Thread Tools Display Modes
Old 3rd August 2010, 17:18   #201  |  Link
littleD
littleD's Avatar
OK, styled subtitles works. I found that ffdshow by default load external str sub and doesnt allow change stream to internal one. When i remove srt file, ffdshow load internal sub, but font is so big...
When i use ffdshow for DXVA and subs, in icon tray i see as no_named subtitle stream "A: ". Weird, It shouldt be "S: "? Bug of splitter or ffdshow?
Concerning forced flag. It can be set for any stream. Is it possible to play simultaneously two subs, or maybe two audio files?
littleD is offline   Reply With Quote
Old 3rd August 2010, 17:19   #202  |  Link
cge
According to me the rules with default and forced subs flag should be:
1- If at least one track has default flag set then select this track (Highest priority and should override forced flag)
2- If forced flag is set then the splitter should automatically select the subs track with the same language as the current audio track (selected audio track), example if audio track is in French by default then select the forced French subs stream if exists (Else select "No subs"), if English audio stream get selected then automatically switch to the forced English subs stream if exists(Else select "No subs"), and so on.
Regards
Christophe
cge is offline   Reply With Quote
Old 3rd August 2010, 17:31   #203  |  Link
robpdotcom
That's exactly how I thought it should work too. Then, streams flagged "forced" would always load, and if no "forced" streams are found, then no subs are loaded. Also, the user always would have the option to override the flags, and select any stream.
robpdotcom is offline   Reply With Quote
Old 3rd August 2010, 17:32   #204  |  Link
SamuriHL
SamuriHL's Avatar
I could go with that model.
Old 4th August 2010, 15:36   #205  |  Link
Stanislav Mikhailenko
Stanislav Mikhailenko's Avatar
This from matroska spec:
Flag Default - Set if that track (audio, video or subs) SHOULD be used if no language found matches the user preference.
Flag Forced - Set if that track MUST be used during playback. There can be many forced track for a kind (audio, video or subs), the player should select the one which language matches the user preference or the default + forced track. Overlay MAY happen between a forced and non-forced track of the same kind.
Flags Are applied to tracks, not for separate samples.
Solveig Multimedia - Video Editing Software
Stanislav Mikhailenko is offline   Reply With Quote
Old 4th August 2010, 15:39   #206  |  Link
SamuriHL
SamuriHL's Avatar
Alrighty then.
Old 4th August 2010, 15:46   #207  |  Link
If you use mpc-hc menu Play->Filters->SMM MKV Splitter should show right tracks. Can't say anything about ffdshow.
Old 7th August 2010, 17:52   #208  |  Link
nevcairiel
Originally Posted by Stanislav Mikhailenko View Post
SMM splitter displays stream name which was set while muxing mkv file. If it was empty - nothing displayed. So there needs to add language of the track additionally to stream title. This will be done in next release.
Language will certainly greatly improve it. What i would really love however would be to simply dump a quick format recap in there, like the MPC-HC internal MPEG splitter does.
Just show what codec, for video what resolution, for audio how many channels and possibly bitrate.
I have yet to encounter a file that actually had a track name set in the mkv.
Additionally, all subtitles did show "No Subtitles". For subs the language would be enough, i guess. Showing there if a subs track is "forced" would be good, i guess.
Short of the shortcomings in the dropdowns, it seems to work beautifully now. The "lag" during startup i reported before seems to be gone, good job guys.
Now if we just had a proper MPEG-TS splitter to go with this. Anyone have the full (and latest) MPEG-TS spec and wants to share, so i can work on it?
Old 22nd August 2010, 17:44   #209  |  Link
mata7
mata7's Avatar
stan any new on supporting vob sub?
thanks
mata7 is offline   Reply With Quote
Old 23rd August 2010, 04:33   #210  |  Link
thanks
About "insert vobsubs filter if available" ? No, it's not done yet. Or is there another problem with it.
Old 23rd August 2010, 05:19   #211  |  Link
mata7
mata7's Avatar
yeah about insert vobsubs filter if was available, thanks
Old 21st September 2010, 04:13   #212  |  Link
Alex-Kid
Antronio's DV ambassador
Alex-Kid's Avatar
I didn't see this thread before. At the moment, this is the only application I found that let me mux TS files with mixed fields/MBAFF video. Mkvtoonix doesn't have support for TS files and it can't handle this kind of video properly, when it's demuxed to an elementary stream.
Thank you Dmitry. Saludos
By ALEX-KID
Alex-Kid is offline   Reply With Quote
Old 24th September 2010, 09:18   #213  |  Link
Dmitry Vergheles
Dmitry Vergheles's Avatar
Hi Alex-Kid,
Thank you. If you need it for busines purposes, we are implementing MKV Demuxer / Muxer to our Video Editing SDK -
http://solveigmm.com/?Products&id=EditingSDK
So, don't hesitate to contact us if you have any questions.
http://www.solveigmm.com/?Support&id=Feedback
Regards,
Dmitry Vergeles
Dmitry Vergheles is offline   Reply With Quote
Old 29th September 2010, 22:14   #214  |  Link
rica
Guys,
we are stil waiting you to finalize or pre-finalize your filters.
Thx.
rica is offline   Reply With Quote
Old 30th September 2010, 01:46   #215  |  Link
jdc0730
This is also causing issues with Media Control inside Media Center. The Audio tracks are listed as subtitles and there are no subtitle tracks listed (although it plays the default one). The video track is also identified as an audio track at least in media control. All that being said....
WOW
I have been struggling getting adequate performance from my blu-ray rips with HD Audio bitstream. Your splitter is hands done the best of the bunch. Files that would stutter in MPC-HC's standalone filter or Haali play smooth as silk with yours. If it played nicer with Media Control to allow for audio and subtitle switching, it would be nirvana. I honestly can't believe there is not more discussion about your splitter. I am very pleased to have found it.
jdc0730 is offline   Reply With Quote
Old 2nd October 2010, 22:56   #216  |  Link
Dmitry Vergheles
Originally Posted by rica View Post
Guys,
Thx.
Could you remind, what features you are waiting to be finalized?
Regards,
Dmitry Vergeles
Old 2nd October 2010, 23:14   #217  |  Link
mata7
mata7's Avatar
Old 5th October 2010, 22:45   #218  |  Link
rica
Hi Dmitry ,
I can see here (page 9) your latest version seems to be 1.0.1008.2.
Or it must have been 1.0.1008.13?
If so why it's absent here?
Dunno what version i gonna test
Or i've missed something?
_ _ _ __
Old 6th October 2010, 06:08   #219  |  Link
Updates splitter version - 1.0.1010.4 / muxer version 1.0.1009.6:
SMM Matroska Splitter/Muxer x86
SMM Matroska Splitter/Muxer x64
Changes/Fixes:
Splitter:
- mkv muxer/splitter chapters support - Navigation
- IAMExtendedSeeking iface for chapter in mpc
- Add to "stream select titles" language, because name can be empty
- bugfix with no subtitles for empty names
- matorska splitter fix for V_MS/VFW/FOURCC codecs params
- KaxVideoPixelWidth KaxVideoDisplayHeight not a mandatory element fix (hangup on some files)
Muxer:
- muxer file blocking not in running state.
Old 6th October 2010, 13:39   #220  |  Link
SamuriHL
SamuriHL's Avatar
Awesome! Thanks for the update!!
Thread Tools
