#201 | Link |
After searching that same website I found this doc on "Efficient Traitor Tracing". It made for some good reading.
http://domino.watson.ibm.com/library/cyberdig.nsf/papers/AF8C220CB33D5A98852571FF00570458/$File/rj10390.pdf Regards |
#202 | Link | |
Timeline (of your new case): 1- LA releases the first movie with SKB (Shrek1) 2- Attacker A publishes his SK at first column (123), but this is not enought to decrypt because your SKB requires at least 2 SKs to decrypt. 3- Attacker B downloads the first published SK (SK from attacker A player). He founds that this SK outputs a link to second column (124). Attacker B has his SK at column 123, but this is not enought to decrypt because your SK requires at least 2 SKs to decrypt. He also has his SK at column 124. Attacker B can go to column 124 because he has the SK from attacker A. He tries at column 124 his SK 124. If it outputs a link or final Variant Data, this means that there are a lot of players whose SK 124 will output a link or final Variant Data. He knows this because player A and player B are different players. It is extremely improbable that just these 2 players are the only ones that have a valid output (a link or final Variant Data) when mixing keys from player A and another player. So he publishes his SK 124 safely (his player can not be identified). If not, he publishes his SK 123. There are 2 possibilities: 1- Attacker B publishes his SK 124: now everybody has 2 links, or one link and final Variant Data. 2- Attacker B publishes his SK 123: now everybody has 2 links. There are 10 columns on your SKB, and each published SK gives everybody one link more or final Variant Data. After 10 attackers have published 10 SKs (just one SK per player) your SKB will become broken (probably before 10 SKs). |
#203 | Link | |
*Most* players decrypt at column one. Virtually no player decrypts at column 4. Of course this is not your SKB, but it is the SKB spec authors chose as a good example. You are simply blind about this matter. If they send *most* players to column 4, *most* players will have the keys to reach it. If they send just a few players to column 4, *most* players will have the keys to decrypt at other columns. Your requirement is far away of reality. |
#204 | Link | |
) but just this.
Not sure if that helps. But maybe. Regards, arnezami PS. Should I do a study and write an article on Sequence Keys (instead of programming that is?) Last edited by arnezami; 16th March 2007 at 08:04. |
#205 | Link |
Please, I am right in these assertions:
Thanks, for any reply. I just need to ensure I understand well. |
#206 | Link |
I may get a chance to respond later. Our discussion was an attempt to guess 1) how they assigned SKs and 2) how they traced traitors with released keys or movies. Guessing was useful to help us understsand what they could have done. However, it's far more useful to read the papers at the website I listed and actually have them tell us what they did. We need to understand:
inner codes outer codes slot assignments. Have you read the papers? Let's talk about the limits they say are on the system. |
#207 | Link | |||||
Note that a not random distribution is a Bad Idea for them. However I don't know which is FoxDisc's key distribution, i don't even know is he has decided a key distribution, and i am not assuming random distribution when i talk about his SKB. I think this is fair because we don't know which is key distribution LA have chosen for already sold standalones. However it is not fair he changes the case again and again. He has done it several times, and it is far frustrating for me he does so. I suggest we (FoxDisc and me) keep focused on his SKB until we decide if attackers have broken it or not. Quote:
#208 | Link | |||
I really think the skeptic role is far important on any good discussion, but please keep focused on your SKB until you see it is broken or until you get the identity of a player. |
#209 | Link | |||
This looks wrong. If you specify the device number, everyone knows the location (nodes) of the device keys for that device. The LA knows the value of all of those device keys. An adjacent device would know almost all of the values of those device keys. |
#210 | Link | ||||
The first thing I get from the papers is that they are not trying to identify a player from a single movie/SKB. The "outer code" specifies one of a group of 255 movies. The inner code specifies one of 256 variations of the movie. I don't see much point in taklking about my hypothetical 10 column SKB until we understand the process. Another thing I get from the papers is that they aren't looking for the most likely individual traitor for a single movie. They are looking for the most likely group of traitors releasing a large group of movies. Specifically, yesterday, I would have agreed with arnezami that the first column would mostly have links. Now I'm less sure. The first column may have many answer key K's (these are Variant Data). They are assigning a group of Dvs within a column so that they know which columns from a specific SKB were used. They may be using the six SKBs and rotating the SKBs for each movie release to collect the bulk data on groups of compromised devices. Quote:
With the new information, it is clear that we can't simplify that much and still understand the tracing system. You repeatedly misunderstood or made assumptions that were not true or inconsistent. Do you want me to go on with explaining how a single device can be identified from a single SKB using an assignment system that they are not using? Just assume the first 16 million devices got one of the 16 million unique keys, and that they've assigned less than 16 million devices a key set so far. Of course, then we'd have to discuss size limitations on discs, and whether those are reasonable limitations. I had a more complex assignment scheme in mind, but there's no point to discussing it, it's not the one the AACS selected. You've never given any hint of how you think their SKB system works to trace traitors. Do you really think it does not work? I think the burden is on you to show why. I think it works, but has limits. It is the limits that I am interested in. You never discuss the six SKBs, just one. You never say how a movie can be decrypted with released keys. You don't give enough information about your example, then complain when I make an assumption that differs from what you expected. OK, enough rant. Let's try to stay on point and focus on our common interest - how does it actually work. Quote:
To do that, we're going to have to talk about how many movies are released, how many traitors T have released keys, how the keys were assigned, etc. We're going to have to talk in their language of slot assignment, and inner and outer codes. I don't yet fully understand that. Do you? If not, let's work on that, not on old hypotheticals based on assumptions about key assignments that are not correct. |
#211 | Link | |||||
There is no doubt that enough attackers in the right assignment slots will completely break the system. Quote:
I don't think there is any doubt that the system can be broken if you assume that all attackers can access their SKs and are willing to disclose one or more Quote:
To understand the SK system, we are going to have to make some assumptions about how many attackers there are, and what slot/slots their devices are assigned to. "Slots" correspond to manufacturers or models. When you read the papers, look at some of the charts on how many movies it will take to identify attackers to a one in a million probability of error under various assumptions. Some SK assignment options require hundreds of movies before a large group of attackers is identified. Last edited by FoxDisc; 16th March 2007 at 16:00. |
#212 | Link | ||
I have not read it yet, but it seems that the document says they are not giving keys to players in a full random way. So it is possible attackers can publish safely more than one SK per player. Again, i will read it as soon as posible. |
#213 | Link | ||||
If attackers can avoid "sacrificing" their players (revocation), they will publish the keys, and the only question is to know if there are enought attackers. Quote:
#214 | Link |
Country Member
Gentlemen,
The discussion here is getting just a little heated for my liking. The road is long and we all know it is not an easy one to travel. Let's respect each other's views at all times please. Regards
Les Only use genuine Verbatim or Taiyo Yuden media. |
#215 | Link | |
. Its from the designers of AACS themselves so we can see how they have been thinking and reasoning.What surprises me most is the fact that they are clustering devices from the same model/manufacturer. At some point they talk about only 64 keys (per column) used for one model (wth total of 4096 rows). With up to 250,000 devices (64^3) using that 64 keys cluster. To me that means that if you only release one Sequence Key (which is in a small cluster of 64 keys used by the other devices of the same model) there will always be another (innocent) device having this same Sequence Key. So given enough people willing to do this we would have enough keys to decrypt all movies released by then. The releasers of Sequence Keys do not even have to check whether their sequence key is shared (before releasing it) because if they use the same cluster they already know this is the case. And when they have the same model they are in the same cluster. Sure they can revoke these keys but this can be done with many people many times. It seems like they are so much concentrating on anonymous attacks (one attacker that has only one or a very few devices "opened" and releasing only content keys) that they are not capable of coping with many people releasing just one Sequence Key anymore. -- I can already imagine whats going to happen: some hacker is going to find some kind of buffer overflow exploit for a specific model. He gives out an iso which when burned and inserted as a dvd produces this overflow and runs some designed code: revealing the Sequence Keys on your screen/tv . Maybe even with a menu so we could choose which sequence key we want to see using our remote control --In fact: the document talks about only 32 fully compromised devices (thus one person/group having all these sequence keys) being a major problem for the system. Thats not a lot of devices if we would find a hack for one model... (although this part deals with the anonymous attack so we have to see what this really does) Anyway. Good stuff. We should pick it apart and try to learn as much as possible from it. But we've got time so no hurry. ![]() Regards, arnezami PS. Just to put things into perspective concerning the amount of rows: 6 SKBs with 4K/16K/64K rows would take: 4096 rows * 256 columns * 10 bytes * 6 SKBs =~ 63MB. 16383 rows =~ 250MB. 64K rows =~ 1GB... [edit]It appears that this paper (oct 4 2006) was released before they found and fixed the "security issues to support multi-time tracing" in the following paper (nov 1 2006). So it seems their "fix" introduced these clusters... And btw: when were the first HD players released/manufactured? When did they have the time to assign Sequence keys according to the new cluster style? Did they assign them at all? This really smells like a last minute fix... Last edited by arnezami; 17th March 2007 at 18:50. |
#216 | Link |
I'm still thinking about this out but... (btw: this is completely different from what I mentioned earlier about "sharing notes")
Here is a possible (and simple) scheme to release all Sequence Keys (that say 50-200 people have in common) at once. Thus not making it possible for the AACS LA to see which sequence keys came from whom and therefore not possible to revoke specific players.
[edited]The question here is: what happens exactly if all these keys get revoked. Will many, some or no innocent players be revoked? Can they even do this? (edit: Hmmm. I'm now guessing they can... unless almost all sequence keys are released within these clusters. Probably the only way this would work is if everybody would give their keys to one person/group and they would release the segment keys for every movie while keeping the sequence keys hidden) arnezami Last edited by arnezami; 17th March 2007 at 19:36. |
#217 | Link | ||
BTW i would like to give this method (publishing just one SK per player) a name. We can call it "lone SK attack". Quote:
#218 | Link |
Been thinking about it a little more:
This is a combination of "releasing them all" and "releasing just one key". And its very powerful I think .The "one column at a time" approach: A better approach would be to let each participant give its Sequence key for 1 agreed upon column (eg all beginning at the first column). If the website/webmaster/organizer doesn't show where each Key is coming from it/he can safely release these keys since the AACS LA wouldn't know which devices nor which persons these are from. This goes on until all 64 keys (or very close to it) of that column are released. This can be done for each column at a time until all columns (and thus rows) from these clusters are released (with 4096 columns that would be 4096/64 = 64 keys per cluster. So that would be a total of 256 columns * 64 keys = 16256 keys to be retrieved by people having this player model). The AACS LA could consequently revoke these released keys (64 keys for each column) but this will eventually end in either (1) revoking all devices of that model (they won't do this) or (2) when the last columns are fully released they have to stop: so none of the devices are revoked. Voila! Sequence Keys: Game Over. The beauty is: everyone releases only 1 key at a time (privately to the website/webhost) so none of the participants nor any observer will ever know which keys came from whom and none of the devices will be identified since only 1 key is released at a time (and none of the previous released keys from each column does identify anyone of course). I think this will actually work very well (if keys are roughly evenly distributed within the model's clusters)Given 4096 rows my guestimate would be we need approximately 100-150 participants/devices to make this work (of the same model/manufacturer). This technique won't work that well if 16K or 65K rows are used (since you need so many participants). But its still possible. And if they release some DVDs/BDs with only 4096 rows in their SKBs then this will certainly work (assuming they would then also be using this clustering for SK device assigment using 4096 rows). In other words: one exploit in a well sold player model will very likely kill the traitor system permanently. arnezami [edit] If you would combine the above approach with this idea it seems AACS really can be beaten.
#219 | Link | ||
#220 | Link | |
In the old system (with no clustering) this wouldn't work very well since you would need something like 7000-10000 volunteers (assuming only 4096 rows). Although any model could be used so it might have been a little easier to get more volunteers but still. However because they used clustering (did they really btw or was Lotspiech too late with his "fix"?) they reduced the keys per column (for one model) from 4096 to 64. Thats quite significant! Even with 16K keys it will still be possible to use this technique. In that case there will be 256 keys per cluster. So I guess we would need around 400-700 volunteers. Thats still doable I think (especially since its fun and disables an important part of a major DRM system )Keep in mind: if the sequence key system is disabled then revocation (MKB) becomes quite useless (for standalones) since they will not know which standalones the device/processing keys come from. And somehow I suspect some standalones out there don't even use the KCD protection which would mean we could use their processing/device keys on a PC (without a drive firmware hack for retrieving the KCD). Need I go on? Regards, arnezami PS. I'm still trying to understand certain things in the paper about some hazy things he said. Eg he is talking about 4 or 6 columns (sometimes 18) and seems to completely ignore the fact that there are 256 columns. There is also the picture of 1 movie per column which is weird because 256 movies using 256 columns won't work because if one key is revoked innocent devices will be revoked to. So interpretation of the text is still a bit of an issue for me atm. Some parts seem to be written hastely (especially the multi-time "fixing" parts) indicated by the many typos, short sentences and lack of precision. Last edited by arnezami; 18th March 2007 at 14:21. |
| Thread Tools | |
| Display Modes | |
