#381 | Link | |
Posts: n/a
Have you made a tutorial of this process, or is there one somewhere on how to do it ?? I ordered my Gigabyte RTX 4080 Super today , 2nd most expensive single PC part I have ever bought
#382 | Link | ||
E:\DoVi_Scripts\tools\ffmpeg.exe -i E:\input.mkv -c:v jpeg2000 -an -profile:v 3 -q 1 -compression_level 30 -pix_fmt yuv422p10le -y E:\output.mxf E:\DoVi_Scripts\tools\cm_analyze.exe -m 20 --source-format "pq bt2020" --analysis-tuning 1 E:\output.mxf E:\DV.xml EG, this a Resolve mxf file that works Quote:
DoVi_Scripts //// Dolby Vision Stuff (more tabs below) LG OLED G5 77'' + 7.2.4 Denon AVR + Ugoos AM6Bplus + Kaleidescape Strato E Sorry for my English |
#383 | Link | |
Posts: n/a
And what do I do with that .mxf file ?? |
#384 | Link |
nop, anything I tried in ffmpeg failed to be decoded by cm.
Will try again this weekend...
#386 | Link |
No, it's just a reference.
#387 | Link |
Pig on the wing
I tried to have a quick peek to see if this workflow I'm thinking of is there, but not sure so I'll ask. Sorry for being a DoVi n00b, I'm just about to get a proper TV that supports TV Led DoVi so I'm going to create some samples to try it out.
I have a profile 7 STDL MKV file. I was thinking of extracting the BL, FEL and RPU, downscaling and re-encoding the BL video and recombining these three back to MKV. Is the extracting and recombining possible to do with the script? And is it possible to downscale the BL or does the frame size need to match the FEL?
#388 | Link |
It's possible but I wouldn't do that without DEE.exe. Re-encoding the BL and muxing back the original EL can be destructive and cause issues.
Instead, you should bake FEL into the BL and convert the RPU to Profile 8 which will be the same quality as the original FEL P7 playback.
#389 | Link | |
Pig on the wing
I tried to find a way to extract the two layers with the script but didn't see the workflow there? Did I just miss it or is it not there?
#390 | Link | |
Yes, you bake/encode with x265.exe at the same time, it's a one-step process. In dovi_scripts you can create the avs script in 8-2-1 or 7-1
Set echo to ''on'' (line 2) to expose the cmd lines I use and then run 8-2-1. Cancel the encode and go into the temp folder, you will have the demuxed layers + RPU and the AVS script needed to bake/encode. you can downscale to 1080p at line 120. Quote:
In both ways, my scripts require an nvidia gpu.
#391 | Link |
Pig on the wing
Thank you for the comprehensive answer, I'll take a deeper look at the process using those workflows
#392 | Link |
I'm getting this error when attempting to use the works.mxf. Am I doing something wrong?
I:\Working\Movies\2160>I:\Working\Dolby-Vision-Tools\tools\cm_analyze.exe -m 20 --source-format "pq bt2020" --analysis-tuning 1 I:\Working\Movies\2160\output.mxf I:\Working\Movies\2160\DV.xml Copyright (c) 2013-2024 Dolby Laboratories, Inc. All Rights Reserved 06/11/2024/15:06:53.060000000 CPU: AMD Ryzen 7 2700X Eight-Core Processor (AuthenticAMD) [ mmx mmxext sse sse2 sse3 ssse3 sse41 sse42 sse4a avx avx2 fma ] 06/11/2024/15:06:53.062000000 cm_analyze: ERROR Unable to open MXF 'I:\Working\Movies\2160\output.mxf' for read: File open failure. Last edited by Gatorman3385; 11th June 2024 at 20:25. |
#393 | Link |
well you have to change the command to:
I:\Working\Dolby-Vision-Tools\tools\cm_analyze.exe -m 20 --source-format "pq bt2020" --analysis-tuning 1 I:\Working\Movies\2160\works.mxf I:\Working\Movies\2160\DV.xml
#395 | Link | |
Pig on the wing
EDIT: or is it that if you go DoVi and not static HDR10, you just bake BL+FEL and then input the RPU while encoding to get a proper stream with dynamic metadata.
And if the band you're in starts playing different tunes I'll see you on the dark side of the Moon... Last edited by Boulder; 12th June 2024 at 06:53. |
#396 | Link |
The original P7 RPU is required when you bake/decode EL+BL to a 16bit RGB PQ stream. Then, that 16bit PQ HDR stream is fed to the x265.exe with the P8 RPU.
#397 | Link |
Pig on the wing
Yeah, I was just a little confused when I consulted the DoViBaker examples in GitHub.. in the script there were all three items incorporated in the DoViBaker call, but in this case I would use only BL and EL there and RPU with x265.
#398 | Link |
yeah , ffms2 and lsmash read the P7 rpu directly from the stream. My script uses DGdecode.
#399 | Link |
Posts: n/a
Is there a way to speed this part of the 3-1 process up ??
I'm using nVme's where I can, but maybe there not "fast" ones, if that is what is governing this speed. Code:
Metadata:
encoder : Lavc61.5.104 prores_ks
frame= 8856 fps=105 q=-0.0 size= 6854912KiB time=00:06:09.36 bitrate=152030.7kbits/s speed=4.39x
#400 | Link | |
You can try to raise qscale at line 164 but 4.39x(105fps) is already a decent speed for prores encoding.
| Tags |
| batch scripts, dolby vision processing, dovi_scripts |
| Thread Tools | |
| Display Modes | |
