Thread Tools Display Modes
Old 26th July 2010, 05:46   #2221  |  Link
MrVideo
MrVideo's Avatar
Everything is renamed now for 2021 and DGMultiSource is retained as a synonym for DGSource.
Damn, didn't know you did that already. There is nothing in the 2021 Readme file about the renaming. Even though I installed the latest version, I didn't notice the change. I just grabbed the files and copied them to the installed location. I'm just now getting around to catching up with the forum.
Suggest that the renaming info be placed in a future Readme file for those who are upgrading from a version earlier than 2021.
Old 26th July 2010, 06:03   #2222  |  Link
MrVideo
MrVideo's Avatar
I don't have a CRLF in my license file and it works...
I don't either. The license files (two of them) are edited on my Solaris 10 X86 server. EOL for unix is LF only. No issues
Old 26th July 2010, 06:20   #2223  |  Link
MrVideo
MrVideo's Avatar
Remove the -y 1. That option no longer exists.
Time for a WAG. If the -e and -h were placed in front of the -y, I'm guessing the -e and -h would have been honored and the use of the old option would never have been detected. The reason is that when the -y option was parsed, all further parsing of the command line stopped.
Normally (I'm speaking Unix world programming), when an illegal, or unknown, option is entered, the program bails with an error indicating that option such-and-such doesn't exist.
In this case, couldn't a GUI be poped up with the error message about the bad option, or spit it out to stderr? That would be a little more user friendly. It is easy to hit the wrong character and not know it. If that creates an error, let the user know.
Old 26th July 2010, 06:25   #2224  |  Link
MrVideo
MrVideo's Avatar
I will include a full history in the ZIP from now on.
Thanks, that is helpful.
Old 26th July 2010, 06:35   #2225  |  Link
MrVideo
MrVideo's Avatar
Originally Posted by jimmydrac View Post
I was in the process of sending the license file to Donald so he could tell me what I was doing wrong when I noticed I had named the file license.txt intead of a text file named license. DUH. Works great now....I feel so dumb.
But license,txt is the correct filename. As mentioned in a previous post, you probably have extension display turned off and you ended up naming your file license.txt.txt. You can thank Windblows for knowing exactly what you want and doing it for you.
Old 26th July 2010, 07:13   #2226  |  Link
lych_necross
ZZZzzzz...
lych_necross's Avatar
After reading these posts and updating to the reposted 2022, I get this error:
Win 7x64, Geforce 460, 1GB video mem, driver version 258.96.
I'm using the 32bit version of dgindexnv
lych_necross is offline   Reply With Quote
Old 26th July 2010, 07:47   #2227  |  Link
cweb
cweb's Avatar
thanks, 2022 works for me now..
PC specs for bug reports: Intel Core i7-4790K @4Ghz Win10(Linux VM) PCI express NVIDIA RTX 2060 SUPER graphics card
http://twitter.com/cwebdesign
cweb is offline   Reply With Quote
Old 26th July 2010, 09:00   #2228  |  Link
MrVideo
MrVideo's Avatar
Does that file exist in the path shown in the error?
Why are you running the 32 bit version on a 64 bit system?
Old 26th July 2010, 09:18   #2229  |  Link
Groucho2004
Version 191.07 is very old and this error is known to occur with older driver versions. Please upgrade drivers to latest version and report results. FYI, I am running 257.21.
http://www.nvidia.com/object/winxp-2...ql-driver.html
I tried the latest drivers (258.96) and DGIndexNV works with those. However, I'm getting all sorts of weird behaviour (for example, Aniti-aliasing doesn't work with older games) and even blue screens with these drivers. When I got the new card I tried a number of drivers (19x and 25x) and I settled on 191.07 because it worked best for me.
I think I'll stick with DGIndexNV 2021 for the time being until the NVidia drivers work for me.
Edit: I'll try 257.21.
Old 26th July 2010, 10:02   #2230  |  Link
lych_necross
ZZZzzzz...
Yep, the file exists in the shown path. I'm running the 32bit version because I use avisynth plugins and scripts that are not supported yet on the x86_86 build of avisynth (that and there is no official 64bit build of avisynth yet).
Old 26th July 2010, 10:53   #2231  |  Link
Groucho2004
Using driver version 196.21 now. Works fine with 2022 (it seems).
Old 26th July 2010, 11:34   #2232  |  Link
tormento
Acid fr0g
tormento's Avatar
@neuron2
Can't get the multiple license file work. Tried to put every license on different line, like in old versions but nicht.
Any new syntax is required?
@turment on Telegram
Old 26th July 2010, 12:38   #2233  |  Link
OK, that's a Fermi that has CUDA compute capability 2.0. I have to include a version of the cubin file that is compiled with -arch sm_20, and if possible, load the correct one dynamically. I'll work on that and report back later today.
Old 26th July 2010, 13:03   #2234  |  Link
Originally Posted by tormento View Post
@neuron2
Nope, I just goofed it up. I slipstreamed the fix. Get the corrected DGIndexNV from a re-download of 2022. Thank you for pointing it out.
Old 26th July 2010, 13:09   #2235  |  Link
Thank you for the test result. I have changed the driver version requirement in the Readme to version 196.21 or higher.
Old 26th July 2010, 14:05   #2236  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
you should change it to "the latest driver available for your videocard"
Old 26th July 2010, 14:07   #2237  |  Link
Nah, because the very latest drivers are apparently hosed right now.
Old 26th July 2010, 14:09   #2238  |  Link
Please try this test version on your Fermi (32-bit binaries):
http://neuron2.net/dgdecnv/fermi.zip
Put all three files together.
Old 26th July 2010, 18:23   #2239  |  Link
aegisofrime
Hosed? How so?
It's interesting that you should post this, because I'm getting random BSOD errors when using DGSource() for H.264 content. I have been wondering what's the cause of the BSODs...
Using a Palit GTX 460 Sonic here...
aegisofrime is offline   Reply With Quote
Old 26th July 2010, 18:28   #2240  |  Link
tormento
Acid fr0g
tormento's Avatar
Nah, the latest are whql (whatever it counts) and very stable when encoding or gaming or ht'ing. At least on my rig.
Thread Tools
