#1 | Link | |
Simple Runtime Function
This moved here from another thread:
http://forum.doom9.org/showthread.ph...43#post1582243 Quote:
#include <windows.h>
#include "Avisynth.h"
// Helper function - exception protected wrapper, From Avisynth source, conditional.cpp
inline AVSValue GetVar(IScriptEnvironment* env, const char* name) {
try {return env->GetVar(name);} catch (IScriptEnvironment::NotFound) {} return AVSValue();
AVSValue __cdecl AveLuma(AVSValue args, void* user_data, IScriptEnvironment* env) {
PClip child = args[0].AsClip();
int n;
if(args[1].IsInt()) {n = args[1].AsInt(); }
else {
AVSValue cn = GetVar(env,"current_frame");
if (!cn.IsInt()) env->ThrowError("AveLuma: 'current_frame' only available in runtime scripts");
n = cn.AsInt();
const VideoInfo &vi = child->GetVideoInfo();
n = (n<0) ? 0 : (n>=vi.num_frames)?vi.num_frames-1:n; // Range limit frame n
PVideoFrame src = child->GetFrame(n,env);
int h,w;
const int pitch = src->GetPitch(PLANAR_Y); // PLANAR_Y no effect on non-Planar (equates to 0)
const int rowsize = src->GetRowSize(PLANAR_Y);
const int height = src->GetHeight(PLANAR_Y);
const BYTE *srcp = src->GetReadPtr(PLANAR_Y);
const double Pixels = (double)(height * vi.width);
__int64 acc = 0;
unsigned long sum = 0;
if(vi.IsYUV()) {
const int wstep = (vi.IsYUY2()) ? 2 : 1;
for(h=height ; --h >= 0 ; ) { // h is upside down to actual scan
// for (w=0 ; w < rowsize; w += wstep) { // w scans left to right
// Slightly faster on non-optimized compiler, about same on optimised compiler
for (w=rowsize ; (w -= wstep) >= 0; ) { // w scans right to left
sum += srcp[w];
if(sum & 0x80000000) {acc += sum;sum=0;} // avoid possiblilty of overflow
srcp += pitch;
} else {
// RGB to YUV-Y Conversion
int matrix = args[2].AsInt(0); // Default=0=REC601 : 1=REC709 : 2 = PC601 : 3 = PC709
if(matrix & 0xFFFFFFFC) env->ThrowError("AveLuma: RGB matrix 0 to 3 Only");
double Kr,Kb;
int Sy,offset_y;
if(matrix & 0x01) {Kr = 0.2126; Kb = 0.0722;} // 709 1 or 3
else {Kr = 0.2990; Kb = 0.1140;} // 601 0 or 2
if(matrix & 0x02) {Sy = 255 ; offset_y = 0;} // PC 2 or 3
else {Sy = 219 ; offset_y = 16;} // TV 0 or 1
const int shift = 15;
const int half = 1 << (shift - 1);
const double mulfac = double(1<<shift);
double Kg = 1.0 - Kr - Kb;
const int Srgb = 255;
const int Yb = int(Sy * Kb * mulfac / Srgb + 0.5); //B
const int Yg = int(Sy * Kg * mulfac / Srgb + 0.5); //G
const int Yr = int(Sy * Kr * mulfac / Srgb + 0.5); //R
const int OffyPlusHalf = (offset_y<<shift) + half;
const int wstep = (vi.IsRGB24()) ? 3 : 4;
for(h=height ; --h >= 0; ) { // h is same as actual RGB scan, bottom to top
// Seems slightly faster on optimized compiler, nothing in it on non optimized.
sum += (srcp[w] * Yb + srcp[w+1] * Yg + srcp[w+2] * Yr + OffyPlusHalf) >> shift;
srcp += pitch;
acc += sum;
return (float)((double)acc / Pixels);
extern "C" __declspec(dllexport) const char* __stdcall AvisynthPluginInit2(IScriptEnvironment* env) {
env->AddFunction("AveLuma", "c[n]i[matrix]i", AveLuma, 0);
return "`AveLuma' AveLuma plugin";
AviSource("D:\avs\avi\1.avi")
#Return AveLuma() # Show "AveLuma: 'current_frame' only available in runtime scripts"
V1=ScriptClip(""" Subtitle(String(AveLuma),Align=1) """ ) # Default current_frame
#V1=ScriptClip(""" Subtitle(String(AveLuma(current_frame)),Align=1) """ ) # current_frame explicitly supplied
#V1=ScriptClip(""" Subtitle(String(AveLuma(current_frame-100)),Align=1) """ ) # current_frame relative
V2=ShowChannels() # for comparison
StackVertical(V1,V2)
Works just fine. Another test script: Demos in YV12, YUY2, Y8, RGB24, RGB32, YV16, YV24 etc (RGB mode, converts and returns RGB to YUV Luma) Added Matrix arg The result (Subtitled Average Accumulated Luma) is valid on the final frame. Code:
AviSource("D:\avs\avi\1.avi").trim(0,0999)
# Set to ConvertToRGB matrix
COL = 0 MATRIX = "rec601" # Default 0=REC601
#COL = 1 MATRIX = "rec709"
#COL = 2 MATRIX = "pc601"
#COL = 3 MATRIX = "pc709"
#ConvertToYV12()
#ConvertToYUY2()
#ConvertToY8()
#ConvertToYV16()
#ConvertToYV24()
#ConvertToRGB24(matrix=MATRIX)
#ConvertToRGB32(matrix=MATRIX)
Sum = 0.0
SumHi=0.0 # Hi part Extra precision (need for long scans)
SumLo=0.0 # Lo part Extra precision
GScript("""
for(n=0,FrameCount()-1) {
# Sum = Sum + AveLuma(n,matrix=COL) # Were gonna use extra precision instead
SumLo = SumLo + AveLuma(n,matrix=COL)
SumHi = SumHi + floor(SumLo / 256.0) # Hi part, Extra Precision
SumLo = frac(SumLo / 256.0) * 256.0 # Lo part, Extra Precision
# Sum=Sum/Float(FrameCount()) # Were gonna use extra precision instead
Sum = (SumHi / Float(FrameCount()) * 256.0) + (SumLo / Float(FrameCount()))
ConvertToYV12(matrix=MATRIX) # For Display and Showchannels info
s=showchannels() # Show eg Ave Luma for frame and Accumulated Ave luma for all frames visited
s.Subtitle(String(Sum),Align=1)
http://forum.doom9.org/showthread.ph...me#post1394689 EDIT: Added, YUY2, RGB and v2.6 planar modes. Renamed to AveLuma EDIT: Added matrix arg: 0=rec601 : 1=rec709 : 2=pc601 : 3=pc709 EDIT: Minor mods EDIT: Accumulator now 64 bit. AveLuma(clip , int "n", int "matrix") : n defaults to current_frame : matrix defaults=0=rec601 EDIT: About 10% slower than AverageLuma (in above GScript test) as no SSE, BUT, supports optional frame number (or eg current_frame-2), YUY2 and RGB with conversion to Luma. EDIT: ShowChannels() Available via MediaFire in sig EDIT: Seems that this thread subject is/was almost identical to example from Avisynth Docs: http://avisynth.org/mediawiki/Filter...on-clip_sample
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 31st July 2012 at 03:11. |
#3 | Link |
If I understand properly, a simple
srcp -= (pitch * height); (You want to process the same frame again ?) EDIT: If you want to process say n to n+3, then something like Code:
unsigned long sum_store[4];
frm = n; // rem starting frame
for (z=0 ; z< 4;++z) {
n=frm+z;
const float Pixels = (float)(height * rowsize);
int h,w;
for(h=0; h<height; ++h) {
for (w=0; w<rowsize; ++w) {
sum += srcp[w];
srcp += pitch;
sum_store[z] = sum;
AverageLuma results to a file for every frame, look at MatchFrames, although there are probably much shorter examples, matchframes would require a fair amount of chopping out of unnecessary stuff. Tell you what take a peek at the Gavino FindFrames linked by Matchframes., and use WriteFile instead of WriteFileIf variation (if that's what it uses). Also see ConditionalReader (which I have not yet used).
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 12th July 2012 at 17:40. |
#4 | Link | |
Super Moderator
![]() Join Date: Nov 2001
const BYTE *srcp = src->GetReadPtr(PLANAR_Y); ... srcp = src->GetReadPtr(PLANAR_Y); Last edited by Wilbert; 12th July 2012 at 21:12. |
#5 | Link |
One asterisk too many Wilbert.
#6 | Link |
@Anybody interested (I'm sure there are those that know already).
I just tried the above filter but using an 'n' frame number argument, in a GScript script, I was expecting some kind of problem that did not appear, here:- Code:
AviSource("D:\avs\avi\1.avi").trim(0,999)
sum=0.0
GScript("""
sum=sum+AveLumatest(n)
sum=sum/Float(FrameCount())
s=showchannels()
s.Subtitle(String(sum),Align=1)
autocropping, field order, interlacing, pulldown etc, and then process clip proper, all in single pass could be incorporated into an automated rendering system, this is just what I was looking for. It's only the missing 'current_frame' that prevents runtime functions from working properley outside of the runtime environment, if you supply your own frame number (as the above plug allows), then GScript supplies the magic dust. Runtime filters, running either at runtime or during compile time. ![]() EDIT: Although, if you assign values to current_frame directly, that also works for built in runtime filters (I think, cant remember where I've used it though, Oh, of course, MatchFrames). OK, it's NOT as wonderful as I first thought, being able to supply a frame arg is pretty much the same as synthesizing the missing current_frame, wish I understood the compile time run time stuff properly, but at least the automated prescan stuff still holds true. EDIT: The result (Accumulated Average Luma) is valid on the final frame.
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 31st July 2012 at 03:13. |
#7 | Link |
Not to worry, it was only a calculation over pixels which required two passes. I did multiple frames in taverage. Which reminds me, how did I solve it there?
I think I'm not clear on pointers. It makes perfect sense that a variable has an address in memory that it's stored, and that I can manipulate this address as a form of indexing. When you define Code:
const BYTE *srcp = src->GetReadPtr(PLANAR_Y); I also don't get how a pointer can be a constant, wouldn't that mean you can't increment it? The byte must indicate the way the pointer increments; if it were int (and int were 16bit), then adding 1 to the pointer would really add 2. So adding pitch to the pointer is going to the next row (which includes some padding for alignment). srcp[0]=n would place n at the current address, where n would be cast to BYTE. Is this right? My problem is, if I reset the pointer do srcp=0 is that setting the address to 0, or is it setting the memory pointed to to 0? If I set *scrp=0 that should mean address 0 which is probably going to crash. If I do const BYTE *scrp=src->Get... again, it will say I redefined a variable. If I set *scrp=src->GET.. it gave me another error. And strangely enough, in my latest code I didn't reset it at all and it still worked, but I don't know why. |
#8 | Link | ||
srcp is a pointer (*) to type "const BYTE", meaning that what it points to cannot be altered (const), ie read only.
It's just allowing the compiler to do checking to enforce your compliance with the wishes of the developer that implemented GetReadPtr. src->GetReadPtr(PLANAR_Y); You are calling the GetReadPtr member function of class PVideoFrame via src. You access the member functions just like you access struct members. I'm a bit rusty on this but in C, I think you can also call a function pointer in a struct using the same pointer teminology, eg src->GetReadPtr(PLANAR_Y). A class can have both member properties (data) and member functions (like constructor, GetFrame etc) and you can call those member functions via a pointer to an instance of a class, and those member functions can access the properties (data) for the particular instance of the class on which it was called (really clever stuff). For instance, you could have two copies of the same filter (class, like a structure with member functions), if you call eg GetFrame on a particular instance of the filter, there is no confusion about which data members belong to it, they can be treated like local variable. In the CPP for proggers thing, each instance of the Example class would have it's very own 'LongLife' property and when Avisynth calls the filter via f->GetFrame(n), GetFrame knows which LongLife belongs to filter 'f'. (It's all very clever, with a lot of behind the scenes stuff going on and a secret pointer called a 'this' pointer, which you dont really need to know anything about, but the 'this' pointer points at the particular instance of a class data, that is the sort of secret way that member functions know which class data members are local to them [if that makes sense]). Quote:
*srcp = 0; is zeroing what p points at. // Hopefully OK EDIT: *srcp=0; is same as srcp[0]=0; As Wilbert said, const BYTE *srcp = src->GetReadPtr(PLANAR_Y); Can do this the first time ... srcp = src->GetReadPtr(PLANAR_Y); do this thereafter The *srcp= src->Get etc was a typo, Wilbert fixed it. "And strangely enough, in my latest code I didn't reset it at all and it still worked, but I don't know why. " Your god looks after you. ![]() EDIT: By the way you can check out the Avisynth.h header to see some of the Avisynth classes etc.
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 13th July 2012 at 02:09. |
#10 | Link |
Jmac, forgot what it was that you were trying to do, (as posting over multiple threads).
Firstly, now that you've changed operation, (ie now using a sum array in taverage [I assume thats what we're talking about]) You need not a 'const BYTE * srcp =GetReadPtr(PLANAR_Y)' but a BYTE * srcp =GetWritePtr(PLANAR_Y);' as although you only read on first pass (summing), on second pass (to update the frame itself) you will write to it, so you might as well get a write pointer from the beginning, and dont use 'srcp =GetWritePtr(PLANAR_Y)' for the second pass, use the "srcp -= (pitch * height);" for as we found out, excessive calls to GetWritePtr can cause problems, so why tempt fate. You would also need to reset sum ie sum = LifeLong (if thats what you used, I have not seen the taverage source). EDIT: Seems that this thread subject is almost identical to example from Avisynth Docs: http://avisynth.org/mediawiki/Filter...on-clip_sample Dont know if thread should be closed. Perhaps does have merit due to example implementation of Gavinio's suggested "exception protected wrapper", and direct use of optional frame arg.
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 13th July 2012 at 20:56. |
#11 | Link | |
Super Moderator
#13 | Link |
Added, YUY2, RGB and v2.6 planar modes. See 1st post.
#14 | Link |
Added matrix arg for RGB -> YUV_Y modes. 0=rec601:1=rec709:2=pc601:3=pc709
See 1st post. EDIT: If no problems reported, will publish in Usage Forum.
#15 | Link |
Minor Mods. See 1st post.
#16 | Link |
Excessively jovial fellow
Why on earth have you implemented your own YUV-to-RGB conversion in an Avisynth plugin? Try something like this:
const char *argnames[2] = {0, "matrix"};
AVSValue args[2] = {child, "Rec.601"};
// might want to handle potential exceptions here, but who cares
PVideoFrame yv12_frame = env->Invoke("converttoyv12", AVSValue(args, 2), argnames).AsClip()->GetFrame(n, env);
#18 | Link | ||
you can even invoke loadplugin or import to load more functions, if you want to you can also, like, read the filtersdk documentation if you're wondering about something related to filter development, it's actually pretty good Quote:
Slightly academic, but this can overflow with very large frames (slightly bigger than 4096x4096). If you want a 64-bit integer with MSVC in 32-bit mode use __int64 (or #include <stdint.h> and use int64_t). sizeof(long) is 4 in pretty much all 32-bit compilers. Last edited by TheFluff; 18th July 2012 at 21:39. |
#19 | Link | ||
unsigned int accum = 0; EDIT: I'll look at the "YUV-to-RGB conversion", thanks, but dont look hopeful as would require invoke on every frame (runtime filters dont have constructors), from the link you posted: Quote:
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 19th July 2012 at 17:13. |
#20 | Link |
One of my uses, would be for example in drawing test patterns in deepcolor, there's nothing to convert here, I'd have to supply an INT for each color channel. 10bit colorbars are used professionally, even something that simple would require this. I've also proven that color conversions require at least 10bit precision, namely the conversion of yellow. You can tell if yellow was converted properly if it's Y is 162 instead of 161, as it relies on a 10 bit precision. (I mean, rec601 yellow in 75% colorbars).
| Tags |
| runtime, runtime error, runtime functions |
| Thread Tools | |
| Display Modes | |
