#21 | Link | |
I will upload short samples later. Last edited by rica; 17th May 2010 at 16:02. |
#22 | Link |
dtshd-ma sample:
http://www.mediafire.com/?tmufzougmjt thd sample: http://www.mediafire.com/?5rjhgj1wyzk (btw thd mkv doesn't include ac3 core but thd alone since mkvmerge can not mux them together. On the other hand with graph method Haali or Gabest mkvmuxer can mux only ac3 core while the source file is thd+ac3 -demuxed via eac3to.) Last edited by rica; 17th May 2010 at 21:38. |
#23 | Link |
Re: my earlier post. I have now upgraded Media Player Classic HC to the newer build 1.3.1881.0
,and changed to using the recent FFDShow-Tryouts build to decode H264 (ffdshow_rev3435_20100512_sse_icl11.exe), instead of an MPC filter. Now what happens is I don't get the shimmering blocking for a few seconds after seeking, but instead when I seek the picture frame 'freezes' for a couple of seconds or so and then catches up with the audio. I am going to try the newer MKV filters you are posting in this thread.
Thankyou!, I am grateful for any help |
#24 | Link |
Updates:
SMM_MatroskaSplitter (version - 1.0.1005.19) SMM_MatroskaMuxer (version - 1.0.1005.19) Changes/Fixes: Splitter: Fixed shimmering when seeking (Regressive bug) Muxer: Fixed unable to mux avc video streams an exception occures (Regressive bug)
Solveig Multimedia - Video Editing Software Last edited by Stanislav Mikhailenko; 19th May 2010 at 09:24. |
#25 | Link | |
Solveig Multimedia - Video Editing Software |
#26 | Link | |
_ _ _ _ _ Last edited by rica; 19th May 2010 at 20:20. |
#27 | Link |
There was an ax only and now it is, what do you mean?
#28 | Link |
Hello, I can confirm that with the new splitter version 1.0.1005.19 the 'pausing after seeking' problem is almost gone.
It still pauses noticeably (this is on my fast system) for just 1 second maybe a little less, but not a problem for me. This is a very good splitter, thankyou.
#29 | Link | |
Hello video_magic, Thank you for your help! Concerning Pause, it is important to figure out if it the Splitter problem or not. Do you still test it with MPC? Could you check MPC without our Splitter with the same stream to say if it is better or same? |
#30 | Link | |
Regarding MKV chapters, they work as standard when using mpc matroska splitter and haali media splitter. Players such as MPC-HC use them. Thanks |
#32 | Link | |
I successfully unregistered your filter (regsvr32 /u C:\1tmp\SMM_MKVSplitter.ax) I then installed the newest Haali Splitter build from today 20-05-10 (v1.10.175.0)! This new Haali Matroska splitter worked fine without the brief pause after each seek, in Media Player Classic HC.
#34 | Link |
Updates:
SMM_MatroskaSplitter (version - 1.0.1005.27) SMM_MatroskaMuxer (version - 1.0.1005.27) Changes/Fixes: Splitter: BugFix: accurate seeking on B-frames with correct prerolling "A_TRUEHD" True HD ac3 audio support. Seek TIME_FORMAT_FRAME support + start/stop seek positions Muxer: muxing AVC: slice type (I,P,B) determination by parsing coded data ( not by using sample times). Both: upgrade to libmatroska 0.9.0
Solveig Multimedia - Video Editing Software Last edited by Stanislav Mikhailenko; 28th May 2010 at 07:33. |
#35 | Link | |
dtshd-ma sample: plays and seeks well without any problems using "ffdshow video decoder", may be it's disfunction of "microsoft dtv-dvd video decoder" (Win7 tweak tool will help "http://www.codecguide.com/windows7_preferred_filter_tweaker.htm") thd sample: I've added "A_TRUEHD" audio support to splitter. SMM_MatroskaSplitter (version - 1.0.1005.27) PS: in archive shouldn't be any ".exe" there is only ".ax" file.
#36 | Link | |
It works for both without any issue. Haven't tried muxer yet, is it muxing ac3 core and thd together? Second, is it possible to give m2ts support to splitter? Thx. |
#37 | Link |
I'm curious about this one to. MKVMerge and MakeMKV both remove the core AC3 file from a TrueHD soundtrack. I would love to be able to keep, so TrueHD behaviour is the same as DTS-HD! You then have automatic AC3 bitstream backup... automatic in the fact that you don't have to select a separate track.
Also, this is probably a stupid question, but how do you use a muxer when it's a .ax file on it's own? I'm only used to using a complete solution like MKVMerge. Cheers |
#38 | Link | |
I use Graph things for remux. (GraphEdit or GraphStudio) Ideally for every separate files *.h264 or *.thd should connect to any muxer via file source (Async) filter. But no chance. So finally for Gabest or Haali, you may connect any m2ts via Gabest or Haali Source filter to any muxer; since both filters are source/splitter filter as well and also muxing filters are muxer/file writer. ![]() But for Solveig: it's not a source filter, just a splitter by alone. So you have to use File Source (Async) before. And also, Solveig muxer is not a combined filter like Haali or Gabest, so you have to use File Writer Filter after muxing. And it's just an mkv splitter and this time the source file must be an mkv: ![]() But my trials showed me today DTSHD-MA mkv can be muxed with Solveig muxer but while playing the remuxed file, i got this: ![]() And i couldn't remux a THD mkv since Graphthings crashed while muxing. _ _ _ _ _ _ Last edited by rica; 30th May 2010 at 23:27. |
#39 | Link |
With the newest SMM Splitter 1.0.1005.27 there is still the little '1 second or less' pause after seeking, which the newest haali splitter doesn't have.
Here is the mediainfo report on the mkv which exhibits that behaviour: Code:
Format : Matroska
File size : 1.63 GiB
Duration : 2h 27mn
Overall bit rate : 1 586 Kbps
Encoded date : UTC 2009-10-13 15:23:38
Writing application : mkvmerge v2.9.8 ('C'est le bon') built on Aug 13 2009 12:49:06
Writing library : libebml v0.7.7 + libmatroska v0.8.1
Video
Format : AVC
Format profile : High@L3.1
Format settings, CABAC : Yes
Format settings, ReFrames : 3 frames
Muxing mode : Container profile=Unknown@3.1
Codec ID : V_MPEG4/ISO/AVC
Duration : 2h 27mn
Bit rate : 1 170 Kbps
Nominal bit rate : 1 200 Kbps
Width : 720 pixels
Height : 416 pixels
Display aspect ratio : 16:9
Frame rate : 25.000 fps
Resolution : 8 bits
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.156
Stream size : 1.20 GiB (74%)
Writing library : x264 core 68 r1183M f21daff
Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy_rd=1.0:0.0 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=-2 / threads=3 / nr=0 / decimate=1 / mbaff=0 / bframes=3 / b_pyramid=0 / b_adapt=1 / b_bias=0 / direct=1 / wpredb=1 / keyint=250 / keyint_min=25 / scenecut=40 / rc=2pass / bitrate=1200 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:1.00
Language : English
Audio
Format : AC-3
Format/Info : Audio Coding 3
Format_Settings_ModeExtension : CM (complete main)
Codec ID : A_AC3
Duration : 2h 27mn
Bit rate mode : Constant
Bit rate : 384 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Stream size : 404 MiB (24%)
Language : English
| Thread Tools | |
| Display Modes | |
