Old 22nd February 2022, 16:44   #1  |  Link
Overdrive80
Anime addict
Overdrive80's Avatar
What are encoder lossless with 32 bit support
Hey, I am searching one encoder with support for 32 bitdepth. https://wiki.hydrogenaud.io/index.ph...dec_.28ALAC.29
ALAC would be good choice but I dont know how decoder audio after encoding (audio.wav | refalac64 -b 32 - -o output.m4a)
What other encoder you would recommend??
Intel i7-6700K + Noctua NH-D15 + Z170A XPower G. Titanium + Kingston HyperX Savage DDR4 2x8GB + Radeon RX580 8GB DDR5 + ADATA SX8200 Pro 1 TB + Antec EDG750 80 Plus Gold Mod + Corsair 780T Graphite
Overdrive80 is offline   Reply With Quote
Old 23rd February 2022, 00:31   #2  |  Link
Brazil2
Wavpack: https://www.wavpack.com
I don't know any other one.
Brazil2 is offline   Reply With Quote
Old 23rd February 2022, 03:20   #3  |  Link
tebasuna51
tebasuna51's Avatar
wavpack work fine but refalac also can do it.
Both can be decoded fine (bitidentical to the source in my test) with ffmpeg (using -acodec pcm_s32le).
Old 23rd February 2022, 12:27   #4  |  Link
Overdrive80
Anime addict
Thanks to both, I gonna to testing it.
Old 26th January 2023, 12:07   #5  |  Link
Balling
Flac in FFmpeg after https://github.com/FFmpeg/FFmpeg/com...abf56b5c5e9ee2 (it requires -strict experimental).
ffmpeg.exe -i https://trac.ffmpeg.org/raw-attachment/ticket/9563/signal_short.wav -strict experimental output.flac
Balling is offline   Reply With Quote
Old 27th January 2023, 00:35   #6  |  Link
Brazil2
Official FLAC supports 32 bits integer since version 1.4.0.
Old 4th March 2023, 06:36   #7  |  Link
Balling
Dolby E also by default outputs 32 bit integer, so allows 32 bit flac encoding with -strict experimental
