#41 | Link |
Could you provide small sample of remuxed mkv, if you remuxed it by yourself (did you use Solveig mkv muxer?)
Solveig Multimedia - Video Editing Software |
#42 | Link |
Yes, it puts data to container as is and marks it as ac3. No parsing for now.
You can remux m2ts to mkv and then play it by splitter. What did you mean m2ts support? Thanks for information this will be resolved soon.
#44 | Link | |
#45 | Link | ||
On the other hand we need a mkv source file for remuxing since no muxer does accept seperate files as source files. (on Graph things.) So, for testing we don't have any sample in our hands as an mkv. (which includes thd+ac3) Quote:
Create a m2ts via TSMuxer using h264 and thd+ac3 raw files extracted by eac3to. Split with Solveig m2ts splitter and remux to mkv via Solveig mkv muxer. My expectation is to create an mkv which includes a thd+ac3 file. (even renamed as ac3-doesn't matter.) And i was trying to ask if it is gonna be possible to use Solveig mkv splitter as an m2ts splitter (like Haali) as well or do i need to use the splitter.ax of Solveig splitter-editor? Last edited by rica; 1st June 2010 at 02:38. |
#46 | Link | |
#48 | Link | |
Remux it without subtitle and try again.(or maybe chapters as well?) Don't forget developers trying to explore the deficiencies. This is why we are trying. Last edited by rica; 1st June 2010 at 01:54. |
#49 | Link | |
And it doesn't recognize new audio formats at all: ![]() EDIT: I'll give it a try with Gabest/Haali Source filter as splitter and Solveig muxer filter as muxer. LAST EDIT: I gave it a go with Gabest with DTSHD m2ts but Solveig needs an audio decoder this time like Cyberlink audio decoder. As for Haali: i gave it a try with thd+ac3 m2ts. This time Haali works but Solveig muxer/splitter can not. _ _ _ _ _ Last edited by rica; 1st June 2010 at 02:47. |
#50 | Link | |
Mkv splitter demux only mkv (no m2ts). If you got it work with Gabest which output guid it provides for audio(why it needs audio decoder)? Anyway it will be more fast resolving if you post a sample of m2ts.
#55 | Link | |
THD.m2ts: http://www.mediafire.com/?jzmijuzgdq4 DTSHD.m2ts: http://www.mediafire.com/?odmgz2ymd1j BTW i get always blue-light with this chain: ![]() Thanks. |
#58 | Link |
Regarding your deleted post in the General Discussion forum: The procedure for contesting strikes is documented here:
http://forum.doom9.org/sanctions.htm At this point you can contest only your rule 17 strike and not the initial rule 6 strike, because you complained about it in the public forum. I note your extensive history of rule 4, 6, 8, and 11 strikes. Last edited by Guest; 2nd June 2010 at 06:59. |
#59 | Link |
Updates:
SMM_MatroskaSplitter (version - 1.0.1006.7) SMM_MatroskaMuxer (version - 1.0.1006.7) Changes/Fixes: Splitter: Seek speed optimization Dynamic data buffer allocation + Memory load minimization. Muxer: mux dtshd-ma as "dts". conformity muxer's output to spec (checked by mkvalidator)
Solveig Multimedia - Video Editing Software Last edited by Stanislav Mikhailenko; 7th June 2010 at 09:41. |
#60 | Link | |
SMM_MatroskaSplitter (version - 1.0.1006.7) SMM_MatroskaMuxer (version - 1.0.1006.7). Now it should work. I've remuxed samples with new version of muxer and played it with the splitter.
| Thread Tools | |
| Display Modes | |
