#21 | Link |
Here An updated QueryBorderCrop(), unfortunately, the site screws up at a simple 16K script, so
I'm splitting it into several posts. Here Some of the Text I will have to strip out of the AVS file. Code:
Function QueryBorderCrop(clip c,int "Samples",Float "Thresh",bool "Laced",int "XMod",int "YMod",int "WMod",int "HMod", \
bool "Relative", String "Prefix",int "RLBT",bool "DEBUG",float "Ignore",int "Matrix") {
# QueryBorderCrop v1.08, By StainlessS, Requires GScript & RT_Stats v1.01 Plugins.
# http://forum.doom9.org/showthread.php?p=1586858#post1586858
# Prescan function to get coords for eg cropping black borders. Planar, YUY2, RGB.
# Simultaneously returns 4 sets of strings holding crop coords, here is one set: "QBCropX=8 QBCropY=8 QBCropW=640 QBCropH=480".
# String sets are Chr(10) separated, the 'exact found' coords set as above, not rounded at all and possibly throwing an error if
# you try to crop, although could use in eg resize.
# Second set using eg "QBCropXL=8", which is CropLess("L" trailer), ie when rounding for Xmod,WMod etc may leave some black border.
# Third set using eg "QBCropXM=8", which is CropMore, ie when rounding for Xmod,WMod etc may crop some image.
# Forth set using eg "QBCropXP=8", which is CropPlus, moves border positions an extra 2 pixels inwards on each edge and then as CropMore.
# The non-exact coords try to center the coords when cropping for larger WMod/HMod's so as to evenly crop from eg both left and right instead of
# just one side. Also returned in the return string is the used Threshold, perhaps set by AutoThresh, as eg "QBCropThresh=32.0"
# You can use eg Eval(QueryBorderCrop()) to set values into QBCropX, QBCropY,QBCropW,QBCropH etc variables.
# Args:-
# Samples=24, Number of frames to sample from source clip c.
# Thresh= -32.0, Average luma value below or equal to which is considered possible black border, above considered possible image
# (if 3 adjacent pixel rows/columns above Thresh, then taken as image).
# A zero or negative value is 'AutoThresh', will prescan 'Samples' frames looking for minimum pixel luma value (but ignoring a percentage
# of the darkest pixels, see Ignore) and set 'Thresh' to that value plus the negated AutoThresh value, ie defaults sets Thresh to minimum
# found Y value + 32.0.
# Auto cropping will likely fail on END CREDITS ONLY clips, where on black background, and will probably crop off the sides that are no
# different in average luma to any letterbox borders, if you cannot see the borders, then neither can QueryBorderCrop(), even setting the
# auto Thresh to eg -1.0 or 0.0 is quite likely to fail. (See RLBT edge bitflags).
# v1.08, If 'samples' < 12 [samples would have been reduced if greater than framecount], and Thresh is not specified, then default
# AutoThresh will be adjusted.
# Thresh = -(((samples - 1) * (31.5/(12-1))) + 0.5) # samples==1 comes out as -0.5 : samples==12 would come out at -32.0
# So if eg single frame, would use an AutoThresh of -0.5
# If RGB and user specified a PC matrix then AutoThresh would also be scaled up a little (by (255.0/(235-16)).
# The adjustment to auto Thresh where samples < 12, is to reduce the possibility of overcropping on eg a dark single 'Samples' clip,
# but could result in not cropping enough border, its a bit of a balancing act really.
# As an observation, most clips have good border recogition within the 1st 2 sampled frames using the default -32 AutoThresh
# although have noticed some dark clips that required ~8 samples (or more) for full recognition @ default Thresh = -32.
# We use a default Samples=24, because we are intrinsically paranoid.
# To speed up, you may want to leave Auto-Thresh alone and reduce samples, but there is danger that it will not detect all borders
# (overcrop).
# NOTE, The plugin AutoCrop() uses a Thresh of 40.0 and samples == 5 by default (No AutoThresh), but the logic is not too dissimilar.
# Laced=true, set true for Interlaced. (Modifies defaults for YMod,HMod, explicit YMod/HMod will override).
# XMod, Default: Planar 2, YUY2=2, RGB=1
# YMod, Default: Planar=2, YUY2=1, RGB=1: BUT, Doubled if laced=true.
# WMod, Default: Planar=4, YUY2=2, RGB=1
# HMod, Default: Planar=2, YUY2=1, RGB=1: BUT, Doubled if laced=true.
# The above XMod etc set rounding for the non-exact cropping coords.
# The only real reason for default planar WMod=4 is VirtualDubMod dont like it less than that (Vdub latest, OK).
# Relative=false, False returns Width and Height, true returns Width/Height relative eg QBCropW=-6 QBCropH=-4.
# Prefix="QBCrop", string for returned variable names, only use valid variable name characters eg NO SPACES. Default returns eg "QBCropX".
# RLBT=15=All Borders, Bitflags of edges to crop, 15 ($0F) crops all four. Each letter in the name 'RLBT' represents an edge and bit position
# starting with 'R' in bit 3 representing the value 8 (2^3=8). 'L' = bit 2=4 (2^2=4), 'B' = bit 1=2 (2^1=2), 'T' = bit 0=1 (2^0=1).
# To calculate the RLBT bitflags, for 'R'(Right) add 8, for 'L'(Left) add 4, for 'B'(Bottom) add 2, and for 'T'(Top) add 1.
# Add all of the bit flags together 8+4+2+1 (=15) crops all four edges, 8+4 crops only Right & Left, and 2+1 crops only Bottom & Top.
# DEBUG=False=No Debug. Set True for debugging info, need DebugView: http://technet.microsoft.com/en-gb/sysinternals/bb545027
# Ignore=0.2, percentage of darkest pixels to ignore during Full image AutoThresh scan.
# Matrix, For conversion of RGB to YUV-Y, 0 = Rec601, 1 = Rec709, 2 = PC601, 3 = PC709
# Default for RGB is 2(PC601) if width <= 720 else 1(PC709) : YUV not used
# The defaults are for PC601 & PC709 range 0-255.
# So as to not require different Thresh for RGB, if clip c is RGB and matrix is PC range, then Thresh will be scaled
# to RGB full range ie Thresh = Thresh * (255.0/(235.0-16.0))
# If cropping too much border, then increase Samples or reduce Thresh
# If not cropping enough border then border is being seen as image, increase Thresh.
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 4th September 2012 at 14:53. |
#22 | Link |
QueryBorderCrop(), See Also previous and following posts.
VERS="QueryBorderCrop v1.08 - 29 Aug 2012"
c
GScript("""
DEBUG=default(DEBUG,False)
Laced = Default(Laced,True)
XM=IsPlanar()?2:IsYUY2()?2:1 WM=IsPlanar()?4:IsYUY2()?2:1 YM=IsPlanar()?2:IsYUY2()?1:1 YM=(Laced)?2*YM:YM
XMod = int(Default(XMod,XM)) YMod = int(Default(YMod,YM)) WMod = int(Default(WMod,WM)) HMod = int(Default(HMod,YM))
Prefix= Default(Prefix,"QBCrop") Relative= Default(Relative,false) RLBT=int(Default(RLBT,15)) w=Width h=Height Frames = Framecount()
Ignore=Float(Default(Ignore,0.2))
Samples = int(Default(Samples,24))
Samples = (Samples > Frames)? Frames : Samples
Mat = (width <= 720) ? 2 : 3 # Default to PC levels
Matrix = Default(Matrix,Mat)
Assert((Samples >= 1), "QueryBorderCrop: Requires Samples>=1")
Assert(XMod>0 && YMod>0 && WMod>0 && HMod>0,"QueryBorderCrop: XMod,YMod,WMod,HMod Must be at least 1")
Assert(WMod%XMod==0,"QueryBorderCrop: WMod must be a multiple of XMod")
Assert(HMod%YMod==0,"QueryBorderCrop: HMod must be a multiple of YMod")
Assert(RLBT>=1 && RLBT<=15,"QueryBorderCrop: RLBT 1->15 Only")
flgs=RLBT flgR=(flgs>=8) flgs=flgs % 8 flgL=(flgs>=4) flgs=flgs % 4 flgB=(flgs>=2) flgs=flgs % 2 flgT=(flgs>=1)
CX=0 CY=0 CW=0 CH=0 Rgt=w/2 Bot=h/2 Lft=Rgt-1 Top=Bot-1
DBGS1="" DBGS2=""
if(!Defined(Thresh)) {
if(samples < 12) {
Thresh = -(((samples - 1) * (31.5/(12-1))) + 0.5) # samples==12 would come out at -32
DBGS1="QBC: Low Samples count, AutoThresh reduced from default -32 to "+String(Thresh)
else {Thresh = -32.0}
if(isRGB() && Matrix >= 2) {
Thresh=Thresh *(255.0/(235.0-16.0)) # Scale up a bit for PC levels
DBGS2="QBC: RGB PC Levels Thresh Auto Scaled to "+String(Thresh)
if(DEBUG){RT_Debug("QBC:") RT_Debug("QBC:",VERS,"- By StainlessS") RT_Debug("QBC:")
RT_Debug(DBGS1)
RT_Debug(DBGS2)
RT_Debug("QBC:","Samples="+String(Samples),"Thresh="+String(Thresh,"%.2f"),"Laced="+String(Laced),"Matrix="+String(Matrix))
RT_Debug("QBC:","XMod="+String(XMod),"YMod="+String(YMod),"WMod="+String(WMod),"HMod="+String(HMod))
RT_Debug("QBC:","Relative="+String(Relative),"Prefix="+String(Prefix),"RLBT="+String(RLBT),"Ignore="+String(Ignore,"%.2f"))
RT_Debug("QBC:")}
if(Thresh < 0.0) { thmin = 255.0
if(IsPlanar() && Width < 4096 && Height < 4096) { if(DEBUG){RT_Debug("QBC:","AutoThresh Using Avisynth Planar Luma Sampling")}
for(Samp = 1,Samples) { current_frame = int(Samp * ((Frames - 1.0) / (Samples+1)) + 0.5)
th=YPlaneMin(threshold=Ignore) if (thmin>th){thmin=th}
if(DEBUG){
RT_Debug("QBC:","AutoThresh",String(Samp,"%-2.0f")+")","["+String(current_frame,"%-5.0f")+ "]","YPlaneMin="+String(thmin))}
if(thmin==0.0){Samp = Samples + 1} # No smaller possible, Break.
} else { if(DEBUG) {RT_Debug("QBC:","AutoThresh Using RT_Stats Luma Sampling")}
for(Samp = 1,Samples) { Frm = int(Samp * ((Frames - 1.0) / (Samples+1)) + 0.5)
th=RT_YPlaneMin(Frm,threshold=Ignore,matrix=Matrix) if (thmin>th){thmin=th}
if(DEBUG){ RT_Debug("QBC:","AutoThresh",String(Samp,"%-2.0f")+")","["+String(frm,"%-5.0f")+"]","YPlaneMin="+String(thmin))}
Thresh = thmin + (-Thresh) if(DEBUG) {RT_Debug("QBC:","AutoThresh","Thresh="+String(Thresh,"%.2f")) RT_Debug("QBC:")}
GotF=-1 GotN=0 # Track Number of frames where coords 1st found
Frm = int(Samp * ((Frames - 1.0) / (Samples+1)) + 0.5) # Sample frame
th2=0.0 th1=0.0 th=0.0 # Init, Previous luma values (pass the parcel)
# Only Y-Top Commented
if(flgT && Top>=2) { # Required and some more to do ?
cnt=0 # Init, got none yet
For(y=0,Top) { # Searching from outside inwards
th2=th1 th1=th th=RT_AverageLuma(Frm,y=y,h=1,x=CX,w=CW,matrix=Matrix) # Pass the parcel
if(th>Thresh) { # Possible image
if(Cnt>=2) { # Is Image, (found 3 adjacent scanlines all passing Thresh, No Incr this time)
CY=y-2 # The outer scanline that passed first (th2 was th at that time).
Top=(y<=2)?0:y-1 # If no top border at all, no more search: else, next time search max scanline y-1.
if(Frm<>GotF) {
GotF=Frm # Rememeber Last active Frame where image found
GotN=GotN+1 # Incr number of active frames
y=h # Force loop exit. (No more to do this frame, found 1st match scanning inwards)
if(DEBUG) {
RT_Debug("QBC:","Top",String(Samp)+")","["+String(Frm,"%-5.0f")+"]","AveY="+String(th2,"%3.2f"),"CY="+String(CY))
} else {
Cnt=Cnt+1 # Incr count, scanlines passed OK as possible image
} else {
Cnt=0 # Failed, maybe border.
if(flgB && Bot<=(h-1)-2){
cnt=0 For(y=h-1,Bot,-1){th2=th1 th1=th th=RT_AverageLuma(Frm,y=y,h=1,x=CX,w=CW,matrix=Matrix)
if(th>Thresh){if(Cnt>=2){CH= -((h-1)-(y+2)) Bot=((h-1)-y<=2)?h-1: y+1 if(Frm<>GotF) {GotF=Frm GotN=GotN+1} y=-1
if(DEBUG){RT_Debug("QBC:","Bot",String(Samp)+")","["+String(Frm,"%-5.0f")+"]","AveY="+String(th2,"%3.2f"),"CH="+String(CH))}
} else {Cnt=Cnt+1}}else {Cnt=0}}}
if(flgL && Lft>=2){
cnt=0 For(x=0,Lft){th2=th1 th1=th th=RT_AverageLuma(Frm,x=x,w=1,y=CY,h=CH,matrix=Matrix)
if(th>Thresh){if(Cnt>=2){CX=x-2 Lft=(x<=2)?0:x-1 if(Frm<>GotF) {GotF=Frm GotN=GotN+1} x=w
if(DEBUG){RT_Debug("QBC:","Lft",String(Samp)+")","["+String(Frm,"%-5.0f")+"]","AveY="+String(th2,"%3.2f"),"CX="+String(CX))}
} else {Cnt=Cnt+1}} else {Cnt=0}}}
if(flgR && Rgt<=(w-1)-2){
cnt=0 For(x=w-1,Rgt,-1){th2=th1 th1=th th=RT_AverageLuma(Frm,x=x,w=1,y=CY,h=CH,matrix=Matrix)
if(th>Thresh){if(Cnt>=2){CW= -((w-1)-(x+2)) Rgt=((w-1)-x<=2)?w-1:x+1 if(Frm<>GotF) {GotF=Frm GotN=GotN+1} x=-1
if(DEBUG){RT_Debug("QBC:","Rgt",String(Samp)+")","["+String(Frm,"%-5.0f")+"]","AveY="+String(th2,"%3.2f"),"CW="+String(CW))}
if((!flgT||Top==0) && (!flgL||Lft==0) && (!flgB||Bot==h-1) && (!flgR||Rgt==w-1))
{Samp = Samples + 1} # No further cropping possible, Break.
if(DEBUG){ RT_Debug("QBC:","Active Frames (where image coords first found) = "+String(GotN))
RT_Debug("QBC:","Sampled Borders:","X="+String(CX),"Y="+String(CY), \
"W="+String(CW)+"("+String(w-CX+CW)+")","H="+String(CH)+"("+String(h-CY+CH)+")")
RT_Debug("QBC:")
# Crop Exact # Make Exact found Coords: Default, QBCropX, QBCropY, QBCropW, QBCropH
CX0 = CX # Just make dupes
CY0 = CY
CW0 = w - CX + CW # Dont change CW and CH as needed for CropMore/CropLess/CropPlus
CH0 = h - CY + CH
if(DEBUG){RT_Debug("QBC:","CropExact:","X ="+String(CX0,"%2.0f"),"Y ="+String(CY0,"%2.0f"), \
"W ="+String(CW0,"%3.0f")+"("+String(CX0+CW0-w)+")","H ="+String(CH0,"%3.0f")+"("+String(CY0+CH0-h)+")")}
# CropLess X,W # Make CropLess Coords: Default, QBCropXL, QBCropYL, QBCropWL, QBCropHL
CX1 = int(CX / XMod)
CW1_Lim = int(w / XMod) - CX1
CW1 = int((w - (CX1*XMod) + CW + WMod - 1) / XMod)
CW1 = (CW1 > CW1_Lim) ? CW1_Lim : CW1
CW1_D = int(WMod/XMod)
CW1_M = int((CW1 % CW1_D) / 2)
CW1_Off = (CX1 < CW1_M) ? CX1 : CW1_M
CX1 = CX1 - CW1_Off
CW1 = CW1 + CW1_Off
CX1 = CX1 * XMod
CW1 = int(CW1 / CW1_D) * CW1_D * XMod
# CropLess Y,H
CY1 = int(CY / YMod)
CH1_Lim = int(h / YMod) - CY1
CH1 = int((h - (CY1*YMod) + CH + HMod - 1) / YMod)
CH1 = (CH1 > CH1_Lim) ? CH1_Lim : CH1
CH1_D = int(HMod/YMod)
CH1_M = int((CH1 % CH1_D) / 2)
CH1_Off = (CY1 < CH1_M) ? CY1 : CH1_M
CY1 = CY1 - CH1_Off
CH1 = CH1 + CH1_Off
CY1 = CY1 * YMod
CH1 = int(CH1 / CH1_D) * CH1_D * YMod
if(DEBUG) {
if(CW1_Off<>0) {RT_Debug("QBC:","CropLess: "," XL Centered - "+String(CW1_Off))}
if(CH1_Off<>0) {RT_Debug("QBC:","CropLess: "," YL Centered - "+String(CH1_Off))}
RT_Debug("QBC:","CropLess: "," XL="+String(CX1,"%2.0f"),"YL="+String(CY1,"%2.0f"), \
"WL="+String(CW1,"%3.0f")+"("+String(CX1+CW1-w)+")","HL="+String(CH1,"%3.0f")+"("+String(CY1+CH1-h)+")")
# CropMore X,W # Make CropMore Coords: Default, QBCropXM, QBCropYM, QBCropWM, QBCropHM
CX2 = int((CX+XMod-1)/XMod)*XMod # Round up CX2
CW2_Tmp = int(((w - CX2 + CW)/XMod))*XMod # wid Mod XMod
CW2 = int(CW2_Tmp/WMod)*WMod # wid Mod WMod
CW2_Dif = int((CW2_Tmp - CW2) / XMod) # Diff due to WMod in XMod steps
CW2_Off = (int(CW2_Dif/2)) * XMod # Half difference to try and center
CX2 = CX2 + CW2_Off # Center, try to share out cropping due to big WMod
# CropMore Y,H
CY2 = int((CY+YMod-1)/YMod)*YMod # Round up CY2
CH2_Tmp = int(((h - CY2 + CH)/YMod))*YMod # height Mod YMod
CH2 = int(CH2_Tmp/HMod)*HMod # height Mod HMod
CH2_Dif = int((CH2_Tmp - CH2) / YMod) # Diff due to HMod in YMod steps
CH2_Off = (int(CH2_Dif/2)) * YMod # Half difference to try and center
CY2 = CY2 + CH2_Off # Center, try to share out cropping due to big HMod
if(DEBUG) {
if(CW2_Off<>0) {RT_Debug("QBC:","CropMore: "," XM Centered + "+String(CW2_Off))}
if(CH2_Off<>0) {RT_Debug("QBC:","CropMore: "," YM Centered + "+String(CH2_Off))}
RT_Debug("QBC:","CropMore: "," XM="+String(CX2,"%2.0f"),"YM="+String(CY2,"%2.0f"), \
"WM="+String(CW2,"%3.0f")+"("+String(CX2+CW2-w)+")","HM="+String(CH2,"%3.0f")+"("+String(CY2+CH2-h)+")")
# CropPlus X,W # Make CropPlus Coords: Default, QBCropXP, QBCropYP, QBCropWP, QBCropHP
CXP = CX+2 # CropPlus Over Cropping, dont touch orig vars
CYP = CY+2 # Cropping extra 2 pixels from each edge
CWP = CW-2 # After that, as CropMore
CHP = CH-2
CX3 = int((CXP+XMod-1)/XMod)*XMod # Round up CX3
CW3_Tmp = int(((w - CX3 + CWP)/XMod))*XMod # wid Mod XMod
CW3 = int(CW3_Tmp/WMod)*WMod # wid Mod WMod
CW3_Dif = int((CW3_Tmp - CW3) / XMod) # Diff due to WMod in XMod steps
CW3_Off = (int(CW3_Dif/2)) * XMod # Half difference to try and center
CX3 = CX3 + CW3_Off # Center, try to share out cropping due to big WMod
# CropPlus Y,H
CY3 = int((CYP+YMod-1)/YMod)*YMod # Round up CY3
CH3_Tmp = int(((h - CY3 + CHP)/YMod))*YMod # height Mod YMod
CH3 = int(CH3_Tmp/HMod)*HMod # height Mod HMod
CH3_Dif = int((CH3_Tmp - CH3) / YMod) # Diff due to HMod in YMod steps
CH3_Off = (int(CH3_Dif/2)) * YMod # Half difference to try and center
CY3 = CY3 + CH3_Off # Center, try to share out cropping due to big HMod
if(DEBUG) {
if(CW3_Off<>0) {RT_Debug("QBC:","CropPlus: "," XP Centered + "+String(CW3_Off))}
if(CH3_Off<>0) {RT_Debug("QBC:","CropPlus: "," YP Centered + "+String(CH3_Off))}
RT_Debug("QBC:","CropPlus: "," XP="+String(CX3,"%2.0f"),"YP="+String(CY3,"%2.0f"), \
"WP="+String(CW3,"%3.0f")+"("+String(CX3+CW3-w)+")","HP="+String(CH3,"%3.0f")+"("+String(CY3+CH3-h)+")")
if(Relative) { CW0 = CX0 + CW0 - w CH0 = CY0 + CH0 - h CW1 = CX1 + CW1 - w CH1 = CY1 + CH1 - h
CW2 = CX2 + CW2 - w CH2 = CY2 + CH2 - h CW3 = CX3 + CW3 - w CH3 = CY3 + CH3 - h}
RS0=Prefix+"X=" +String(CX0)+" "+Prefix+"Y=" +String(CY0)+" "+Prefix+"W=" +String(CW0)+" "+Prefix+"H=" +String(CH0)
RS1=Prefix+"XL="+String(CX1)+" "+Prefix+"YL="+String(CY1)+" "+Prefix+"WL="+String(CW1)+" "+Prefix+"HL="+String(CH1)
RS2=Prefix+"XM="+String(CX2)+" "+Prefix+"YM="+String(CY2)+" "+Prefix+"WM="+String(CW2)+" "+Prefix+"HM="+String(CH2)
RS3=Prefix+"XP="+String(CX3)+" "+Prefix+"YP="+String(CY3)+" "+Prefix+"WP="+String(CW3)+" "+Prefix+"HP="+String(CH3)
RST=Prefix+"Thresh="+String(Thresh) # Return used Thresh, might be useful to avoid 2nd prescan for AutoThresh.
if(DEBUG){RT_Debug("QBC:") RT_Debug("QBC:","Return:",RS0) RT_Debug("QBC:","Return:",RS1) RT_Debug("QBC:","Return:",RS2)
RT_Debug("QBC:","Return:",RS3) RT_Debug("QBC:","Return:",RST)}
Return RS0+Chr(10)+RS1+Chr(10)+RS2+Chr(10)+RS3+Chr(10)+RST+Chr(10)
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 29th August 2012 at 10:39. |
#23 | Link |
QueryLumaMinMax(), And a couple of other script functions. See Previous and following posts.
Function QueryLumaMinMax(clip c,int "Samples",float "Ignore",String "Prefix",bool "DEBUG",int "X",int "Y",int "W",int "H",int "Matrix") {
# QueryLumaMinMax v1.01, By StainlessS, Requires GScript & RT_Stats v1.01 Plugins.
# Prescan function to get Luma Min,Max. Planar, YUY2, RGB.
# Returns luma min/max as string Default eg "QLMMMin=25 QLMMMax=244", use eg "Eval(QueryLumaMinMax())" to set variables for
# use in Avisynth.
# http://forum.doom9.org/showthread.php?p=1586859#post1586859
# Samples=24=frames to sample.
# Ignore=0.2=Percentage of extreme pixels to ignore.
# Prefix="QLMM"=Prefix for return values.
# X=Y=W=H=0=Full screen, as crop.
# DEBUG=false= dont show. True=debug info. Need DebugView: http://technet.microsoft.com/en-gb/sysinternals/bb545027
# Default for RGB is 2(PC601) if width <= 720 else 3(PC709) : YUV not used
# For RGB, it probably does not make sense to use anything other than PC levels, unless studio RGB.
# Usage:
# # Auto levels using Levels() filter.
# AUTOLEVEL_STRENGTH = 0.5 # 0.0 -> 1.0
# Eval(QueryLumaMinMax()) # using default values, sets QLMMMin and QLMMMax.
# if(IsRGB()) { # Requires GScript
# CSMin = 0
# CSMax = 255
# } else {
# CSMin = 16
# CSMax = 235
# ALMin = Int(CSMin - ((CSMin - QLMMMin) * AUTOLEVEL_STRENGTH) + 0.5) # Round Up
# ALMax = Int(CSMax - ((CSMax - QLMMMax) * AUTOLEVEL_STRENGTH)) # Round down
# Levels(ALMin,1.0,ALMax,CSMin,CSMax,Coring=False) # DO NOT use Coring
VERS="QueryLumaMinMax v1.01 - 29 Aug 2012"
c
Samples = Default(Samples,24) Ignore=Float(Default(Ignore,0.2)) Prefix = Default(Prefix,"QLMM") DEBUG=default(DEBUG,False)
X=int(Default(X,0)) Y=int(Default(Y,0)) W=int(Default(W,0)) H=int(Default(H,0))
W = (W<=0) ? Width - X + W : W H = (H<=0) ? Height - Y + H : H
Mat = (width <= 720) ? 2 : 3 # Default, PC601 or PC709 for RGB
GScript("""
Assert((Samples >= 1), "QueryLumaMinMax: Requires Samples>=1")
Frames=FrameCount mn=255.0 mx=0.0 Samples = (Samples > Frames)? Frames : Samples
if(DEBUG){RT_Debug("QLMM:") RT_Debug("QLMM:",VERS,"- By StainlessS") RT_Debug("QLMM:")
RT_Debug("QLMM:","Samples="+String(Samples),"Ignore="+String(Ignore,"%.2f"),"Prefix="+String(Prefix))
RT_Debug("QLMM:","X="+String(X),"Y="+String(Y),"W="+String(W),"H="+String(H),"Matrix="+String(Matrix))
RT_Debug("QLMM:")}
if(IsPlanar==True && X==0 && Y==0 && W==Width && H==Height && Width < 4096 && Height < 4096) {
if(DEBUG){RT_Debug("QLMM:","Using Avisynth Planar Full Frame Luma Sampling")}
Mn_Tmp = YPlaneMin(threshold=ignore) Mx_Tmp = YPlaneMax(threshold=ignore)
if(DEBUG){RT_Debug("QLMM:","LumaRange:",String(Samp,"%-2.0f")+")","["+String(current_frame,"%-5.0f")+"]", \
"LumaMin = "+String(Mn_Tmp),"LumaMax = "+String(Mx_Tmp))}
mn=(Mn_Tmp<mn)?Mn_Tmp:mn mx=(Mx_Tmp>mx)?Mx_Tmp:mx}
} else {if(DEBUG){RT_Debug("QLMM:","Using RT_Stats Luma Sampling")}
n = int(Samp * ((Frames - 1.0) / (Samples+1)) + 0.5)
Mn_Tmp = RT_YPlaneMin(n,x=X,y=Y,w=W,h=H,threshold=ignore,matrix=Matrix)
Mx_Tmp = RT_YPlaneMax(n,x=X,y=Y,w=W,h=H,threshold=ignore,matrix=Matrix)
if(DEBUG){RT_Debug("QLMM:","LumaRange:",String(Samp,"%-2.0f")+")","["+String(n,"%-5.0f")+"]", \
RS=Prefix+"Min="+String(Mn) + " " + Prefix+"Max=" + String(mx)
if(DEBUG){RT_Debug("QLMM:") RT_Debug("QLMM:","Return:",RS)}
Return RS
# Get File extension from filename, use to eg select Source filter for audio file.
Function GetFileExtension(String fn) {len = FindStr(RevStr(fn),".") - 1 Return Len>=1 ? RightStr(fn,Len) : ""}
Function GetCropDAR(clip c,float DAR,float "X",float "Y",float "W",float "H") {
# Call prior to Crop/Resize with (possibly fractional) cropping to calc resultant DAR, X,Y,W,H are cropping coords
# DAR = FAR * SAR ::: FAR = DAR / SAR ::: SAR = DAR / FAR
X=Float(Default(X,0.0)) Y=Float(Default(Y,0.0)) W=Float(Default(W,0.0)) H=Float(Default(H,0.0))
W=W<=0.0?c.width+W-X:W H=H<=0.0?c.height+H-Y:H
# Irrespective of what various resizers in various Avisynth versions silently correct, we dont allow eg -ve X
Assert(X>=0.0&&X < c.width, "GetCropDAR: Invalid X("+String(X)+")")
Assert(Y>=0.0&&Y < c.height,"GetCropDAR: Invalid Y("+String(Y)+")")
Assert(W> 0.0&&X+W<=c.width, "GetCropDAR: Invalid W("+String(W)+")")
Assert(H> 0.0&&Y+H<=c.height,"GetCropDAR: Invalid H("+String(H)+")")
Return c.GetSAR(DAR) * W / H
# From MeGUI Wiki:
Function GetDAR(clip c, float SAR) { return Float(c.width) * SAR / Float(c.height)} # Gets the DAR from the SAR
Function GetSAR(clip c, float DAR) { return DAR * Float(c.height) / Float(c.width) } # Gets the SAR from the DAR
Function SignalDAR(float DAR){global MeGUI_darx=Round(1000*DAR) global MeGUI_dary=1000} # Signal DAR for MEGUI (Name change from SetDar)
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 29th August 2012 at 10:41. |
#24 | Link |
A Little Demo script for QueryBorderCrop() and QueryLumaMinMax (), See previous few posts.
Import ("D:\avs\QueryBorderCrop.avs")
Import ("D:\avs\QueryLumaMinMax.avs")
GSCript("""
DAR = 16.0/9.0 # Input Full Frame Display Aspect Ratio
SIZE_X = 640 # Output X dim
SIZE_Y = 480 # Output Y dim
DEBUG = True # Debug ON
TFF = True
AUTOLEVEL_STRENGTH = 0.5 # Strength of auto leveling, 0.0 -> 1.0
VideoFileName =LCase("D:\TEST_VOBS\1.d2v")
AudioFileName =LCase("D:\TEST_VOBS\1 T80 3_2ch 448Kbps DELAY 0ms.ac3")
AudioDelay =Value(LCase("0.000"))
MPEG2Source(VideoFileName,cpu2="xxxxxx")
AudioExt=GetFileExtension(AudioFileName)
Audio= (AudioExt=="ac3") ? NICAC3Source(AudioFileName,channels=2,DRC=0)
\ : (AudioExt=="mpa"||AudioExt=="mp1"||AudioExt=="mp2"||AudioExt=="mp3") ? NicMPG123Source(AudioFileName,Normalize=False)
\ : (AudioExt=="wav") ? RaWavSource(AudioFileName)
\ : 0
(!isInt(Audio))?AudioDub(Audio).DelayAudio(AudioDelay).Trim(0,0):NOP
(AudioRate() <> 44100 && AudioRate() <> 48000)?ResampleAudio(44100):NOP
(TFF)?AssumeTFF():AssumeBFF
Eval(QueryBorderCrop(laced=false,Debug=DEBUG)) # Get Return string and initialize QBCropX type variables in Avisynth
PreCrop=Crop(QBCropXP,QBCropYP,QBCropWP,QBCropHP) # Get OverCropped coord clip using CropPlus Coords ('P' trailer character)
# Get Auto Levels Min/Max from OVERCROPPED Clip (Ignore black borders)
Eval(QueryLumaMinMax(PreCrop,Debug=DEBUG))
if(IsYUV()) {
CSMin = 16
CSMax = 235
} else {
CSMin = 0
CSMax = 255
Levels(ALMin,1.0,ALMax,CSMin,CSMax,Coring=False) # AutoLevel, DONT USE Coring
if(DEBUG) {
RT_Debug("AutoLevel: Levels("+String(ALMin)+",1.0,"+String(ALMax)+","+String(CSMin)+","+String(CSMax)+")")
if(QBCropXM<>0||QBCropYM<>0||QBCropWM<>SIZE_X||QBCropHM<>SIZE_Y) {
DAR=GetCropDAR(DAR,QBCropXM,QBCropYM,QBCropWM,QBCropHM) # Calc New DAR after Resize with CropMore ('M' Trailer Char)
Spline36Resize(SIZE_X,SIZE_Y,QBCropXM,QBCropYM,QBCropWM,QBCropHM)
if(DEBUG){RT_Debug("SIGNALDAR:","MeGUI DAR="+String(DAR))}
SignalDAR(DAR) # Tell MeGUI the new Resized/Cropped Display Aspect Ratio
return last
00000005 10:53:34 RT_Debug: QBC: 00000006 10:53:34 RT_Debug: QBC: QueryBorderCrop v1.08 - 29 Aug 2012 - By StainlessS 00000007 10:53:34 RT_Debug: QBC: 00000008 10:53:34 RT_Debug: QBC: Samples=24 Thresh=-32.00 Laced=false Matrix=2 00000009 10:53:34 RT_Debug: QBC: XMod=2 YMod=2 WMod=4 HMod=2 00000010 10:53:34 RT_Debug: QBC: Relative=false Prefix=QBCrop RLBT=15 Ignore=0.20 00000011 10:53:34 RT_Debug: QBC: 00000012 10:53:34 RT_Debug: QBC: AutoThresh Using Avisynth Planar Luma Sampling 00000013 10:53:34 RT_Debug: QBC: AutoThresh 1 ) [715 ] YPlaneMin=16 00000014 10:53:35 RT_Debug: QBC: AutoThresh 2 ) [1430 ] YPlaneMin=16 00000015 10:53:35 RT_Debug: QBC: AutoThresh 3 ) [2145 ] YPlaneMin=16 00000016 10:53:35 RT_Debug: QBC: AutoThresh 4 ) [2860 ] YPlaneMin=16 00000017 10:53:35 RT_Debug: QBC: AutoThresh 5 ) [3575 ] YPlaneMin=16 00000018 10:53:36 RT_Debug: QBC: AutoThresh 6 ) [4290 ] YPlaneMin=16 00000019 10:53:36 RT_Debug: QBC: AutoThresh 7 ) [5004 ] YPlaneMin=16 00000020 10:53:36 RT_Debug: QBC: AutoThresh 8 ) [5719 ] YPlaneMin=16 00000021 10:53:36 RT_Debug: QBC: AutoThresh 9 ) [6434 ] YPlaneMin=16 00000022 10:53:36 RT_Debug: QBC: AutoThresh 10) [7149 ] YPlaneMin=16 00000023 10:53:37 RT_Debug: QBC: AutoThresh 11) [7864 ] YPlaneMin=16 00000024 10:53:37 RT_Debug: QBC: AutoThresh 12) [8579 ] YPlaneMin=16 00000025 10:53:37 RT_Debug: QBC: AutoThresh 13) [9294 ] YPlaneMin=16 00000026 10:53:37 RT_Debug: QBC: AutoThresh 14) [10009] YPlaneMin=16 00000027 10:53:37 RT_Debug: QBC: AutoThresh 15) [10724] YPlaneMin=16 00000028 10:53:38 RT_Debug: QBC: AutoThresh 16) [11439] YPlaneMin=16 00000029 10:53:38 RT_Debug: QBC: AutoThresh 17) [12154] YPlaneMin=16 00000030 10:53:38 RT_Debug: QBC: AutoThresh 18) [12869] YPlaneMin=16 00000031 10:53:38 RT_Debug: QBC: AutoThresh 19) [13583] YPlaneMin=16 00000032 10:53:39 RT_Debug: QBC: AutoThresh 20) [14298] YPlaneMin=16 00000033 10:53:39 RT_Debug: QBC: AutoThresh 21) [15013] YPlaneMin=16 00000034 10:53:39 RT_Debug: QBC: AutoThresh 22) [15728] YPlaneMin=16 00000035 10:53:39 RT_Debug: QBC: AutoThresh 23) [16443] YPlaneMin=16 00000036 10:53:40 RT_Debug: QBC: AutoThresh 24) [17158] YPlaneMin=16 00000037 10:53:40 RT_Debug: QBC: AutoThresh Thresh=48.00 00000038 10:53:40 RT_Debug: QBC: 00000039 10:53:44 RT_Debug: QBC: Top 2) [1430 ] AveY=65.15 CY=75 00000040 10:53:44 RT_Debug: QBC: Bot 2) [1430 ] AveY=61.18 CH=-76 00000041 10:53:44 RT_Debug: QBC: Lft 2) [1430 ] AveY=48.26 CX=46 00000042 10:53:44 RT_Debug: QBC: Rgt 2) [1430 ] AveY=48.14 CW=-77 00000043 10:53:45 RT_Debug: QBC: Lft 3) [2145 ] AveY=120.76 CX=0 00000044 10:53:45 RT_Debug: QBC: Rgt 3) [2145 ] AveY=106.21 CW=0 00000045 10:53:58 RT_Debug: QBC: Active Frames (where image coords first found) = 2 00000046 10:53:58 RT_Debug: QBC: Sampled Borders: X=0 Y=75 W=0(720) H=-76(425) 00000047 10:53:58 RT_Debug: QBC: 00000048 10:53:58 RT_Debug: QBC: CropExact: X = 0 Y =75 W =720(0) H =425(-76) 00000049 10:53:58 RT_Debug: QBC: CropLess: XL= 0 YL=74 WL=720(0) HL=426(-76) 00000050 10:53:58 RT_Debug: QBC: CropMore: XM= 0 YM=76 WM=720(0) HM=424(-76) 00000051 10:53:58 RT_Debug: QBC: CropPlus: XP= 2 YP=78 WP=716(-2) HP=420(-78) 00000052 10:53:58 RT_Debug: QBC: 00000053 10:53:58 RT_Debug: QBC: Return: QBCropX=0 QBCropY=75 QBCropW=720 QBCropH=425 00000054 10:53:58 RT_Debug: QBC: Return: QBCropXL=0 QBCropYL=74 QBCropWL=720 QBCropHL=426 00000055 10:53:58 RT_Debug: QBC: Return: QBCropXM=0 QBCropYM=76 QBCropWM=720 QBCropHM=424 00000056 10:53:58 RT_Debug: QBC: Return: QBCropXP=2 QBCropYP=78 QBCropWP=716 QBCropHP=420 00000057 10:53:58 RT_Debug: QBC: Return: QBCropThresh=48.000000 00000058 10:53:58 RT_Debug: QLMM: 00000059 10:53:58 RT_Debug: QLMM: QueryLumaMinMax v1.01 - 29 Aug 2012 - By StainlessS 00000060 10:53:58 RT_Debug: QLMM: 00000061 10:53:58 RT_Debug: QLMM: Samples=24 Ignore=0.20 Prefix=QLMM 00000062 10:53:58 RT_Debug: QLMM: X=0 Y=0 W=716 H=420 Matrix=2 00000063 10:53:58 RT_Debug: QLMM: 00000064 10:53:58 RT_Debug: QLMM: Using Avisynth Planar Full Frame Luma Sampling 00000065 10:53:58 RT_Debug: QLMM: LumaRange: 1 ) [715 ] LumaMin = 16 LumaMax = 23 00000066 10:53:58 RT_Debug: QLMM: LumaRange: 2 ) [1430 ] LumaMin = 18 LumaMax = 163 00000067 10:53:58 RT_Debug: QLMM: LumaRange: 3 ) [2145 ] LumaMin = 83 LumaMax = 199 00000068 10:53:58 RT_Debug: QLMM: LumaRange: 4 ) [2860 ] LumaMin = 21 LumaMax = 103 00000069 10:53:58 RT_Debug: QLMM: LumaRange: 5 ) [3575 ] LumaMin = 25 LumaMax = 159 00000070 10:53:58 RT_Debug: QLMM: LumaRange: 6 ) [4290 ] LumaMin = 17 LumaMax = 164 00000071 10:53:58 RT_Debug: QLMM: LumaRange: 7 ) [5004 ] LumaMin = 19 LumaMax = 170 00000072 10:53:58 RT_Debug: QLMM: LumaRange: 8 ) [5719 ] LumaMin = 17 LumaMax = 145 00000073 10:53:58 RT_Debug: QLMM: LumaRange: 9 ) [6434 ] LumaMin = 17 LumaMax = 159 00000074 10:53:58 RT_Debug: QLMM: LumaRange: 10) [7149 ] LumaMin = 16 LumaMax = 176 00000075 10:53:58 RT_Debug: QLMM: LumaRange: 11) [7864 ] LumaMin = 16 LumaMax = 191 00000076 10:53:58 RT_Debug: QLMM: LumaRange: 12) [8579 ] LumaMin = 17 LumaMax = 196 00000077 10:53:58 RT_Debug: QLMM: LumaRange: 13) [9294 ] LumaMin = 20 LumaMax = 195 00000078 10:53:58 RT_Debug: QLMM: LumaRange: 14) [10009] LumaMin = 18 LumaMax = 197 00000079 10:53:58 RT_Debug: QLMM: LumaRange: 15) [10724] LumaMin = 18 LumaMax = 155 00000080 10:53:58 RT_Debug: QLMM: LumaRange: 16) [11439] LumaMin = 16 LumaMax = 143 00000081 10:53:58 RT_Debug: QLMM: LumaRange: 17) [12154] LumaMin = 16 LumaMax = 153 00000082 10:53:58 RT_Debug: QLMM: LumaRange: 18) [12869] LumaMin = 20 LumaMax = 191 00000083 10:53:58 RT_Debug: QLMM: LumaRange: 19) [13583] LumaMin = 24 LumaMax = 127 00000084 10:53:58 RT_Debug: QLMM: LumaRange: 20) [14298] LumaMin = 27 LumaMax = 204 00000085 10:53:58 RT_Debug: QLMM: LumaRange: 21) [15013] LumaMin = 21 LumaMax = 191 00000086 10:53:58 RT_Debug: QLMM: LumaRange: 22) [15728] LumaMin = 20 LumaMax = 184 00000087 10:53:58 RT_Debug: QLMM: LumaRange: 23) [16443] LumaMin = 18 LumaMax = 200 00000088 10:53:58 RT_Debug: QLMM: LumaRange: 24) [17158] LumaMin = 29 LumaMax = 191 00000089 10:53:58 RT_Debug: QLMM: 00000090 10:53:58 RT_Debug: QLMM: Return: QLMMMin=16 QLMMMax=204 00000091 10:53:58 RT_Debug: AutoLevel: Levels(16,1.0,219,16,235) 00000092 10:53:58 RT_Debug: SIGNALDAR: MeGUI DAR=2.415094
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 29th August 2012 at 10:57. |
#25 | Link |
New version RT_Stats() v1.02, see first post.
#26 | Link |
New version RT_Stats() v1.03, see first post.
Also updated QueryBorderCrop() and QueryLumaMinMax(), a few posts earlier (Also now contained in RT_Stats zip).
#27 | Link |
New Version RT_Stats, See first post.
Added RT_Call() function, calls an executable.
#30 | Link |
StainlessS,
tried RT_call, because you gave it a 'hide' option . It performs different from 'Call', like I wrote in that thread. What I mean is shown in this example:Code:
ColorBars()
ShowFrameNumber()
ConvertToRGB24()
ScriptClip("""
c = last
Trim(current_frame, -1)
ImageWriter("C:\Temp\", 0, 0, type="tif")
Call("C:\PortableApps\ImageMagick\Mogrify.exe -flip C:\Temp\000000.tif", "0")
#RT_Call("C:\PortableApps\ImageMagick\Mogrify.exe -flip C:\Temp\000000.tif",true)
StackHorizontal(last,ImageSource("C:\Temp\000000.tif")).Crop(c.width,0,0,0)
You will see the flipped frame. Now move the comment marker to Call, and you see that the frame is no longer flipped! In my humble words: It seems as if RT_Call, like Run, are executed when the realtime environment is compiled, rather than when a frame is requested. Call however is executed during frame #0 request, and because the clip is always trimmed to start with the current frame, every frame is frame #0 for Call. Of course I would be happy if you decided to extend RT_Call to my need, because the 'hide' option is very nice indeed. And btw., here I demonstrate how all Imagemagick filters in fact can even be used inside the runtime environment. In the thread where I first asked for an interface and then proposed a solution, I had not yet found the StackHorizontal... trick and hence needed a separate ScriptClip to read the file back. Last edited by martin53; 23rd September 2012 at 20:20. Reason: link to other thread |
#31 | Link |
@Martin53,
See CallCmd() v0.0 beta, source included here:- http://forum.doom9.org/showthread.ph...32#post1593132 NOTE, your above example fails if 000000.tif does not already exist before script executed, ImageSource() checks for it in its constructor (EDIT: before tif created) and fails if absent. EDIT: Also, mogrify.exe produces below text in console window, seems to be an incompatibility between ImageWriter and mogrify.exe, presume in EXIF (or similar) data. Code:
mogrify.exe: incorrect count for field "DateTime" (21, expecting 20); tag ignored. (C:\Temp\000000.tif).
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 28th September 2012 at 06:27. Reason: additional |
#32 | Link |
@StainlessS,
sorry for the inconvenience. Yes, it seems that the file must be there in advance. I propose this approach (red line added). Code:
ColorBars()
ShowFrameNumber()
ConvertToRGB24()
Exist("C:\Temp\000000.tif") ? last : ImageWriter("C:\Temp\", 0, 0, type="tif")
ScriptClip("""
c = last
Anyway, tif format is not mandatory. I just chose it because I expected that it fulfills the requirements (speed, compatibility, no quality loss due to compression) Last edited by martin53; 29th September 2012 at 13:29. |
#33 | Link |
Nice Exist solution.
I recently downloaded ImageMagick (already got a copy but could not find it), perhaps you have newer version. From Mogrify.exe Version: @(#)ImageMagick 5.4.6 06/01/02 Q:8 http://www.imagemagick.org Copyright: Copyright (C) 2002 ImageMagick Studio LLC It was only a warning anyway, did not affect result.
#34 | Link |
Mine says
Version: ImageMagick 6.7.8-3 2012-07-11 Q16 http://www.imagemagick.org Copyright: Copyright (C) 1999-2012 ImageMagick Studio LLC Never gave version issues a thought - just downloaded and used. I tested the command line Mogrify.exe -flip C:\Temp\000000.tif - no warnings, works as expected. |
#35 | Link |
@Martin53
The initial Mogrify.exe I was using from 2002 (v5.4.6) was from here: http://www.dylanbeattie.net/magick/downloads.html Works fine and only 2.3MB. Portable one I just downloaded from ImageMagick.org (ImageMagick-6.7.9-9-Q16-windows.zip) 44MB http://imagemagick.org/script/binary...es.php#windows But this one displays mogrify'ed images as bright green with a little darker color around font edges when loaded into any MS apps except MS Paint. Other paint type programs I tried all loaded them OK, so strangely its only the more capable MS apps that screw up. Think I'll stick with the older smaller portable version. EDIT: the newer one is listed as "16 bits-per-pixel", strange that MS Paint (XP32) has no problems and MS OFFICE 2003 picture manager fails. (I dont like office 2007+).
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 1st October 2012 at 18:11. |
#37 | Link |
StainlessS,
I never said for RT_Stats. I do now!I am just facing a problem: I use MVTools2's MMask(kind=5) to get a U/V frame of object motion. MMask leaves U/V at the default 128 for blocks it can not assign a valid motion vector to. Now I need the average motion of a part of the image. Aside from needing crop and AverageChromaU, or UToY and RT_AverageLuma - so two steps either way (I am always in the RTE with my projects), the pixels with 128 spoil the result. I could use if (RT_AverageLuma>128) { #start a while () loop with RT_YPlaneMin() and ascending threshold to get the %age of pixels with 128, then recalculate the average ond the basis of that amount } else { #RT_YPlaneMax()... } but that would fail if some blocks move in one direction, and some in the other. I could convert to RGBA, ResetMask(), ColorMask() to create a copy of these pixels in the mask clip. That's all so complicated. Do you have a better idea? Maybe a new function I give two numbers and the function tells me how many % of the pixels are in that range? That would also allow cool histogram functions. |
#38 | Link | |
I'll implement "Greater or equal to low" and "below high", if not as desired, say so. I'll look here again before I post link. EDIT: Ps, hope you saw the edit in the developer Call() thread concerning Exist().
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 1st October 2012 at 23:06. |
#39 | Link |
Here tis, given a moniker of YBetwixt(), (EDIT: "betwixt", usage archaic, "in the interval", ie "between")
EDIT: Link removed, See 1st post, renamed func to RT_YInRange(). Code:
As for RT_Stats funcs
YBetwixt(clip,int "n"=current_frame,int "delta"=0,int "x"=0,int "y"=0,int "w"=0,int "h"=0,bool "interlaced"=false,int "Matrix"=0,
int "lo"=64,int "hi"=192)
Returns Float % population of pixels above or equal to "lo" and below "hi".
If hi <= lo then will return 0.0
EDIT: If I do add it to RT_Stats, may return value in range 0.0-255.0 comparable to other RT_Stats funcs, can easily convert to percent by *100.0/255.0
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 3rd October 2012 at 18:07. |
#40 | Link |
@Stainless
Re RT_Stats One thing I noticed is that RT_Stats won't work reading an imagelist if the imagefile name is e.g. %big_file06.jpg - the problem being the % [probably some other funky characters as well] Is there a way to overcome this without having to rename the files in question? TIA |
| Tags |
| averageluma, correlation, lumadifference, runtime |
| Thread Tools | |
| Display Modes | |
