#604 | Link |
Posts: n/a
I was able to get the specs on this....is it a 75" ??
It doesn't mention anything about that, but I would think that it will be OK with CM4.0, but like I said, try a sample of each, and test for yourself, it won't take long, and you'll know for sure ![]() You can easily create a 5 minute chunk of a movie, and process it both ways. Good luck. |
#605 | Link | |
#606 | Link | ||
DoVi_Scripts //// Dolby Vision Stuff (more tabs below) LG OLED G5 77'' + 7.2.4 Denon AVR + Ugoos AM6Bplus + Kaleidescape Strato E Sorry for my English |
#607 | Link |
My only serious reason for wanting to try P5 was to see if there was *any* profile that would get 8K DV working in the LG Z3.
Of the files you offered, unfortunately, none worked on the LG and only one would play on his Mac (p8.1.HDR10plus.8K DS_NEW_mp4box). He did say that a file I created in P8.1 played on the Z3 in HDR10. My assumption prior to that was that standalone HDR10 would be playable anyway, but perhaps not. Does the LG need HDR10 to be the base layer in a DV profile to play? Edit: It's an LG Z2, not 3, Last edited by ReciprocalUniverse; 18th August 2024 at 19:19. |
#608 | Link | |
#611 | Link |
Posts: n/a
I've been doing a bit of "research", and there must be a fairly simple explanation why nobody can get 8K DV to work (yet) on LG Z2 (3), I wonder if it needs different settings ???
Chipset-based 8K TV • dvhe.05.12 • dvhe.08.12 • dvhe.09.05 Dolby Vision 8.4 Profile Level Maximum pixel rate resolution at frame rate Maximum bit rates ID 11 995,328,000 7680 7680 × 4320 @ 30 60 240 12 1,990,656,000 7680 7680 × 4320 @ 60 120 480 13 3,981,312,000 7680 7680 × 4320 @ 120 240 800 |
#612 | Link |
We know that dvhe.08.12 works in 4K, and that 8K did not, even after lowering 8K bitrate to 30 Mbps, except HDR10 it did. If you have a 8.4 profile to try in 8K, we will. My theory has been tv is not supporting 8K DV in any flavor.
#613 | Link | |
Posts: n/a
![]() Not sure how to create an 8.4, that's something that Kuler would have to comment on. You might be able to do something with Resolve, and inject the DV metadata into "something" I downloaded an 8K clip off YouTube earlier today, but it was encoded with AV1, as an mp4, but of course I don't have an 8K LG TV. |
#614 | Link | |
#615 | Link | |
Posts: n/a
Here's a link to something that may help:- https://www.youtube.com/watch?v=QqI9eKQnFL4 |
#616 | Link |
We haven't found any clips streamed in DV by YouTube. They play fine in regular HDR10 and even 8K. By DV I mean it's got to turn on the Dolby Vision icon on the tv set, not just whatever badge the YouTuber sticks on his video saying Dolby Vision. I think there is confusion with people seeing a DV badge added by the uploader versus actually turning on the tv's own icon or indicator light, whatever. My understanding remains that YouTube does not stream DV. I will try your link though.
#617 | Link | |
Posts: n/a
#618 | Link | |
I found one here that plays in 8K HDR10 on my Samsung. https://youtu.be/7PIji8OubXU?si=G3jZr5wBhg_pc6Pa I have to go in the other room where my U8 is to see if it plays in actual DV (in 4K). Will report back. |
#619 | Link | |
Posts: n/a
Did it actually display @ 8K ?? here's another:- choose to play it in 4320p !!! https://www.youtube.com/watch?v=vIN9Q1Slk0w Last edited by TDS; 21st August 2024 at 05:12. |
#620 | Link |
[QUOTE=TDS;2005861]That clip was only available (to download & play) in 2160p/4K @ 60fps, you need at least 4320p/8K @ whatever fps !!!
Did it actually display @ 8K ?? Yes, it streamed in 7680 x 4320 @ 60fps AV1 smpte2084/bt2020 ...but not Dolby Vision. 120 fps is just the camera frame rate it was shot at, slowed to 60 in post. YouTube doesn't stream higher than 60, at least not at 8K. And there's no tv that supports native 8K 120 playback either. I don't know about downloading from YouTube, never tried, just streaming. |
| Tags |
| batch scripts, dolby vision processing, dovi_scripts |
| Thread Tools | |
| Display Modes | |
