20th August 2022, 06:44 | #1 | Link |
Scenarist BD, MM Challenge
Hi All,
I have an Always On - MM that looks like a piece of paper. The first section is selecting four different Audio formats, the second is four different videos. Each button has a black under line, but once selected it turns red. I would like to select one of the audio formats, have that selection turn red (and stay red) so you know what audio you selected. Then jump to the four video selections with the black underline and once a video is selected that turns red (stays red), and finally onto the Play all button, etc. I am having trouble keeping each button selected red and staying red. I tried doubling the button but not sure if that is right? Any thoughts on how to keep a button highlighted while selecting other buttons? Thanks for the insight. Last edited by TahoeP; 20th August 2022 at 06:49. |
20th August 2022, 13:13 | #2 | Link |
You neeed two buttons on the same BOG, one for standard state and one for the "selected" state. Plus you need a hidden button (for each real button) which controls the selection (enable/disable one of the two buttons in the same BOG) and probably an additional hidden button for the initialization once you enter into the page. So, for example, if you have a page with four different audio, you need:
- One hidden button for initialization (this is button 0 with auto-action, that enable/disable which buttons are in standard state and which ones are selected) - Four audio buttons (x2, you have two buttons for each BOG, one with standard state and one with selected state) - Four hidden buttons (these are for routing purposes, when you go from one button to another, you go on the hidden button which take care to enable/disable one of the two buttons in the same BOG). It's not that hard, but it may sounds complicated. There is a tutorial made by Scenarist for that, there's also a template file that cover this. You can take a look at it and adapt to your menu. |
20th August 2022, 17:44 | #3 | Link |
Very cool! It does sound complicated but I like a challenge. I will give it a try and if I struggle with it I will reach out to Scenarist for the tutorial and template.
Thank you so much for your quick reply! |
buttons, main menu, scenarist bd |
