Thread Tools Display Modes
Old 6th October 2010, 15:57   #221  |  Link
Sebastiii
Thx
HTPC : i7 920 6Go Win10(x64) / Nvidia 1050Ti / P6T Deluxe / Harman-Kardon AVR-355.
Sebastiii is offline   Reply With Quote
Old 7th October 2010, 12:01   #222  |  Link
Tacio
Would someone explain differences/advantages between this splitter and Haali splitter?
Tacio is offline   Reply With Quote
Old 7th October 2010, 14:24   #223  |  Link
SamuriHL
SamuriHL's Avatar
It can properly pass DTS-HD MA tracks from an MKV to ffdshow that aren't corrupted? Haali has a nasty bug that breaks bitstreaming with MKV/DTS-HD MA tracks that are made with anything other than MakeMKV. SolveigMM does not have this problem.
Old 7th October 2010, 21:27   #224  |  Link
Kurtnoise
Swallowed in the Sea
Kurtnoise's Avatar
1/ Any chance to port these filters into Media Foundation ?
2/ Could you add these audio formats please ?
- A_EAC3
- A_MLP
- A_TRUEHD
edit: haali splitter is able to split matroska files w/ nested chapters, not this one iirc.
Old 7th October 2010, 22:29   #225  |  Link
rica
Guys i can't find a current source filter for muxing with Solveig.
New versions of Gabest splitter:
Either can not link the audio pin to muxer,
Or put MS DTV-DVD Audio decoder between source and muxer (for PCM), or put ffdshow audio decoder (for THD).
DTSHD-MA can be linked directly btw.
Dear developers, what do you suggest?
EDIT: Sorry, that's not the source filter issue; there must have been a problem on my PC: fixed.
The only issue left that i haven't been able to fixed is
to connect the subtitle:
Any ideas?
_ _ _ _
rica is offline   Reply With Quote
Old 10th October 2010, 12:37   #226  |  Link
cge
I've tried this new build but I can't select streams from ffdshow because video track are listed in audio section and audio tracks are listed in sub section !!!
Other issues are:
1- "No Subtitles" still not selected by default if none of other sub streams have default/forced flag set
2- PGS sub doesn't work, only tested with mks embbeded PGS sub
Christophe
cge is offline   Reply With Quote
Old 11th October 2010, 04:38   #227  |  Link
Stanislav Mikhailenko
Stanislav Mikhailenko's Avatar
May be in future. "For some time there will be a co-existence of Media Foundation and DirectShow." WIKI .
Could you explain why do you need this?
- A_EAC3
- A_MLP
- A_TRUEHD
There are already A_TRUEHD
(with MEDIASUBTYPE_DOLBY_TRUEHD eb27cec4-163e-4ca3-8b74-8e25f91b517e)
and A_EAC3 (with FOURCCMap(0x2000) as for regualar A_AC3)
If you have files which can't be opened please upload it to some hosting we will check that.
Could you say what is A_MLP and how subtype info should be saved (in matroska codecs spec there is no such format)
Or provide the mkv file with such audio.
Solveig Multimedia - Video Editing Software
Stanislav Mikhailenko is offline   Reply With Quote
Old 11th October 2010, 04:43   #228  |  Link
Any ideas?
What is subtype information on property page of subtitle pin graphstudio shows? (right mouse click on pin -> Properties)
Old 11th October 2010, 04:51   #229  |  Link
Originally Posted by cge View Post
Not exactly catch that, could you provide the screenshot of the problem? The Stream Selection managed by the Splitter itself not by ffdshow.
Other issues are:
Christophe
1. Yes, The first issue was missing. Will fix it on next update.
2. PGS subs was tested only once (with only one file), so could you provide your file by uploading to some hosting? I'll check that.
Old 11th October 2010, 04:53   #230  |  Link
It can dump playable ANNEXB VES for AVC video.
Old 11th October 2010, 09:03   #231  |  Link
Kurtnoise
Kurtnoise's Avatar
For my own tool, based on MF...
This is wrong...I've got some files with this subtype : {0xAF,0x87,0xFB,0xA7,0x02,0x2D,0xFB,0x42,0xA4,0xD4,0x05,0xCD,0x93,0x84,0x3B,0xDD}. I'll upload a sample tonight.
This page is outdated...this is clearly mentioned. You should read mkvtoolnix's code to be up-to-date.
I'll upload several samples tonight.
Old 11th October 2010, 13:50   #232  |  Link
Thanks for samples,
If your tool is commercial you can directly contact us to discuss this.
Old 11th October 2010, 19:57   #233  |  Link
rica
{04EBA53E-9330-436C-9133-553EC87031DC}
Old 13th October 2010, 21:58   #234  |  Link
cge
Here a mkv sample with embedded PGS, note that it works fine using Haali.
Regards
Christophe
Old 14th October 2010, 20:18   #235  |  Link
cge
Hi Stan,
Here the requested screendump, splitter stream selection pop up menu is ok but it's not the case through ffdshow.
Regards
Christophe
Old 18th October 2010, 20:23   #236  |  Link
Kurtnoise
Kurtnoise's Avatar
ok...trueHD is working but EAC-3 doesn't. Here is a sample.
Originally Posted by Stanislav Mikhailenko;1449681Could you say what is A_MLP and how subtype info should be saved (in [URL="http://www.matroska.org/technical/specs/codecid/index.html"
matroska codecs spec[/URL] there is no such format)
http://www.mediafire.com/?lwgacj3bwtau1yl
Old 19th October 2010, 10:20   #237  |  Link
nevcairiel
MLP is the format that TrueHD uses, well, or based on, anyway. TrueHD is an "enhanced" MLP. I don't know of any subtype for MLP itself, so maybe going with the TrueHD subtype is the best choice there.
Old 19th October 2010, 13:12   #238  |  Link
SamuriHL
SamuriHL's Avatar
Take a look at the source code for ffdshow. I'm pretty sure it has some of the types in there. I can't remember if MLP was there or not.
Old 19th October 2010, 17:08   #239  |  Link
robpdotcom
If it's any help, I have an mlp track; ffdshow shows it as TrueHD, and so does my AVR.
Windows 7 x64
i7 870
16GB RAM
AMD 6870
robpdotcom is offline   Reply With Quote
Old 25th October 2010, 09:47   #240  |  Link
I've checked this sample it works fine using ffdshow as audio decoder. Which decoder did you use?
about mkvtoolnix i've found only in src code:
strlen(MKV_A_AC3)) || (t->codec_id == MKV_A_EAC3))
t->a_formattag = 0x2000;
and seems it has the same format tag. But which guids of subtypes it needs i didn't find.
If you provide the proof link which subtype needs when A_AC3 is used and when A_EAC3 it will be good. For now it remains as is.
Thread Tools
