Old 17th December 2014, 17:48   #1  |  Link
filler56789
SuperVirus
filler56789's Avatar
[SOLVED] fdkaac.EXE - ¿how to compile it?
I'm trying to compile nu774's fdkaac.exe with MinGW-w64.
I've already compiled and "installed" the required libfdk-aac thing.
The big question is,
¿where does the stupid ./configure expect to find libfdk-aac?
checking fdk-aac/aacenc_lib.h usability... no
checking fdk-aac/aacenc_lib.h presence... no
checking for fdk-aac/aacenc_lib.h... no
configure: error: libfdk-aac is required
filler56789 is offline   Reply With Quote
Old 17th December 2014, 21:57   #2  |  Link
LoRd_MuldeR
Software Developer
LoRd_MuldeR's Avatar
In your "include" path?
Old 17th December 2014, 23:22   #3  |  Link
filler56789
SuperVirus
And my "include path" would be where, exactly?
 Directory of E:\GCC481
2014-07-26  16:18    <DIR>          .
2014-07-26  16:18    <DIR>          ..
2013-07-23  06:06             4,401 !components.txt
2013-08-22  13:43    <DIR>          at-home
2014-12-17  19:52    <DIR>          bin
2013-08-08  06:22    <DIR>          etc
2014-12-17  16:26    <DIR>          include
2014-12-17  16:27    <DIR>          lib
2014-07-26  16:19    <DIR>          local
2009-07-11  18:34             2,238 m.ico
2013-07-23  06:11    <DIR>          manifest
2013-06-01  06:23    <DIR>          mingw
2009-07-11  18:34            37,758 msys.ico
2014-12-17  19:49             7,367 msys481.bat
2013-07-23  06:11    <DIR>          postinstall
2013-07-23  06:11    <DIR>          sbin
2010-09-28  16:34    <DIR>          share
2013-07-23  06:11    <DIR>          var
ANSWER:
mingw/i686-w64-mingw32/bin
mingw/i686-w64-mingw32/include
mingw/i686-w64-mingw32/lib
argh
Old 18th December 2014, 00:32   #4  |  Link
LoRd_MuldeR
Software Developer
The include path(s), i.e. the directories that the compiler will search for header files, is set by the CPATH environment variable:
https://gcc.gnu.org/onlinedocs/gcc/E...Variables.html
It defaults to the subfolder "include" in your MinGW installation directory.
However, instead of messing with your MinGW installation (or modifying CPATH), you probably want add libfdk's "include" directory as an additional include directory via -I compiler option:
https://gcc.gnu.org/onlinedocs/gcc/D...ectory-Options
Note that, usually, the ./configure script will accept the "--extra-cflags" parameter to set additional compiler options. So you can do something like:
./configure --extra-cflags="-I/path_to_libfdkaac/include"
Old 18th December 2014, 01:50   #5  |  Link
filler56789
SuperVirus
Thanks for the information. However I must say that... Well, when I managed to compile libfdk-aac, the files were automagically copied to local/bin,
local/include and local/lib. The first folder to where I manually copied the libfdk-aac files was the most obvious choice (to me at least), i.e., /include. And the trick didn't work -_- I only wish that the "./configure --helpS" were a lot more helpful *by default*, because most of them are not, and IMHO it's a big mistake to assume that every user of a compiler is a skilled programmer who will take the time to study the entire source-codes or the compiler documentation -_-
For the time being, I really prefer to tweak my MinGW setup, because it's something I am able to understand and to control =^.^=
And oh BTW, I still have to find out how to make twolame compatible with the recent versions of MinGW-w64, since Nicholas Humfrey still believes Unix and Linux "are ALL that matters" -_-
Last edited by filler56789; 18th December 2014 at 05:40. Reason: formatting + clarity
Old 18th December 2014, 09:03   #6  |  Link
Kurtnoise
Swallowed in the Sea
Kurtnoise's Avatar
It's because you mix up MSYS folders within the MinGW ones...not relative to program skills.
Old 18th December 2014, 12:07   #7  |  Link
pandy
Works for me: fdkaac_autobuild.zip
https://sites.google.com/site/qaacpage/cabinet
pandy is offline   Reply With Quote
Old 18th December 2014, 15:32   #8  |  Link
filler56789
SuperVirus
@Kurtnoise: thanks for the tip
— I will try to improve my organizational skills when I upgrade to GCC 4.9.2
(yes, about time!)
«Your software patents have expired.»
Old 20th December 2014, 12:26   #9  |  Link
foxyshadis
Angel of Night
foxyshadis's Avatar
If MSYS is too annoying (believe me, I really understand), another option is a linux virtual machine with mingw for cross-compiling. That works wonders for me, and the only reason I ever touch MSYS anymore is to build with VS2013 without creating a MSVC project.
Old 29th January 2019, 11:33   #10  |  Link
martynuzza
I'm trying to cross-compile an EXE in ubuntu with mingw64. I read the possibility here https://marc.wäckerlin.ch/computer/c...ws-using-mingw
I've downloaded and compiled this: https://github.com/mstorsjo/fdk-aac
Then i attempt to compile this https://github.com/nu774/fdkaac
the windows version but i'm stuck with this error when i try to do ./configure --host=i686-w64-mingw32
1° Is possible to create an EXE in ubuntu in the way I do?
2° Otherwise?
------ edit -------
include folder for ubuntu crosscompiler is in /usr/i686-w64-mingw32 and /usr/x86_64-w64-mingw32 for 64bit
martynuzza is offline   Reply With Quote
Old 29th January 2019, 13:15   #11  |  Link
martynuzza
Done myself:
Frontend version 1.0.0
libfdk version 2.0.0
Here is the 32bit exe windows build static:
https://mega.nz/#!6do3ASjL!ApJTfNAWw...A_o9KERgcjC9uI
Here is the 64bit exe windows build static:
https://mega.nz/#!jM5FESzA!vMb5eNEQX...jN54hemeaCPGl8
Old 29th January 2019, 14:16   #12  |  Link
martynuzza
I was doing listening tests....very disappointed with the coding quality, it is a lot lower than the good old nero aac 1.5.4.0
so much effort for nothing
Old 29th January 2019, 18:30   #13  |  Link
Taurus
Taurus's Avatar
@ which samplerate, @ which bitrate?!
Please dont spread FUD without facts.
Many come here for learning and maybe take your opinion for granted.
Just use the Qaac encoder and you will be fine.
No more search for obsolete and outdated stuff.
Taurus is offline   Reply With Quote
Old 30th January 2019, 03:06   #14  |  Link
GMJCZP
GMJCZP's Avatar
I did some tests with Behappy to compare fdkaac 0.6.2 with this version, compressing to CBR 32 Kbps gapless iTunSMPB with the profile MPEG-4 HE-AAC v2 (SBR + PS). Using Paris Latino - Bandolero as sample and subjectively I do not notice difference any.
By law and justice!
GMJCZP's Arsenal
GMJCZP is offline   Reply With Quote
Old 5th December 2019, 06:16   #15  |  Link
kedautinh12
Done myself:
i see new ver, can you compile it?
https://github.com/mstorsjo/fdk-aac/releases/tag/v2.0.1
Old 9th December 2019, 02:25   #16  |  Link
filler56789
SuperVirus
Originally Posted by kedautinh12 View Post
DONE.
Oh my goddess, the library took ages to compile
Anyway — unzip, unrar, profit :–p
http://www.mediafire.com/file/jphuy8...v2.0.1.7z/file
Old 9th December 2019, 21:16   #17  |  Link
orion44
None
orion44's Avatar
Originally Posted by filler56789 View Post
DONE.
orion44 is offline   Reply With Quote
Old 13th December 2019, 05:28   #18  |  Link
kedautinh12
DONE.
thanks, but are you use Frontend fdkaac version: v1.0.0 and included libfdk version: v2.0.1 compilier?
Frontend homepage
Lib homepage
Old 13th December 2019, 06:37   #19  |  Link
filler56789
SuperVirus
As I said,
fdkaac-v2.0.1.7z
By the way, welcome to my Ignore List
Old 13th December 2019, 09:57   #20  |  Link
kedautinh12
As I said,
fdkaac-v2.0.1.7z
Oh, i see filesize = 1/4 v2.0.0 and i only ask to confirm again. I don't think you angry very much, i'm very sorry 😱😱😱😱
