Old 23rd January 2013, 08:34   #1  |  Link
slayer583
Merge 3D video from two-2D videos
Dear,
I had to make 3D video file from two-2d videos.
I should get 3D video file with 3D frame packing format.
I have heard that MVC codec could merge two 2d-videos into 3D frame packing format.
However, I couldn't get practical program or codes.
If you know suitable program or code, please help me.
Thanks,
p.s. : I want to get the 3D video with the quality of blue-ray.
slayer583 is offline   Reply With Quote
Old 23rd January 2013, 12:35   #2  |  Link
J_Darnley
J_Darnley's Avatar
x264 can encode a packed 3D video. Probably the easiest way is to use avisynth. Load the two videos, Interleave() and then encode with x264 and --frame-packing 5.
Before spending time on this find out what frame packing method you need to use.
x264 log explained || x264 deblocking how-to
preset -> tune -> user set options -> fast first pass -> profile -> level
Doom10 - Of course it's better, it's one more.
J_Darnley is offline   Reply With Quote
3d merging, frame packing, mvc
