff (more tabs below) LG OLED G5 77'' + 7.2.4 Denon AVR + Ugoos AM6Bplus + Kaleidescape Strato E Sorry for my English |
#1706 | Link |
Did you accidentally use a base file such as HDR10+ to create the 8.6 profile?
my PC with Ryzen 7950X Last edited by DMD; 2nd February 2026 at 22:38. |
#1707 | Link | |
On a related note, is there a way to produce a madVR plot for the BL+FEL? Because for Nosferatu, I am trying to understand what was the original grade and what the BL was tonemapped to. It is not clear to me from the disc BL madVR and DV L1 plots what is happening that would explain FEL brightness expansion. |
#1708 | Link | |
#1710 | Link |
Hi! I'm trying to understand the profile 7 to 8.1 converting process (8-2-1 workflow) so to replicate it on Linux. For now, this is what I have:
1- Obtain MDL, MaxCLL and MaxFAL (What are they used for) 2- Demux MKV to obtain HEVC stream 3- Demux stream with dovi_tool to get BL and EL 4- Index BL and EL 5- Extract RPU P7 from EL 6- Convert RPU P7 to P8 with dovi_tool 7- From RPU P8 get MaxCLL and MAxFALL (What's the difference between these and the ones from the video stream?) 8- From RPU P8 get MinPQ and MaxPQ and map them based on their values 9- Load the AVS script with: DGDecodeNV DoviBaker Libplacebo (Is this being used? No command from the script seems to be using it) AVSresize BL with its index EL with its index 10- Run the script through X265 to bake FEL (Could this be done directly with FFMPEG? If so, could there be support for hardware encoding on other platforms than NVenc?) If I got any part wrong, please correct me. |
#1711 | Link | |||
Yes, ffmpeg can be used to encode the avs file, but dovi_scripts supports only x265.exe and nvenc.exe, and I have no plans to add support for any other indexing, encoding, or decoding options.
#1712 | Link | ||
Also, in the case of MEL, will these values be equal to the original HDR10 metadata? If so, could you just use those? Quote:
#1713 | Link | ||||
#1715 | Link |
workflow 2-2
#1717 | Link |
Are you talking about the RPU or the video cropping or both?
Check the last part of the first post to understand how L5 and the cropping/letterbox should be handled.
#1718 | Link |
I'm talking about the RPU cropping, from the JSON you pass into dovi_tool to convert the RPU from P7 to P8. The script gets those through mediainfo and then uses them on the AVS script. Is that something necessary for the conversion? or is done only if the user says yes to the cropping question?
#1719 | Link |
theres nothing special about the rpu crop function in dovi_tool, it just resets L5 to 0, and as I mentioned, everything you need to know about cropping and L5 is written in the first post.
#1720 | Link |
| Tags |
| batch scripts, dolby vision processing, dovi_scripts |
| Thread Tools | |
| Display Modes | |
