Thread Tools Display Modes
Old 26th July 2009, 14:17   #1  |  Link
Max of S2D
Machinima.com Director
Max of S2D's Avatar
WMV VCM - What about the runtime?
Hello there,
I'm planning on using the VCM Implementation of WMV along with VirtualDub. I'd like to know if this version actually uses the runtime installed on one's system; I wouldn't like it using an outdated component.
Max of S2D is offline   Reply With Quote
Old 26th July 2009, 14:36   #2  |  Link
Midzuki
Unavailable
Midzuki's Avatar
Since Windows XP Service Pack 0 , Microsoft, by default, doesn't let MS applications install outdated components. FWIW, the file wmv9vcm.dll hasn't been updated since 2003. More info at:
http://forum.doom9.org/showthread.php?t=112634
HTH.
Midzuki is offline   Reply With Quote
Old 26th July 2009, 15:12   #3  |  Link
Max of S2D
Max of S2D's Avatar
Yeah, I saw that. To be more exact, is the VCM going to use the latest runtime it will find or does it use its own?
Old 27th July 2009, 05:34   #4  |  Link
Midzuki
Unavailable
Midzuki's Avatar
The VfW interface of WMV9 is "self-contained" --- it's not related to the DirectShow "runtime files" for the latest Windows Media Player. Don't worry, it's not going to "downgrade" anything on your computer.
Old 27th July 2009, 11:10   #5  |  Link
benwaggoner
And what are you trying to do with it?
It'd be nice if he added straight-up Format SDK, DirectShow, or MediaFoundation support to VirtualDub, as that'd get better WMV support for free.
I know there was supposedly someone from Microsoft who said he couldn't at one point. But it's clearly allowed by the EULA. If someone from Microsoft waved him off, they were freelancing, and haven't been willing to fess up since .
Ben Waggoner
My Compression Book
Old 27th July 2009, 11:15   #6  |  Link
Dark Shikari
x264 developer
Dark Shikari's Avatar
Last I recall the VCM version doesn't even support B-frames...
Old 28th July 2009, 05:23   #7  |  Link
Max of S2D
Max of S2D's Avatar
Encode!
:v
I'd better use WME9 + AviSynth if it turns out not to be using the latest improvements, though...
Old 28th July 2009, 10:34   #8  |  Link
Blue_MiSfit
Derek Prestegard IRL
Blue_MiSfit's Avatar
Try out expression encoder 3 if you're hard-set on encoding VC-1. Otherwise, encode H.264 with x264 in a CLI based GUI, like MeGUI or Ripbot264.
Old 28th July 2009, 11:29   #9  |  Link
Max of S2D
Max of S2D's Avatar
Well, yes, VC1 is a restriction.
Is Expression Encoder definitely better than WME9, though? And does it support AviSynth input?
Old 28th July 2009, 18:50   #10  |  Link
benwaggoner
Yes and yes!
Faster, 8-way threaded encoder.
Better 2-pass VBR rate control
All the advanced registry key features implemented as parameters.
Honestly, you can probably cut bitrate in half at a given quality compared to the VCM codec.
If you can share any info about your scenario, I'd be happy to offer some tuning advice.
Ben Waggoner
My Compression Book
Old 28th July 2009, 21:07   #11  |  Link
Max of S2D
Max of S2D's Avatar
Sending 960x540 masters for upscale on HD 720p on YouTube, and download available at will on a site. Filesize limit is 400 megabytes, and the running time is between 2:30 and 20/30 minutes (it truly depends). It's entirely CG content (machinima actually).
Now I gotta see how much EE costs.
Also, does it support encoding from a set of PNG/BMP files, otherwise than through an AVS script? That's why I wanted to stick with VirtualDub + WMV VCM
EDIT: http://blogs.msdn.com/expressionenco...2/9845044.aspx
Unexpected. What limitations does this free version have, other than the uninteresting (in my case) smooth streaming?
Old 29th July 2009, 20:04   #12  |  Link
benwaggoner
Okay. So your bitrate range goes down to 2667 Mbps. That's in the reasonable range for 2-pass VBR for most Machima. But if you're uploading to YouTube, wouldn't you want 720p @ 1 Mbps? Or are these two different encodes?
Anyway, the VC-1 HD 720p VBR preset would be a good starting point. Is this 30p or 60p?
It'd start by turning on chroma search; CGI, particularly if there's colored text, can get help from that. Do you have any online samples of what you're working with?
AVS is pretty easy for that. If you have QuickTime Player Pro, you can also use it to make an image sequence (.mov reference movie)
For what you want to do, nothing.
You don't get the MPEG-2/H.264/AC-3 decoders, nor Smooth Streaming or MPEG-4/H.264 output.
But AVS to WMV, you'd get everything you'd need with the free version, and MUCH better quality and performance than VCM.
Ben Waggoner
My Compression Book
Old 30th July 2009, 00:51   #13  |  Link
Max of S2D
Max of S2D's Avatar
Sample: http://www.youtube.com/watch?v=GreFp6H7Lo0
I'm not the one that will upscale onto HD; that's the YouTube staff with their special things who are gonna do that.
Also, I stick with 25fps all the time.
Thanks a lot for the tips & tricks
Old 30th July 2009, 02:57   #14  |  Link
aldenml
I recomend you play a little with Smooth Streaming. I would like to see your videos with true HD quality. Regards.
aldenml is offline   Reply With Quote
Old 31st July 2009, 12:46   #15  |  Link
Max of S2D
Max of S2D's Avatar
Question: is there a way to embed a subtitle (SRT, for example) file into a WMV using EE3?
Old 31st July 2009, 15:34   #16  |  Link
Midzuki
Unavailable
Midzuki's Avatar
AFAIK, the ASF container only supports the "script command" type of subtitles But you can always remux the WMV stream into a less-inflexible container such as MKV
http://forum.doom9.org/showthread.php?t=147953
Old 31st July 2009, 19:44   #17  |  Link
benwaggoner
As Midzuki says, a WMV only has a script stream of text. If you're using Silverlight for playback, you've got plenty of control over how that's presented (or could do runtime rendering of .srt directly with a little managed code parser work). That wouldn't render in WMP.
In theory, SRT or anything coudl be muxed into ASF as user data, but existing players don't support it.
But if the script stream works for you, yes. You can either input captions directly, or import them in DXPF, SAMI, or XML format. It works quite nicely. You can also extract script streams from existing content back to XML
Ben Waggoner
My Compression Book
runtime, vcm, virtualdub, windows media format, wmv
Thread Tools
