Old 30th January 2019, 05:49   #6061  |  Link
Aleksoid1978
Aleksoid1978's Avatar
Originally Posted by Klaus1189 View Post
Is it possible to edit the close button of the new Playlist window, because it is cut off when using 200% scaling, see here.
Possible - why not, but i don't have monitor > 1080 and can't set 200%, maximum 175%(look normal).
AMD Ryzen 5 3600 /GIGABYTE B450 Gaming X /Patriot 32Gb@3200 /Kingston 500Gb M.2 /RTX 4060 /Samsung U28R550UQI /OLED Philips 55OLED707 /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215
Aleksoid1978 is offline   Reply With Quote
Old 30th January 2019, 06:39   #6062  |  Link
there are two way to workaround that.
apply nvidia DSR to the desktop and you should get up 350% as an option or you use the newer custom option to type the number in.
Old 31st January 2019, 07:27   #6063  |  Link
wushantao
https://send.firefox.com/download/82...PMmnH6duYTFd6w
https://anonfile.com/90U5m7sfb7/mplayerc.sc.rc_7z
https://bayfiles.com/A2U5mfs9b5/mplayerc.sc.rc_7z
http://www.solidfiles.com/v/NaB6KGMvkYXXM
Simplified Chinese update
wushantao is offline   Reply With Quote
Old 31st January 2019, 11:35   #6064  |  Link
v0lt
@wushantao
Thanks. Updated in r4392.
v0lt is offline   Reply With Quote
Old 31st January 2019, 19:00   #6065  |  Link
Klaus1189
If you need/want me to try a testbuild, just send me one.
I made a new screenshot of r4391. Here you can see that only the close symbol is larger than the button. The button itself should be fine. Maybe it helps you, although I am pretty sure you know it already.
I beg to fix this little cosmetic issue.
Thank you devs
Old 2nd February 2019, 08:07   #6066  |  Link
Aleksoid1978
Thank you devs
Test this build - https://yadi.sk/d/rspJFwy3X4ZPvQ
Old 2nd February 2019, 08:52   #6067  |  Link
Klaus1189
Looks good to me
Old 2nd February 2019, 10:20   #6068  |  Link
Aleksoid1978
I'm glad
Old 4th February 2019, 17:02   #6069  |  Link
Klaus1189
Updated german translation based on r4402
Old 6th February 2019, 00:23   #6070  |  Link
ryrynz
ryrynz's Avatar
I see the translations being fixed up. 1.5.3 release imminent?
Old 10th February 2019, 18:57   #6071  |  Link
GCRaistlin
GCRaistlin's Avatar
Feature requests:
  1. [ ] Show MPC-BE in tray instead of taskbar.
    This may be useful when playing a video on the secondary display and doing some other work on the primary one: MPC-BE won't hinder on Alt-Tab and in the taskbar.
  2. [ ] Repeat reopening file in case of an error.
    Now sometimes we have to press Ctrl-E tens of times (literally!) when opening an AceStream link because of repeating "Cannot render a file" error.
  3. Increase timeout for opening external links. Now we get "File not found" error in case of heavy bandwidth load (by uTorrent on another machine). Limiting download speed in uTorrent helps. Once the link is catched we can remove the limiting or at least set it to a higher value.
Windows 8.1 x64
Magically yours
Raistlin
GCRaistlin is offline   Reply With Quote
Old 11th February 2019, 04:55   #6072  |  Link
Anima123
The mouse scroll will not be able to adjust volumn with recent builds.
Anima123 is offline   Reply With Quote
Old 11th February 2019, 04:59   #6073  |  Link
Aleksoid1978
All working good.
Old 11th February 2019, 17:53   #6074  |  Link
v0lt
Perhaps you have an active playlist window. Click on the main window and check again.
Old 11th February 2019, 20:19   #6075  |  Link
Anima123
You're right about it. But shouldn't the main window be the active one in the first place?
Old 11th February 2019, 20:49   #6076  |  Link
VipZ
Thanks for the updates for High DPI settings
There are 3 additional places which could do with similar tweaks.
Flybar and header within settings dialog;
Additional thought, is that header text even required within the dialogs now?
OSD;
I have set font size 18 for OSD which is likely slighly bigger than default. At 100% its good and 250% its a bit too big.
Windows is set with 250% within the above snips.
Thanks
Windows 11 Pro, CPU: Ryzen 9 5900X, GPU: GeForce RTX 3090 /w 512.95, Audio: HDMI to Yamaha RX-A3060 (5.1)
VipZ is offline   Reply With Quote
Old 17th February 2019, 00:00   #6077  |  Link
artins90
I have been using MPC BE for more than a year without issues but after upgrading to a 4K screen, I am now facing Desktop Window Manager crashes when using this player.
I figured out a way to trigger the crash consistently, basically in full screen (Madvr standard, not exclusive) when I make the seek bar appear there is a very brief white flash across the entire screen, like a random white frame.
This doesn't make the Desktop Window Manager crash, but if I make the seek bar appear and disappear for 5-10 times in a row, I can trigger the crash consistently.
After the Desktop Window Manager crashes, the video's audio still plays in the background with the last frame stuck on the screen. The mouse is displayed on the screen but it cannot interact with anything and the application can't be closed, forcing me to cut the power the PC.
I tried to reset the player's settings to their defaults, I also tried to run the standard EVR but I can still trigger the crash.
The crash is limited to MPC BE, all the other players, 3D applications, games are stable.
The event viewer reports the following:
Faulting application name: dwm.exe, version: 10.0.17763.1, time stamp: 0xe52aabf3
Faulting module name: KERNEL32.DLL, version: 10.0.17763.292, time stamp: 0x7c9c19c8
Exception code: 0xe0464645
Fault offset: 0x00000000000181f4
Faulting process id: 0x230
Faulting application start time: 0x01d4bb2c84b487c9
Faulting application path: C:\WINDOWS\system32\dwm.exe
Faulting module path: C:\WINDOWS\System32\KERNEL32.DLL
Report Id: 7a653986-1b58-42ac-84ea-8521496361dd
Faulting package full name:
Faulting package-relative application ID:
Any suggestion on how to solve this issue would be appreciated.
System:
i7 7820X
GTX 1080
16 GB DDR4 3400
Windows 10 v 1809 with the latest updates applied.
MPC BE 1.5.3 (build 4419) beta (the current stable release crashes as well).
artins90 is offline   Reply With Quote
Old 17th February 2019, 08:42   #6078  |  Link
Aleksoid1978
OSD;
Thanks
Flybar don't support High DPI.
About osd text - it's scale by DPI.
Old 18th February 2019, 22:54   #6079  |  Link
Grimsdyke
Regarding: Infinite Pin Tee Filter
Shouldn't the 64-bit version of mpc-be load/use qcap.dll from SysWow64 instead from System32 ??
Grimsdyke is offline   Reply With Quote
Old 18th February 2019, 23:06   #6080  |  Link
Aleksoid1978
It's automatically load from system.
